[petsc-users] Question about MatGetRow
Matthew Knepley
knepley at gmail.com
Fri Feb 3 07:54:17 CST 2023
On Fri, Feb 3, 2023 at 8:52 AM 김성익 <ksi2443 at gmail.com> wrote:
> I want to extract same row values of global matrix in all processes.
> Then how can I do this??
Create the same IS on each process.
THanks,
Matt
> The case of same problem of vector, I just use vecscattertoall.
> However, I can't find same function for matrix.
> Hyung Kim
> 2023년 2월 3일 (금) 오후 10:47, Matthew Knepley <knepley at gmail.com>님이 작성:
>> On Fri, Feb 3, 2023 at 8:45 AM 김성익 <ksi2443 at gmail.com> wrote:
>>> Following your comments,
>>> If I extract first row of below matrix.
>>> [image: image.png]
>>> IS isrow;
>>> PetscInt *indices;
>>> PetscMalloc1(1, *indices);
>> That should be &indices.
>>> Indices[0] = 0;
>>> ISCreateGenreral(PETSC_COMM_WORLD, 1, indices, PETSC_COPY_VALUES,
>>> &isrow);
>> You should use PETSC_OWN_POINTER.
>>> MatCreateSubMatrix(mat,isrow,NULL,MAT_INITIAL_MATRIX,&newmat);
>>> Then can I get the array about first row of global matrix in all
>>> processes?
>> No, just on the process which gives 0. If you do that on every process,
>> every rank with get row 0.
>> Thanks,
>> Matt
>>> Hyung Kim
>>> 2023년 2월 3일 (금) 오후 10:26, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>> I want to check below things.
>>>>> For example, the global dense matrix are as below.
>>>>> [image: image.png]
>>>>> If I want to get first row ('1 2 0 0 3 0 0 4') in Proc 1.
>>>>> Then I should put 'MatCreateSubMatrix
>>>>> <https://petsc.org/main/docs/manualpages/Mat/MatCreateSubMatrix/>(mat,
>>>>> isrow, NULL, MAT_INITIAL_MATRIX, *&*newmat)'
>>>>> and isrow will be [0 1 2 3 4 5 6 7].
>>>>> In this case, How can I make isrow?
>>>>> Actually I can't understand the procedure of handling isrow.
>>>> You create an IS object of type ISGENERAL and give it the array of
>>>> global indices that you want to extract.
>>>> Thanks,
>>>> Matt
>>>>> Hyung Kim
>>>>> 2023년 2월 3일 (금) 오후 9:03, Mark Adams <mfadams at lbl.gov>님이 작성:
>>>>>> Note, PETSc lets you give NULL arguments if there is a reasonable
>>>>>> default.
>>>>>> In this case give NULL for the column IS and you will get the whole
>>>>>> columns.
>>>>>> Mark
>>>>>> On Fri, Feb 3, 2023 at 4:05 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>>> Hello,
>>>>>>> By using MatGetRow, user can get vectors from local matrix (at each
>>>>>>> process).
>>>>>>> However, I need other process's row values.
>>>>>>> So I have 2 questions.
>>>>>>> 1. Is there any function for getting arrays from other process's??
>>>>>>> 2. Or is there any function like matrix version of vecscattertoall??
>>>>>>> Thanks,
>>>>>>> Hyung Kim
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/c7e1a94e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/c7e1a94e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/c7e1a94e/attachment-0003.png>
