[petsc-users] PCHPDDM and matrix type
Alexander Lindsay alexlindsay239 at gmail.com
Mon Apr 17 18:26:28 CDT 2023
I don't really get much more of a stack trace out:
[0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
be the program crashed before they were used or a spelling mistake, etc!
[1]PETSC ERROR: Invalid argument
[1]PETSC ERROR:
[0]PETSC ERROR:   Option left: name:-i value: full_upwinding_2D.i source:
command line
[0]PETSC ERROR: [1]PETSC ERROR: WARNING! There are option(s) set that were
not used! Could be the program crashed before they were used or a spelling
mistake, etc!
  Option left: name:-ksp_converged_reason value: ::failed source: code
[0]PETSC ERROR:   Option left: name:-pc_hpddm_coarse_mat_type value: baij
source: command line
[0]PETSC ERROR:   Option left: name:-pc_hpddm_coarse_pc_type value: lu
[1]PETSC ERROR:   Option left: name:-i value: full_upwinding_2D.i source:
command line
[1]PETSC ERROR:   Option left: name:-ksp_converged_reason value: ::failed
source: code
[0]PETSC ERROR:   Option left: name:-snes_converged_reason value: ::failed
source: code
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.17.4-3368-g5a48edb989d
 GIT Date: 2023-04-16 17:35:24 +0000
[1]PETSC ERROR:   Option left: name:-pc_hpddm_coarse_mat_type value: baij
[1]PETSC ERROR:   Option left: name:-pc_hpddm_coarse_pc_type value: lu
[0]PETSC ERROR: ../../../moose_test-opt on a arch-moose named
rod.hpc.inl.gov by lindad Mon Apr 17 16:11:09 2023
[0]PETSC ERROR: Configure options --download-hypre=1
--with-shared-libraries=1 --download-hdf5=1 --with-hdf5-fortran-bindings=0
  --with-debugging=no --download-fblaslapack=1 --download-metis=1
--download-ptscotch=1 --download-parmetis=1 --download-superlu_dist=1
--download-mumps=1 --download-strumpack=1 --download-scalapack=1
--download-slepc=1 --with-mpi=1 --with-openmp=1 --with-cxx-dialect=C++11
--with-fortran-bindings=0 --with-sowing=0 --with-64-bit-indices
 --with-make-np=256 --download-hpddm
[1]PETSC ERROR:   Option left: name:-snes_converged_reason value: ::failed
source: code
[1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[1]PETSC ERROR: [0]PETSC ERROR: #1 buildTwo() at
/raid/lindad/moose/petsc/arch-moose/include/HPDDM_schwarz.hpp:1012
Petsc Development GIT revision: v3.17.4-3368-g5a48edb989d  GIT Date:
[1]PETSC ERROR: ../../../moose_test-opt on a arch-moose named
[1]PETSC ERROR: Configure options --download-hypre=1
[1]PETSC ERROR: #1 buildTwo() at
On Mon, Apr 17, 2023 at 4:55 PM Matthew Knepley <knepley at gmail.com> wrote:
> I don't think so. Can you show the whole stack?
>   THanks,
>     Matt
> On Mon, Apr 17, 2023 at 6:24 PM Alexander Lindsay <
> alexlindsay239 at gmail.com> wrote:
>> If it helps: if I use those exact same options in serial, then no errors
>> and the linear solve is beautiful :-)
>> On Mon, Apr 17, 2023 at 4:22 PM Alexander Lindsay <
>>> I'm likely revealing a lot of ignorance, but in order to use HPDDM as a
>>> preconditioner does my system matrix (I am using the same matrix for A and
>>> P) need to be block type, e.g. baij or sbaij ? In MOOSE our default is aij
>>> and I am currently getting
>>> with options:
>>> -pc_type hpddm -pc_hpddm_block_splitting -pc_hpddm_coarse_mat_type baij
>>> -pc_hpddm_coarse_pc_type lu -pc_hpddm_define_subdomains
>>> -pc_hpddm_levels_1_eps_gen_non_hermitian -pc_hpddm_levels_1_eps_nev 50
>>> -pc_hpddm_levels_1_eps_threshold 0.1 -pc_hpddm_levels_1_st_matstructure
>>> SAME -pc_hpddm_levels_1_st_share_sub_ksp
>>> -pc_hpddm_levels_1_sub_pc_factor_mat_solver_type mumps
>>> -pc_hpddm_levels_1_sub_pc_type lu
>>> Alex
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230417/bbf9ddc1/attachment-0001.html>
