[petsc-users] [EXTERNAL] Re: Call to DMSetMatrixPreallocateSkip not changing allocation behavior
Jed Brown
jed at jedbrown.org
Mon Dec 18 13:47:06 CST 2023
Great, thanks for letting us know. It'll merge to release shortly and thus be in petsc >= 3.20.3.
"Fackler, Philip" <facklerpw at ornl.gov> writes:
> Jed,
> That seems to have worked (ridiculously well). It's now 55MB, and it's happening in the call to MatSetPreallocationCOO.
> Thank you,
> Philip Fackler
> Research Software Engineer, Application Engineering Group
> Advanced Computing Systems Research Section
> Computer Science and Mathematics Division
> Oak Ridge National Laboratory
> ________________________________
> From: Jed Brown <jed at jedbrown.org>
> Sent: Thursday, December 14, 2023 16:27
> To: Fackler, Philip <facklerpw at ornl.gov>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>
> Subject: [EXTERNAL] Re: [petsc-users] Call to DMSetMatrixPreallocateSkip not changing allocation behavior
> I had a one-character typo in the diff above. This MR to release should work now.
> https://urldefense.us/v2/url?u=https-3A__gitlab.com_petsc_petsc_-2D_merge-5Frequests_7120&d=DwIBAg&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=v9sHqomCGBRWotign4NcwYwOpszOJehUGs_EO3eGn4SSZqxnfK7Iv15-X8nO1lii&s=h_jIP-6WcIjR6LssfGrV6Z2DojlN_w7Me4-a4rBE074&e=
> Jed Brown <jed at jedbrown.org> writes:
>> 17 GB for a 1D DMDA, wow. :-)
>> Could you try applying this diff to make it work for DMDA (it's currently handled by DMPlex)?
>> diff --git i/src/dm/impls/da/fdda.c w/src/dm/impls/da/fdda.c
>> index cad4d926504..bd2a3bda635 100644
>> --- i/src/dm/impls/da/fdda.c
>> +++ w/src/dm/impls/da/fdda.c
>> @@ -675,19 +675,21 @@ PetscErrorCode DMCreateMatrix_DA(DM da, Mat *J)
>> specialized setting routines depend only on the particular preallocation
>> details of the matrix, not the type itself.
>> - PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIAIJSetPreallocation_C", &aij));
>> - if (!aij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqAIJSetPreallocation_C", &aij));
>> - if (!aij) {
>> - PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIBAIJSetPreallocation_C", &baij));
>> - if (!baij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqBAIJSetPreallocation_C", &baij));
>> - if (!baij) {
>> - PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISBAIJSetPreallocation_C", &sbaij));
>> - if (!sbaij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSBAIJSetPreallocation_C", &sbaij));
>> - if (!sbaij) {
>> - PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISELLSetPreallocation_C", &sell));
>> - if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSELLSetPreallocation_C", &sell));
>> + if (!dm->prealloc_skip) { // Flag is likely set when user intends to use MatSetPreallocationCOO()
>> + PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIAIJSetPreallocation_C", &aij));
>> + if (!aij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqAIJSetPreallocation_C", &aij));
>> + if (!aij) {
>> + PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIBAIJSetPreallocation_C", &baij));
>> + if (!baij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqBAIJSetPreallocation_C", &baij));
>> + if (!baij) {
>> + PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISBAIJSetPreallocation_C", &sbaij));
>> + if (!sbaij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSBAIJSetPreallocation_C", &sbaij));
>> + if (!sbaij) {
>> + PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISELLSetPreallocation_C", &sell));
>> + if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSELLSetPreallocation_C", &sell));
>> + if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatISSetPreallocation_C", &is));
>> - if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatISSetPreallocation_C", &is));
>> if (aij) {
>> "Fackler, Philip via petsc-users" <petsc-users at mcs.anl.gov> writes:
>>> I'm using the following sequence of functions related to the Jacobian matrix:
>>> DMDACreate1d(..., &da);
>>> DMSetFromOptions(da);
>>> DMSetUp(da);
>>> DMSetMatType(da, MATAIJKOKKOS);
>>> DMSetMatrixPreallocateSkip(da, PETSC_TRUE);
>>> Mat J;
>>> DMCreateMatrix(da, &J);
>>> MatSetPreallocationCOO(J, ...);
>>> I recently added the call to DMSetMatrixPreallocateSkip, hoping the allocation would be delayed to MatSetPreallocationCOO, and that it would require less memory. The documentation<https://urldefense.us/v2/url?u=https-3A__petsc.org_release_manualpages_DM_DMSetMatrixPreallocateSkip_&d=DwIBAg&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=v9sHqomCGBRWotign4NcwYwOpszOJehUGs_EO3eGn4SSZqxnfK7Iv15-X8nO1lii&s=IMLBs0ydxDPvuXeD6jmsq1BN_8oieHVSyG6VA9c0DyM&e= > says that the data structures will not be preallocated. The following data from heaptrack shows that the allocation is still happening in the call to DMCreateMatrix.
>>> [cid:bda9ef12-a46f-47b2-9b9b-a4b2808b6b13]
>>> Can someone help me understand this?
>>> Thanks,
>>> Philip Fackler
