[petsc-users] make all check error
Tue Oct 11 04:10:50 CDT 2022
hwloc is giving this warning on your machine:
hwloc/linux: Ignoring PCI device with non-16bit domain.
Pass --enable-32bits-pci-domain to configure to support such devices
(warning: it would break the library ABI, don't enable unless really
needed).
The PETSc results are fine, so you can use your installation. I have not
seen the warning
before.
     Matt
On Tue, Oct 11, 2022 at 12:32 AM Sijie Zhang <zhan2355 at purdue.edu> wrote:
> Hi,
> When I try to install petsc on my PC and run the make all check commend it
> has the following error. Can you help me to troubleshoot that?
> Thanks.
> Sijie
> Running check examples to verify correct installation
> Using PETSC_DIR=/home/zhangsijie1995/Documents/Packages/petsc-3.18.0 and
> PETSC_ARCH=arch-linux-c-debug
> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> See https://petsc.org/release/faq/
> needed).
> lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
> Number of SNES iterations = 2
> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> needed).
> needed).
> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI
> process
> needed).
> Number of SNES iterations =     3
> Completed test examples
> Error while running make check
> gmake[1]: *** [makefile:149: check] Error 1
> make: *** [GNUmakefile:17: check] Error 2
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221011/a644e1a0/attachment.html>
