[petsc-users] Problem setting Fieldsplit fields
Matthew Knepley
knepley at gmail.com
Fri Feb 3 13:55:02 CST 2023
On Fri, Feb 3, 2023 at 2:52 PM Nicolas Barnafi <nbarnafi at cmm.uchile.cl>
wrote:
> Thanks Matt,
> Sorry, I copied the output from the error, but in the options file I do
> it as expected:
> -pc_fieldsplit_0_fields 0,1
> -pc_fieldsplit_1_fields 2,3
There are a number of common errors:
1) Your PC has a prefix
2) You have not called KSPSetFromOptions() here
Can you send the -ksp_view output?
Matt
> Best
> On 03-02-23 16:50, Matthew Knepley wrote:
> > On Fri, Feb 3, 2023 at 2:46 PM Nicolas Barnafi via petsc-users
> > <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> > Dear community,
> > I am using a fieldsplit preconditioner, but for some reason I cannot
> > group fields as in other libraries (i.e. I do this in Firedrake and
> it
> > works). Some context:
> > I have set four fields to the preconditioner, which I want to
> > regroup with
> > -pc_fieldsplit_0_fields value: 0,1
> > -pc_fieldsplit_1_fields value: 2,3
> > You should not have a colon, ":"
> > Thanks,
> > Matt
> > But apparently this doesn't get read for some reason. In fact, from
> > -ksp_view I still see all 4 fields, and it fails as one of the blocks
> > has a null diagonal (coming from a saddle point problem), so it gives
> > the following error. Interestingly, it shows that the groupings where
> > not considered:
> > [0]PETSC ERROR: Object is in wrong state
> > [0]PETSC ERROR: Matrix is missing diagonal entry 0
> > [0]PETSC ERROR: WARNING! There are option(s) set that were not used!
> > Could be the program crashed before they were used or a spelling
> > mistake, etc!
> > [0]PETSC ERROR: Option left: name:-pc_fieldsplit_0_fields value: 0,1
> > [0]PETSC ERROR: Option left: name:-pc_fieldsplit_1_fields value: 2,3
> > Any clues to why this can happen? Best regards,
> > Nicolás Barnafi
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/ea385bb4/attachment-0001.html>
