[petsc-users] VecScatter
Jorti, Zakariae zjorti at lanl.gov
Tue Oct 11 18:45:20 CDT 2022
Hello,
I have a code that handles a PETSc Vec on many procs and I would like to use VecScatterCreateToZero to have all elements of this vector on a single proc, call VecGetArrayRead on this proc to get the corresponding array to carry out some diagnostics.
Unfortunately, what I noticed is that the ordering of the initial Vec is not preserved after the VecScatterCreateToZero call. Is there a way to have the same ordering for both Vecs?
You will find below a minimal example that demonstrates the issue.
Many thanks,
Zakariae
static char help[] = "Demonstrates ordering change after VecScatterCreateToZero call.\n\n";
#include <petscpf.h>
#include <petscdm.h>
#include <petscdmda.h>
int main(int argc,char **argv)
  Vec            xy;
  DM             da;
  PetscErrorCode ierr;
  PetscInt       m = 11, n = 11, dof = 2;
  PetscMPIInt rank;
  DMDACoor2d **coors;
  ierr = PetscInitialize(&argc,&argv,(char*)0,help);if (ierr) return ierr;
  ierr = DMDACreate2d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, DM_BOUNDARY_NONE,DMDA_STENCIL_BOX,m,n,PETSC_DECIDE,PETSC_DECIDE,dof,1,0,0,&da);CHKERRQ(ierr);
  ierr = DMSetFromOptions(da);CHKERRQ(ierr);
  ierr = DMSetUp(da);CHKERRQ(ierr);
  ierr = DMDASetUniformCoordinates(da,0.0,1.0,0.0,1.0,0.0,1.0);CHKERRQ(ierr);
  ierr = DMGetCoordinates(da,&xy);CHKERRQ(ierr);
  PetscInt      i, j, ixs, ixm, iys, iym;
  MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
  DMDAGetCorners(da, &ixs, &iys, 0, &ixm, &iym, 0);
  DMDAVecGetArray(da, xy, &coors);
  for (j = iys; j < iys + iym; j++) {
    for (i = ixs; i < ixs + ixm; i++) {
        PetscPrintf(PETSC_COMM_SELF, "rank=%d, %d, %d, (%g, %g)\n",rank,
                    i, j,coors[j][i].x,coors[j][i].y);
  DMDAVecRestoreArray(da, xy, &coors);
  VecScatter  scat;
  Vec         Xseq;
  const PetscScalar *array;
  /* create scater to zero */
  VecScatterCreateToZero(xy, &scat, &Xseq);
  VecScatterBegin(scat, xy, Xseq, INSERT_VALUES, SCATTER_FORWARD);
  VecScatterEnd(scat, xy, Xseq, INSERT_VALUES, SCATTER_FORWARD);
  if (rank == 0) {
    PetscInt sizeX;
    VecGetSize(Xseq, &sizeX);
    PetscPrintf(PETSC_COMM_SELF,"The size of Xseq is %d, and the grid size is %d\n",sizeX,11*11);
    VecGetArrayRead(Xseq, &array);
    for (j = 0; j < 11; j++) {
      for (i = 0; i < 11; i++) {
        PetscPrintf(PETSC_COMM_SELF, "%d,%d, (%g,%g)\n", i, j, (double)array[2*(j*11+i)], (double)array[1+2*(j*11+i)]);
    VecRestoreArrayRead(Xseq, &array);
     Free work space.  All PETSc objects should be destroyed when they
     are no longer needed.
  ierr = DMDestroy(&da);CHKERRQ(ierr);
  ierr = PetscFinalize();
  return ierr;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221011/96458d51/attachment-0001.html>
