[petsc-users] Problem setting Fieldsplit fields
Fri Feb 3 14:11:51 CST 2023
On Fri, Feb 3, 2023 at 3:03 PM Nicolas Barnafi <nbarnafi at cmm.uchile.cl>
wrote:
> > There are a number of common errors:
> >    1) Your PC has a prefix
> >    2) You have not called KSPSetFromOptions() here
> > Can you send the -ksp_view output?
> The PC at least has no prefix. I had to set ksp_rtol to 1 to get through
> the solution process, you will find both the petsc_rc and the ksp_view
> at the bottom of this message.
> Options are indeed being set from the options file, but there must be
> something missing at a certain level. Thanks for looking into this.
Okay, the next step is to pass
  -info
and send the output. This will tell us how the default splits were done. If
that
is not conclusive, we will have to use the debugger.
     Matt
> Best
> ---- petsc_rc file
> -ksp_monitor
> -ksp_type gmres
> -ksp_view
> -mat_type aij
> -ksp_norm_type unpreconditioned
> -ksp_atol 1e-14
> -ksp_rtol 1
> -pc_type fieldsplit
> -pc_fieldsplit_type multiplicative
> ---- ksp_view
> KSP Object: 1 MPI process
>    type: gmres
>      restart=500, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>      happy breakdown tolerance 1e-30
>    maximum iterations=10000, nonzero initial guess
>    tolerances:  relative=1., absolute=1e-14, divergence=10000.
>    right preconditioning
>    using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI process
>    type: fieldsplit
>      FieldSplit with MULTIPLICATIVE composition: total splits = 4
>      Solver info for each split is in the following KSP objects:
>    Split number 0 Defined by IS
>    KSP Object: (fieldsplit_0_) 1 MPI process
>      type: preonly
>      maximum iterations=10000, initial guess is zero
>      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>      left preconditioning
>      using DEFAULT norm type for convergence test
>    PC Object: (fieldsplit_0_) 1 MPI process
>      type: ilu
>      PC has not been set up so information may be incomplete
>        out-of-place factorization
>        0 levels of fill
>        tolerance for zero pivot 2.22045e-14
>        matrix ordering: natural
>        matrix solver type: petsc
>        matrix not yet factored; no additional information available
>      linear system matrix = precond matrix:
>      Mat Object: (fieldsplit_0_) 1 MPI process
>        type: seqaij
>        rows=615, cols=615
>        total: nonzeros=9213, allocated nonzeros=9213
>        total number of mallocs used during MatSetValues calls=0
>          not using I-node routines
>    Split number 1 Defined by IS
>    KSP Object: (fieldsplit_1_) 1 MPI process
>      type: preonly
>    PC Object: (fieldsplit_1_) 1 MPI process
>      type: ilu
>        0 levels of fill
>      Mat Object: (fieldsplit_1_) 1 MPI process
>        type: seqaij
>        rows=64, cols=64
>        total: nonzeros=0, allocated nonzeros=0
>          using I-node routines: found 13 nodes, limit used is 5
>    Split number 2 Defined by IS
>    KSP Object: (fieldsplit_2_) 1 MPI process
>      type: preonly
>    PC Object: (fieldsplit_2_) 1 MPI process
>      type: ilu
>        0 levels of fill
>      Mat Object: (fieldsplit_2_) 1 MPI process
>        type: seqaij
>        rows=240, cols=240
>        total: nonzeros=2140, allocated nonzeros=2140
>    Split number 3 Defined by IS
>    KSP Object: (fieldsplit_3_) 1 MPI process
>      type: preonly
>    PC Object: (fieldsplit_3_) 1 MPI process
>      type: ilu
>        0 levels of fill
>      Mat Object: (fieldsplit_3_) 1 MPI process
>        type: seqaij
>        rows=300, cols=300
>        total: nonzeros=2292, allocated nonzeros=2292
>    Mat Object: 1 MPI process
>      type: seqaij
>      rows=1219, cols=1219
>      total: nonzeros=26443, allocated nonzeros=26443
>               solving time: 0.00449609
>                 iterations: 0
>            estimated error: 25.4142
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/539af3b3/attachment.html>
