[petsc-users] PETSc usage issues
Matthew Knepley
knepley at gmail.com
Wed Sep 28 14:00:16 CDT 2022
On Wed, Sep 28, 2022 at 2:27 PM wangzj997 <wangzj997 at foxmail.com> wrote:
> Dear PETSc development team:
> Currently, I am learning and trying to use PETSc's KSP to solve
> large-scale sparse linear systems Ax= b, where A is symmetric positive
> definite
How do you know it is positive definite? This is unusual when you have 0 on
the diagonal.
Preconditioners depend sensitively on the matrix properties. Is this a
discretization of some operator?
Matt
> and nonsingular. However, the main diagonal of A contains many 0 items,
> which leads to the fact that many preconditioners cannot be used when using
> MPI for multi-process solution, and the number of iterations is large, and
> the convergence is slow. May I ask how to solve this problem? If it is
> necessary to make the main diagonal of A all non-zero items, is there any
> solution in PETSc?
> I would be grateful if you would reply and answer my question.
> Best Regards.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220928/d1ba506e/attachment.html>
