[petsc-users] Call to DMSetMatrixPreallocateSkip not changing allocation behavior
Jed Brown jed at jedbrown.org
Thu Dec 14 15:27:53 CST 2023
I had a one-character typo in the diff above. This MR to release should work now.
https://gitlab.com/petsc/petsc/-/merge_requests/7120
Jed Brown <jed at jedbrown.org> writes:
> 17 GB for a 1D DMDA, wow. :-)
> Could you try applying this diff to make it work for DMDA (it's currently handled by DMPlex)?
> diff --git i/src/dm/impls/da/fdda.c w/src/dm/impls/da/fdda.c
> index cad4d926504..bd2a3bda635 100644
> --- i/src/dm/impls/da/fdda.c
> +++ w/src/dm/impls/da/fdda.c
> @@ -675,19 +675,21 @@ PetscErrorCode DMCreateMatrix_DA(DM da, Mat *J)
>     specialized setting routines depend only on the particular preallocation
>     details of the matrix, not the type itself.
> -  PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIAIJSetPreallocation_C", &aij));
> -  if (!aij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqAIJSetPreallocation_C", &aij));
> -  if (!aij) {
> -    PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIBAIJSetPreallocation_C", &baij));
> -    if (!baij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqBAIJSetPreallocation_C", &baij));
> -    if (!baij) {
> -      PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISBAIJSetPreallocation_C", &sbaij));
> -      if (!sbaij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSBAIJSetPreallocation_C", &sbaij));
> -      if (!sbaij) {
> -        PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISELLSetPreallocation_C", &sell));
> -        if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSELLSetPreallocation_C", &sell));
> +  if (!dm->prealloc_skip) { // Flag is likely set when user intends to use MatSetPreallocationCOO()
> +    PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIAIJSetPreallocation_C", &aij));
> +    if (!aij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqAIJSetPreallocation_C", &aij));
> +    if (!aij) {
> +      PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIBAIJSetPreallocation_C", &baij));
> +      if (!baij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqBAIJSetPreallocation_C", &baij));
> +      if (!baij) {
> +        PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISBAIJSetPreallocation_C", &sbaij));
> +        if (!sbaij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSBAIJSetPreallocation_C", &sbaij));
> +        if (!sbaij) {
> +          PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISELLSetPreallocation_C", &sell));
> +          if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSELLSetPreallocation_C", &sell));
> +        if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatISSetPreallocation_C", &is));
> -      if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatISSetPreallocation_C", &is));
>    if (aij) {
> "Fackler, Philip via petsc-users" <petsc-users at mcs.anl.gov> writes:
>> I'm using the following sequence of functions related to the Jacobian matrix:
>> DMDACreate1d(..., &da);
>> DMSetFromOptions(da);
>> DMSetUp(da);
>> DMSetMatType(da, MATAIJKOKKOS);
>> DMSetMatrixPreallocateSkip(da, PETSC_TRUE);
>> Mat J;
>> DMCreateMatrix(da, &J);
>> MatSetPreallocationCOO(J, ...);
>> I recently added the call to DMSetMatrixPreallocateSkip, hoping the allocation would be delayed to MatSetPreallocationCOO, and that it would require less memory. The documentation<https://petsc.org/release/manualpages/DM/DMSetMatrixPreallocateSkip/> says that the data structures will not be preallocated. The following data from heaptrack shows that the allocation is still happening in the call to DMCreateMatrix.
>> [cid:bda9ef12-a46f-47b2-9b9b-a4b2808b6b13]
>> Can someone help me understand this?
>> Thanks,
>> Philip Fackler
>> Research Software Engineer, Application Engineering Group
>> Advanced Computing Systems Research Section
>> Computer Science and Mathematics Division
>> Oak Ridge National Laboratory
