[petsc-users] VecScatter
Barry Smith
bsmith at petsc.dev
Tue Oct 11 19:05:55 CDT 2022
You need to first convert the Vec to the "natural" ordering and then bring that vector down to one rank. Something like
DMDACreateNaturalVector(dm,&n);
DMDAGlobalToNaturalBegin/End(dm, n);
> VecScatterCreateToZero(n, &scat, &Xseq);
> VecScatterBegin(scat, n Xseq, INSERT_VALUES, SCATTER_FORWARD);
> VecScatterEnd(scat, n, Xseq, INSERT_VALUES, SCATTER_FORWARD);
> On Oct 11, 2022, at 7:45 PM, Jorti, Zakariae via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I have a code that handles a PETSc Vec on many procs and I would like to use VecScatterCreateToZero to have all elements of this vector on a single proc, call VecGetArrayRead on this proc to get the corresponding array to carry out some diagnostics.
> Unfortunately, what I noticed is that the ordering of the initial Vec is not preserved after the VecScatterCreateToZero call. Is there a way to have the same ordering for both Vecs?
> You will find below a minimal example that demonstrates the issue.
> Many thanks,
> Zakariae
> static char help[] = "Demonstrates ordering change after VecScatterCreateToZero call.\n\n";
> #include <petscpf.h>
> #include <petscdm.h>
> #include <petscdmda.h>
> int main(int argc,char **argv)
> Vec xy;
> DM da;
> PetscErrorCode ierr;
> PetscInt m = 11, n = 11, dof = 2;
> PetscMPIInt rank;
> DMDACoor2d **coors;
> ierr = PetscInitialize(&argc,&argv,(char*)0,help);if (ierr) return ierr;
> ierr = DMDACreate2d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, DM_BOUNDARY_NONE,DMDA_STENCIL_BOX,m,n,PETSC_DECIDE,PETSC_DECIDE,dof,1,0,0,&da);CHKERRQ(ierr);
> ierr = DMSetFromOptions(da);CHKERRQ(ierr);
> ierr = DMSetUp(da);CHKERRQ(ierr);
> ierr = DMDASetUniformCoordinates(da,0.0,1.0,0.0,1.0,0.0,1.0);CHKERRQ(ierr);
> ierr = DMGetCoordinates(da,&xy);CHKERRQ(ierr);
> PetscInt i, j, ixs, ixm, iys, iym;
> MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
> DMDAGetCorners(da, &ixs, &iys, 0, &ixm, &iym, 0);
> DMDAVecGetArray(da, xy, &coors);
> for (j = iys; j < iys + iym; j++) {
> for (i = ixs; i < ixs + ixm; i++) {
> PetscPrintf(PETSC_COMM_SELF, "rank=%d, %d, %d, (%g, %g)\n",rank,
> i, j,coors[j][i].x,coors[j][i].y);
> DMDAVecRestoreArray(da, xy, &coors);
> VecScatter scat;
> Vec Xseq;
> const PetscScalar *array;
> /* create scater to zero */
> VecScatterCreateToZero(xy, &scat, &Xseq);
> VecScatterBegin(scat, xy, Xseq, INSERT_VALUES, SCATTER_FORWARD);
> VecScatterEnd(scat, xy, Xseq, INSERT_VALUES, SCATTER_FORWARD);
> if (rank == 0) {
> PetscInt sizeX;
> VecGetSize(Xseq, &sizeX);
> PetscPrintf(PETSC_COMM_SELF,"The size of Xseq is %d, and the grid size is %d\n",sizeX,11*11);
> VecGetArrayRead(Xseq, &array);
> for (j = 0; j < 11; j++) {
> for (i = 0; i < 11; i++) {
> PetscPrintf(PETSC_COMM_SELF, "%d,%d, (%g,%g)\n", i, j, (double)array[2*(j*11+i)], (double)array[1+2*(j*11+i)]);
> VecRestoreArrayRead(Xseq, &array);
> Free work space. All PETSc objects should be destroyed when they
> are no longer needed.
> ierr = DMDestroy(&da);CHKERRQ(ierr);
> ierr = PetscFinalize();
> return ierr;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221011/d1be13d5/attachment.html>
