[petsc-users] MatCreateSeqAIJWithArrays for GPU / cusparse
Matthew Knepley
knepley at gmail.com
Wed Jan 4 18:02:01 CST 2023
On Wed, Jan 4, 2023 at 6:49 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> On Wed, Jan 4, 2023 at 5:40 PM Mark Lohry <mlohry at gmail.com> wrote:
>> Oh, is the device backend not known at compile time?
> Currently it is known at compile time.
Are you sure? I don't think it is known at compile time.
Matt
> Or multiple backends can be alive at once?
> Some petsc developers (Jed and Barry) want to support this, but we are
> incapable now.
>> On Wed, Jan 4, 2023, 6:27 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> On Wed, Jan 4, 2023 at 5:19 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>> Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>>> would need another for MATMPIAIJCUSPARSE, and then for HIPSPARSE on AMD
>>>>> GPUs, ...
>>>> Wouldn't one function suffice? Assuming these are contiguous arrays in
>>>> CSR format, they're just raw device pointers in all cases.
>>> But we need to know what device it is (to dispatch to either petsc-CUDA
>>> or petsc-HIP backend)
>>>> On Wed, Jan 4, 2023 at 6:02 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> No, we don't have a counterpart of MatCreateSeqAIJWithArrays() for
>>>>> GPUs. Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>>> GPUs, ...
>>>>> The real problem I think is to deal with multiple MPI ranks. Providing
>>>>> the split arrays for petsc MATMPIAIJ is not easy and thus is discouraged
>>>>> for users to do so.
>>>>> A workaround is to let petsc build the matrix and allocate the memory,
>>>>> then you call MatSeqAIJCUSPARSEGetArray() to get the array and fill it up.
>>>>> We recently added routines to support matrix assembly on GPUs, see if
>>>>> MatSetValuesCOO
>>>>> <https://petsc.org/release/docs/manualpages/Mat/MatSetValuesCOO/>
>>>>> helps
>>>>> --Junchao Zhang
>>>>> On Wed, Jan 4, 2023 at 2:22 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>> I have a sparse matrix constructed in non-petsc code using a standard
>>>>>> CSR representation where I compute the Jacobian to be used in an implicit
>>>>>> TS context. In the CPU world I call
>>>>>> MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, nrows, ncols, rowidxptr,
>>>>>> colidxptr, valptr, Jac);
>>>>>> which as I understand it -- (1) never copies/allocates that
>>>>>> information, and the matrix Jac is just a non-owning view into the already
>>>>>> allocated CSR, (2) I can write directly into the original data structures
>>>>>> and the Mat just "knows" about it, although it still needs a call to
>>>>>> MatAssemblyBegin/MatAssemblyEnd after modifying the values. So far this
>>>>>> works great with GAMG.
>>>>>> I have the same CSR representation filled in GPU data allocated with
>>>>>> cudaMalloc and filled on-device. Is there an equivalent Mat constructor for
>>>>>> GPU arrays, or some other way to avoid unnecessary copies?
>>>>>> Thanks,
>>>>>> Mark
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230104/67880547/attachment.html>
