[petsc-users] On PCFIELDSPLIT and its implementation
Matthew Knepley
knepley at gmail.com
Tue Nov 8 11:15:02 CST 2022
On Tue, Nov 8, 2022 at 12:05 PM Edoardo alinovi <edoardo.alinovi at gmail.com>
wrote:
> Hello Guys,
> Thanks to your suggestions on the block matrices, my fully coupled solver
> is proceeding very well!
> I am now about to take advantage of the block structure of the matrix
> using PCFIELDSPLIT. I have learned a bit from the user manual and followed
> with interest this discussion in the mailing list:
> https://lists.mcs.anl.gov/pipermail/petsc-users/2015-February/024154.html
> which is actually the exact same situation I am in, so I guess most of the
> command line options will be copy and paste.
> I would like however to code them in fortran, as I usually provide some
> default implementation alongside the command line options.
> While coding some of the options I got an error here
> in PCFieldSplitSetFields() which looks to be undefined. I am importing
> petscksp, do I need to import something else maybe?
Since it uses arrays, we will have to write the Fortran wrapper by hand. I
will see if I can do it soon.
Matt
> Thank you!
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221108/4338c51a/attachment.html>
