[petsc-users] Petsc Fortran Memory stack trace
Sanjay Govindjee
s_g at berkeley.edu
Mon Nov 21 13:39:37 CST 2022
Other options I have found useful:
-v --leak-check=full --show-reachable=yes
On 11/21/22 11:27 AM, Satish Balay via petsc-users wrote:
> valgrind is a useful tool to learn to use..
> valgrind --tool=memcheck ./executable
> Satish
> On Mon, 21 Nov 2022, Nicholas Arnold-Medabalimi wrote:
>> Hi Petsc users
>> I'm working on an integration of Petsc into an existing fortran code. Most
>> of my memory debugging is very primitive and is usually accomplished using
>> the -check bounds option in the compiler. However with Petsc attached the
>> stack trace becomes much more opaque compared to the original code. At
>> least as far as I can tell the error becomes much harder to pin down (just
>> pointing to libpetsc.so). Any assistance in getting more informative error
>> messages or checks would be much appreciated.
>> Sincerely
>> Nicholas
