[petsc-users] About MatMumpsSetIcntl function
김성익
ksi2443 at gmail.com
Wed Nov 30 08:20:13 CST 2022
In my code there are below.
PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp));
PetscCall(KSPSetOperators(ksp, xGK, xGK));
PetscCall(KSPGetPC(ksp, &pc));
PetscCall(PCSetType(pc, PCLU));
PetscCall(PCFactorSetMatSolverType(pc, MATSOLVERMUMPS));
PetscCall(KSPSetFromOptions(ksp));
and my runtime options are as below.
mpirun -np 3 ./app -mpi_linear_solver_server -mpi_linear_solver_server_view
-pc_type mpi -ksp_type preonly -mpi_ksp_monitor -mpi_ksp_converged_reason
-mpi_pc_type lu -pc_mpi_always_use_server -mat_mumps_icntl_7 5
2022년 11월 30일 (수) 오후 11:16, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Wed, Nov 30, 2022 at 9:10 AM 김성익 <ksi2443 at gmail.com> wrote:
>> When I adopt icntl by using option, the outputs are as below.
>> WARNING! There are options you set that were not used!
>> WARNING! could be spelling mistake, etc!
>> There is one unused database option. It is:
>> Option left: name:-mat_mumps_icntl_7 value: 5
>> Is it work??
> Are you calling KSPSetFromOptions() after the PC is created?
> -pc_type lu -pc_factor_mat_solver_type mumps -mat_mumps_icntl_7 3
> Thanks,
> Matt
>> Thanks,
>> Hyung Kim
>> 2022년 11월 30일 (수) 오후 11:04, Matthew Knepley <knepley at gmail.com>님이 작성:
>>> On Wed, Nov 30, 2022 at 8:58 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>> I'm working on FEM.
>>>> When I used mumps alone, I fount it efficient to use mumps with
>>>> metis.
>>>> So my purpose is using MUMPSsolver with METIS.
>>>> I tried to set metis (by icntl_7 : 5) after global matrix assembly and
>>>> just before kspsolve.
>>>> However there is error because of 'pcfactorgetmatrix' and
>>>> 'matmumpsseticntl'.
>>>> How can I fix this?
>>> Give the Icntrl as an option.
>>> Thanks,
>>> Matt
>>>> Thanks,
>>>> Hyung Kim
>>>> 2022년 11월 30일 (수) 오후 10:44, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>> On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>> Following your comments,
>>>>>> After matrix assembly end,
>>>>>> PetscCall(KSPGetPC(ksp,&pc));
>>>>>> PetscCall(KSPSetUp(ksp));
>>>>>> PetscCall(PCFactorGetMatrix(pc,&xGK));
>>>>>> However there is another error as below.
>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>> [0]PETSC ERROR: Not for factored matrix
>>>>> The error message is telling you that you cannot alter values in the
>>>>> factored matrix. This is because
>>>>> the direct solvers use their own internal storage formats which we
>>>>> cannot alter, and you should probably
>>>>> not alter either.
>>>>> What are you trying to do?
>>>>> Thanks,
>>>>> Matt
>>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>> shooting.
>>>>>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>>>>>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksi2443
>>>>>> Wed Nov 30 05:37:52 2022
>>>>>> [0]PETSC ERROR: Configure options -download-mumps -download-scalapack
>>>>>> -download-parmetis -download-metis
>>>>>> [0]PETSC ERROR: #1 MatZeroEntries() at
>>>>>> /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
>>>>>> [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:339
>>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>>> How can I fix this?
>>>>>> Thanks,
>>>>>> Hyung Kim
>>>>>> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es>님이 작성:
>>>>>>> You have to call PCFactorGetMatrix() first. See any of the examples
>>>>>>> that use MatMumpsSetIcntl(), for instance
>>>>>>> https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>>>>>>> Jose
>>>>>>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com> escribió:
>>>>>>> > Hello,
>>>>>>> > I tried to adopt METIS option in MUMPS by using
>>>>>>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>>>>>>> > However, there is an error as follows
>>>>>>> > [0]PETSC ERROR: Only for factored matrix
>>>>>>> shooting.
>>>>>>> ksi2443 Tue Nov 29 21:12:41 2022
>>>>>>> -download-scalapack -download-parmetis -download-metis
>>>>>>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at
>>>>>>> /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>>>>>>> /home/ksi2443/Downloads/coding/a1.c:149
>>>>>>> > How can I fix this error?
>>>>>>> > Thank you for your help.
>>>>>>> > Hyung Kim
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221130/3ede6c69/attachment.html>
