[petsc-users] Solve Linear System with Field Split Preconditioner
晓峰 何
tlanyan at hotmail.com
Tue Sep 27 05:20:32 CDT 2022
Hello,
A00 comes from shell structures and discretized by FEM.
Xiaofeng
On Sep 27, 2022, at 17:48, Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
what equations and discetizations are in A00?
On Tue, Sep 27, 2022 at 1:45 AM 晓峰 何 <tlanyan at hotmail.com<mailto:tlanyan at hotmail.com>> wrote:
Hi Barry,
A00 is formed from elliptic operator.
I tried GAMG with A00, but it was extremely slow to solve the system with field-split preconditioner(I’m not sure I did it with the right way).
Xiaofeng
On Sep 26, 2022, at 23:11, Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
What is your A00 operator? ILU is almost never a good choice for large scale problems. If it is an elliptic operator that using a PC of gamg may work well for the A00 preconditioner instead of ILU.
Barry
For moderate size problems you can use a PC type LU for AOO to help you understand the best preconditioner to use for the A11 (the Schur complement block), once you have a good preconditioner for the A11 block you would then go back and determine a good preconditioner for the A00 block.
On Sep 26, 2022, at 10:08 AM, 晓峰 何 <tlanyan at hotmail.com<mailto:tlanyan at hotmail.com>> wrote:
Hello Jed,
The saddle point is due to Lagrange multipliers, thus the size of A11 is much smaller than A00.
Best Regards,
Xiaofeng
On Sep 26, 2022, at 21:03, Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>> wrote:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220927/3cdc0ced/attachment-0001.html>
