[petsc-users] MatCreateSeqAIJWithArrays for GPU / cusparse
Junchao Zhang
junchao.zhang at gmail.com
Wed Jan 4 18:22:34 CST 2023
We don't have a machine for us to test with both "--with-cuda --with-hip"
--Junchao Zhang
On Wed, Jan 4, 2023 at 6:17 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 4, 2023 at 7:09 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> On Wed, Jan 4, 2023 at 6:02 PM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Wed, Jan 4, 2023 at 6:49 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> On Wed, Jan 4, 2023 at 5:40 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>> Oh, is the device backend not known at compile time?
>>>> Currently it is known at compile time.
>>> Are you sure? I don't think it is known at compile time.
>> We define either PETSC_HAVE_CUDA or PETSC_HAVE_HIP or NONE, but not both
> Where is the logic for that in the code? This seems like a crazy design.
> Thanks,
> Matt
>> Thanks,
>>> Matt
>>>> Or multiple backends can be alive at once?
>>>> Some petsc developers (Jed and Barry) want to support this, but we are
>>>> incapable now.
>>>>> On Wed, Jan 4, 2023, 6:27 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>>> wrote:
>>>>>> On Wed, Jan 4, 2023 at 5:19 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>> Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then
>>>>>>>> we would need another for MATMPIAIJCUSPARSE, and then for HIPSPARSE on AMD
>>>>>>>> GPUs, ...
>>>>>>> Wouldn't one function suffice? Assuming these are contiguous arrays
>>>>>>> in CSR format, they're just raw device pointers in all cases.
>>>>>> But we need to know what device it is (to dispatch to either
>>>>>> petsc-CUDA or petsc-HIP backend)
>>>>>>> On Wed, Jan 4, 2023 at 6:02 PM Junchao Zhang <
>>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>>> No, we don't have a counterpart of MatCreateSeqAIJWithArrays() for
>>>>>>>> GPUs. Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>>>>>> GPUs, ...
>>>>>>>> The real problem I think is to deal with multiple MPI ranks.
>>>>>>>> Providing the split arrays for petsc MATMPIAIJ is not easy and thus is
>>>>>>>> discouraged for users to do so.
>>>>>>>> A workaround is to let petsc build the matrix and allocate the
>>>>>>>> memory, then you call MatSeqAIJCUSPARSEGetArray() to get the array and fill
>>>>>>>> it up.
>>>>>>>> We recently added routines to support matrix assembly on GPUs, see
>>>>>>>> if MatSetValuesCOO
>>>>>>>> <https://petsc.org/release/docs/manualpages/Mat/MatSetValuesCOO/>
>>>>>>>> helps
>>>>>>>> --Junchao Zhang
>>>>>>>> On Wed, Jan 4, 2023 at 2:22 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>>>> I have a sparse matrix constructed in non-petsc code using a
>>>>>>>>> standard CSR representation where I compute the Jacobian to be used in an
>>>>>>>>> implicit TS context. In the CPU world I call
>>>>>>>>> MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, nrows, ncols,
>>>>>>>>> rowidxptr, colidxptr, valptr, Jac);
>>>>>>>>> which as I understand it -- (1) never copies/allocates that
>>>>>>>>> information, and the matrix Jac is just a non-owning view into the already
>>>>>>>>> allocated CSR, (2) I can write directly into the original data structures
>>>>>>>>> and the Mat just "knows" about it, although it still needs a call to
>>>>>>>>> MatAssemblyBegin/MatAssemblyEnd after modifying the values. So far this
>>>>>>>>> works great with GAMG.
>>>>>>>>> I have the same CSR representation filled in GPU data allocated
>>>>>>>>> with cudaMalloc and filled on-device. Is there an equivalent Mat
>>>>>>>>> constructor for GPU arrays, or some other way to avoid unnecessary copies?
>>>>>>>>> Thanks,
>>>>>>>>> Mark
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230104/6b863b39/attachment-0001.html>
