[petsc-users] About MatMumpsSetIcntl function
Matthew Knepley
knepley at gmail.com
Wed Nov 30 08:54:00 CST 2022
On Wed, Nov 30, 2022 at 9:31 AM 김성익 <ksi2443 at gmail.com> wrote:
> After folloing the comment, ./app -pc_type lu -ksp_type preonly
> -ksp_monitor_true_residual -ksp_converged_reason -ksp_view
> -mat_mumps_icntl_7 5
Okay, you can see that it is using METIS:
INFOG(7) (ordering option effectively used after analysis): 5
It looks like the server stuff was not seeing the option. Put it back in
and send the output.
Matt
The outputs are as below.
> 0 KSP none resid norm 2.000000000000e+00 true resid norm
> 4.241815708566e-16 ||r(i)||/||b|| 2.120907854283e-16
> 1 KSP none resid norm 4.241815708566e-16 true resid norm
> Linear solve converged due to CONVERGED_ITS iterations 1
> KSP Object: 1 MPI process
> type: preonly
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> left preconditioning
> using NONE norm type for convergence test
> PC Object: 1 MPI process
> type: lu
> out-of-place factorization
> tolerance for zero pivot 2.22045e-14
> matrix ordering: external
> factor fill ratio given 0., needed 0.
> Factored matrix follows:
> Mat Object: 1 MPI process
> type: mumps
> rows=24, cols=24
> package used to perform factorization: mumps
> total: nonzeros=576, allocated nonzeros=576
> MUMPS run parameters:
> Use -ksp_view ::ascii_info_detail to display information for
> all processes
> RINFOG(1) (global estimated flops for the elimination after
> analysis): 8924.
> RINFOG(2) (global estimated flops for the assembly after
> factorization): 0.
> RINFOG(3) (global estimated flops for the elimination after
> factorization): 8924.
> (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
> (0.,0.)*(2^0)
> INFOG(3) (estimated real workspace for factors on all
> processors after analysis): 576
> INFOG(4) (estimated integer workspace for factors on all
> processors after analysis): 68
> INFOG(5) (estimated maximum front size in the complete
> tree): 24
> INFOG(6) (number of nodes in the complete tree): 1
> INFOG(8) (structural symmetry in percent of the permuted
> matrix after analysis): 100
> INFOG(9) (total real/complex workspace to store the matrix
> factors after factorization): 576
> INFOG(10) (total integer space store the matrix factors
> after factorization): 68
> INFOG(11) (order of largest frontal matrix after
> factorization): 24
> INFOG(12) (number of off-diagonal pivots): 0
> INFOG(13) (number of delayed pivots after factorization): 0
> INFOG(14) (number of memory compress after factorization): 0
> INFOG(15) (number of steps of iterative refinement after
> solution): 0
> INFOG(16) (estimated size (in MB) of all MUMPS internal data
> for factorization after analysis: value on the most memory consuming
> processor): 0
> INFOG(17) (estimated size of all MUMPS internal data for
> factorization after analysis: sum over all processors): 0
> INFOG(18) (size of all MUMPS internal data allocated during
> factorization: value on the most memory consuming processor): 0
> INFOG(19) (size of all MUMPS internal data allocated during
> factorization: sum over all processors): 0
> INFOG(20) (estimated number of entries in the factors): 576
> INFOG(21) (size in MB of memory effectively used during
> factorization - value on the most memory consuming processor): 0
> INFOG(22) (size in MB of memory effectively used during
> factorization - sum over all processors): 0
> INFOG(23) (after analysis: value of ICNTL(6) effectively
> used): 0
> INFOG(24) (after analysis: value of ICNTL(12) effectively
> used): 1
> INFOG(25) (after factorization: number of pivots modified by
> static pivoting): 0
> INFOG(28) (after factorization: number of null pivots
> encountered): 0
> INFOG(29) (after factorization: effective number of entries
> in the factors (sum over all processors)): 576
> INFOG(30, 31) (after solution: size in Mbytes of memory used
> during solution phase): 0, 0
> INFOG(32) (after analysis: type of analysis done): 1
> INFOG(33) (value used for ICNTL(8)): 7
> INFOG(34) (exponent of the determinant if determinant is
> requested): 0
> INFOG(35) (after factorization: number of entries taking
> into account BLR factor compression - sum over all processors): 576
> INFOG(36) (after analysis: estimated size of all MUMPS
> internal data for running BLR in-core - value on the most memory consuming
> processor): 0
> INFOG(37) (after analysis: estimated size of all MUMPS
> internal data for running BLR in-core - sum over all processors): 0
> INFOG(38) (after analysis: estimated size of all MUMPS
> internal data for running BLR out-of-core - value on the most memory
> INFOG(39) (after analysis: estimated size of all MUMPS
> internal data for running BLR out-of-core - sum over all processors): 0
> linear system matrix = precond matrix:
> type: seqaij
> rows=24, cols=24
> total: nonzeros=576, allocated nonzeros=840
> total number of mallocs used during MatSetValues calls=48
> using I-node routines: found 5 nodes, limit used is 5
> 2022년 11월 30일 (수) 오후 11:26, Matthew Knepley <knepley at gmail.com>님이 작성:
>> On Wed, Nov 30, 2022 at 9:20 AM 김성익 <ksi2443 at gmail.com> wrote:
>>> In my code there are below.
>>> PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp));
>>> PetscCall(KSPSetOperators(ksp, xGK, xGK));
>>> PetscCall(KSPGetPC(ksp, &pc));
>>> PetscCall(PCSetType(pc, PCLU));
>>> PetscCall(PCFactorSetMatSolverType(pc, MATSOLVERMUMPS));
>>> PetscCall(KSPSetFromOptions(ksp));
>>> and my runtime options are as below.
>>> mpirun -np 3 ./app -mpi_linear_solver_server
>>> -mpi_linear_solver_server_view -pc_type mpi -ksp_type preonly
>>> -mpi_ksp_monitor -mpi_ksp_converged_reason -mpi_pc_type lu
>>> -pc_mpi_always_use_server -mat_mumps_icntl_7 5
>> 1) Get rid of the all server stuff until we see what is wrong with your
>> code
>> 2) Always run in serial until it works
>> ./app -pc_type lu -ksp_type preonly -ksp_monitor_true_residual
>> -ksp_converged_reason -ksp_view -mat_mumps_icntl_7 5
>> Send the output so we can see what the solver is.
>> Thanks,
>> Matt
>> 2022년 11월 30일 (수) 오후 11:16, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>> On Wed, Nov 30, 2022 at 9:10 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>> When I adopt icntl by using option, the outputs are as below.
>>>>> WARNING! There are options you set that were not used!
>>>>> WARNING! could be spelling mistake, etc!
>>>>> There is one unused database option. It is:
>>>>> Option left: name:-mat_mumps_icntl_7 value: 5
>>>>> Is it work??
>>>> Are you calling KSPSetFromOptions() after the PC is created?
>>>> -pc_type lu -pc_factor_mat_solver_type mumps -mat_mumps_icntl_7 3
>>>> Thanks,
>>>> Matt
>>>>> Thanks,
>>>>> Hyung Kim
>>>>> 2022년 11월 30일 (수) 오후 11:04, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>>> On Wed, Nov 30, 2022 at 8:58 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>>> I'm working on FEM.
>>>>>>> When I used mumps alone, I fount it efficient to use mumps with
>>>>>>> metis.
>>>>>>> So my purpose is using MUMPSsolver with METIS.
>>>>>>> I tried to set metis (by icntl_7 : 5) after global matrix assembly
>>>>>>> and just before kspsolve.
>>>>>>> However there is error because of 'pcfactorgetmatrix' and
>>>>>>> 'matmumpsseticntl'.
>>>>>>> How can I fix this?
>>>>>> Give the Icntrl as an option.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Thanks,
>>>>>>> Hyung Kim
>>>>>>> 2022년 11월 30일 (수) 오후 10:44, Matthew Knepley <knepley at gmail.com>님이
>>>>>>> 작성:
>>>>>>>> On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>>>>> Following your comments,
>>>>>>>>> After matrix assembly end,
>>>>>>>>> PetscCall(KSPGetPC(ksp,&pc));
>>>>>>>>> PetscCall(KSPSetUp(ksp));
>>>>>>>>> PetscCall(PCFactorGetMatrix(pc,&xGK));
>>>>>>>>> However there is another error as below.
>>>>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>>>>> [0]PETSC ERROR: Not for factored matrix
>>>>>>>> The error message is telling you that you cannot alter values in
>>>>>>>> the factored matrix. This is because
>>>>>>>> the direct solvers use their own internal storage formats which we
>>>>>>>> cannot alter, and you should probably
>>>>>>>> not alter either.
>>>>>>>> What are you trying to do?
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>>>>> shooting.
>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>>>>>>>>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by
>>>>>>>>> ksi2443 Wed Nov 30 05:37:52 2022
>>>>>>>>> [0]PETSC ERROR: Configure options -download-mumps
>>>>>>>>> -download-scalapack -download-parmetis -download-metis
>>>>>>>>> [0]PETSC ERROR: #1 MatZeroEntries() at
>>>>>>>>> /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
>>>>>>>>> [0]PETSC ERROR: #2 main() at
>>>>>>>>> /home/ksi2443/Downloads/coding/a1.c:339
>>>>>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>>>>>> How can I fix this?
>>>>>>>>> Thanks,
>>>>>>>>> Hyung Kim
>>>>>>>>> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es>님이
>>>>>>>>> 작성:
>>>>>>>>>> You have to call PCFactorGetMatrix() first. See any of the
>>>>>>>>>> examples that use MatMumpsSetIcntl(), for instance
>>>>>>>>>> https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>>>>>>>>>> Jose
>>>>>>>>>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com> escribió:
>>>>>>>>>> > Hello,
>>>>>>>>>> > I tried to adopt METIS option in MUMPS by using
>>>>>>>>>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>>>>>>>>>> > However, there is an error as follows
>>>>>>>>>> > [0]PETSC ERROR: Only for factored matrix
>>>>>>>>>> shooting.
>>>>>>>>>> ksi2443 Tue Nov 29 21:12:41 2022
>>>>>>>>>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at
>>>>>>>>>> /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>>>>>>>>>> /home/ksi2443/Downloads/coding/a1.c:149
>>>>>>>>>> > How can I fix this error?
>>>>>>>>>> > Thank you for your help.
>>>>>>>>>> > Hyung Kim
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221130/3605cfa1/attachment-0001.html>
