[petsc-users] Question about MatGetRow
Matthew Knepley
knepley at gmail.com
Fri Feb 3 08:32:49 CST 2023
On Fri, Feb 3, 2023 at 9:04 AM 김성익 <ksi2443 at gmail.com> wrote:
> Actually in the last mail, below scripts are running in all processes.
> IS isrow;
> PetscInt *indices;
> PetscMalloc1(1, &indices);
> Indices[0] = 0;
> ISCreateGenreral(PETSC_COMM_WORLD, 1, indices, PETSC_OWN_POINTER, &isrow);
> MatCreateSubMatrix(mat,isrow,NULL,MAT_INITIAL_MATRIX,&newmat);
> (extract from newmat)
> However, you said it cannot get the values of first row of global matrix.
> Please let me know how can I fix this scripts for getting the 1st row of
> global matrix in all processes.
Did you run and see what you get? If it is on all processes, it should work.
Matt
> Hyung Kim
> 2023년 2월 3일 (금) 오후 10:54, Matthew Knepley <knepley at gmail.com>님이 작성:
>> On Fri, Feb 3, 2023 at 8:52 AM 김성익 <ksi2443 at gmail.com> wrote:
>>> I want to extract same row values of global matrix in all processes.
>>> Then how can I do this??
>> Create the same IS on each process.
>> THanks,
>> Matt
>>> The case of same problem of vector, I just use vecscattertoall.
>>> However, I can't find same function for matrix.
>>> Hyung Kim
>>> 2023년 2월 3일 (금) 오후 10:47, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>> On Fri, Feb 3, 2023 at 8:45 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>> Following your comments,
>>>>> If I extract first row of below matrix.
>>>>> [image: image.png]
>>>>> IS isrow;
>>>>> PetscInt *indices;
>>>>> PetscMalloc1(1, *indices);
>>>> That should be &indices.
>>>>> Indices[0] = 0;
>>>>> ISCreateGenreral(PETSC_COMM_WORLD, 1, indices, PETSC_COPY_VALUES,
>>>>> &isrow);
>>>> You should use PETSC_OWN_POINTER.
>>>>> Then can I get the array about first row of global matrix in all
>>>>> processes?
>>>> No, just on the process which gives 0. If you do that on every process,
>>>> every rank with get row 0.
>>>> Thanks,
>>>> Matt
>>>>> Hyung Kim
>>>>> 2023년 2월 3일 (금) 오후 10:26, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>>>> I want to check below things.
>>>>>>> For example, the global dense matrix are as below.
>>>>>>> [image: image.png]
>>>>>>> If I want to get first row ('1 2 0 0 3 0 0 4') in Proc 1.
>>>>>>> Then I should put 'MatCreateSubMatrix
>>>>>>> <https://petsc.org/main/docs/manualpages/Mat/MatCreateSubMatrix/>(
>>>>>>> mat, isrow, NULL, MAT_INITIAL_MATRIX, *&*newmat)'
>>>>>>> and isrow will be [0 1 2 3 4 5 6 7].
>>>>>>> In this case, How can I make isrow?
>>>>>>> Actually I can't understand the procedure of handling isrow.
>>>>>> You create an IS object of type ISGENERAL and give it the array of
>>>>>> global indices that you want to extract.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Hyung Kim
>>>>>>> 2023년 2월 3일 (금) 오후 9:03, Mark Adams <mfadams at lbl.gov>님이 작성:
>>>>>>>> Note, PETSc lets you give NULL arguments if there is a reasonable
>>>>>>>> default.
>>>>>>>> In this case give NULL for the column IS and you will get the whole
>>>>>>>> columns.
>>>>>>>> Mark
>>>>>>>> On Fri, Feb 3, 2023 at 4:05 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>>>>> Hello,
>>>>>>>>> By using MatGetRow, user can get vectors from local matrix (at
>>>>>>>>> each process).
>>>>>>>>> However, I need other process's row values.
>>>>>>>>> So I have 2 questions.
>>>>>>>>> 1. Is there any function for getting arrays from other process's??
>>>>>>>>> 2. Or is there any function like matrix version of
>>>>>>>>> vecscattertoall??
>>>>>>>>> Thanks,
>>>>>>>>> Hyung Kim
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/22638950/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/22638950/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/22638950/attachment-0003.png>
