[petsc-users] Petsc Fortran Memory stack trace
    Nicholas Arnold-Medabalimi
    narnoldm at umich.edu
    Mon Nov 21 13:43:20 CST 2022
I have been using valgrind with the mem checker. I should have mentioned
that. My question was probably ill posed. I'm more asking about is how
linking petsc affects the stack trace provided by the compiler side checks.
Valgrind is great but sometimes is a little ambiguous whereas the compile
side check bounds will usually be more specific so I was curious if there
is a way to change the petsc stack trace effect.
Thanks
On Mon, Nov 21, 2022 at 2:39 PM Sanjay Govindjee <s_g at berkeley.edu> wrote:
> Other options I have found useful:
> -v --leak-check=full --show-reachable=yes
> On 11/21/22 11:27 AM, Satish Balay via petsc-users wrote:
> > valgrind is a useful tool to learn to use..
> > valgrind --tool=memcheck ./executable
> > Satish
> > On Mon, 21 Nov 2022, Nicholas Arnold-Medabalimi wrote:
> >> Hi Petsc users
> >> I'm working on an integration of Petsc into an existing fortran code.
> Most
> >> of my memory debugging is very primitive and is usually accomplished
> using
> >> the -check bounds option in the compiler. However with Petsc attached
> the
> >> stack trace becomes much more opaque compared to the original code. At
> >> least as far as I can tell the error becomes much harder to pin down
> (just
> >> pointing to libpetsc.so). Any assistance in getting more informative
> error
> >> messages or checks would be much appreciated.
> >> Sincerely
> >> Nicholas
Ph.D. Candidate
Computational Aeroscience Lab
University of Michigan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221121/83467c78/attachment-0001.html>
