[petsc-users] Petsc Fortran Memory stack trace
    Satish Balay
    balay at mcs.anl.gov
    Mon Nov 21 13:27:13 CST 2022
valgrind is a useful tool to learn to use..
valgrind --tool=memcheck ./executable
Satish
On Mon, 21 Nov 2022, Nicholas Arnold-Medabalimi wrote:
> Hi Petsc users
> I'm working on an integration of Petsc into an existing fortran code. Most
> of my memory debugging is very primitive and is usually accomplished using
> the -check bounds option in the compiler. However with Petsc attached the
> stack trace becomes much more opaque compared to the original code. At
> least as far as I can tell the error becomes much harder to pin down (just
> pointing to libpetsc.so). Any assistance in getting more informative error
> messages or checks would be much appreciated.
> Sincerely
> Nicholas
