[petsc-users] Solve Linear System with Field Split Preconditioner
Mark Adams mfadams at lbl.gov
Tue Sep 27 04:48:51 CDT 2022
what equations and discetizations are in A00?
On Tue, Sep 27, 2022 at 1:45 AM 晓峰 何 <tlanyan at hotmail.com> wrote:
> Hi Barry,
> A00 is formed from elliptic operator.
> I tried GAMG with A00, but it was extremely slow to solve the system with
> field-split preconditioner(I’m not sure I did it with the right way).
> Thanks,
> Xiaofeng
> On Sep 26, 2022, at 23:11, Barry Smith <bsmith at petsc.dev> wrote:
>   What is your A00 operator? ILU is almost never a good choice for large
> scale problems. If it is an elliptic operator that using a PC of gamg may
> work well for the A00 preconditioner instead of ILU.
>   Barry
>   For moderate size problems you can use a PC type LU for AOO to help you
> understand the best preconditioner to use for the A11 (the Schur complement
> block), once you have a good preconditioner for the A11 block you would
> then go back and determine a good preconditioner for the A00 block.
> On Sep 26, 2022, at 10:08 AM, 晓峰 何 <tlanyan at hotmail.com> wrote:
> Hello Jed,
> The saddle point is due to Lagrange multipliers, thus the size of A11 is
> much smaller than A00.
> Best Regards,
> Xiaofeng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220927/36876795/attachment.html>
