[petsc-users] [EXTERNAL] Re: Call to DMSetMatrixPreallocateSkip not changing allocation behavior
Fackler, Philip facklerpw at ornl.gov
Mon Dec 18 12:54:27 CST 2023
Jed,
That seems to have worked (ridiculously well). It's now 55MB, and it's happening in the call to MatSetPreallocationCOO.
Thank you,
Philip Fackler
Research Software Engineer, Application Engineering Group
Advanced Computing Systems Research Section
Computer Science and Mathematics Division
Oak Ridge National Laboratory
Sent: Thursday, December 14, 2023 16:27
To: Fackler, Philip <facklerpw at ornl.gov>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>
Subject: [EXTERNAL] Re: [petsc-users] Call to DMSetMatrixPreallocateSkip not changing allocation behavior
I had a one-character typo in the diff above. This MR to release should work now.
https://urldefense.us/v2/url?u=https-3A__gitlab.com_petsc_petsc_-2D_merge-5Frequests_7120&d=DwIBAg&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=v9sHqomCGBRWotign4NcwYwOpszOJehUGs_EO3eGn4SSZqxnfK7Iv15-X8nO1lii&s=h_jIP-6WcIjR6LssfGrV6Z2DojlN_w7Me4-a4rBE074&e=
Jed Brown <jed at jedbrown.org> writes:
> 17 GB for a 1D DMDA, wow. :-)
> Could you try applying this diff to make it work for DMDA (it's currently handled by DMPlex)?
> diff --git i/src/dm/impls/da/fdda.c w/src/dm/impls/da/fdda.c
> index cad4d926504..bd2a3bda635 100644
> --- i/src/dm/impls/da/fdda.c
> +++ w/src/dm/impls/da/fdda.c
> @@ -675,19 +675,21 @@ PetscErrorCode DMCreateMatrix_DA(DM da, Mat *J)
>     specialized setting routines depend only on the particular preallocation
>     details of the matrix, not the type itself.
> -  PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIAIJSetPreallocation_C", &aij));
> -  if (!aij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqAIJSetPreallocation_C", &aij));
> -  if (!aij) {
> -    PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIBAIJSetPreallocation_C", &baij));
> -    if (!baij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqBAIJSetPreallocation_C", &baij));
> -    if (!baij) {
> -      PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISBAIJSetPreallocation_C", &sbaij));
> -      if (!sbaij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSBAIJSetPreallocation_C", &sbaij));
> -      if (!sbaij) {
> -        PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISELLSetPreallocation_C", &sell));
> -        if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSELLSetPreallocation_C", &sell));
> +  if (!dm->prealloc_skip) { // Flag is likely set when user intends to use MatSetPreallocationCOO()
> +    PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIAIJSetPreallocation_C", &aij));
> +    if (!aij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqAIJSetPreallocation_C", &aij));
> +    if (!aij) {
> +      PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIBAIJSetPreallocation_C", &baij));
> +      if (!baij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqBAIJSetPreallocation_C", &baij));
> +      if (!baij) {
> +        PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISBAIJSetPreallocation_C", &sbaij));
> +        if (!sbaij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSBAIJSetPreallocation_C", &sbaij));
> +        if (!sbaij) {
> +          PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISELLSetPreallocation_C", &sell));
> +          if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSELLSetPreallocation_C", &sell));
> +        if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatISSetPreallocation_C", &is));
> -      if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatISSetPreallocation_C", &is));
>    if (aij) {
> "Fackler, Philip via petsc-users" <petsc-users at mcs.anl.gov> writes:
>> I'm using the following sequence of functions related to the Jacobian matrix:
>> DMDACreate1d(..., &da);
>> DMSetFromOptions(da);
>> DMSetUp(da);
>> DMSetMatType(da, MATAIJKOKKOS);
>> DMSetMatrixPreallocateSkip(da, PETSC_TRUE);
>> Mat J;
>> DMCreateMatrix(da, &J);
>> MatSetPreallocationCOO(J, ...);
>> I recently added the call to DMSetMatrixPreallocateSkip, hoping the allocation would be delayed to MatSetPreallocationCOO, and that it would require less memory. The documentation<https://urldefense.us/v2/url?u=https-3A__petsc.org_release_manualpages_DM_DMSetMatrixPreallocateSkip_&d=DwIBAg&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=v9sHqomCGBRWotign4NcwYwOpszOJehUGs_EO3eGn4SSZqxnfK7Iv15-X8nO1lii&s=IMLBs0ydxDPvuXeD6jmsq1BN_8oieHVSyG6VA9c0DyM&e= > says that the data structures will not be preallocated. The following data from heaptrack shows that the allocation is still happening in the call to DMCreateMatrix.
>> [cid:bda9ef12-a46f-47b2-9b9b-a4b2808b6b13]
>> Can someone help me understand this?
>> Thanks,
>> Philip Fackler
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231218/7b5e8769/attachment.html>
