[petsc-users] MatCreateSeqAIJWithArrays for GPU / cusparse
Junchao Zhang
junchao.zhang at gmail.com
Wed Jan 4 18:09:02 CST 2023
On Wed, Jan 4, 2023 at 6:02 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 4, 2023 at 6:49 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> On Wed, Jan 4, 2023 at 5:40 PM Mark Lohry <mlohry at gmail.com> wrote:
>>> Oh, is the device backend not known at compile time?
>> Currently it is known at compile time.
> Are you sure? I don't think it is known at compile time.
We define either PETSC_HAVE_CUDA or PETSC_HAVE_HIP or NONE, but not both
> Thanks,
> Matt
>> Or multiple backends can be alive at once?
>> Some petsc developers (Jed and Barry) want to support this, but we are
>> incapable now.
>>> On Wed, Jan 4, 2023, 6:27 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> On Wed, Jan 4, 2023 at 5:19 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>> Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>>>> would need another for MATMPIAIJCUSPARSE, and then for HIPSPARSE on AMD
>>>>>> GPUs, ...
>>>>> Wouldn't one function suffice? Assuming these are contiguous arrays in
>>>>> CSR format, they're just raw device pointers in all cases.
>>>> But we need to know what device it is (to dispatch to either petsc-CUDA
>>>> or petsc-HIP backend)
>>>>> On Wed, Jan 4, 2023 at 6:02 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>>> wrote:
>>>>>> No, we don't have a counterpart of MatCreateSeqAIJWithArrays() for
>>>>>> GPUs. Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>>>> GPUs, ...
>>>>>> The real problem I think is to deal with multiple MPI ranks.
>>>>>> Providing the split arrays for petsc MATMPIAIJ is not easy and thus is
>>>>>> discouraged for users to do so.
>>>>>> A workaround is to let petsc build the matrix and allocate the
>>>>>> memory, then you call MatSeqAIJCUSPARSEGetArray() to get the array and fill
>>>>>> it up.
>>>>>> We recently added routines to support matrix assembly on GPUs, see if
>>>>>> MatSetValuesCOO
>>>>>> <https://petsc.org/release/docs/manualpages/Mat/MatSetValuesCOO/>
>>>>>> helps
>>>>>> --Junchao Zhang
>>>>>> On Wed, Jan 4, 2023 at 2:22 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>> I have a sparse matrix constructed in non-petsc code using a
>>>>>>> standard CSR representation where I compute the Jacobian to be used in an
>>>>>>> implicit TS context. In the CPU world I call
>>>>>>> MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, nrows, ncols, rowidxptr,
>>>>>>> colidxptr, valptr, Jac);
>>>>>>> which as I understand it -- (1) never copies/allocates that
>>>>>>> information, and the matrix Jac is just a non-owning view into the already
>>>>>>> allocated CSR, (2) I can write directly into the original data structures
>>>>>>> and the Mat just "knows" about it, although it still needs a call to
>>>>>>> MatAssemblyBegin/MatAssemblyEnd after modifying the values. So far this
>>>>>>> works great with GAMG.
>>>>>>> I have the same CSR representation filled in GPU data allocated with
>>>>>>> cudaMalloc and filled on-device. Is there an equivalent Mat constructor for
>>>>>>> GPU arrays, or some other way to avoid unnecessary copies?
>>>>>>> Thanks,
>>>>>>> Mark
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230104/2942f2df/attachment-0001.html>
