[petsc-users] make all check error
Sijie Zhang zhan2355 at purdue.edu
Mon Oct 10 22:54:28 CDT 2022
When I try to install petsc on my PC and run the make all check commend it has the following error. Can you help me to troubleshoot that?
Thanks.
Sijie
Running check examples to verify correct installation
Using PETSC_DIR=/home/zhangsijie1995/Documents/Packages/petsc-3.18.0 and PETSC_ARCH=arch-linux-c-debug
Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
See https://petsc.org/release/faq/
hwloc/linux: Ignoring PCI device with non-16bit domain.
Pass --enable-32bits-pci-domain to configure to support such devices
(warning: it would break the library ABI, don't enable unless really needed).
lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
Number of SNES iterations = 2
Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process
Number of SNES iterations =     3
Completed test examples
Error while running make check
gmake[1]: *** [makefile:149: check] Error 1
make: *** [GNUmakefile:17: check] Error 2
Type: text/x-log
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221011/2e3185a6/attachment-0002.bin>
Type: text/x-log
Desc: make.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221011/2e3185a6/attachment-0003.bin>
