[petsc-users] Question about MatGetRow
    김성익
    ksi2443 at gmail.com
    Fri Feb  3 08:04:04 CST 2023
Actually in the last mail, below scripts are running in all processes.
IS isrow;
PetscInt *indices;
PetscMalloc1(1, &indices);
Indices[0] = 0;
ISCreateGenreral(PETSC_COMM_WORLD, 1, indices, PETSC_OWN_POINTER, &isrow);
MatCreateSubMatrix(mat,isrow,NULL,MAT_INITIAL_MATRIX,&newmat);
(extract from newmat)
However, you said it cannot get the values of first row of global matrix.
Please let me know how can I fix this scripts for getting the 1st row of
global matrix in all processes.
Hyung Kim
2023년 2월 3일 (금) 오후 10:54, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Fri, Feb 3, 2023 at 8:52 AM 김성익 <ksi2443 at gmail.com> wrote:
>> I want to extract same row values of global matrix in all processes.
>> Then how can I do this??
> Create the same IS on each process.
>   THanks,
>     Matt
>> The case of same problem of vector, I just use vecscattertoall.
>> However, I can't find same function for matrix.
>> Hyung Kim
>> 2023년 2월 3일 (금) 오후 10:47, Matthew Knepley <knepley at gmail.com>님이 작성:
>>> On Fri, Feb 3, 2023 at 8:45 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>> Following your comments,
>>>> If I extract first row of below matrix.
>>>> [image: image.png]
>>>> IS isrow;
>>>> PetscInt *indices;
>>>> PetscMalloc1(1, *indices);
>>> That should be &indices.
>>>> Indices[0] = 0;
>>>> ISCreateGenreral(PETSC_COMM_WORLD, 1, indices, PETSC_COPY_VALUES,
>>>> &isrow);
>>> You should use PETSC_OWN_POINTER.
>>>> Then can I get the array about first row of global matrix in all
>>>> processes?
>>> No, just on the process which gives 0. If you do that on every process,
>>> every rank with get row 0.
>>>   Thanks,
>>>      Matt
>>>> Hyung Kim
>>>> 2023년 2월 3일 (금) 오후 10:26, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>>> I want to check below things.
>>>>>> For example, the global dense matrix are as below.
>>>>>> [image: image.png]
>>>>>> If I want to get first row ('1 2 0 0 3 0 0 4') in Proc 1.
>>>>>> Then I should put 'MatCreateSubMatrix
>>>>>> <https://petsc.org/main/docs/manualpages/Mat/MatCreateSubMatrix/>(mat
>>>>>> , isrow, NULL, MAT_INITIAL_MATRIX, *&*newmat)'
>>>>>> and isrow will be [0 1 2 3 4 5 6 7].
>>>>>> In this case, How can I make isrow?
>>>>>> Actually I can't understand the procedure of handling isrow.
>>>>> You create an IS object of type ISGENERAL and give it the array of
>>>>> global indices that you want to extract.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Hyung Kim
>>>>>> 2023년 2월 3일 (금) 오후 9:03, Mark Adams <mfadams at lbl.gov>님이 작성:
>>>>>>> Note, PETSc lets you give NULL arguments if there is a reasonable
>>>>>>> default.
>>>>>>> In this case give NULL for the column IS and you will get the whole
>>>>>>> columns.
>>>>>>> Mark
>>>>>>> On Fri, Feb 3, 2023 at 4:05 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>>>> Hello,
>>>>>>>> By using MatGetRow, user can get vectors from local matrix (at each
>>>>>>>> process).
>>>>>>>> However, I need other process's row values.
>>>>>>>> So I have 2 questions.
>>>>>>>> 1. Is there any function for getting arrays from other process's??
>>>>>>>> 2. Or is there any function like matrix version of vecscattertoall??
>>>>>>>> Thanks,
>>>>>>>> Hyung Kim
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/c3bbbdb2/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/c3bbbdb2/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/c3bbbdb2/attachment-0003.png>
