[petsc-users] MatCreateSeqAIJWithArrays for GPU / cusparse
Wed Jan 4 18:17:04 CST 2023
On Wed, Jan 4, 2023 at 7:09 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> On Wed, Jan 4, 2023 at 6:02 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Jan 4, 2023 at 6:49 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> On Wed, Jan 4, 2023 at 5:40 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>> Oh, is the device backend not known at compile time?
>>> Currently it is known at compile time.
>> Are you sure? I don't think it is known at compile time.
> We define either PETSC_HAVE_CUDA or PETSC_HAVE_HIP or NONE, but not both
Where is the logic for that in the code? This seems like a crazy design.
    Matt
>   Thanks,
>>      Matt
>>> Or multiple backends can be alive at once?
>>> Some petsc developers (Jed and Barry) want to support this, but we are
>>> incapable now.
>>>> On Wed, Jan 4, 2023, 6:27 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> On Wed, Jan 4, 2023 at 5:19 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>> Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>>>>> would need another for MATMPIAIJCUSPARSE, and then for HIPSPARSE on AMD
>>>>>>> GPUs, ...
>>>>>> Wouldn't one function suffice? Assuming these are contiguous arrays
>>>>>> in CSR format, they're just raw device pointers in all cases.
>>>>> But we need to know what device it is (to dispatch to either
>>>>> petsc-CUDA or petsc-HIP backend)
>>>>>> On Wed, Jan 4, 2023 at 6:02 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>>>> wrote:
>>>>>>> No, we don't have a counterpart of MatCreateSeqAIJWithArrays() for
>>>>>>> GPUs. Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>>>>> GPUs, ...
>>>>>>> The real problem I think is to deal with multiple MPI ranks.
>>>>>>> Providing the split arrays for petsc MATMPIAIJ is not easy and thus is
>>>>>>> discouraged for users to do so.
>>>>>>> A workaround is to let petsc build the matrix and allocate the
>>>>>>> memory, then you call MatSeqAIJCUSPARSEGetArray() to get the array and fill
>>>>>>> it up.
>>>>>>> We recently added routines to support matrix assembly on GPUs, see if
>>>>>>>  MatSetValuesCOO
>>>>>>> <https://petsc.org/release/docs/manualpages/Mat/MatSetValuesCOO/>
>>>>>>>  helps
>>>>>>> --Junchao Zhang
>>>>>>> On Wed, Jan 4, 2023 at 2:22 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>>> I have a sparse matrix constructed in non-petsc code using a
>>>>>>>> standard CSR representation where I compute the Jacobian to be used in an
>>>>>>>> implicit TS context. In the CPU world I call
>>>>>>>> MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, nrows, ncols,
>>>>>>>> rowidxptr, colidxptr, valptr, Jac);
>>>>>>>> which as I understand it -- (1) never copies/allocates that
>>>>>>>> information, and the matrix Jac is just a non-owning view into the already
>>>>>>>> allocated CSR, (2) I can write directly into the original data structures
>>>>>>>> and the Mat just "knows" about it, although it still needs a call to
>>>>>>>> MatAssemblyBegin/MatAssemblyEnd after modifying the values. So far this
>>>>>>>> works great with GAMG.
>>>>>>>> I have the same CSR representation filled in GPU data allocated
>>>>>>>> with cudaMalloc and filled on-device. Is there an equivalent Mat
>>>>>>>> constructor for GPU arrays, or some other way to avoid unnecessary copies?
>>>>>>>> Thanks,
>>>>>>>> Mark
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230104/9d1c117d/attachment.html>
