[petsc-users] Problem setting Fieldsplit fields
Nicolas Barnafi
nbarnafi at cmm.uchile.cl
Fri Feb 3 13:52:34 CST 2023
Thanks Matt,
Sorry, I copied the output from the error, but in the options file I do
it as expected:
-pc_fieldsplit_0_fields 0,1
-pc_fieldsplit_1_fields 2,3
Best
On 03-02-23 16:50, Matthew Knepley wrote:
> On Fri, Feb 3, 2023 at 2:46 PM Nicolas Barnafi via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Dear community,
> I am using a fieldsplit preconditioner, but for some reason I cannot
> group fields as in other libraries (i.e. I do this in Firedrake and it
> works). Some context:
> I have set four fields to the preconditioner, which I want to
> regroup with
> -pc_fieldsplit_0_fields value: 0,1
> -pc_fieldsplit_1_fields value: 2,3
> You should not have a colon, ":"
> Thanks,
> Matt
> But apparently this doesn't get read for some reason. In fact, from
> -ksp_view I still see all 4 fields, and it fails as one of the blocks
> has a null diagonal (coming from a saddle point problem), so it gives
> the following error. Interestingly, it shows that the groupings where
> not considered:
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Matrix is missing diagonal entry 0
> [0]PETSC ERROR: WARNING! There are option(s) set that were not used!
> Could be the program crashed before they were used or a spelling
> mistake, etc!
> [0]PETSC ERROR: Option left: name:-pc_fieldsplit_0_fields value: 0,1
> [0]PETSC ERROR: Option left: name:-pc_fieldsplit_1_fields value: 2,3
> Any clues to why this can happen? Best regards,
> Nicolás Barnafi
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
