[petsc-users] About MatMumpsSetIcntl function
Matthew Knepley
knepley at gmail.com
Wed Nov 30 08:26:23 CST 2022
On Wed, Nov 30, 2022 at 9:20 AM 김성익 <ksi2443 at gmail.com> wrote:
> In my code there are below.
> PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp));
> PetscCall(KSPSetOperators(ksp, xGK, xGK));
> PetscCall(KSPGetPC(ksp, &pc));
> PetscCall(PCSetType(pc, PCLU));
> PetscCall(PCFactorSetMatSolverType(pc, MATSOLVERMUMPS));
> PetscCall(KSPSetFromOptions(ksp));
> and my runtime options are as below.
> mpirun -np 3 ./app -mpi_linear_solver_server
> -mpi_linear_solver_server_view -pc_type mpi -ksp_type preonly
> -mpi_ksp_monitor -mpi_ksp_converged_reason -mpi_pc_type lu
> -pc_mpi_always_use_server -mat_mumps_icntl_7 5
1) Get rid of the all server stuff until we see what is wrong with your code
2) Always run in serial until it works
./app -pc_type lu -ksp_type preonly -ksp_monitor_true_residual
-ksp_converged_reason -ksp_view -mat_mumps_icntl_7 5
Send the output so we can see what the solver is.
Matt
2022년 11월 30일 (수) 오후 11:16, Matthew Knepley <knepley at gmail.com>님이 작성:
>> On Wed, Nov 30, 2022 at 9:10 AM 김성익 <ksi2443 at gmail.com> wrote:
>>> When I adopt icntl by using option, the outputs are as below.
>>> WARNING! There are options you set that were not used!
>>> WARNING! could be spelling mistake, etc!
>>> There is one unused database option. It is:
>>> Option left: name:-mat_mumps_icntl_7 value: 5
>>> Is it work??
>> Are you calling KSPSetFromOptions() after the PC is created?
>> -pc_type lu -pc_factor_mat_solver_type mumps -mat_mumps_icntl_7 3
>> Thanks,
>> Matt
>>> Thanks,
>>> Hyung Kim
>>> 2022년 11월 30일 (수) 오후 11:04, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>> On Wed, Nov 30, 2022 at 8:58 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>> I'm working on FEM.
>>>>> When I used mumps alone, I fount it efficient to use mumps with
>>>>> metis.
>>>>> So my purpose is using MUMPSsolver with METIS.
>>>>> I tried to set metis (by icntl_7 : 5) after global matrix assembly and
>>>>> just before kspsolve.
>>>>> However there is error because of 'pcfactorgetmatrix' and
>>>>> 'matmumpsseticntl'.
>>>>> How can I fix this?
>>>> Give the Icntrl as an option.
>>>> Thanks,
>>>> Matt
>>>>> Thanks,
>>>>> Hyung Kim
>>>>> 2022년 11월 30일 (수) 오후 10:44, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>>> On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>>> Following your comments,
>>>>>>> After matrix assembly end,
>>>>>>> PetscCall(KSPGetPC(ksp,&pc));
>>>>>>> PetscCall(KSPSetUp(ksp));
>>>>>>> PetscCall(PCFactorGetMatrix(pc,&xGK));
>>>>>>> However there is another error as below.
>>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>>> [0]PETSC ERROR: Not for factored matrix
>>>>>> The error message is telling you that you cannot alter values in the
>>>>>> factored matrix. This is because
>>>>>> the direct solvers use their own internal storage formats which we
>>>>>> cannot alter, and you should probably
>>>>>> not alter either.
>>>>>> What are you trying to do?
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>>> shooting.
>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>>>>>>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by
>>>>>>> ksi2443 Wed Nov 30 05:37:52 2022
>>>>>>> [0]PETSC ERROR: Configure options -download-mumps
>>>>>>> -download-scalapack -download-parmetis -download-metis
>>>>>>> [0]PETSC ERROR: #1 MatZeroEntries() at
>>>>>>> /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
>>>>>>> [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:339
>>>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>>>> How can I fix this?
>>>>>>> Thanks,
>>>>>>> Hyung Kim
>>>>>>> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es>님이 작성:
>>>>>>>> You have to call PCFactorGetMatrix() first. See any of the examples
>>>>>>>> that use MatMumpsSetIcntl(), for instance
>>>>>>>> https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>>>>>>>> Jose
>>>>>>>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com> escribió:
>>>>>>>> > Hello,
>>>>>>>> > I tried to adopt METIS option in MUMPS by using
>>>>>>>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>>>>>>>> > However, there is an error as follows
>>>>>>>> > [0]PETSC ERROR: Only for factored matrix
>>>>>>>> shooting.
>>>>>>>> ksi2443 Tue Nov 29 21:12:41 2022
>>>>>>>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at
>>>>>>>> /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>>>>>>>> /home/ksi2443/Downloads/coding/a1.c:149
>>>>>>>> > How can I fix this error?
>>>>>>>> > Thank you for your help.
>>>>>>>> > Hyung Kim
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221130/c182fc03/attachment-0001.html>
