[petsc-users] Call to DMSetMatrixPreallocateSkip not changing allocation behavior
Thu Dec 14 15:19:01 CST 2023
On Thu, Dec 14, 2023 at 2:06 PM Fackler, Philip via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> I'm using the following sequence of functions related to the Jacobian
> matrix:
> DMDACreate1d(..., &da);
> DMSetFromOptions(da);
> DMSetUp(da);
> DMSetMatType(da, MATAIJKOKKOS);
> DMSetMatrixPreallocateSkip(da, PETSC_TRUE);
> Mat J;
> DMCreateMatrix(da, &J);
> MatSetPreallocationCOO(J, ...);
> I recently added the call to DMSetMatrixPreallocateSkip, hoping the
> allocation would be delayed to MatSetPreallocationCOO, and that it would
> require less memory. The documentation
> <https://petsc.org/release/manualpages/DM/DMSetMatrixPreallocateSkip/> says
> that the data structures will not be preallocated.
You are completely correct. DMDA is just ignoring this flag. We will fix it.
  Thanks for catching this.
     Matt
> The following data from heaptrack shows that the allocation is still
> happening in the call to DMCreateMatrix.
> Can someone help me understand this?
> Thanks,
> *Philip Fackler *
> Research Software Engineer, Application Engineering Group
> Advanced Computing Systems Research Section
> Computer Science and Mathematics Division
> *Oak Ridge National Laboratory*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231214/b34c081e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231214/b34c081e/attachment-0001.png>
