[petsc-users] MatCreateSeqAIJWithArrays for GPU / cusparse
Junchao Zhang
junchao.zhang at gmail.com
Wed Jan 4 17:49:07 CST 2023
On Wed, Jan 4, 2023 at 5:40 PM Mark Lohry <mlohry at gmail.com> wrote:
> Oh, is the device backend not known at compile time?
Currently it is known at compile time.
Or multiple backends can be alive at once?
Some petsc developers (Jed and Barry) want to support this, but we are
incapable now.
> On Wed, Jan 4, 2023, 6:27 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> On Wed, Jan 4, 2023 at 5:19 PM Mark Lohry <mlohry at gmail.com> wrote:
>>> Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>> would need another for MATMPIAIJCUSPARSE, and then for HIPSPARSE on AMD
>>>> GPUs, ...
>>> Wouldn't one function suffice? Assuming these are contiguous arrays in
>>> CSR format, they're just raw device pointers in all cases.
>> But we need to know what device it is (to dispatch to either petsc-CUDA
>> or petsc-HIP backend)
>>> On Wed, Jan 4, 2023 at 6:02 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> No, we don't have a counterpart of MatCreateSeqAIJWithArrays() for
>>>> GPUs. Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>> GPUs, ...
>>>> The real problem I think is to deal with multiple MPI ranks. Providing
>>>> the split arrays for petsc MATMPIAIJ is not easy and thus is discouraged
>>>> for users to do so.
>>>> A workaround is to let petsc build the matrix and allocate the memory,
>>>> then you call MatSeqAIJCUSPARSEGetArray() to get the array and fill it up.
>>>> We recently added routines to support matrix assembly on GPUs, see if
>>>> MatSetValuesCOO
>>>> <https://petsc.org/release/docs/manualpages/Mat/MatSetValuesCOO/> helps
>>>> --Junchao Zhang
>>>> On Wed, Jan 4, 2023 at 2:22 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>> I have a sparse matrix constructed in non-petsc code using a standard
>>>>> CSR representation where I compute the Jacobian to be used in an implicit
>>>>> TS context. In the CPU world I call
>>>>> MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, nrows, ncols, rowidxptr,
>>>>> colidxptr, valptr, Jac);
>>>>> which as I understand it -- (1) never copies/allocates that
>>>>> information, and the matrix Jac is just a non-owning view into the already
>>>>> allocated CSR, (2) I can write directly into the original data structures
>>>>> and the Mat just "knows" about it, although it still needs a call to
>>>>> MatAssemblyBegin/MatAssemblyEnd after modifying the values. So far this
>>>>> works great with GAMG.
>>>>> I have the same CSR representation filled in GPU data allocated with
>>>>> cudaMalloc and filled on-device. Is there an equivalent Mat constructor for
>>>>> GPU arrays, or some other way to avoid unnecessary copies?
>>>>> Thanks,
>>>>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230104/115a15bc/attachment-0001.html>
