[petsc-users] About MatMumpsSetIcntl function
Matthew Knepley
knepley at gmail.com
Wed Nov 30 08:16:07 CST 2022
On Wed, Nov 30, 2022 at 9:10 AM 김성익 <ksi2443 at gmail.com> wrote:
> When I adopt icntl by using option, the outputs are as below.
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> There is one unused database option. It is:
> Option left: name:-mat_mumps_icntl_7 value: 5
> Is it work??
Are you calling KSPSetFromOptions() after the PC is created?
-pc_type lu -pc_factor_mat_solver_type mumps -mat_mumps_icntl_7 3
Matt
> Thanks,
> Hyung Kim
> 2022년 11월 30일 (수) 오후 11:04, Matthew Knepley <knepley at gmail.com>님이 작성:
>> On Wed, Nov 30, 2022 at 8:58 AM 김성익 <ksi2443 at gmail.com> wrote:
>>> I'm working on FEM.
>>> When I used mumps alone, I fount it efficient to use mumps with
>>> metis.
>>> So my purpose is using MUMPSsolver with METIS.
>>> I tried to set metis (by icntl_7 : 5) after global matrix assembly and
>>> just before kspsolve.
>>> However there is error because of 'pcfactorgetmatrix' and
>>> 'matmumpsseticntl'.
>>> How can I fix this?
>> Give the Icntrl as an option.
>> Thanks,
>> Matt
>>> Thanks,
>>> Hyung Kim
>>> 2022년 11월 30일 (수) 오후 10:44, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>> On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>> Following your comments,
>>>>> After matrix assembly end,
>>>>> PetscCall(KSPGetPC(ksp,&pc));
>>>>> PetscCall(KSPSetFromOptions(ksp));
>>>>> PetscCall(KSPSetUp(ksp));
>>>>> PetscCall(PCFactorGetMatrix(pc,&xGK));
>>>>> However there is another error as below.
>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>> [0]PETSC ERROR: Not for factored matrix
>>>> The error message is telling you that you cannot alter values in the
>>>> factored matrix. This is because
>>>> the direct solvers use their own internal storage formats which we
>>>> cannot alter, and you should probably
>>>> not alter either.
>>>> What are you trying to do?
>>>> Thanks,
>>>> Matt
>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>> shooting.
>>>>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>>>>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksi2443
>>>>> Wed Nov 30 05:37:52 2022
>>>>> [0]PETSC ERROR: Configure options -download-mumps -download-scalapack
>>>>> -download-parmetis -download-metis
>>>>> [0]PETSC ERROR: #1 MatZeroEntries() at
>>>>> /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
>>>>> [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:339
>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>> How can I fix this?
>>>>> Thanks,
>>>>> Hyung Kim
>>>>> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es>님이 작성:
>>>>>> You have to call PCFactorGetMatrix() first. See any of the examples
>>>>>> that use MatMumpsSetIcntl(), for instance
>>>>>> https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>>>>>> Jose
>>>>>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com> escribió:
>>>>>> > Hello,
>>>>>> > I tried to adopt METIS option in MUMPS by using
>>>>>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>>>>>> > However, there is an error as follows
>>>>>> > [0]PETSC ERROR: Only for factored matrix
>>>>>> shooting.
>>>>>> ksi2443 Tue Nov 29 21:12:41 2022
>>>>>> -download-scalapack -download-parmetis -download-metis
>>>>>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at
>>>>>> /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>>>>>> > [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:149
>>>>>> > How can I fix this error?
>>>>>> > Thank you for your help.
>>>>>> > Hyung Kim
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221130/3fb5eec9/attachment.html>
