[petsc-users] Problem setting Fieldsplit fields
    Nicolas Barnafi
    nbarnafi at cmm.uchile.cl
    Mon Feb  6 10:45:08 CST 2023
Thank you Matt,
Again, at the bottom of this message you will find the -info output. I
don't see any output related to the fields,
Best
------ -info
[0] <sys> PetscDetermineInitialFPTrap(): Floating point trapping is on
by default 13
[0] <sys> PetscDeviceInitializeTypeFromOptions_Private():
PetscDeviceType host available, initializing
[0] <sys> PetscDeviceInitializeTypeFromOptions_Private(): PetscDevice
host initialized, default device id 0, view FALSE, init type lazy
PetscDeviceType cuda not available
PetscDeviceType hip not available
PetscDeviceType sycl not available
[0] <sys> PetscInitialize_Common(): PETSc successfully started: number
of processors = 1
[0] <sys> PetscGetHostName(): Rejecting domainname, likely is NIS
nico-santech.(none)
[0] <sys> PetscInitialize_Common(): Running on machine: nico-santech
[0] <sys> SlepcInitialize(): SLEPc successfully started
[0] <sys> PetscCommDuplicate(): Duplicating a communicator
94770066936960 94770087780768 max tags = 2147483647
[0] <sys> Petsc_OuterComm_Attr_Delete_Fn(): Removing reference to PETSc
communicator embedded in a user MPI_Comm 94770087780768
[0] <sys> Petsc_InnerComm_Attr_Delete_Fn(): User MPI_Comm 94770066936960
is being unlinked from inner PETSc comm 94770087780768
[0] <sys> PetscCommDestroy(): Deleting PETSc MPI_Comm 94770087780768
[0] <sys> Petsc_Counter_Attr_Delete_Fn(): Deleting counter data in an
[0] <sys> PetscCommDuplicate(): Using internal PETSc communicator
[0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 1219 X 1219; storage
space: 0 unneeded,26443 used
[0] <mat> MatAssemblyEnd_SeqAIJ(): Number of mallocs during
MatSetValues() is 0
[0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 150
[0] <mat> MatCheckCompressedRow(): Found the ratio (num_zerorows
0)/(num_localrows 1219) < 0.6. Do not use CompressedRow routines.
[0] <mat> MatSeqAIJCheckInode(): Found 1160 nodes out of 1219 rows. Not
using Inode routines
nico-santech.(none)
[0] <pc> PCSetUp(): Setting up PC for first time
[0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 615 X 615; storage
space: 0 unneeded,9213 used
MatSetValues() is 0
[0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 117
0)/(num_localrows 615) < 0.6. Do not use CompressedRow routines.
[0] <mat> MatSeqAIJCheckInode(): Found 561 nodes out of 615 rows. Not
94770066934048 94770110251424 max tags = 2147483647
communicator embedded in a user MPI_Comm 94770110251424
[0] <sys> Petsc_InnerComm_Attr_Delete_Fn(): User MPI_Comm 94770066934048
is being unlinked from inner PETSc comm 94770110251424
[0] <sys> PetscCommDestroy(): Deleting PETSc MPI_Comm 94770110251424
[0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 64 X 64; storage space:
0 unneeded,0 used
MatSetValues() is 0
[0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 0
64)/(num_localrows 64) > 0.6. Use CompressedRow routines.
[0] <mat> MatSeqAIJCheckInode(): Found 13 nodes of 64. Limit used: 5.
Using Inode routines
94770066934048 94770100861088 max tags = 2147483647
communicator embedded in a user MPI_Comm 94770100861088
is being unlinked from inner PETSc comm 94770100861088
[0] <sys> PetscCommDestroy(): Deleting PETSc MPI_Comm 94770100861088
[0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 240 X 240; storage
space: 0 unneeded,2140 used
MatSetValues() is 0
0)/(num_localrows 240) < 0.6. Do not use CompressedRow routines.
[0] <mat> MatSeqAIJCheckInode(): Found 235 nodes out of 240 rows. Not
[0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 300 X 300; storage
space: 0 unneeded,2292 used
MatSetValues() is 0
[0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 33
0)/(num_localrows 300) < 0.6. Do not use CompressedRow routines.
[0] <mat> MatSeqAIJCheckInode(): Found 300 nodes out of 300 rows. Not
[0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 615 X 1219; storage
space: 0 unneeded,11202 used
MatSetValues() is 0
[0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 64 X 1219; storage
space: 0 unneeded,288 used
MatSetValues() is 0
[0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 6
0)/(num_localrows 64) < 0.6. Do not use CompressedRow routines.
[0] <mat> MatSeqAIJCheckInode(): Found 64 nodes out of 64 rows. Not
[0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 240 X 1219; storage
space: 0 unneeded,8800 used
MatSetValues() is 0
[0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 78
[0] <mat> MatAssemblyEnd_SeqAIJ(): Matrix size: 300 X 1219; storage
space: 0 unneeded,6153 used
MatSetValues() is 0
[0] <mat> MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 89
   0 KSP Residual norm 2.541418258630e+01
[0] <ksp> KSPConvergedDefault(): user has provided nonzero initial
guess, computing 2-norm of RHS
[0] <pc> PCSetUp(): Leaving PC with identical preconditioner since
operator is unchanged
94770066934048 947701008610882
On 03/02/23 21:11, Matthew Knepley wrote:
> On Fri, Feb 3, 2023 at 3:03 PM Nicolas Barnafi
> <nbarnafi at cmm.uchile.cl> wrote:
>     > There are a number of common errors:
>     >    1) Your PC has a prefix
>     >    2) You have not called KSPSetFromOptions() here
>     > Can you send the -ksp_view output?
>     The PC at least has no prefix. I had to set ksp_rtol to 1 to get
>     through
>     the solution process, you will find both the petsc_rc and the
>     ksp_view
>     at the bottom of this message.
>     Options are indeed being set from the options file, but there must be
>     something missing at a certain level. Thanks for looking into this.
> Okay, the next step is to pass
>   -info
> and send the output. This will tell us how the default splits were
> done. If that
> is not conclusive, we will have to use the debugger.
>   Thanks,
>      Matt
>     Best
>     ---- petsc_rc file
>     -ksp_monitor
>     -ksp_type gmres
>     -ksp_view
>     -mat_type aij
>     -ksp_norm_type unpreconditioned
>     -ksp_atol 1e-14
>     -ksp_rtol 1
>     -pc_type fieldsplit
>     -pc_fieldsplit_type multiplicative
>     ---- ksp_view
>     KSP Object: 1 MPI process
>        type: gmres
>          restart=500, using Classical (unmodified) Gram-Schmidt
>     Orthogonalization with no iterative refinement
>          happy breakdown tolerance 1e-30
>        maximum iterations=10000, nonzero initial guess
>        tolerances:  relative=1., absolute=1e-14, divergence=10000.
>        right preconditioning
>        using UNPRECONDITIONED norm type for convergence test
>     PC Object: 1 MPI process
>        type: fieldsplit
>          FieldSplit with MULTIPLICATIVE composition: total splits = 4
>          Solver info for each split is in the following KSP objects:
>        Split number 0 Defined by IS
>        KSP Object: (fieldsplit_0_) 1 MPI process
>          type: preonly
>          maximum iterations=10000, initial guess is zero
>          tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>          left preconditioning
>          using DEFAULT norm type for convergence test
>        PC Object: (fieldsplit_0_) 1 MPI process
>          type: ilu
>          PC has not been set up so information may be incomplete
>            out-of-place factorization
>            0 levels of fill
>            tolerance for zero pivot 2.22045e-14
>            matrix ordering: natural
>            matrix solver type: petsc
>            matrix not yet factored; no additional information available
>          linear system matrix = precond matrix:
>          Mat Object: (fieldsplit_0_) 1 MPI process
>            type: seqaij
>            rows=615, cols=615
>            total: nonzeros=9213, allocated nonzeros=9213
>            total number of mallocs used during MatSetValues calls=0
>              not using I-node routines
>        Split number 1 Defined by IS
>        KSP Object: (fieldsplit_1_) 1 MPI process
>          type: preonly
>        PC Object: (fieldsplit_1_) 1 MPI process
>          type: ilu
>            0 levels of fill
>          Mat Object: (fieldsplit_1_) 1 MPI process
>            type: seqaij
>            rows=64, cols=64
>            total: nonzeros=0, allocated nonzeros=0
>              using I-node routines: found 13 nodes, limit used is 5
>        Split number 2 Defined by IS
>        KSP Object: (fieldsplit_2_) 1 MPI process
>          type: preonly
>        PC Object: (fieldsplit_2_) 1 MPI process
>          type: ilu
>            0 levels of fill
>          Mat Object: (fieldsplit_2_) 1 MPI process
>            type: seqaij
>            rows=240, cols=240
>            total: nonzeros=2140, allocated nonzeros=2140
>        Split number 3 Defined by IS
>        KSP Object: (fieldsplit_3_) 1 MPI process
>          type: preonly
>        PC Object: (fieldsplit_3_) 1 MPI process
>          type: ilu
>            0 levels of fill
>          Mat Object: (fieldsplit_3_) 1 MPI process
>            type: seqaij
>            rows=300, cols=300
>            total: nonzeros=2292, allocated nonzeros=2292
>        Mat Object: 1 MPI process
>          type: seqaij
>          rows=1219, cols=1219
>          total: nonzeros=26443, allocated nonzeros=26443
>                   solving time: 0.00449609
>                     iterations: 0
>                estimated error: 25.4142
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230206/1fc8da9d/attachment-0001.html>
