[petsc-users] Call to DMSetMatrixPreallocateSkip not changing allocation behavior
Jed Brown jed at jedbrown.org
Thu Dec 14 14:49:25 CST 2023
17 GB for a 1D DMDA, wow. :-)
Could you try applying this diff to make it work for DMDA (it's currently handled by DMPlex)?
diff --git i/src/dm/impls/da/fdda.c w/src/dm/impls/da/fdda.c
index cad4d926504..bd2a3bda635 100644
--- i/src/dm/impls/da/fdda.c
+++ w/src/dm/impls/da/fdda.c
@@ -675,19 +675,21 @@ PetscErrorCode DMCreateMatrix_DA(DM da, Mat *J)
    specialized setting routines depend only on the particular preallocation
    details of the matrix, not the type itself.
-  PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIAIJSetPreallocation_C", &aij));
-  if (!aij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqAIJSetPreallocation_C", &aij));
-  if (!aij) {
-    PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIBAIJSetPreallocation_C", &baij));
-    if (!baij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqBAIJSetPreallocation_C", &baij));
-    if (!baij) {
-      PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISBAIJSetPreallocation_C", &sbaij));
-      if (!sbaij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSBAIJSetPreallocation_C", &sbaij));
-      if (!sbaij) {
-        PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISELLSetPreallocation_C", &sell));
-        if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSELLSetPreallocation_C", &sell));
+  if (!dm->prealloc_skip) { // Flag is likely set when user intends to use MatSetPreallocationCOO()
+    PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIAIJSetPreallocation_C", &aij));
+    if (!aij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqAIJSetPreallocation_C", &aij));
+    if (!aij) {
+      PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPIBAIJSetPreallocation_C", &baij));
+      if (!baij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqBAIJSetPreallocation_C", &baij));
+      if (!baij) {
+        PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISBAIJSetPreallocation_C", &sbaij));
+        if (!sbaij) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSBAIJSetPreallocation_C", &sbaij));
+        if (!sbaij) {
+          PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatMPISELLSetPreallocation_C", &sell));
+          if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatSeqSELLSetPreallocation_C", &sell));
+        if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatISSetPreallocation_C", &is));
-      if (!sell) PetscCall(PetscObjectQueryFunction((PetscObject)A, "MatISSetPreallocation_C", &is));
   if (aij) {
"Fackler, Philip via petsc-users" <petsc-users at mcs.anl.gov> writes:
> I'm using the following sequence of functions related to the Jacobian matrix:
> DMDACreate1d(..., &da);
> DMSetFromOptions(da);
> DMSetUp(da);
> DMSetMatType(da, MATAIJKOKKOS);
> DMSetMatrixPreallocateSkip(da, PETSC_TRUE);
> Mat J;
> DMCreateMatrix(da, &J);
> MatSetPreallocationCOO(J, ...);
> I recently added the call to DMSetMatrixPreallocateSkip, hoping the allocation would be delayed to MatSetPreallocationCOO, and that it would require less memory. The documentation<https://petsc.org/release/manualpages/DM/DMSetMatrixPreallocateSkip/> says that the data structures will not be preallocated. The following data from heaptrack shows that the allocation is still happening in the call to DMCreateMatrix.
> [cid:bda9ef12-a46f-47b2-9b9b-a4b2808b6b13]
> Can someone help me understand this?
> Thanks,
> Philip Fackler
> Research Software Engineer, Application Engineering Group
> Advanced Computing Systems Research Section
> Computer Science and Mathematics Division
> Oak Ridge National Laboratory
