[petsc-users] About MatMumpsSetIcntl function
김성익
ksi2443 at gmail.com
Wed Nov 30 08:31:25 CST 2022
After folloing the comment, ./app -pc_type lu -ksp_type preonly
-ksp_monitor_true_residual -ksp_converged_reason -ksp_view
-mat_mumps_icntl_7 5
The outputs are as below.
0 KSP none resid norm 2.000000000000e+00 true resid norm
4.241815708566e-16 ||r(i)||/||b|| 2.120907854283e-16
1 KSP none resid norm 4.241815708566e-16 true resid norm
Linear solve converged due to CONVERGED_ITS iterations 1
KSP Object: 1 MPI process
type: preonly
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using NONE norm type for convergence test
PC Object: 1 MPI process
type: lu
out-of-place factorization
tolerance for zero pivot 2.22045e-14
matrix ordering: external
factor fill ratio given 0., needed 0.
Factored matrix follows:
Mat Object: 1 MPI process
type: mumps
rows=24, cols=24
package used to perform factorization: mumps
total: nonzeros=576, allocated nonzeros=576
MUMPS run parameters:
Use -ksp_view ::ascii_info_detail to display information for
all processes
RINFOG(1) (global estimated flops for the elimination after
analysis): 8924.
RINFOG(2) (global estimated flops for the assembly after
factorization): 0.
RINFOG(3) (global estimated flops for the elimination after
factorization): 8924.
(RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
(0.,0.)*(2^0)
INFOG(3) (estimated real workspace for factors on all
processors after analysis): 576
INFOG(4) (estimated integer workspace for factors on all
processors after analysis): 68
INFOG(5) (estimated maximum front size in the complete tree):
24
INFOG(6) (number of nodes in the complete tree): 1
INFOG(7) (ordering option effectively used after analysis): 5
INFOG(8) (structural symmetry in percent of the permuted
matrix after analysis): 100
INFOG(9) (total real/complex workspace to store the matrix
factors after factorization): 576
INFOG(10) (total integer space store the matrix factors after
factorization): 68
INFOG(11) (order of largest frontal matrix after
factorization): 24
INFOG(12) (number of off-diagonal pivots): 0
INFOG(13) (number of delayed pivots after factorization): 0
INFOG(14) (number of memory compress after factorization): 0
INFOG(15) (number of steps of iterative refinement after
solution): 0
INFOG(16) (estimated size (in MB) of all MUMPS internal data
for factorization after analysis: value on the most memory consuming
processor): 0
INFOG(17) (estimated size of all MUMPS internal data for
factorization after analysis: sum over all processors): 0
INFOG(18) (size of all MUMPS internal data allocated during
factorization: value on the most memory consuming processor): 0
INFOG(19) (size of all MUMPS internal data allocated during
factorization: sum over all processors): 0
INFOG(20) (estimated number of entries in the factors): 576
INFOG(21) (size in MB of memory effectively used during
factorization - value on the most memory consuming processor): 0
INFOG(22) (size in MB of memory effectively used during
factorization - sum over all processors): 0
INFOG(23) (after analysis: value of ICNTL(6) effectively
used): 0
INFOG(24) (after analysis: value of ICNTL(12) effectively
used): 1
INFOG(25) (after factorization: number of pivots modified by
static pivoting): 0
INFOG(28) (after factorization: number of null pivots
encountered): 0
INFOG(29) (after factorization: effective number of entries
in the factors (sum over all processors)): 576
INFOG(30, 31) (after solution: size in Mbytes of memory used
during solution phase): 0, 0
INFOG(32) (after analysis: type of analysis done): 1
INFOG(33) (value used for ICNTL(8)): 7
INFOG(34) (exponent of the determinant if determinant is
requested): 0
INFOG(35) (after factorization: number of entries taking into
account BLR factor compression - sum over all processors): 576
INFOG(36) (after analysis: estimated size of all MUMPS
internal data for running BLR in-core - value on the most memory consuming
processor): 0
INFOG(37) (after analysis: estimated size of all MUMPS
internal data for running BLR in-core - sum over all processors): 0
INFOG(38) (after analysis: estimated size of all MUMPS
internal data for running BLR out-of-core - value on the most memory
INFOG(39) (after analysis: estimated size of all MUMPS
internal data for running BLR out-of-core - sum over all processors): 0
linear system matrix = precond matrix:
type: seqaij
rows=24, cols=24
total: nonzeros=576, allocated nonzeros=840
total number of mallocs used during MatSetValues calls=48
using I-node routines: found 5 nodes, limit used is 5
2022년 11월 30일 (수) 오후 11:26, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Wed, Nov 30, 2022 at 9:20 AM 김성익 <ksi2443 at gmail.com> wrote:
>> In my code there are below.
>> PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp));
>> PetscCall(KSPSetOperators(ksp, xGK, xGK));
>> PetscCall(KSPGetPC(ksp, &pc));
>> PetscCall(PCSetType(pc, PCLU));
>> PetscCall(PCFactorSetMatSolverType(pc, MATSOLVERMUMPS));
>> PetscCall(KSPSetFromOptions(ksp));
>> and my runtime options are as below.
>> mpirun -np 3 ./app -mpi_linear_solver_server
>> -mpi_linear_solver_server_view -pc_type mpi -ksp_type preonly
>> -mpi_ksp_monitor -mpi_ksp_converged_reason -mpi_pc_type lu
>> -pc_mpi_always_use_server -mat_mumps_icntl_7 5
> 1) Get rid of the all server stuff until we see what is wrong with your
> code
> 2) Always run in serial until it works
> ./app -pc_type lu -ksp_type preonly -ksp_monitor_true_residual
> -ksp_converged_reason -ksp_view -mat_mumps_icntl_7 5
> Send the output so we can see what the solver is.
> Thanks,
> Matt
> 2022년 11월 30일 (수) 오후 11:16, Matthew Knepley <knepley at gmail.com>님이 작성:
>>> On Wed, Nov 30, 2022 at 9:10 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>> When I adopt icntl by using option, the outputs are as below.
>>>> WARNING! There are options you set that were not used!
>>>> WARNING! could be spelling mistake, etc!
>>>> There is one unused database option. It is:
>>>> Option left: name:-mat_mumps_icntl_7 value: 5
>>>> Is it work??
>>> Are you calling KSPSetFromOptions() after the PC is created?
>>> -pc_type lu -pc_factor_mat_solver_type mumps -mat_mumps_icntl_7 3
>>> Thanks,
>>> Matt
>>>> Thanks,
>>>> Hyung Kim
>>>> 2022년 11월 30일 (수) 오후 11:04, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>> On Wed, Nov 30, 2022 at 8:58 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>> I'm working on FEM.
>>>>>> When I used mumps alone, I fount it efficient to use mumps with
>>>>>> metis.
>>>>>> So my purpose is using MUMPSsolver with METIS.
>>>>>> I tried to set metis (by icntl_7 : 5) after global matrix assembly
>>>>>> and just before kspsolve.
>>>>>> However there is error because of 'pcfactorgetmatrix' and
>>>>>> 'matmumpsseticntl'.
>>>>>> How can I fix this?
>>>>> Give the Icntrl as an option.
>>>>> Thanks,
>>>>> Matt
>>>>>> Thanks,
>>>>>> Hyung Kim
>>>>>> 2022년 11월 30일 (수) 오후 10:44, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>>>> On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>>>> Following your comments,
>>>>>>>> After matrix assembly end,
>>>>>>>> PetscCall(KSPGetPC(ksp,&pc));
>>>>>>>> PetscCall(KSPSetUp(ksp));
>>>>>>>> PetscCall(PCFactorGetMatrix(pc,&xGK));
>>>>>>>> However there is another error as below.
>>>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>>>> [0]PETSC ERROR: Not for factored matrix
>>>>>>> The error message is telling you that you cannot alter values in the
>>>>>>> factored matrix. This is because
>>>>>>> the direct solvers use their own internal storage formats which we
>>>>>>> cannot alter, and you should probably
>>>>>>> not alter either.
>>>>>>> What are you trying to do?
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>>>> shooting.
>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>>>>>>>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by
>>>>>>>> ksi2443 Wed Nov 30 05:37:52 2022
>>>>>>>> [0]PETSC ERROR: Configure options -download-mumps
>>>>>>>> -download-scalapack -download-parmetis -download-metis
>>>>>>>> [0]PETSC ERROR: #1 MatZeroEntries() at
>>>>>>>> /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
>>>>>>>> [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:339
>>>>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>>>>> How can I fix this?
>>>>>>>> Thanks,
>>>>>>>> Hyung Kim
>>>>>>>> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es>님이 작성:
>>>>>>>>> You have to call PCFactorGetMatrix() first. See any of the
>>>>>>>>> examples that use MatMumpsSetIcntl(), for instance
>>>>>>>>> https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>>>>>>>>> Jose
>>>>>>>>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com> escribió:
>>>>>>>>> > Hello,
>>>>>>>>> > I tried to adopt METIS option in MUMPS by using
>>>>>>>>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>>>>>>>>> > However, there is an error as follows
>>>>>>>>> > [0]PETSC ERROR: Only for factored matrix
>>>>>>>>> shooting.
>>>>>>>>> ksi2443 Tue Nov 29 21:12:41 2022
>>>>>>>>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at
>>>>>>>>> /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>>>>>>>>> /home/ksi2443/Downloads/coding/a1.c:149
>>>>>>>>> > How can I fix this error?
>>>>>>>>> > Thank you for your help.
>>>>>>>>> > Hyung Kim
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221130/613f4169/attachment-0001.html>
