[petsc-users] About MatMumpsSetIcntl function
김성익 ksi2443 at gmail.com
Wed Nov 30 08:10:36 CST 2022
When I adopt icntl by using option, the outputs are as below.
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There is one unused database option. It is:
Option left: name:-mat_mumps_icntl_7 value: 5
Is it work??
Hyung Kim
2022년 11월 30일 (수) 오후 11:04, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Wed, Nov 30, 2022 at 8:58 AM 김성익 <ksi2443 at gmail.com> wrote:
>> I'm working on FEM.
>>   When I used mumps alone, I fount it efficient to use mumps with metis.
>> So my purpose is using MUMPSsolver with METIS.
>> I tried to set metis (by icntl_7 : 5) after global matrix assembly and
>> just before kspsolve.
>> However there is error because of 'pcfactorgetmatrix' and
>> 'matmumpsseticntl'.
>> How can I fix this?
> Give the Icntrl as an option.
>   Thanks,
>      Matt
>> Thanks,
>> Hyung Kim
>> 2022년 11월 30일 (수) 오후 10:44, Matthew Knepley <knepley at gmail.com>님이 작성:
>>> On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>> Following your comments,
>>>> After matrix assembly end,
>>>> PetscCall(KSPGetPC(ksp,&pc));
>>>> PetscCall(KSPSetFromOptions(ksp));
>>>> PetscCall(KSPSetUp(ksp));
>>>> PetscCall(PCFactorGetMatrix(pc,&xGK));
>>>> However there is another error as below.
>>>> [0]PETSC ERROR: Object is in wrong state
>>>> [0]PETSC ERROR: Not for factored matrix
>>> The error message is telling you that you cannot alter values in the
>>> factored matrix. This is because
>>> the direct solvers use their own internal storage formats which we
>>> cannot alter, and you should probably
>>> not alter either.
>>> What are you trying to do?
>>>   Thanks,
>>>      Matt
>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>> shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>>>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksi2443
>>>> Wed Nov 30 05:37:52 2022
>>>> [0]PETSC ERROR: Configure options -download-mumps -download-scalapack
>>>> -download-parmetis -download-metis
>>>> [0]PETSC ERROR: #1 MatZeroEntries() at
>>>> /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
>>>> [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:339
>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>> How can I fix this?
>>>> Thanks,
>>>> Hyung Kim
>>>> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es>님이 작성:
>>>>> You have to call PCFactorGetMatrix() first. See any of the examples
>>>>> that use MatMumpsSetIcntl(), for instance
>>>>> https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>>>>> Jose
>>>>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com> escribió:
>>>>> > Hello,
>>>>> > I tried to adopt METIS option in MUMPS by using
>>>>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>>>>> > However, there is an error as follows
>>>>> > [0]PETSC ERROR: Only for factored matrix
>>>>> shooting.
>>>>> ksi2443 Tue Nov 29 21:12:41 2022
>>>>> -download-scalapack -download-parmetis -download-metis
>>>>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at
>>>>> /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>>>>> > [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:149
>>>>> > How can I fix this error?
>>>>> > Thank you for your help.
>>>>> > Hyung Kim
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221130/17343c0a/attachment-0001.html>
