[petsc-users] Problem setting Fieldsplit fields
Nicolas Barnafi
nbarnafi at cmm.uchile.cl
Fri Feb 3 14:03:21 CST 2023
> There are a number of common errors:
> 1) Your PC has a prefix
> 2) You have not called KSPSetFromOptions() here
> Can you send the -ksp_view output?
The PC at least has no prefix. I had to set ksp_rtol to 1 to get through
the solution process, you will find both the petsc_rc and the ksp_view
at the bottom of this message.
Options are indeed being set from the options file, but there must be
something missing at a certain level. Thanks for looking into this.
Best
---- petsc_rc file
-ksp_monitor
-ksp_type gmres
-ksp_view
-mat_type aij
-ksp_norm_type unpreconditioned
-ksp_atol 1e-14
-ksp_rtol 1
-pc_type fieldsplit
-pc_fieldsplit_type multiplicative
---- ksp_view
KSP Object: 1 MPI process
type: gmres
restart=500, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=10000, nonzero initial guess
tolerances: relative=1., absolute=1e-14, divergence=10000.
right preconditioning
using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI process
type: fieldsplit
FieldSplit with MULTIPLICATIVE composition: total splits = 4
Solver info for each split is in the following KSP objects:
Split number 0 Defined by IS
KSP Object: (fieldsplit_0_) 1 MPI process
type: preonly
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using DEFAULT norm type for convergence test
PC Object: (fieldsplit_0_) 1 MPI process
type: ilu
PC has not been set up so information may be incomplete
out-of-place factorization
0 levels of fill
tolerance for zero pivot 2.22045e-14
matrix ordering: natural
matrix solver type: petsc
matrix not yet factored; no additional information available
linear system matrix = precond matrix:
Mat Object: (fieldsplit_0_) 1 MPI process
type: seqaij
rows=615, cols=615
total: nonzeros=9213, allocated nonzeros=9213
total number of mallocs used during MatSetValues calls=0
not using I-node routines
Split number 1 Defined by IS
KSP Object: (fieldsplit_1_) 1 MPI process
type: preonly
PC Object: (fieldsplit_1_) 1 MPI process
type: ilu
0 levels of fill
Mat Object: (fieldsplit_1_) 1 MPI process
type: seqaij
rows=64, cols=64
total: nonzeros=0, allocated nonzeros=0
using I-node routines: found 13 nodes, limit used is 5
Split number 2 Defined by IS
KSP Object: (fieldsplit_2_) 1 MPI process
type: preonly
PC Object: (fieldsplit_2_) 1 MPI process
type: ilu
0 levels of fill
Mat Object: (fieldsplit_2_) 1 MPI process
type: seqaij
rows=240, cols=240
total: nonzeros=2140, allocated nonzeros=2140
Split number 3 Defined by IS
KSP Object: (fieldsplit_3_) 1 MPI process
type: preonly
PC Object: (fieldsplit_3_) 1 MPI process
type: ilu
0 levels of fill
Mat Object: (fieldsplit_3_) 1 MPI process
type: seqaij
rows=300, cols=300
total: nonzeros=2292, allocated nonzeros=2292
Mat Object: 1 MPI process
type: seqaij
rows=1219, cols=1219
total: nonzeros=26443, allocated nonzeros=26443
solving time: 0.00449609
iterations: 0
estimated error: 25.4142
