[petsc-users] PCHPDDM and matrix type
Matthew Knepley
knepley at gmail.com
Mon Apr 17 18:49:04 CDT 2023
Yes, I cannot figure the error out. We will wait for Pierre to weigh in.
Matt
On Mon, Apr 17, 2023 at 7:26 PM Alexander Lindsay <alexlindsay239 at gmail.com>
wrote:
> I don't really get much more of a stack trace out:
> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
> be the program crashed before they were used or a spelling mistake, etc!
> [1]PETSC ERROR: Invalid argument
> [1]PETSC ERROR:
> [0]PETSC ERROR: Option left: name:-i value: full_upwinding_2D.i source:
> command line
> [0]PETSC ERROR: [1]PETSC ERROR: WARNING! There are option(s) set that were
> not used! Could be the program crashed before they were used or a spelling
> mistake, etc!
> Option left: name:-ksp_converged_reason value: ::failed source: code
> [0]PETSC ERROR: Option left: name:-pc_hpddm_coarse_mat_type value: baij
> source: command line
> [0]PETSC ERROR: Option left: name:-pc_hpddm_coarse_pc_type value: lu
> [1]PETSC ERROR: Option left: name:-i value: full_upwinding_2D.i source:
> command line
> [1]PETSC ERROR: Option left: name:-ksp_converged_reason value: ::failed
> source: code
> [0]PETSC ERROR: Option left: name:-snes_converged_reason value: ::failed
> source: code
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.17.4-3368-g5a48edb989d
> GIT Date: 2023-04-16 17:35:24 +0000
> [1]PETSC ERROR: Option left: name:-pc_hpddm_coarse_mat_type value: baij
> [1]PETSC ERROR: Option left: name:-pc_hpddm_coarse_pc_type value: lu
> [0]PETSC ERROR: ../../../moose_test-opt on a arch-moose named
> rod.hpc.inl.gov by lindad Mon Apr 17 16:11:09 2023
> [0]PETSC ERROR: Configure options --download-hypre=1
> --with-shared-libraries=1 --download-hdf5=1 --with-hdf5-fortran-bindings=0
> --with-debugging=no --download-fblaslapack=1 --download-metis=1
> --download-ptscotch=1 --download-parmetis=1 --download-superlu_dist=1
> --download-mumps=1 --download-strumpack=1 --download-scalapack=1
> --download-slepc=1 --with-mpi=1 --with-openmp=1 --with-cxx-dialect=C++11
> --with-fortran-bindings=0 --with-sowing=0 --with-64-bit-indices
> --with-make-np=256 --download-hpddm
> [1]PETSC ERROR: Option left: name:-snes_converged_reason value: ::failed
> source: code
> [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [1]PETSC ERROR: [0]PETSC ERROR: #1 buildTwo() at
> /raid/lindad/moose/petsc/arch-moose/include/HPDDM_schwarz.hpp:1012
> Petsc Development GIT revision: v3.17.4-3368-g5a48edb989d GIT Date:
> [1]PETSC ERROR: ../../../moose_test-opt on a arch-moose named
> [1]PETSC ERROR: Configure options --download-hypre=1
> [1]PETSC ERROR: #1 buildTwo() at
> On Mon, Apr 17, 2023 at 4:55 PM Matthew Knepley <knepley at gmail.com> wrote:
>> I don't think so. Can you show the whole stack?
>> THanks,
>> Matt
>> On Mon, Apr 17, 2023 at 6:24 PM Alexander Lindsay <
>> alexlindsay239 at gmail.com> wrote:
>>> If it helps: if I use those exact same options in serial, then no errors
>>> and the linear solve is beautiful :-)
>>> On Mon, Apr 17, 2023 at 4:22 PM Alexander Lindsay <
>>>> I'm likely revealing a lot of ignorance, but in order to use HPDDM as a
>>>> preconditioner does my system matrix (I am using the same matrix for A and
>>>> P) need to be block type, e.g. baij or sbaij ? In MOOSE our default is aij
>>>> and I am currently getting
>>>> with options:
>>>> -pc_type hpddm -pc_hpddm_block_splitting -pc_hpddm_coarse_mat_type baij
>>>> -pc_hpddm_coarse_pc_type lu -pc_hpddm_define_subdomains
>>>> -pc_hpddm_levels_1_eps_gen_non_hermitian -pc_hpddm_levels_1_eps_nev 50
>>>> -pc_hpddm_levels_1_eps_threshold 0.1 -pc_hpddm_levels_1_st_matstructure
>>>> SAME -pc_hpddm_levels_1_st_share_sub_ksp
>>>> -pc_hpddm_levels_1_sub_pc_factor_mat_solver_type mumps
>>>> -pc_hpddm_levels_1_sub_pc_type lu
>>>> Alex
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230417/7751faef/attachment.html>
