[petsc-users] Field Split PC for Fully-Coupled 3d stationary incompressible Navier-Stokes Solution Algorithm
    Fabian Gabel
    gabel.fabian at gmail.com
    Mon Feb  2 03:39:22 CST 2015
Dear PETSc Team,
I implemented a fully-coupled solution algorithm (finite volume method)
for the 3d stationary incompressible Navier-Stokes equations. Currently
I am solving the resulting linear systems using GMRES and ILU and I
wanted to ask, if solver convergence could be improved using a field
split preconditioner. The possibility to use PCFIELDSPLIT (Matrix is
stored as interlaced) has already been implemented in my solver program,
but I am not sure on how to choose the parameters.
Each field corresponds to one of the variables (u,v,w,p). Considering
the corresponding blocks A_.., the non-interlaced matrix would read as
[A_uu   0     0   A_up]
[0    A_vv    0   A_vp]
[0      0   A_ww  A_up]
[A_pu A_pv  A_pw  A_pp]
where furthermore A_uu = A_vv = A_ww. This might be considered to
further improve the efficiency of the solve.
You find attached the solver output for an analytical test case with 2e6
cells each having 4 degrees of freedom. I used the command-line options:
-log_summary
-coupledsolve_ksp_view
-coupledsolve_ksp_monitor
-coupledsolve_ksp_gmres_restart 100
-coupledsolve_pc_factor_levels 1
-coupledsolve_ksp_gmres_modifiedgramschmidt
Fabian Gabel
Sender: LSF System <lsfadmin at hpb0024>
Subject: Job 399530: <coupling_cpld> in cluster <lichtenberg> Done
Job <coupling_cpld> was submitted from host <hla0003> by user <gu08vomo> in cluster <lichtenberg>.
Job was executed on host(s) <hpb0024>, in queue <test_mpi2>, as user <gu08vomo> in cluster <lichtenberg>.
</home/gu08vomo> was used as the home directory.
</work/scratch/gu08vomo/thesis/singleblock/128_1_1> was used as the working directory.
Started at Mon Feb  2 00:05:57 2015
Results reported at Mon Feb  2 02:21:24 2015
Your job looked like:
# LSBATCH: User input
#! /bin/sh
#BSUB -J coupling_cpld
#BSUB -o /home/gu08vomo/thesis/singleblock/cpld_128.monitor.out.%J
#BSUB -n 1
#BSUB -W 24:00
#BSUB -x
#BSUB -q test_mpi2
#BSUB -a openmpi
module load openmpi/intel/1.8.2
export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr
export MYWORKDIR=/work/scratch/gu08vomo/thesis/singleblock/128_1_1/
export OUTPUTDIR=/home/gu08vomo/thesis/coupling
export PETSC_OPS="-coupledsolve_ksp_gmres_restart 100 -log_summary -coupledsolve_pc_factor_levels 1 -coupledsolve_ksp_monitor -coupledsolve_ksp_view -coupledsolve_ksp_gmres_modifiedgramschmidt -on_error_abort"
echo "PETSC_DIR="$PETSC_DIR
echo "MYWORKDIR="$MYWORKDIR
echo "PETSC_OPS="$PETSC_OPS
cd $MYWORKDIR
mpirun -n 1 ./caffa3d.cpld.lnx ${PETSC_OPS}
Successfully completed.
Resource usage summary:
    CPU time :               8129.75 sec.
    Max Memory :             15153 MB
    Average Memory :         14864.49 MB
    Total Requested Memory : -
    Delta Memory :           -
    (Delta: the difference between total requested memory and actual max usage.)
    Max Swap :               17294 MB
    Max Processes :          6
    Max Threads :            11
The output (if any) follows:
Modules: loading openmpi/intel/1.8.2
PETSC_OPS=-coupledsolve_ksp_gmres_restart 100 -log_summary -coupledsolve_pc_factor_levels 1 -coupledsolve_ksp_monitor -coupledsolve_ksp_view -coupledsolve_ksp_gmres_modifiedgramschmidt -on_error_abort
  ENTER PROBLEM NAME (SIX CHARACTERS):
 NAME OF PROBLEM SOLVED control
 CONTROL SETTINGS
 LREAD,LWRITE,LPOST,LTEST,LOUTS,LOUTE,LTIME,LGRAD
 F F T F F F F F
  IMON, JMON, KMON, MMON, RMON,  IPR,  JPR,  KPR,  MPR,NPCOR,NIGRAD
     8     9     8     1     0     2     2     3     1     1     1
  SORMAX,     SLARGE,     ALFA
  0.1000E-07  0.1000E+31  0.9200E+00
 (URF(I),I=1,6)
  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01
 (SOR(I),I=1,6)
  0.1000E-01  0.1000E-01  0.1000E-01  0.1000E-01  0.1000E-01  0.1000E-07
 (GDS(I),I=1,6) - BLENDING (CDS-UDS)
 LSG
 START COUPLED ALGORITHM
  Residual norms for coupledsolve_ solve.
  0 KSP Residual norm 4.264137584261e+04
  1 KSP Residual norm 3.126035512702e+04
  2 KSP Residual norm 2.204911630524e+04
  3 KSP Residual norm 1.737088109639e+04
  4 KSP Residual norm 1.281240604370e+04
  5 KSP Residual norm 9.496461339190e+03
  6 KSP Residual norm 6.497777189417e+03
  7 KSP Residual norm 4.039003984054e+03
  8 KSP Residual norm 2.316641365557e+03
  9 KSP Residual norm 1.320992942746e+03
 10 KSP Residual norm 1.041475739922e+03
 11 KSP Residual norm 8.440675791671e+02
 12 KSP Residual norm 7.359887768590e+02
 13 KSP Residual norm 6.609284670027e+02
 14 KSP Residual norm 6.053599102666e+02
 15 KSP Residual norm 5.527891080694e+02
 16 KSP Residual norm 5.126410860295e+02
 17 KSP Residual norm 4.849583569954e+02
 18 KSP Residual norm 4.523066587880e+02
 19 KSP Residual norm 4.297597276582e+02
 20 KSP Residual norm 3.892968353545e+02
KSP Object:(coupledsolve_) 1 MPI processes
  type: gmres
    GMRES: restart=100, using Modified Gram-Schmidt Orthogonalization
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=0.01, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object:(coupledsolve_) 1 MPI processes
  type: ilu
    ILU: out-of-place factorization
    1 level of fill
    tolerance for zero pivot 2.22045e-14
    using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
    matrix ordering: natural
    factor fill ratio given 1, needed 2.44153
      Factored matrix follows:
        Mat Object:         1 MPI processes
          type: seqaij
          rows=8788000, cols=8788000
          package used to perform factorization: petsc
          total: nonzeros=3.56993e+08, allocated nonzeros=3.56993e+08
          total number of mallocs used during MatSetValues calls =0
            not using I-node routines
  linear system matrix = precond matrix:
    type: seqaij
    total: nonzeros=1.46217e+08, allocated nonzeros=1.46217e+08
 0000001  0.1000E+01  0.0000E+00
  0 KSP Residual norm 4.663544661243e+04
  1 KSP Residual norm 3.168120179194e+04
  2 KSP Residual norm 2.273711424452e+04
  3 KSP Residual norm 1.764970028953e+04
  4 KSP Residual norm 1.304545968762e+04
  5 KSP Residual norm 9.662351773909e+03
  6 KSP Residual norm 6.567818161453e+03
  7 KSP Residual norm 4.121067803948e+03
  8 KSP Residual norm 2.294490858752e+03
  9 KSP Residual norm 1.331012433748e+03
 10 KSP Residual norm 9.957051616153e+02
 11 KSP Residual norm 8.199631050494e+02
 12 KSP Residual norm 6.814242501106e+02
 13 KSP Residual norm 6.154530370574e+02
 14 KSP Residual norm 5.466964730947e+02
 15 KSP Residual norm 4.965755937205e+02
 16 KSP Residual norm 4.545601147588e+02
 17 KSP Residual norm 4.277460084127e+02
 18 KSP Residual norm 4.010479793577e+02
 19 KSP Residual norm 3.778523411748e+02
 20 KSP Residual norm 3.469200526428e+02
 21 KSP Residual norm 3.219354709128e+02
 22 KSP Residual norm 3.004458639924e+02
 23 KSP Residual norm 2.868550411268e+02
 24 KSP Residual norm 2.722864715656e+02
 25 KSP Residual norm 2.585151498116e+02
 26 KSP Residual norm 2.445346268226e+02
 27 KSP Residual norm 2.322810669447e+02
 28 KSP Residual norm 2.233192387366e+02
 29 KSP Residual norm 2.160507303574e+02
 30 KSP Residual norm 2.083854420275e+02
 31 KSP Residual norm 1.998695144673e+02
 32 KSP Residual norm 1.900820384162e+02
 33 KSP Residual norm 1.804877977814e+02
 34 KSP Residual norm 1.721693524260e+02
 35 KSP Residual norm 1.632041190198e+02
 36 KSP Residual norm 1.511002918775e+02
 37 KSP Residual norm 1.360844140549e+02
 38 KSP Residual norm 1.238601707531e+02
 39 KSP Residual norm 1.118946435195e+02
 40 KSP Residual norm 9.893775824273e+01
 41 KSP Residual norm 8.618294929060e+01
 42 KSP Residual norm 7.181045223647e+01
  type: gmres
  tolerances:  relative=0.00178347, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000002  0.1783E+00  0.0000E+00
  0 KSP Residual norm 4.630065023664e+04
  1 KSP Residual norm 3.164394717005e+04
  2 KSP Residual norm 2.263973343941e+04
  3 KSP Residual norm 1.761218313885e+04
  4 KSP Residual norm 1.299713661834e+04
  5 KSP Residual norm 9.650210925382e+03
  6 KSP Residual norm 6.549685992897e+03
  7 KSP Residual norm 4.117365163497e+03
  8 KSP Residual norm 2.260658726683e+03
  9 KSP Residual norm 1.263210112244e+03
 10 KSP Residual norm 8.932637087965e+02
 11 KSP Residual norm 6.984538826190e+02
 12 KSP Residual norm 5.342589004903e+02
 13 KSP Residual norm 4.534825495870e+02
 14 KSP Residual norm 3.701491789034e+02
 15 KSP Residual norm 3.064850263835e+02
 16 KSP Residual norm 2.556718808864e+02
 17 KSP Residual norm 2.254706924793e+02
 18 KSP Residual norm 2.014038755502e+02
 19 KSP Residual norm 1.847341590994e+02
 20 KSP Residual norm 1.654911370535e+02
 21 KSP Residual norm 1.500670327830e+02
 22 KSP Residual norm 1.360918364067e+02
 23 KSP Residual norm 1.271248745404e+02
 24 KSP Residual norm 1.172161482285e+02
 25 KSP Residual norm 1.087109449318e+02
 26 KSP Residual norm 9.947107291853e+01
 27 KSP Residual norm 9.147688586265e+01
 28 KSP Residual norm 8.536147363800e+01
 29 KSP Residual norm 8.136484384206e+01
 30 KSP Residual norm 7.800503448915e+01
 31 KSP Residual norm 7.518867432949e+01
 32 KSP Residual norm 7.203123146794e+01
 33 KSP Residual norm 6.897490191157e+01
 34 KSP Residual norm 6.641928130540e+01
 35 KSP Residual norm 6.388068582300e+01
 36 KSP Residual norm 6.113690770584e+01
 37 KSP Residual norm 5.783606662707e+01
 38 KSP Residual norm 5.529793507697e+01
 39 KSP Residual norm 5.234092915273e+01
 40 KSP Residual norm 4.915758493970e+01
 41 KSP Residual norm 4.560281972280e+01
 42 KSP Residual norm 4.140181251677e+01
 43 KSP Residual norm 3.673637485107e+01
 44 KSP Residual norm 3.244550907907e+01
 45 KSP Residual norm 2.896610620119e+01
 46 KSP Residual norm 2.548070305247e+01
 47 KSP Residual norm 2.237319456220e+01
 48 KSP Residual norm 2.027302400792e+01
 49 KSP Residual norm 1.910022642661e+01
 50 KSP Residual norm 1.826930728962e+01
 51 KSP Residual norm 1.785655829800e+01
 52 KSP Residual norm 1.763224604356e+01
 53 KSP Residual norm 1.751078309016e+01
 54 KSP Residual norm 1.742263144575e+01
 55 KSP Residual norm 1.739598373764e+01
 56 KSP Residual norm 1.732267664368e+01
 57 KSP Residual norm 1.724504457412e+01
 58 KSP Residual norm 1.712291752753e+01
 59 KSP Residual norm 1.694892174032e+01
 60 KSP Residual norm 1.653834984518e+01
 61 KSP Residual norm 1.593887169818e+01
 62 KSP Residual norm 1.498021817678e+01
 63 KSP Residual norm 1.377339473662e+01
  type: gmres
  tolerances:  relative=0.000315648, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000003  0.3156E-01  0.0000E+00
  0 KSP Residual norm 4.647895869934e+04
  1 KSP Residual norm 3.164140657549e+04
  2 KSP Residual norm 2.267537495404e+04
  3 KSP Residual norm 1.761483262298e+04
  4 KSP Residual norm 1.300443054660e+04
  5 KSP Residual norm 9.651630186412e+03
  6 KSP Residual norm 6.547343453543e+03
  7 KSP Residual norm 4.117438446817e+03
  8 KSP Residual norm 2.256659409064e+03
  9 KSP Residual norm 1.265819166008e+03
 10 KSP Residual norm 8.933660046859e+02
 11 KSP Residual norm 7.016010669894e+02
 12 KSP Residual norm 5.355737541951e+02
 13 KSP Residual norm 4.565881390630e+02
 14 KSP Residual norm 3.722255933169e+02
 15 KSP Residual norm 3.095216022966e+02
 16 KSP Residual norm 2.585396824477e+02
 17 KSP Residual norm 2.285067693929e+02
 18 KSP Residual norm 2.045913265261e+02
 19 KSP Residual norm 1.875202073998e+02
 20 KSP Residual norm 1.685441753572e+02
 21 KSP Residual norm 1.525519469781e+02
 22 KSP Residual norm 1.390532538886e+02
 23 KSP Residual norm 1.297738331046e+02
 24 KSP Residual norm 1.204293080673e+02
 25 KSP Residual norm 1.116138208749e+02
 26 KSP Residual norm 1.028152995873e+02
 27 KSP Residual norm 9.459187263580e+01
 28 KSP Residual norm 8.879098150911e+01
 29 KSP Residual norm 8.468470297290e+01
 30 KSP Residual norm 8.139115426677e+01
 31 KSP Residual norm 7.854365188757e+01
 32 KSP Residual norm 7.543814515137e+01
 33 KSP Residual norm 7.251178248557e+01
 34 KSP Residual norm 6.993131774268e+01
 35 KSP Residual norm 6.747206805630e+01
 36 KSP Residual norm 6.450178891522e+01
 37 KSP Residual norm 6.122755579171e+01
 38 KSP Residual norm 5.847176167259e+01
 39 KSP Residual norm 5.558872649235e+01
 40 KSP Residual norm 5.199440186325e+01
 41 KSP Residual norm 4.827838163440e+01
 42 KSP Residual norm 4.357770469309e+01
 43 KSP Residual norm 3.874033022020e+01
 44 KSP Residual norm 3.403086111802e+01
 45 KSP Residual norm 3.034296410178e+01
 46 KSP Residual norm 2.657911534277e+01
 47 KSP Residual norm 2.338518073473e+01
 48 KSP Residual norm 2.119252989273e+01
 49 KSP Residual norm 1.999042707430e+01
 50 KSP Residual norm 1.916867198104e+01
 51 KSP Residual norm 1.876179121985e+01
 52 KSP Residual norm 1.855117992720e+01
 53 KSP Residual norm 1.843615588967e+01
 54 KSP Residual norm 1.837481864393e+01
 55 KSP Residual norm 1.835041400648e+01
 56 KSP Residual norm 1.829311897991e+01
 57 KSP Residual norm 1.821187384047e+01
 58 KSP Residual norm 1.810348141614e+01
 59 KSP Residual norm 1.790611204688e+01
 60 KSP Residual norm 1.748908091503e+01
 61 KSP Residual norm 1.678499937403e+01
 62 KSP Residual norm 1.570470339445e+01
 63 KSP Residual norm 1.432632256838e+01
 64 KSP Residual norm 1.282560896521e+01
 65 KSP Residual norm 1.088303615451e+01
 66 KSP Residual norm 9.056100054935e+00
 67 KSP Residual norm 7.574126511480e+00
 68 KSP Residual norm 6.656785636415e+00
  type: gmres
  tolerances:  relative=0.00014427, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000004  0.1443E-01  0.0000E+00
  0 KSP Residual norm 4.646166895679e+04
  1 KSP Residual norm 3.162794916970e+04
  2 KSP Residual norm 2.266738619716e+04
  3 KSP Residual norm 1.760736748111e+04
  4 KSP Residual norm 1.299932064878e+04
  5 KSP Residual norm 9.647941758129e+03
  6 KSP Residual norm 6.544994184392e+03
  7 KSP Residual norm 4.116457773313e+03
  8 KSP Residual norm 2.255664935077e+03
  9 KSP Residual norm 1.264306308044e+03
 10 KSP Residual norm 8.908901589557e+02
 11 KSP Residual norm 6.987468717809e+02
 12 KSP Residual norm 5.319073501972e+02
 13 KSP Residual norm 4.524196934948e+02
 14 KSP Residual norm 3.674186403965e+02
 15 KSP Residual norm 3.040321938762e+02
 16 KSP Residual norm 2.524309113091e+02
 17 KSP Residual norm 2.219799064945e+02
 18 KSP Residual norm 1.978568247666e+02
 19 KSP Residual norm 1.806983446511e+02
 20 KSP Residual norm 1.617468589079e+02
 21 KSP Residual norm 1.457027385030e+02
 22 KSP Residual norm 1.321605852649e+02
 23 KSP Residual norm 1.227949944746e+02
 24 KSP Residual norm 1.133692598350e+02
 25 KSP Residual norm 1.044410904210e+02
 26 KSP Residual norm 9.547669714017e+01
 27 KSP Residual norm 8.703595042809e+01
 28 KSP Residual norm 8.104780888404e+01
 29 KSP Residual norm 7.684348355059e+01
 30 KSP Residual norm 7.351615328806e+01
 31 KSP Residual norm 7.071771512030e+01
 32 KSP Residual norm 6.768391869107e+01
 33 KSP Residual norm 6.487019341949e+01
 34 KSP Residual norm 6.238797207379e+01
 35 KSP Residual norm 6.007900086671e+01
 36 KSP Residual norm 5.734821016072e+01
 37 KSP Residual norm 5.445313412774e+01
 38 KSP Residual norm 5.205568293699e+01
 39 KSP Residual norm 4.956750124140e+01
 40 KSP Residual norm 4.645229525338e+01
 41 KSP Residual norm 4.327214568058e+01
 42 KSP Residual norm 3.929588207545e+01
 43 KSP Residual norm 3.511642540487e+01
 44 KSP Residual norm 3.094695757531e+01
 45 KSP Residual norm 2.761787475871e+01
 46 KSP Residual norm 2.418823206906e+01
 47 KSP Residual norm 2.115021466160e+01
 48 KSP Residual norm 1.896971718445e+01
 49 KSP Residual norm 1.773171799152e+01
 50 KSP Residual norm 1.688936695070e+01
 51 KSP Residual norm 1.644873693463e+01
 52 KSP Residual norm 1.620624421908e+01
 53 KSP Residual norm 1.606235825223e+01
 54 KSP Residual norm 1.597603165603e+01
 55 KSP Residual norm 1.592979313395e+01
 56 KSP Residual norm 1.585070667704e+01
 57 KSP Residual norm 1.575850937273e+01
 58 KSP Residual norm 1.565022954513e+01
 59 KSP Residual norm 1.548292885902e+01
 60 KSP Residual norm 1.516675021353e+01
 61 KSP Residual norm 1.466313551891e+01
 62 KSP Residual norm 1.389064887442e+01
 63 KSP Residual norm 1.288656989332e+01
 64 KSP Residual norm 1.174443423833e+01
 65 KSP Residual norm 1.018064747125e+01
 66 KSP Residual norm 8.617403304011e+00
 67 KSP Residual norm 7.290597684937e+00
 68 KSP Residual norm 6.442366684519e+00
 69 KSP Residual norm 5.877792172302e+00
 70 KSP Residual norm 5.471068144115e+00
 71 KSP Residual norm 5.180425165192e+00
 72 KSP Residual norm 4.919723230471e+00
 73 KSP Residual norm 4.712300980874e+00
 74 KSP Residual norm 4.538905220129e+00
 75 KSP Residual norm 4.424414845165e+00
 76 KSP Residual norm 4.347508963862e+00
 77 KSP Residual norm 4.286801810203e+00
 78 KSP Residual norm 4.228492099686e+00
 79 KSP Residual norm 4.158691869148e+00
 80 KSP Residual norm 4.074545832104e+00
 81 KSP Residual norm 3.962654065224e+00
 82 KSP Residual norm 3.813497008497e+00
 83 KSP Residual norm 3.626672326407e+00
 84 KSP Residual norm 3.411326356042e+00
 85 KSP Residual norm 3.208359689142e+00
 86 KSP Residual norm 3.026816883459e+00
 87 KSP Residual norm 2.878539493112e+00
 88 KSP Residual norm 2.745009596150e+00
 89 KSP Residual norm 2.632408525415e+00
 90 KSP Residual norm 2.527542369945e+00
 91 KSP Residual norm 2.402218233625e+00
 92 KSP Residual norm 2.263578042553e+00
 93 KSP Residual norm 2.135997663149e+00
 94 KSP Residual norm 2.040608697474e+00
 95 KSP Residual norm 1.963473994745e+00
 96 KSP Residual norm 1.895099898148e+00
 97 KSP Residual norm 1.840999762006e+00
 98 KSP Residual norm 1.787353606136e+00
 99 KSP Residual norm 1.726725823332e+00
100 KSP Residual norm 1.671297723702e+00
101 KSP Residual norm 1.671268205371e+00
102 KSP Residual norm 1.671256170705e+00
103 KSP Residual norm 1.671236538684e+00
104 KSP Residual norm 1.671214560026e+00
105 KSP Residual norm 1.671161981492e+00
106 KSP Residual norm 1.671122556315e+00
107 KSP Residual norm 1.671029915334e+00
108 KSP Residual norm 1.670993667023e+00
109 KSP Residual norm 1.670864888360e+00
110 KSP Residual norm 1.670808105537e+00
111 KSP Residual norm 1.670758091248e+00
112 KSP Residual norm 1.670623436100e+00
113 KSP Residual norm 1.669983091255e+00
114 KSP Residual norm 1.669404821472e+00
115 KSP Residual norm 1.666783314748e+00
116 KSP Residual norm 1.664073050381e+00
117 KSP Residual norm 1.658300718698e+00
118 KSP Residual norm 1.652487203337e+00
119 KSP Residual norm 1.641952718903e+00
120 KSP Residual norm 1.630647882043e+00
121 KSP Residual norm 1.611026859856e+00
122 KSP Residual norm 1.596546484602e+00
123 KSP Residual norm 1.582487393499e+00
124 KSP Residual norm 1.572208202935e+00
125 KSP Residual norm 1.557930113763e+00
126 KSP Residual norm 1.544299404084e+00
127 KSP Residual norm 1.526462343761e+00
  type: gmres
  tolerances:  relative=3.30054e-05, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000005  0.3301E-02  0.0000E+00
  0 KSP Residual norm 4.646767606450e+04
  1 KSP Residual norm 3.162275664728e+04
  2 KSP Residual norm 2.266678835526e+04
  3 KSP Residual norm 1.760405539287e+04
  4 KSP Residual norm 1.299731442450e+04
  5 KSP Residual norm 9.645913289170e+03
  6 KSP Residual norm 6.543256704091e+03
  7 KSP Residual norm 4.115472801140e+03
  8 KSP Residual norm 2.254515372798e+03
  9 KSP Residual norm 1.263803538394e+03
 10 KSP Residual norm 8.898910453689e+02
 11 KSP Residual norm 6.979268154493e+02
 12 KSP Residual norm 5.306317602403e+02
 13 KSP Residual norm 4.511960851342e+02
 14 KSP Residual norm 3.658945090470e+02
 15 KSP Residual norm 3.024619159863e+02
 16 KSP Residual norm 2.507078919539e+02
 17 KSP Residual norm 2.202254396975e+02
 18 KSP Residual norm 1.961323217073e+02
 19 KSP Residual norm 1.789958195745e+02
 20 KSP Residual norm 1.601911164136e+02
 21 KSP Residual norm 1.441855508663e+02
 22 KSP Residual norm 1.307810591903e+02
 23 KSP Residual norm 1.214166456000e+02
 24 KSP Residual norm 1.120875839080e+02
 25 KSP Residual norm 1.031234334005e+02
 26 KSP Residual norm 9.419353991793e+01
 27 KSP Residual norm 8.566665798779e+01
 28 KSP Residual norm 7.966600953171e+01
 29 KSP Residual norm 7.540448037391e+01
 30 KSP Residual norm 7.206607048159e+01
 31 KSP Residual norm 6.925307048193e+01
 32 KSP Residual norm 6.622460842507e+01
 33 KSP Residual norm 6.342640550987e+01
 34 KSP Residual norm 6.095150007627e+01
 35 KSP Residual norm 5.867496605567e+01
 36 KSP Residual norm 5.596723916998e+01
 37 KSP Residual norm 5.314895959547e+01
 38 KSP Residual norm 5.079521779221e+01
 39 KSP Residual norm 4.839061277630e+01
 40 KSP Residual norm 4.532356195123e+01
 41 KSP Residual norm 4.223855235322e+01
 42 KSP Residual norm 3.835925124393e+01
 43 KSP Residual norm 3.431508106617e+01
 44 KSP Residual norm 3.022938541630e+01
 45 KSP Residual norm 2.697864808585e+01
 46 KSP Residual norm 2.361219135624e+01
 47 KSP Residual norm 2.062155371921e+01
 48 KSP Residual norm 1.844552464969e+01
 49 KSP Residual norm 1.720509289823e+01
 50 KSP Residual norm 1.636360108453e+01
 51 KSP Residual norm 1.591837813554e+01
 52 KSP Residual norm 1.567021968704e+01
 53 KSP Residual norm 1.551929851513e+01
 54 KSP Residual norm 1.542825501826e+01
 55 KSP Residual norm 1.537433717926e+01
 56 KSP Residual norm 1.528985025953e+01
 57 KSP Residual norm 1.519213783688e+01
 58 KSP Residual norm 1.508280341137e+01
 59 KSP Residual norm 1.491628651855e+01
 60 KSP Residual norm 1.461843414631e+01
 61 KSP Residual norm 1.414344287823e+01
 62 KSP Residual norm 1.342757985312e+01
 63 KSP Residual norm 1.249593206045e+01
 64 KSP Residual norm 1.143574304534e+01
 65 KSP Residual norm 9.967288826620e+00
 66 KSP Residual norm 8.481275204481e+00
 67 KSP Residual norm 7.204807272123e+00
 68 KSP Residual norm 6.381903836935e+00
 69 KSP Residual norm 5.831545434036e+00
 70 KSP Residual norm 5.432592966671e+00
 71 KSP Residual norm 5.146861617958e+00
 72 KSP Residual norm 4.888642929897e+00
 73 KSP Residual norm 4.683030206719e+00
 74 KSP Residual norm 4.510175850692e+00
 75 KSP Residual norm 4.396185687853e+00
 76 KSP Residual norm 4.318858248932e+00
 77 KSP Residual norm 4.258175544978e+00
 78 KSP Residual norm 4.199544367719e+00
 79 KSP Residual norm 4.129966169271e+00
 80 KSP Residual norm 4.046140565241e+00
 81 KSP Residual norm 3.935619374937e+00
 82 KSP Residual norm 3.788898051796e+00
 83 KSP Residual norm 3.605901597905e+00
 84 KSP Residual norm 3.395295241465e+00
 85 KSP Residual norm 3.197042767807e+00
 86 KSP Residual norm 3.019627954305e+00
 87 KSP Residual norm 2.874222889676e+00
 88 KSP Residual norm 2.742794221649e+00
 89 KSP Residual norm 2.631166883611e+00
 90 KSP Residual norm 2.526643311653e+00
 91 KSP Residual norm 2.400727080802e+00
 92 KSP Residual norm 2.260939631374e+00
 93 KSP Residual norm 2.131729354992e+00
 94 KSP Residual norm 2.035029521617e+00
 95 KSP Residual norm 1.956764697974e+00
 96 KSP Residual norm 1.887767577461e+00
 97 KSP Residual norm 1.833468687463e+00
 98 KSP Residual norm 1.780152526381e+00
 99 KSP Residual norm 1.720320716957e+00
100 KSP Residual norm 1.665988784985e+00
101 KSP Residual norm 1.665965240507e+00
102 KSP Residual norm 1.665954729088e+00
103 KSP Residual norm 1.665937194501e+00
104 KSP Residual norm 1.665916777406e+00
105 KSP Residual norm 1.665867946666e+00
106 KSP Residual norm 1.665827785805e+00
107 KSP Residual norm 1.665736540807e+00
108 KSP Residual norm 1.665693951910e+00
109 KSP Residual norm 1.665570595936e+00
110 KSP Residual norm 1.665515054958e+00
111 KSP Residual norm 1.665471153261e+00
112 KSP Residual norm 1.665358754451e+00
113 KSP Residual norm 1.664845137439e+00
114 KSP Residual norm 1.664376381382e+00
115 KSP Residual norm 1.662248880461e+00
116 KSP Residual norm 1.659973629100e+00
117 KSP Residual norm 1.655076155974e+00
118 KSP Residual norm 1.649993775032e+00
119 KSP Residual norm 1.640535134866e+00
120 KSP Residual norm 1.629867537149e+00
121 KSP Residual norm 1.610463310720e+00
122 KSP Residual norm 1.595168600483e+00
123 KSP Residual norm 1.580109807276e+00
124 KSP Residual norm 1.569428991184e+00
125 KSP Residual norm 1.555259089321e+00
126 KSP Residual norm 1.542524009704e+00
127 KSP Residual norm 1.526183086647e+00
128 KSP Residual norm 1.508440296237e+00
129 KSP Residual norm 1.487833281136e+00
130 KSP Residual norm 1.463532112925e+00
131 KSP Residual norm 1.429179455160e+00
132 KSP Residual norm 1.387700294617e+00
133 KSP Residual norm 1.336789727491e+00
134 KSP Residual norm 1.292147284535e+00
135 KSP Residual norm 1.254777761143e+00
136 KSP Residual norm 1.222901571442e+00
137 KSP Residual norm 1.194432637970e+00
138 KSP Residual norm 1.177009606224e+00
139 KSP Residual norm 1.166974674460e+00
140 KSP Residual norm 1.155020626859e+00
141 KSP Residual norm 1.135308380726e+00
142 KSP Residual norm 1.107859723490e+00
143 KSP Residual norm 1.069210017639e+00
144 KSP Residual norm 1.028207577076e+00
145 KSP Residual norm 9.848070999139e-01
146 KSP Residual norm 9.517861703484e-01
147 KSP Residual norm 9.253198705547e-01
148 KSP Residual norm 9.081970818881e-01
149 KSP Residual norm 8.977878465527e-01
150 KSP Residual norm 8.935757543749e-01
151 KSP Residual norm 8.915346081796e-01
152 KSP Residual norm 8.885860230732e-01
153 KSP Residual norm 8.786930532800e-01
154 KSP Residual norm 8.519866676699e-01
155 KSP Residual norm 8.026900627722e-01
156 KSP Residual norm 7.290658292478e-01
157 KSP Residual norm 6.433221713529e-01
  type: gmres
  tolerances:  relative=1.54225e-05, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000006  0.1542E-02  0.0000E+00
  0 KSP Residual norm 4.646682314705e+04
  1 KSP Residual norm 3.162224808417e+04
  2 KSP Residual norm 2.266700350315e+04
  3 KSP Residual norm 1.760399404085e+04
  4 KSP Residual norm 1.299736447403e+04
  5 KSP Residual norm 9.645867449042e+03
  6 KSP Residual norm 6.543278613621e+03
  7 KSP Residual norm 4.115534018034e+03
  8 KSP Residual norm 2.254625032713e+03
  9 KSP Residual norm 1.263936952881e+03
 10 KSP Residual norm 8.899984952188e+02
 11 KSP Residual norm 6.980402120813e+02
 12 KSP Residual norm 5.307223020484e+02
 13 KSP Residual norm 4.512707553700e+02
 14 KSP Residual norm 3.659387048094e+02
 15 KSP Residual norm 3.024843851480e+02
 16 KSP Residual norm 2.507149614618e+02
 17 KSP Residual norm 2.202265941830e+02
 18 KSP Residual norm 1.961337756767e+02
 19 KSP Residual norm 1.789992105643e+02
 20 KSP Residual norm 1.602019365546e+02
 21 KSP Residual norm 1.442002362882e+02
 22 KSP Residual norm 1.308009566207e+02
 23 KSP Residual norm 1.214357003137e+02
 24 KSP Residual norm 1.121050276959e+02
 25 KSP Residual norm 1.031322685775e+02
 26 KSP Residual norm 9.418932380941e+01
 27 KSP Residual norm 8.564495313533e+01
 28 KSP Residual norm 7.962958233368e+01
 29 KSP Residual norm 7.535618133974e+01
 30 KSP Residual norm 7.200777786142e+01
 31 KSP Residual norm 6.918808703243e+01
 32 KSP Residual norm 6.615355942714e+01
 33 KSP Residual norm 6.335422266158e+01
 34 KSP Residual norm 6.087994810096e+01
 35 KSP Residual norm 5.860768305111e+01
 36 KSP Residual norm 5.590605079199e+01
 37 KSP Residual norm 5.309692677547e+01
 38 KSP Residual norm 5.074937855236e+01
 39 KSP Residual norm 4.834985837531e+01
 40 KSP Residual norm 4.528521713467e+01
 41 KSP Residual norm 4.220152845758e+01
 42 KSP Residual norm 3.832512548078e+01
 43 KSP Residual norm 3.428544141697e+01
 44 KSP Residual norm 3.020429577065e+01
 45 KSP Residual norm 2.695690934582e+01
 46 KSP Residual norm 2.359414263150e+01
 47 KSP Residual norm 2.060552006026e+01
 48 KSP Residual norm 1.842936351276e+01
 49 KSP Residual norm 1.718743101553e+01
 50 KSP Residual norm 1.634513113602e+01
 51 KSP Residual norm 1.589910831290e+01
 52 KSP Residual norm 1.565048632185e+01
 53 KSP Residual norm 1.549913015086e+01
 54 KSP Residual norm 1.540796344631e+01
 55 KSP Residual norm 1.535377118215e+01
 56 KSP Residual norm 1.526899154893e+01
 57 KSP Residual norm 1.517085203187e+01
 58 KSP Residual norm 1.506106668467e+01
 59 KSP Residual norm 1.489374090919e+01
 60 KSP Residual norm 1.459539877189e+01
 61 KSP Residual norm 1.412030415525e+01
 62 KSP Residual norm 1.340561633295e+01
 63 KSP Residual norm 1.247722217449e+01
 64 KSP Residual norm 1.142223355488e+01
 65 KSP Residual norm 9.960759904218e+00
 66 KSP Residual norm 8.479724764253e+00
 67 KSP Residual norm 7.205175367411e+00
 68 KSP Residual norm 6.382247645371e+00
 69 KSP Residual norm 5.831379327774e+00
 70 KSP Residual norm 5.431781045368e+00
 71 KSP Residual norm 5.145590103592e+00
 72 KSP Residual norm 4.887058188869e+00
 73 KSP Residual norm 4.681378237868e+00
 74 KSP Residual norm 4.508678739551e+00
 75 KSP Residual norm 4.394966289798e+00
 76 KSP Residual norm 4.317858378339e+00
 77 KSP Residual norm 4.257323827661e+00
 78 KSP Residual norm 4.198748370852e+00
 79 KSP Residual norm 4.129169139748e+00
 80 KSP Residual norm 4.045395343135e+00
 81 KSP Residual norm 3.935023505436e+00
 82 KSP Residual norm 3.788775727201e+00
 83 KSP Residual norm 3.606590145487e+00
 84 KSP Residual norm 3.397169369894e+00
 85 KSP Residual norm 3.200163402210e+00
 86 KSP Residual norm 3.023822739624e+00
 87 KSP Residual norm 2.879127347325e+00
 88 KSP Residual norm 2.748099503455e+00
 89 KSP Residual norm 2.636515396870e+00
 90 KSP Residual norm 2.531774492895e+00
 91 KSP Residual norm 2.405321602358e+00
 92 KSP Residual norm 2.264683605217e+00
 93 KSP Residual norm 2.134552375778e+00
 94 KSP Residual norm 2.037077099533e+00
 95 KSP Residual norm 1.958190627683e+00
 96 KSP Residual norm 1.888715558971e+00
 97 KSP Residual norm 1.834111026034e+00
 98 KSP Residual norm 1.780632519655e+00
 99 KSP Residual norm 1.720745801196e+00
100 KSP Residual norm 1.666458998667e+00
101 KSP Residual norm 1.666435684710e+00
102 KSP Residual norm 1.666425187739e+00
103 KSP Residual norm 1.666407589462e+00
104 KSP Residual norm 1.666386974836e+00
105 KSP Residual norm 1.666337796650e+00
106 KSP Residual norm 1.666297016972e+00
107 KSP Residual norm 1.666204921832e+00
108 KSP Residual norm 1.666161370903e+00
109 KSP Residual norm 1.666037316950e+00
110 KSP Residual norm 1.665981317531e+00
111 KSP Residual norm 1.665937402920e+00
112 KSP Residual norm 1.665825307209e+00
113 KSP Residual norm 1.665315593546e+00
114 KSP Residual norm 1.664849127774e+00
115 KSP Residual norm 1.662735263087e+00
116 KSP Residual norm 1.660468452198e+00
117 KSP Residual norm 1.655591325115e+00
118 KSP Residual norm 1.650522338355e+00
119 KSP Residual norm 1.641094735433e+00
120 KSP Residual norm 1.630448294649e+00
121 KSP Residual norm 1.611075491174e+00
122 KSP Residual norm 1.595774897502e+00
123 KSP Residual norm 1.580703368287e+00
124 KSP Residual norm 1.570018008550e+00
125 KSP Residual norm 1.555848693583e+00
126 KSP Residual norm 1.543112255037e+00
127 KSP Residual norm 1.526748985029e+00
128 KSP Residual norm 1.508973965304e+00
129 KSP Residual norm 1.488332784886e+00
130 KSP Residual norm 1.464046578349e+00
131 KSP Residual norm 1.429790383006e+00
132 KSP Residual norm 1.388559152436e+00
133 KSP Residual norm 1.338026272560e+00
134 KSP Residual norm 1.293772629189e+00
135 KSP Residual norm 1.256697242651e+00
136 KSP Residual norm 1.225027704653e+00
137 KSP Residual norm 1.196642569402e+00
138 KSP Residual norm 1.179189180775e+00
139 KSP Residual norm 1.169080422271e+00
140 KSP Residual norm 1.157001698950e+00
141 KSP Residual norm 1.137046212942e+00
142 KSP Residual norm 1.109214142657e+00
143 KSP Residual norm 1.069978873622e+00
144 KSP Residual norm 1.028402576664e+00
145 KSP Residual norm 9.844869861312e-01
146 KSP Residual norm 9.511605535844e-01
147 KSP Residual norm 9.245007185831e-01
148 KSP Residual norm 9.072815686860e-01
149 KSP Residual norm 8.968213413508e-01
150 KSP Residual norm 8.926024925512e-01
151 KSP Residual norm 8.905834226558e-01
152 KSP Residual norm 8.877042587324e-01
153 KSP Residual norm 8.779928017088e-01
154 KSP Residual norm 8.516060097454e-01
155 KSP Residual norm 8.026635369935e-01
156 KSP Residual norm 7.293115514688e-01
157 KSP Residual norm 6.437202348367e-01
158 KSP Residual norm 5.624080406391e-01
159 KSP Residual norm 4.858443647817e-01
160 KSP Residual norm 4.264957571657e-01
161 KSP Residual norm 3.858780563124e-01
162 KSP Residual norm 3.598458900999e-01
163 KSP Residual norm 3.410917304099e-01
164 KSP Residual norm 3.229940833118e-01
165 KSP Residual norm 3.027899484024e-01
166 KSP Residual norm 2.755127285400e-01
167 KSP Residual norm 2.498053869347e-01
168 KSP Residual norm 2.314660155452e-01
169 KSP Residual norm 2.188796341968e-01
170 KSP Residual norm 2.113300313226e-01
171 KSP Residual norm 2.083451871524e-01
172 KSP Residual norm 2.072616327406e-01
173 KSP Residual norm 2.067011126820e-01
174 KSP Residual norm 2.062362449857e-01
175 KSP Residual norm 2.048983172897e-01
176 KSP Residual norm 2.031910394026e-01
177 KSP Residual norm 2.005418070100e-01
178 KSP Residual norm 1.971457554824e-01
179 KSP Residual norm 1.931519024998e-01
180 KSP Residual norm 1.871198294090e-01
181 KSP Residual norm 1.780354633589e-01
182 KSP Residual norm 1.647179957053e-01
183 KSP Residual norm 1.498292446234e-01
184 KSP Residual norm 1.354635651340e-01
  type: gmres
  tolerances:  relative=2.91923e-06, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000007  0.2919E-03  0.0000E+00
  0 KSP Residual norm 4.646787455792e+04
  1 KSP Residual norm 3.162241956898e+04
  2 KSP Residual norm 2.266751754353e+04
  3 KSP Residual norm 1.760415085826e+04
  4 KSP Residual norm 1.299754583121e+04
  5 KSP Residual norm 9.645915265046e+03
  6 KSP Residual norm 6.543277917532e+03
  7 KSP Residual norm 4.115529141578e+03
  8 KSP Residual norm 2.254597408668e+03
  9 KSP Residual norm 1.263984275593e+03
 10 KSP Residual norm 8.900177015723e+02
 11 KSP Residual norm 6.980844807830e+02
 12 KSP Residual norm 5.307315524104e+02
 13 KSP Residual norm 4.512901660541e+02
 14 KSP Residual norm 3.659316017433e+02
 15 KSP Residual norm 3.024811783739e+02
 16 KSP Residual norm 2.507046989506e+02
 17 KSP Residual norm 2.202202011191e+02
 18 KSP Residual norm 1.961325403663e+02
 19 KSP Residual norm 1.790000833697e+02
 20 KSP Residual norm 1.602143568404e+02
 21 KSP Residual norm 1.442149915719e+02
 22 KSP Residual norm 1.308282735973e+02
 23 KSP Residual norm 1.214618155162e+02
 24 KSP Residual norm 1.121392228531e+02
 25 KSP Residual norm 1.031604946627e+02
 26 KSP Residual norm 9.422035455444e+01
 27 KSP Residual norm 8.566719561477e+01
 28 KSP Residual norm 7.965142848918e+01
 29 KSP Residual norm 7.537164420944e+01
 30 KSP Residual norm 7.202130634290e+01
 31 KSP Residual norm 6.919785061706e+01
 32 KSP Residual norm 6.616188825782e+01
 33 KSP Residual norm 6.336178439002e+01
 34 KSP Residual norm 6.088707032209e+01
 35 KSP Residual norm 5.861633815668e+01
 36 KSP Residual norm 5.591444042291e+01
 37 KSP Residual norm 5.310815354349e+01
 38 KSP Residual norm 5.075973670845e+01
 39 KSP Residual norm 4.836228448705e+01
 40 KSP Residual norm 4.529410983860e+01
 41 KSP Residual norm 4.221009518246e+01
 42 KSP Residual norm 3.832937524508e+01
 43 KSP Residual norm 3.429058198191e+01
 44 KSP Residual norm 3.020695817573e+01
 45 KSP Residual norm 2.696042554941e+01
 46 KSP Residual norm 2.359701520897e+01
 47 KSP Residual norm 2.060993376571e+01
 48 KSP Residual norm 1.843376433965e+01
 49 KSP Residual norm 1.719212548963e+01
 50 KSP Residual norm 1.634999542504e+01
 51 KSP Residual norm 1.590413186562e+01
 52 KSP Residual norm 1.565566302081e+01
 53 KSP Residual norm 1.550435044233e+01
 54 KSP Residual norm 1.541344580762e+01
 55 KSP Residual norm 1.535915416823e+01
 56 KSP Residual norm 1.527449770347e+01
 57 KSP Residual norm 1.517614215638e+01
 58 KSP Residual norm 1.506626692646e+01
 59 KSP Residual norm 1.489824567240e+01
 60 KSP Residual norm 1.459942366934e+01
 61 KSP Residual norm 1.412270416692e+01
 62 KSP Residual norm 1.340696967410e+01
 63 KSP Residual norm 1.247741269018e+01
 64 KSP Residual norm 1.142243610210e+01
 65 KSP Residual norm 9.961171104813e+00
 66 KSP Residual norm 8.480559919767e+00
 67 KSP Residual norm 7.205833023893e+00
 68 KSP Residual norm 6.382739591642e+00
 69 KSP Residual norm 5.831697601515e+00
 70 KSP Residual norm 5.431880614702e+00
 71 KSP Residual norm 5.145637123761e+00
 72 KSP Residual norm 4.887034548660e+00
 73 KSP Residual norm 4.681444840014e+00
 74 KSP Residual norm 4.508859788039e+00
 75 KSP Residual norm 4.395343085134e+00
 76 KSP Residual norm 4.318343971412e+00
 77 KSP Residual norm 4.257928060761e+00
 78 KSP Residual norm 4.199354655160e+00
 79 KSP Residual norm 4.129805132319e+00
 80 KSP Residual norm 4.046003868938e+00
 81 KSP Residual norm 3.935677862897e+00
 82 KSP Residual norm 3.789529756650e+00
 83 KSP Residual norm 3.607582172816e+00
 84 KSP Residual norm 3.398499981525e+00
 85 KSP Residual norm 3.201877995389e+00
 86 KSP Residual norm 3.025854859658e+00
 87 KSP Residual norm 2.881354373405e+00
 88 KSP Residual norm 2.750413138008e+00
 89 KSP Residual norm 2.638792686404e+00
 90 KSP Residual norm 2.533932644066e+00
 91 KSP Residual norm 2.407215609042e+00
 92 KSP Residual norm 2.266226734110e+00
 93 KSP Residual norm 2.135706585489e+00
 94 KSP Residual norm 2.037929599285e+00
 95 KSP Residual norm 1.958788876664e+00
 96 KSP Residual norm 1.889129148426e+00
 97 KSP Residual norm 1.834399052016e+00
 98 KSP Residual norm 1.780853147274e+00
 99 KSP Residual norm 1.720938968492e+00
100 KSP Residual norm 1.666670021784e+00
101 KSP Residual norm 1.666646700440e+00
102 KSP Residual norm 1.666636179445e+00
103 KSP Residual norm 1.666618515877e+00
104 KSP Residual norm 1.666597776841e+00
105 KSP Residual norm 1.666548372022e+00
106 KSP Residual norm 1.666507323865e+00
107 KSP Residual norm 1.666414847890e+00
108 KSP Residual norm 1.666371007548e+00
109 KSP Residual norm 1.666246603478e+00
110 KSP Residual norm 1.666190378399e+00
111 KSP Residual norm 1.666146346680e+00
112 KSP Residual norm 1.666033891999e+00
113 KSP Residual norm 1.665523331111e+00
114 KSP Residual norm 1.665055600490e+00
115 KSP Residual norm 1.662937657071e+00
116 KSP Residual norm 1.660665567023e+00
117 KSP Residual norm 1.655779543628e+00
118 KSP Residual norm 1.650701962114e+00
119 KSP Residual norm 1.641266669022e+00
120 KSP Residual norm 1.630620732697e+00
121 KSP Residual norm 1.611268755409e+00
122 KSP Residual norm 1.596000653848e+00
123 KSP Residual norm 1.580962642610e+00
124 KSP Residual norm 1.570296077272e+00
125 KSP Residual norm 1.556134011983e+00
126 KSP Residual norm 1.543381660723e+00
127 KSP Residual norm 1.526974751699e+00
128 KSP Residual norm 1.509124894241e+00
129 KSP Residual norm 1.488395562711e+00
130 KSP Residual norm 1.464017993815e+00
131 KSP Residual norm 1.429703471449e+00
132 KSP Residual norm 1.388499817127e+00
133 KSP Residual norm 1.338114606516e+00
134 KSP Residual norm 1.294063089008e+00
135 KSP Residual norm 1.257164973266e+00
136 KSP Residual norm 1.225631006496e+00
137 KSP Residual norm 1.197324597026e+00
138 KSP Residual norm 1.179880255901e+00
139 KSP Residual norm 1.169741878388e+00
140 KSP Residual norm 1.157593883237e+00
141 KSP Residual norm 1.137503987850e+00
142 KSP Residual norm 1.109465455245e+00
143 KSP Residual norm 1.069948744536e+00
144 KSP Residual norm 1.028142160404e+00
145 KSP Residual norm 9.840785732947e-01
146 KSP Residual norm 9.507111349491e-01
147 KSP Residual norm 9.240624806011e-01
148 KSP Residual norm 9.068665897340e-01
149 KSP Residual norm 8.964166177453e-01
150 KSP Residual norm 8.921979647266e-01
151 KSP Residual norm 8.901778256863e-01
152 KSP Residual norm 8.872957430191e-01
153 KSP Residual norm 8.775766569363e-01
154 KSP Residual norm 8.511775594037e-01
155 KSP Residual norm 8.022410365738e-01
156 KSP Residual norm 7.289295591693e-01
157 KSP Residual norm 6.434004077838e-01
158 KSP Residual norm 5.621312062788e-01
159 KSP Residual norm 4.855860452659e-01
160 KSP Residual norm 4.262275129045e-01
161 KSP Residual norm 3.855958854359e-01
162 KSP Residual norm 3.595536528627e-01
163 KSP Residual norm 3.408088035541e-01
164 KSP Residual norm 3.227421183639e-01
165 KSP Residual norm 3.025977007496e-01
166 KSP Residual norm 2.753933126878e-01
167 KSP Residual norm 2.497380870084e-01
168 KSP Residual norm 2.314181657724e-01
169 KSP Residual norm 2.188249695058e-01
170 KSP Residual norm 2.112498991079e-01
171 KSP Residual norm 2.082370872920e-01
172 KSP Residual norm 2.071318079841e-01
173 KSP Residual norm 2.065526809781e-01
174 KSP Residual norm 2.060705227797e-01
175 KSP Residual norm 2.047046273401e-01
176 KSP Residual norm 2.029701399785e-01
177 KSP Residual norm 2.002917530868e-01
178 KSP Residual norm 1.968720676027e-01
179 KSP Residual norm 1.928622438764e-01
180 KSP Residual norm 1.868245574497e-01
181 KSP Residual norm 1.777515286797e-01
182 KSP Residual norm 1.644665551736e-01
183 KSP Residual norm 1.496248021816e-01
184 KSP Residual norm 1.353130468729e-01
185 KSP Residual norm 1.229663189139e-01
186 KSP Residual norm 1.144358947500e-01
187 KSP Residual norm 1.082868255996e-01
188 KSP Residual norm 1.048880652156e-01
189 KSP Residual norm 1.031195062847e-01
190 KSP Residual norm 1.024718673721e-01
191 KSP Residual norm 1.022559174379e-01
192 KSP Residual norm 1.021036783396e-01
193 KSP Residual norm 1.019657881419e-01
194 KSP Residual norm 1.017980457938e-01
195 KSP Residual norm 1.016477359134e-01
196 KSP Residual norm 1.015707516307e-01
197 KSP Residual norm 1.014174585458e-01
198 KSP Residual norm 1.009440615061e-01
199 KSP Residual norm 9.915866894294e-02
200 KSP Residual norm 9.512008215184e-02
201 KSP Residual norm 9.510916826631e-02
202 KSP Residual norm 9.510773078797e-02
203 KSP Residual norm 9.510628781695e-02
204 KSP Residual norm 9.510575565002e-02
205 KSP Residual norm 9.510475251711e-02
206 KSP Residual norm 9.510310432136e-02
207 KSP Residual norm 9.509751978584e-02
208 KSP Residual norm 9.509749481405e-02
209 KSP Residual norm 9.508851576596e-02
210 KSP Residual norm 9.508751404773e-02
211 KSP Residual norm 9.508509492259e-02
212 KSP Residual norm 9.508109513659e-02
213 KSP Residual norm 9.504691055487e-02
214 KSP Residual norm 9.502281050170e-02
215 KSP Residual norm 9.486710123017e-02
216 KSP Residual norm 9.472518441275e-02
217 KSP Residual norm 9.435149394284e-02
218 KSP Residual norm 9.414908049023e-02
219 KSP Residual norm 9.356745513628e-02
220 KSP Residual norm 9.311472317663e-02
221 KSP Residual norm 9.219326331173e-02
222 KSP Residual norm 9.122066012265e-02
223 KSP Residual norm 8.990908305578e-02
224 KSP Residual norm 8.878211262491e-02
225 KSP Residual norm 8.688778679785e-02
226 KSP Residual norm 8.489546160419e-02
227 KSP Residual norm 8.202980281556e-02
228 KSP Residual norm 7.806516571878e-02
229 KSP Residual norm 7.420860430572e-02
230 KSP Residual norm 7.030645800753e-02
231 KSP Residual norm 6.688076405149e-02
  type: gmres
  tolerances:  relative=1.4941e-06, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000008  0.1494E-03  0.0000E+00
  0 KSP Residual norm 4.646785899754e+04
  1 KSP Residual norm 3.162241963523e+04
  2 KSP Residual norm 2.266755474816e+04
  3 KSP Residual norm 1.760416996810e+04
  4 KSP Residual norm 1.299757623853e+04
  5 KSP Residual norm 9.645933075566e+03
  6 KSP Residual norm 6.543295017150e+03
  7 KSP Residual norm 4.115540904692e+03
  8 KSP Residual norm 2.254605622422e+03
  9 KSP Residual norm 1.263989792173e+03
 10 KSP Residual norm 8.900191944198e+02
 11 KSP Residual norm 6.980849611266e+02
 12 KSP Residual norm 5.307290744447e+02
 13 KSP Residual norm 4.512866645668e+02
 14 KSP Residual norm 3.659273432897e+02
 15 KSP Residual norm 3.024770236796e+02
 16 KSP Residual norm 2.507012089798e+02
 17 KSP Residual norm 2.202174960588e+02
 18 KSP Residual norm 1.961310093090e+02
 19 KSP Residual norm 1.789994885772e+02
 20 KSP Residual norm 1.602154149970e+02
 21 KSP Residual norm 1.442172391655e+02
 22 KSP Residual norm 1.308318499035e+02
 23 KSP Residual norm 1.214659030625e+02
 24 KSP Residual norm 1.121437477073e+02
 25 KSP Residual norm 1.031648411327e+02
 26 KSP Residual norm 9.422427673988e+01
 27 KSP Residual norm 8.567044856205e+01
 28 KSP Residual norm 7.965408379279e+01
 29 KSP Residual norm 7.537381860542e+01
 30 KSP Residual norm 7.202298745462e+01
 31 KSP Residual norm 6.919924454463e+01
 32 KSP Residual norm 6.616297935307e+01
 33 KSP Residual norm 6.336283335375e+01
 34 KSP Residual norm 6.088800087541e+01
 35 KSP Residual norm 5.861726798462e+01
 36 KSP Residual norm 5.591522537135e+01
 37 KSP Residual norm 5.310897571943e+01
 38 KSP Residual norm 5.076057173301e+01
 39 KSP Residual norm 4.836318888318e+01
 40 KSP Residual norm 4.529490566091e+01
 41 KSP Residual norm 4.221075436246e+01
 42 KSP Residual norm 3.832997005633e+01
 43 KSP Residual norm 3.429124033383e+01
 44 KSP Residual norm 3.020765036337e+01
 45 KSP Residual norm 2.696108435505e+01
 46 KSP Residual norm 2.359774585096e+01
 47 KSP Residual norm 2.061074646428e+01
 48 KSP Residual norm 1.843457497693e+01
 49 KSP Residual norm 1.719282319883e+01
 50 KSP Residual norm 1.635065497967e+01
 51 KSP Residual norm 1.590474043023e+01
 52 KSP Residual norm 1.565624509311e+01
 53 KSP Residual norm 1.550490689429e+01
 54 KSP Residual norm 1.541401027656e+01
 55 KSP Residual norm 1.535970284754e+01
 56 KSP Residual norm 1.527502174515e+01
 57 KSP Residual norm 1.517663510774e+01
 58 KSP Residual norm 1.506671699214e+01
 59 KSP Residual norm 1.489860076730e+01
 60 KSP Residual norm 1.459967430148e+01
 61 KSP Residual norm 1.412279142878e+01
 62 KSP Residual norm 1.340690841327e+01
 63 KSP Residual norm 1.247731094848e+01
 64 KSP Residual norm 1.142243316674e+01
 65 KSP Residual norm 9.961428273333e+00
 66 KSP Residual norm 8.481147737731e+00
 67 KSP Residual norm 7.206684986896e+00
 68 KSP Residual norm 6.383691533928e+00
 69 KSP Residual norm 5.832639901943e+00
 70 KSP Residual norm 5.432734749361e+00
 71 KSP Residual norm 5.146379698285e+00
 72 KSP Residual norm 4.887647340210e+00
 73 KSP Residual norm 4.681949636685e+00
 74 KSP Residual norm 4.509282888616e+00
 75 KSP Residual norm 4.395722233812e+00
 76 KSP Residual norm 4.318693362313e+00
 77 KSP Residual norm 4.258254178497e+00
 78 KSP Residual norm 4.199655417310e+00
 79 KSP Residual norm 4.130074597887e+00
 80 KSP Residual norm 4.046243813050e+00
 81 KSP Residual norm 3.935887894406e+00
 82 KSP Residual norm 3.789722856844e+00
 83 KSP Residual norm 3.607777098798e+00
 84 KSP Residual norm 3.398720943175e+00
 85 KSP Residual norm 3.202136361923e+00
 86 KSP Residual norm 3.026145839437e+00
 87 KSP Residual norm 2.881657493973e+00
 88 KSP Residual norm 2.750710112900e+00
 89 KSP Residual norm 2.639061204225e+00
 90 KSP Residual norm 2.534154650364e+00
 91 KSP Residual norm 2.407362997564e+00
 92 KSP Residual norm 2.266278488174e+00
 93 KSP Residual norm 2.135668235264e+00
 94 KSP Residual norm 2.037824996927e+00
 95 KSP Residual norm 1.958637350418e+00
 96 KSP Residual norm 1.888947780945e+00
 97 KSP Residual norm 1.834206018615e+00
 98 KSP Residual norm 1.780665311177e+00
 99 KSP Residual norm 1.720772226464e+00
100 KSP Residual norm 1.666535916890e+00
101 KSP Residual norm 1.666512616863e+00
102 KSP Residual norm 1.666502105063e+00
103 KSP Residual norm 1.666484452071e+00
104 KSP Residual norm 1.666463714440e+00
105 KSP Residual norm 1.666414315783e+00
106 KSP Residual norm 1.666373253632e+00
107 KSP Residual norm 1.666280787418e+00
108 KSP Residual norm 1.666236924028e+00
109 KSP Residual norm 1.666112547580e+00
110 KSP Residual norm 1.666056310013e+00
111 KSP Residual norm 1.666012284025e+00
112 KSP Residual norm 1.665899780342e+00
113 KSP Residual norm 1.665389341622e+00
114 KSP Residual norm 1.664921508600e+00
115 KSP Residual norm 1.662804031224e+00
116 KSP Residual norm 1.660532182247e+00
117 KSP Residual norm 1.655648042222e+00
118 KSP Residual norm 1.650572332343e+00
119 KSP Residual norm 1.641143903348e+00
120 KSP Residual norm 1.630507694891e+00
121 KSP Residual norm 1.611181429498e+00
122 KSP Residual norm 1.595938325545e+00
123 KSP Residual norm 1.580925270578e+00
124 KSP Residual norm 1.570272641046e+00
125 KSP Residual norm 1.556122326172e+00
126 KSP Residual norm 1.543371116181e+00
127 KSP Residual norm 1.526957378354e+00
128 KSP Residual norm 1.509087687707e+00
129 KSP Residual norm 1.488329582236e+00
130 KSP Residual norm 1.463915548685e+00
131 KSP Residual norm 1.429563173530e+00
132 KSP Residual norm 1.388335832887e+00
133 KSP Residual norm 1.337957017087e+00
134 KSP Residual norm 1.293934830851e+00
135 KSP Residual norm 1.257072208985e+00
136 KSP Residual norm 1.225574500015e+00
137 KSP Residual norm 1.197301250593e+00
138 KSP Residual norm 1.179875356832e+00
139 KSP Residual norm 1.169742288429e+00
140 KSP Residual norm 1.157592400564e+00
141 KSP Residual norm 1.137491175092e+00
142 KSP Residual norm 1.109428815140e+00
143 KSP Residual norm 1.069873164992e+00
144 KSP Residual norm 1.028029310124e+00
145 KSP Residual norm 9.839374683457e-01
146 KSP Residual norm 9.505588139893e-01
147 KSP Residual norm 9.239080440484e-01
148 KSP Residual norm 9.067164074833e-01
149 KSP Residual norm 8.962720921303e-01
150 KSP Residual norm 8.920570430702e-01
151 KSP Residual norm 8.900393667456e-01
152 KSP Residual norm 8.871605726314e-01
153 KSP Residual norm 8.774468330367e-01
154 KSP Residual norm 8.510519600767e-01
155 KSP Residual norm 8.021187897424e-01
156 KSP Residual norm 7.288150132050e-01
157 KSP Residual norm 6.432975066353e-01
158 KSP Residual norm 5.620378079208e-01
159 KSP Residual norm 4.854986024440e-01
160 KSP Residual norm 4.261411555818e-01
161 KSP Residual norm 3.855071375565e-01
162 KSP Residual norm 3.594622876611e-01
163 KSP Residual norm 3.407175721585e-01
164 KSP Residual norm 3.226556535301e-01
165 KSP Residual norm 3.025210288453e-01
166 KSP Residual norm 2.753330710023e-01
167 KSP Residual norm 2.496947452834e-01
168 KSP Residual norm 2.313879605898e-01
169 KSP Residual norm 2.188033285691e-01
170 KSP Residual norm 2.112327574522e-01
171 KSP Residual norm 2.082207821413e-01
172 KSP Residual norm 2.071148041300e-01
173 KSP Residual norm 2.065345589101e-01
174 KSP Residual norm 2.060510391765e-01
175 KSP Residual norm 2.046829187112e-01
176 KSP Residual norm 2.029457800704e-01
177 KSP Residual norm 2.002641090672e-01
178 KSP Residual norm 1.968410139196e-01
179 KSP Residual norm 1.928278685586e-01
180 KSP Residual norm 1.867862024192e-01
181 KSP Residual norm 1.777084796605e-01
182 KSP Residual norm 1.644184457829e-01
183 KSP Residual norm 1.495766185157e-01
184 KSP Residual norm 1.352711303485e-01
185 KSP Residual norm 1.229360775876e-01
186 KSP Residual norm 1.144177518051e-01
187 KSP Residual norm 1.082789830400e-01
188 KSP Residual norm 1.048868188059e-01
189 KSP Residual norm 1.031220805948e-01
190 KSP Residual norm 1.024760655782e-01
191 KSP Residual norm 1.022606212569e-01
192 KSP Residual norm 1.021083552611e-01
193 KSP Residual norm 1.019700582837e-01
194 KSP Residual norm 1.018016547454e-01
195 KSP Residual norm 1.016505904502e-01
196 KSP Residual norm 1.015729805317e-01
197 KSP Residual norm 1.014187469714e-01
198 KSP Residual norm 1.009439086556e-01
199 KSP Residual norm 9.915660338008e-02
200 KSP Residual norm 9.511765094197e-02
201 KSP Residual norm 9.510673001787e-02
202 KSP Residual norm 9.510529073500e-02
203 KSP Residual norm 9.510384688258e-02
204 KSP Residual norm 9.510331480217e-02
205 KSP Residual norm 9.510231187647e-02
206 KSP Residual norm 9.510066420769e-02
207 KSP Residual norm 9.509508093767e-02
208 KSP Residual norm 9.509505646449e-02
209 KSP Residual norm 9.508608518537e-02
210 KSP Residual norm 9.508508487860e-02
211 KSP Residual norm 9.508266557621e-02
212 KSP Residual norm 9.507866314439e-02
213 KSP Residual norm 9.504445614581e-02
214 KSP Residual norm 9.502033391298e-02
215 KSP Residual norm 9.486451969616e-02
216 KSP Residual norm 9.472248087946e-02
217 KSP Residual norm 9.434860636622e-02
218 KSP Residual norm 9.414611400660e-02
219 KSP Residual norm 9.356443665062e-02
220 KSP Residual norm 9.311183883005e-02
221 KSP Residual norm 9.219103231839e-02
222 KSP Residual norm 9.121932123142e-02
223 KSP Residual norm 8.990890838054e-02
224 KSP Residual norm 8.878256018248e-02
225 KSP Residual norm 8.688817166040e-02
226 KSP Residual norm 8.489423244501e-02
227 KSP Residual norm 8.202467896223e-02
228 KSP Residual norm 7.805350316673e-02
229 KSP Residual norm 7.419063654580e-02
230 KSP Residual norm 7.028431803387e-02
231 KSP Residual norm 6.685751630834e-02
232 KSP Residual norm 6.380711797294e-02
233 KSP Residual norm 6.155045331759e-02
234 KSP Residual norm 6.018003979142e-02
235 KSP Residual norm 5.940591200007e-02
236 KSP Residual norm 5.890639440520e-02
237 KSP Residual norm 5.848752826170e-02
238 KSP Residual norm 5.801574566942e-02
239 KSP Residual norm 5.739878145171e-02
240 KSP Residual norm 5.624796293368e-02
241 KSP Residual norm 5.452934040580e-02
242 KSP Residual norm 5.319665521357e-02
243 KSP Residual norm 5.202264298858e-02
244 KSP Residual norm 5.138992766373e-02
245 KSP Residual norm 5.102604688588e-02
246 KSP Residual norm 5.088229349730e-02
247 KSP Residual norm 5.071870773193e-02
248 KSP Residual norm 5.054432736650e-02
249 KSP Residual norm 5.028913620107e-02
250 KSP Residual norm 4.989355617557e-02
251 KSP Residual norm 4.892839333162e-02
252 KSP Residual norm 4.700994528759e-02
253 KSP Residual norm 4.456504460985e-02
254 KSP Residual norm 4.229141391984e-02
255 KSP Residual norm 4.036476436768e-02
256 KSP Residual norm 3.828564254222e-02
257 KSP Residual norm 3.547978966327e-02
258 KSP Residual norm 3.153846829491e-02
259 KSP Residual norm 2.667749784025e-02
260 KSP Residual norm 2.274456576565e-02
261 KSP Residual norm 2.033797940284e-02
262 KSP Residual norm 1.911937325057e-02
263 KSP Residual norm 1.870784234382e-02
  type: gmres
  tolerances:  relative=4.09832e-07, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000009  0.4098E-04  0.0000E+00
  0 KSP Residual norm 4.646794310590e+04
  1 KSP Residual norm 3.162241144457e+04
  2 KSP Residual norm 2.266758330804e+04
  3 KSP Residual norm 1.760417191668e+04
  4 KSP Residual norm 1.299758670251e+04
  5 KSP Residual norm 9.645932097989e+03
  6 KSP Residual norm 6.543290435478e+03
  7 KSP Residual norm 4.115535858541e+03
  8 KSP Residual norm 2.254598957612e+03
  9 KSP Residual norm 1.263991449396e+03
 10 KSP Residual norm 8.900182590806e+02
 11 KSP Residual norm 6.980861928761e+02
 12 KSP Residual norm 5.307262171508e+02
 13 KSP Residual norm 4.512849622176e+02
 14 KSP Residual norm 3.659236615256e+02
 15 KSP Residual norm 3.024747741226e+02
 16 KSP Residual norm 2.506993815693e+02
 17 KSP Residual norm 2.202170454250e+02
 18 KSP Residual norm 1.961319546780e+02
 19 KSP Residual norm 1.790012692579e+02
 20 KSP Residual norm 1.602190236520e+02
 21 KSP Residual norm 1.442214343746e+02
 22 KSP Residual norm 1.308375134742e+02
 23 KSP Residual norm 1.214712456959e+02
 24 KSP Residual norm 1.121496449570e+02
 25 KSP Residual norm 1.031696554097e+02
 26 KSP Residual norm 9.422898384346e+01
 27 KSP Residual norm 8.567379879561e+01
 28 KSP Residual norm 7.965718907008e+01
 29 KSP Residual norm 7.537607163408e+01
 30 KSP Residual norm 7.202499870580e+01
 31 KSP Residual norm 6.920080031654e+01
 32 KSP Residual norm 6.616434216430e+01
 33 KSP Residual norm 6.336404004538e+01
 34 KSP Residual norm 6.088909609771e+01
 35 KSP Residual norm 5.861844772673e+01
 36 KSP Residual norm 5.591630616401e+01
 37 KSP Residual norm 5.311031080183e+01
 38 KSP Residual norm 5.076181274355e+01
 39 KSP Residual norm 4.836470703420e+01
 40 KSP Residual norm 4.529617348546e+01
 41 KSP Residual norm 4.221214012679e+01
 42 KSP Residual norm 3.833099968552e+01
 43 KSP Residual norm 3.429240068417e+01
 44 KSP Residual norm 3.020848871835e+01
 45 KSP Residual norm 2.696195815941e+01
 46 KSP Residual norm 2.359842148717e+01
 47 KSP Residual norm 2.061145350188e+01
 48 KSP Residual norm 1.843513683908e+01
 49 KSP Residual norm 1.719331526881e+01
 50 KSP Residual norm 1.635107305796e+01
 51 KSP Residual norm 1.590512684974e+01
 52 KSP Residual norm 1.565662148799e+01
 53 KSP Residual norm 1.550527586014e+01
 54 KSP Residual norm 1.541439698856e+01
 55 KSP Residual norm 1.536007310699e+01
 56 KSP Residual norm 1.527539425919e+01
 57 KSP Residual norm 1.517696956921e+01
 58 KSP Residual norm 1.506702907661e+01
 59 KSP Residual norm 1.489882474582e+01
 60 KSP Residual norm 1.459984137835e+01
 61 KSP Residual norm 1.412278623074e+01
 62 KSP Residual norm 1.340680725254e+01
 63 KSP Residual norm 1.247709648053e+01
 64 KSP Residual norm 1.142224760264e+01
 65 KSP Residual norm 9.961300376347e+00
 66 KSP Residual norm 8.481117358976e+00
 67 KSP Residual norm 7.206680906327e+00
 68 KSP Residual norm 6.383699562408e+00
 69 KSP Residual norm 5.832639666836e+00
 70 KSP Residual norm 5.432711365762e+00
 71 KSP Residual norm 5.146344404820e+00
 72 KSP Residual norm 4.887595755564e+00
 73 KSP Residual norm 4.681901403202e+00
 74 KSP Residual norm 4.509245883488e+00
 75 KSP Residual norm 4.395710403693e+00
 76 KSP Residual norm 4.318700048259e+00
 77 KSP Residual norm 4.258281952223e+00
 78 KSP Residual norm 4.199693501965e+00
 79 KSP Residual norm 4.130130389175e+00
 80 KSP Residual norm 4.046313315040e+00
 81 KSP Residual norm 3.935984711809e+00
 82 KSP Residual norm 3.789854031766e+00
 83 KSP Residual norm 3.607956679253e+00
 84 KSP Residual norm 3.398952847764e+00
 85 KSP Residual norm 3.202415188256e+00
 86 KSP Residual norm 3.026455726325e+00
 87 KSP Residual norm 2.881977682188e+00
 88 KSP Residual norm 2.751023760732e+00
 89 KSP Residual norm 2.639353883879e+00
 90 KSP Residual norm 2.534416757160e+00
 91 KSP Residual norm 2.407579119589e+00
 92 KSP Residual norm 2.266443645258e+00
 93 KSP Residual norm 2.135787292804e+00
 94 KSP Residual norm 2.037914242784e+00
 95 KSP Residual norm 1.958703835160e+00
 96 KSP Residual norm 1.888997344448e+00
 97 KSP Residual norm 1.834241780211e+00
 98 KSP Residual norm 1.780690812289e+00
 99 KSP Residual norm 1.720789601595e+00
100 KSP Residual norm 1.666550401716e+00
101 KSP Residual norm 1.666527099891e+00
102 KSP Residual norm 1.666516584670e+00
103 KSP Residual norm 1.666498923018e+00
104 KSP Residual norm 1.666478169502e+00
105 KSP Residual norm 1.666428740981e+00
106 KSP Residual norm 1.666387642753e+00
107 KSP Residual norm 1.666295119458e+00
108 KSP Residual norm 1.666251215522e+00
109 KSP Residual norm 1.666126787424e+00
110 KSP Residual norm 1.666070522422e+00
111 KSP Residual norm 1.666026482957e+00
112 KSP Residual norm 1.665913947737e+00
113 KSP Residual norm 1.665403430808e+00
114 KSP Residual norm 1.664935500925e+00
115 KSP Residual norm 1.662817665628e+00
116 KSP Residual norm 1.660545368051e+00
117 KSP Residual norm 1.655660478666e+00
118 KSP Residual norm 1.650584278468e+00
119 KSP Residual norm 1.641155700937e+00
120 KSP Residual norm 1.630520840913e+00
121 KSP Residual norm 1.611199032449e+00
122 KSP Residual norm 1.595961697251e+00
123 KSP Residual norm 1.580954067886e+00
124 KSP Residual norm 1.570304761874e+00
125 KSP Residual norm 1.556156148504e+00
126 KSP Residual norm 1.543403797953e+00
127 KSP Residual norm 1.526985167703e+00
128 KSP Residual norm 1.509106885936e+00
129 KSP Residual norm 1.488338648035e+00
130 KSP Residual norm 1.463914852118e+00
131 KSP Residual norm 1.429558165709e+00
132 KSP Residual norm 1.388339277738e+00
133 KSP Residual norm 1.337985029284e+00
134 KSP Residual norm 1.293993462940e+00
135 KSP Residual norm 1.257155784566e+00
136 KSP Residual norm 1.225675173103e+00
137 KSP Residual norm 1.197408282337e+00
138 KSP Residual norm 1.179978560088e+00
139 KSP Residual norm 1.169837672066e+00
140 KSP Residual norm 1.157674589905e+00
141 KSP Residual norm 1.137551235046e+00
142 KSP Residual norm 1.109458810874e+00
143 KSP Residual norm 1.069866095757e+00
144 KSP Residual norm 1.027995266046e+00
145 KSP Residual norm 9.838899744228e-01
146 KSP Residual norm 9.505115458137e-01
147 KSP Residual norm 9.238676750750e-01
148 KSP Residual norm 9.066828365376e-01
149 KSP Residual norm 8.962424499389e-01
150 KSP Residual norm 8.920288225402e-01
151 KSP Residual norm 8.900120019444e-01
152 KSP Residual norm 8.871336370193e-01
153 KSP Residual norm 8.774193057046e-01
154 KSP Residual norm 8.510214939527e-01
155 KSP Residual norm 8.020858083748e-01
156 KSP Residual norm 7.287823158652e-01
157 KSP Residual norm 6.432672361620e-01
158 KSP Residual norm 5.620068951550e-01
159 KSP Residual norm 4.854615626631e-01
160 KSP Residual norm 4.260939954273e-01
161 KSP Residual norm 3.854513424254e-01
162 KSP Residual norm 3.594017668521e-01
163 KSP Residual norm 3.406580182381e-01
164 KSP Residual norm 3.226022532991e-01
165 KSP Residual norm 3.024796076452e-01
166 KSP Residual norm 2.753061646896e-01
167 KSP Residual norm 2.496779865785e-01
168 KSP Residual norm 2.313748277234e-01
169 KSP Residual norm 2.187887185454e-01
170 KSP Residual norm 2.112136448556e-01
171 KSP Residual norm 2.081971917529e-01
172 KSP Residual norm 2.070879536415e-01
173 KSP Residual norm 2.065050782067e-01
174 KSP Residual norm 2.060192750336e-01
175 KSP Residual norm 2.046476706809e-01
176 KSP Residual norm 2.029072725267e-01
177 KSP Residual norm 2.002220948854e-01
178 KSP Residual norm 1.967961861007e-01
179 KSP Residual norm 1.927815494278e-01
180 KSP Residual norm 1.867406387423e-01
181 KSP Residual norm 1.776672783632e-01
182 KSP Residual norm 1.643859810357e-01
183 KSP Residual norm 1.495542605159e-01
184 KSP Residual norm 1.352583342086e-01
185 KSP Residual norm 1.229313657374e-01
186 KSP Residual norm 1.144196228877e-01
187 KSP Residual norm 1.082864880341e-01
188 KSP Residual norm 1.048982657023e-01
189 KSP Residual norm 1.031362194973e-01
190 KSP Residual norm 1.024915098503e-01
191 KSP Residual norm 1.022765131754e-01
192 KSP Residual norm 1.021242221115e-01
193 KSP Residual norm 1.019855354507e-01
194 KSP Residual norm 1.018164614942e-01
195 KSP Residual norm 1.016646004383e-01
196 KSP Residual norm 1.015862993282e-01
197 KSP Residual norm 1.014310004435e-01
198 KSP Residual norm 1.009544114157e-01
199 KSP Residual norm 9.916428806450e-02
200 KSP Residual norm 9.512262858618e-02
201 KSP Residual norm 9.511168759429e-02
202 KSP Residual norm 9.511024320826e-02
203 KSP Residual norm 9.510879570347e-02
204 KSP Residual norm 9.510826277069e-02
205 KSP Residual norm 9.510725865324e-02
206 KSP Residual norm 9.510561064569e-02
207 KSP Residual norm 9.510002406592e-02
208 KSP Residual norm 9.510000021914e-02
209 KSP Residual norm 9.509102870196e-02
210 KSP Residual norm 9.509002948167e-02
211 KSP Residual norm 9.508760761180e-02
212 KSP Residual norm 9.508360286743e-02
213 KSP Residual norm 9.504934724857e-02
214 KSP Residual norm 9.502519747918e-02
215 KSP Residual norm 9.486917412467e-02
216 KSP Residual norm 9.472692301088e-02
217 KSP Residual norm 9.435252109202e-02
218 KSP Residual norm 9.414975743975e-02
219 KSP Residual norm 9.356748156215e-02
220 KSP Residual norm 9.311456624145e-02
221 KSP Residual norm 9.219348750040e-02
222 KSP Residual norm 9.122156469638e-02
223 KSP Residual norm 8.991084837146e-02
224 KSP Residual norm 8.878397996698e-02
225 KSP Residual norm 8.688814969143e-02
226 KSP Residual norm 8.489168937643e-02
227 KSP Residual norm 8.201749668379e-02
228 KSP Residual norm 7.803888558309e-02
229 KSP Residual norm 7.416889342667e-02
230 KSP Residual norm 7.025814428144e-02
231 KSP Residual norm 6.683131935899e-02
232 KSP Residual norm 6.378422076232e-02
233 KSP Residual norm 6.153224623010e-02
234 KSP Residual norm 6.016566705703e-02
235 KSP Residual norm 5.939398436678e-02
236 KSP Residual norm 5.889637965047e-02
237 KSP Residual norm 5.847909370662e-02
238 KSP Residual norm 5.800856288600e-02
239 KSP Residual norm 5.739224566279e-02
240 KSP Residual norm 5.624115981895e-02
241 KSP Residual norm 5.452090032369e-02
242 KSP Residual norm 5.318624418262e-02
243 KSP Residual norm 5.201017376862e-02
244 KSP Residual norm 5.137643323998e-02
245 KSP Residual norm 5.101217280212e-02
246 KSP Residual norm 5.086842205965e-02
247 KSP Residual norm 5.070497740905e-02
248 KSP Residual norm 5.053080213257e-02
249 KSP Residual norm 5.027573755945e-02
250 KSP Residual norm 4.988008173340e-02
251 KSP Residual norm 4.891437285274e-02
252 KSP Residual norm 4.699466237240e-02
253 KSP Residual norm 4.454888040084e-02
254 KSP Residual norm 4.227523806995e-02
255 KSP Residual norm 4.034932942623e-02
256 KSP Residual norm 3.827123299276e-02
257 KSP Residual norm 3.546648609787e-02
258 KSP Residual norm 3.152613312200e-02
259 KSP Residual norm 2.666674037777e-02
260 KSP Residual norm 2.273569605434e-02
261 KSP Residual norm 2.033066834631e-02
262 KSP Residual norm 1.911302105857e-02
263 KSP Residual norm 1.870203505914e-02
264 KSP Residual norm 1.859585243834e-02
265 KSP Residual norm 1.856975421484e-02
266 KSP Residual norm 1.855846203228e-02
267 KSP Residual norm 1.855322447262e-02
268 KSP Residual norm 1.854500345722e-02
269 KSP Residual norm 1.854237822720e-02
270 KSP Residual norm 1.854233014646e-02
271 KSP Residual norm 1.853609241506e-02
272 KSP Residual norm 1.853285796832e-02
273 KSP Residual norm 1.852586315895e-02
274 KSP Residual norm 1.841984110565e-02
275 KSP Residual norm 1.814911260436e-02
276 KSP Residual norm 1.766539303344e-02
277 KSP Residual norm 1.688980488546e-02
278 KSP Residual norm 1.582939787606e-02
279 KSP Residual norm 1.443337616179e-02
280 KSP Residual norm 1.276842191257e-02
281 KSP Residual norm 1.117956806968e-02
282 KSP Residual norm 9.945624295268e-03
283 KSP Residual norm 9.275169831088e-03
284 KSP Residual norm 8.947963558305e-03
285 KSP Residual norm 8.794975817142e-03
286 KSP Residual norm 8.693837282785e-03
287 KSP Residual norm 8.624278332891e-03
288 KSP Residual norm 8.540378993711e-03
289 KSP Residual norm 8.468029663769e-03
KSP Object:(coupledsolve_) 1 MPI processes
  type: gmres
    GMRES: restart=100, using Modified Gram-Schmidt Orthogonalization
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1.83022e-07, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object:(coupledsolve_) 1 MPI processes
  type: ilu
    ILU: out-of-place factorization
    1 level of fill
    tolerance for zero pivot 2.22045e-14
    using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
    matrix ordering: natural
    factor fill ratio given 1, needed 2.44153
      Factored matrix follows:
        Mat Object:         1 MPI processes
          type: seqaij
          rows=8788000, cols=8788000
          package used to perform factorization: petsc
          total: nonzeros=3.56993e+08, allocated nonzeros=3.56993e+08
          total number of mallocs used during MatSetValues calls =0
            not using I-node routines
  linear system matrix = precond matrix:
    type: seqaij
    total: nonzeros=1.46217e+08, allocated nonzeros=1.46217e+08
 0000010  0.1830E-04  0.0000E+00
  Residual norms for coupledsolve_ solve.
  0 KSP Residual norm 4.646794056296e+04
  1 KSP Residual norm 3.162242091009e+04
  2 KSP Residual norm 2.266759502361e+04
  3 KSP Residual norm 1.760418081738e+04
  4 KSP Residual norm 1.299759397918e+04
  5 KSP Residual norm 9.645936099992e+03
  6 KSP Residual norm 6.543292839490e+03
  7 KSP Residual norm 4.115536911869e+03
  8 KSP Residual norm 2.254599945204e+03
  9 KSP Residual norm 1.263992322528e+03
 10 KSP Residual norm 8.900188031408e+02
 11 KSP Residual norm 6.980863995846e+02
 12 KSP Residual norm 5.307258692241e+02
 13 KSP Residual norm 4.512842434537e+02
 14 KSP Residual norm 3.659226805885e+02
 15 KSP Residual norm 3.024737477063e+02
 16 KSP Residual norm 2.506985732589e+02
 17 KSP Residual norm 2.202165696071e+02
 18 KSP Residual norm 1.961319159072e+02
 19 KSP Residual norm 1.790016804003e+02
 20 KSP Residual norm 1.602200341348e+02
 21 KSP Residual norm 1.442229888884e+02
 22 KSP Residual norm 1.308394849630e+02
 23 KSP Residual norm 1.214734141373e+02
 24 KSP Residual norm 1.121518713563e+02
 25 KSP Residual norm 1.031717845984e+02
 26 KSP Residual norm 9.423088244960e+01
 27 KSP Residual norm 8.567539374737e+01
 28 KSP Residual norm 7.965849585974e+01
 29 KSP Residual norm 7.537713997088e+01
 30 KSP Residual norm 7.202584630300e+01
 31 KSP Residual norm 6.920148240076e+01
 32 KSP Residual norm 6.616486498631e+01
 33 KSP Residual norm 6.336446977019e+01
 34 KSP Residual norm 6.088947073693e+01
 35 KSP Residual norm 5.861880916656e+01
 36 KSP Residual norm 5.591666788374e+01
 37 KSP Residual norm 5.311069156112e+01
 38 KSP Residual norm 5.076220065733e+01
 39 KSP Residual norm 4.836508472601e+01
 40 KSP Residual norm 4.529650549919e+01
 41 KSP Residual norm 4.221240909645e+01
 42 KSP Residual norm 3.833120934576e+01
 43 KSP Residual norm 3.429257052164e+01
 44 KSP Residual norm 3.020863559246e+01
 45 KSP Residual norm 2.696209794563e+01
 46 KSP Residual norm 2.359858211994e+01
 47 KSP Residual norm 2.061165078003e+01
 48 KSP Residual norm 1.843536499597e+01
 49 KSP Residual norm 1.719355223216e+01
 50 KSP Residual norm 1.635132220793e+01
 51 KSP Residual norm 1.590538225607e+01
 52 KSP Residual norm 1.565687992986e+01
 53 KSP Residual norm 1.550553471517e+01
 54 KSP Residual norm 1.541465683501e+01
 55 KSP Residual norm 1.536033031854e+01
 56 KSP Residual norm 1.527564698424e+01
 57 KSP Residual norm 1.517721471664e+01
 58 KSP Residual norm 1.506725918727e+01
 59 KSP Residual norm 1.489902503880e+01
 60 KSP Residual norm 1.459999572712e+01
 61 KSP Residual norm 1.412287051112e+01
 62 KSP Residual norm 1.340682255853e+01
 63 KSP Residual norm 1.247707230351e+01
 64 KSP Residual norm 1.142222716302e+01
 65 KSP Residual norm 9.961328344467e+00
 66 KSP Residual norm 8.481213097916e+00
 67 KSP Residual norm 7.206828182121e+00
 68 KSP Residual norm 6.383867511199e+00
 69 KSP Residual norm 5.832803891694e+00
 70 KSP Residual norm 5.432857402482e+00
 71 KSP Residual norm 5.146468532459e+00
 72 KSP Residual norm 4.887695490955e+00
 73 KSP Residual norm 4.681982223602e+00
 74 KSP Residual norm 4.509315415008e+00
 75 KSP Residual norm 4.395776113456e+00
 76 KSP Residual norm 4.318765067692e+00
 77 KSP Residual norm 4.258346686070e+00
 78 KSP Residual norm 4.199756797887e+00
 79 KSP Residual norm 4.130191211177e+00
 80 KSP Residual norm 4.046371861089e+00
 81 KSP Residual norm 3.936042058124e+00
 82 KSP Residual norm 3.789914531199e+00
 83 KSP Residual norm 3.608025172921e+00
 84 KSP Residual norm 3.399033578402e+00
 85 KSP Residual norm 3.202507881893e+00
 86 KSP Residual norm 3.026555906042e+00
 87 KSP Residual norm 2.882078843099e+00
 88 KSP Residual norm 2.751120675122e+00
 89 KSP Residual norm 2.639441946727e+00
 90 KSP Residual norm 2.534492532410e+00
 91 KSP Residual norm 2.407637294358e+00
 92 KSP Residual norm 2.266481017361e+00
 93 KSP Residual norm 2.135805753404e+00
 94 KSP Residual norm 2.037918785856e+00
 95 KSP Residual norm 1.958697948058e+00
 96 KSP Residual norm 1.888983954656e+00
 97 KSP Residual norm 1.834223993661e+00
 98 KSP Residual norm 1.780671647359e+00
 99 KSP Residual norm 1.720771876126e+00
100 KSP Residual norm 1.666536770109e+00
101 KSP Residual norm 1.666513473150e+00
102 KSP Residual norm 1.666502959356e+00
103 KSP Residual norm 1.666485298668e+00
104 KSP Residual norm 1.666464543976e+00
105 KSP Residual norm 1.666415113972e+00
106 KSP Residual norm 1.666374009252e+00
107 KSP Residual norm 1.666281480211e+00
108 KSP Residual norm 1.666237565552e+00
109 KSP Residual norm 1.666113135469e+00
110 KSP Residual norm 1.666056866326e+00
111 KSP Residual norm 1.666012828598e+00
112 KSP Residual norm 1.665900295828e+00
113 KSP Residual norm 1.665389846797e+00
114 KSP Residual norm 1.664921953371e+00
115 KSP Residual norm 1.662804391439e+00
116 KSP Residual norm 1.660532330253e+00
117 KSP Residual norm 1.655648077040e+00
118 KSP Residual norm 1.650572507041e+00
119 KSP Residual norm 1.641145478555e+00
120 KSP Residual norm 1.630512588552e+00
121 KSP Residual norm 1.611195161719e+00
122 KSP Residual norm 1.595961667610e+00
123 KSP Residual norm 1.580957657317e+00
124 KSP Residual norm 1.570310445267e+00
125 KSP Residual norm 1.556163620145e+00
126 KSP Residual norm 1.543411561787e+00
127 KSP Residual norm 1.526991880794e+00
128 KSP Residual norm 1.509110645571e+00
129 KSP Residual norm 1.488338195872e+00
130 KSP Residual norm 1.463909600575e+00
131 KSP Residual norm 1.429548831985e+00
132 KSP Residual norm 1.388329429705e+00
133 KSP Residual norm 1.337980167862e+00
134 KSP Residual norm 1.293996825700e+00
135 KSP Residual norm 1.257167080081e+00
136 KSP Residual norm 1.225693383842e+00
137 KSP Residual norm 1.197431430878e+00
138 KSP Residual norm 1.180003399757e+00
139 KSP Residual norm 1.169862075684e+00
140 KSP Residual norm 1.157697004519e+00
141 KSP Residual norm 1.137569095558e+00
142 KSP Residual norm 1.109469211829e+00
143 KSP Residual norm 1.069865369072e+00
144 KSP Residual norm 1.027984207364e+00
145 KSP Residual norm 9.838707471055e-01
146 KSP Residual norm 9.504885046048e-01
147 KSP Residual norm 9.238431663000e-01
148 KSP Residual norm 9.066586108979e-01
149 KSP Residual norm 8.962190554539e-01
150 KSP Residual norm 8.920061885173e-01
151 KSP Residual norm 8.899901598977e-01
152 KSP Residual norm 8.871132014251e-01
153 KSP Residual norm 8.774017876146e-01
154 KSP Residual norm 8.510081109038e-01
155 KSP Residual norm 8.020766019519e-01
156 KSP Residual norm 7.287768110259e-01
157 KSP Residual norm 6.432644624707e-01
158 KSP Residual norm 5.620049604574e-01
159 KSP Residual norm 4.854583733807e-01
160 KSP Residual norm 4.260879556293e-01
161 KSP Residual norm 3.854423650229e-01
162 KSP Residual norm 3.593906731896e-01
163 KSP Residual norm 3.406462382076e-01
164 KSP Residual norm 3.225911158772e-01
165 KSP Residual norm 3.024704481908e-01
166 KSP Residual norm 2.752997590853e-01
167 KSP Residual norm 2.496738533642e-01
168 KSP Residual norm 2.313719053971e-01
169 KSP Residual norm 2.187860753356e-01
170 KSP Residual norm 2.112105947380e-01
171 KSP Residual norm 2.081934802660e-01
172 KSP Residual norm 2.070836328158e-01
173 KSP Residual norm 2.065002047204e-01
174 KSP Residual norm 2.060138761629e-01
175 KSP Residual norm 2.046414802031e-01
176 KSP Residual norm 2.029003322198e-01
177 KSP Residual norm 2.002143923994e-01
178 KSP Residual norm 1.967879484278e-01
179 KSP Residual norm 1.927731669790e-01
180 KSP Residual norm 1.867326105610e-01
181 KSP Residual norm 1.776601067783e-01
182 KSP Residual norm 1.643799801956e-01
183 KSP Residual norm 1.495494543007e-01
184 KSP Residual norm 1.352548079705e-01
185 KSP Residual norm 1.229292742630e-01
186 KSP Residual norm 1.144189997323e-01
187 KSP Residual norm 1.082871200783e-01
188 KSP Residual norm 1.048996886080e-01
189 KSP Residual norm 1.031381095659e-01
190 KSP Residual norm 1.024935802512e-01
191 KSP Residual norm 1.022786058184e-01
192 KSP Residual norm 1.021262302176e-01
193 KSP Residual norm 1.019873775168e-01
194 KSP Residual norm 1.018180847734e-01
195 KSP Residual norm 1.016660000681e-01
196 KSP Residual norm 1.015875287963e-01
197 KSP Residual norm 1.014319989542e-01
198 KSP Residual norm 1.009551049753e-01
199 KSP Residual norm 9.916468075219e-02
200 KSP Residual norm 9.512317883981e-02
201 KSP Residual norm 9.511223745525e-02
202 KSP Residual norm 9.511079266867e-02
203 KSP Residual norm 9.510934504338e-02
204 KSP Residual norm 9.510881212008e-02
205 KSP Residual norm 9.510780801459e-02
206 KSP Residual norm 9.510616003053e-02
207 KSP Residual norm 9.510057399808e-02
208 KSP Residual norm 9.510055023490e-02
209 KSP Residual norm 9.509158103325e-02
210 KSP Residual norm 9.509058190901e-02
211 KSP Residual norm 9.508815983588e-02
212 KSP Residual norm 9.508415374330e-02
213 KSP Residual norm 9.504989235023e-02
214 KSP Residual norm 9.502573544769e-02
215 KSP Residual norm 9.486968429529e-02
216 KSP Residual norm 9.472738886847e-02
217 KSP Residual norm 9.435291305707e-02
218 KSP Residual norm 9.415008183939e-02
219 KSP Residual norm 9.356769363663e-02
220 KSP Residual norm 9.311468882306e-02
221 KSP Residual norm 9.219351064808e-02
222 KSP Residual norm 9.122150475080e-02
223 KSP Residual norm 8.991069859226e-02
224 KSP Residual norm 8.878369496576e-02
225 KSP Residual norm 8.688759851579e-02
226 KSP Residual norm 8.489070499667e-02
227 KSP Residual norm 8.201574769123e-02
228 KSP Residual norm 7.803595193363e-02
229 KSP Residual norm 7.416471819358e-02
230 KSP Residual norm 7.025306261953e-02
231 KSP Residual norm 6.682590398438e-02
232 KSP Residual norm 6.377893222909e-02
233 KSP Residual norm 6.152736829948e-02
234 KSP Residual norm 6.016119184202e-02
235 KSP Residual norm 5.938978317395e-02
236 KSP Residual norm 5.889244029584e-02
237 KSP Residual norm 5.847540252415e-02
238 KSP Residual norm 5.800508562240e-02
239 KSP Residual norm 5.738887327765e-02
240 KSP Residual norm 5.623768416810e-02
241 KSP Residual norm 5.451704139950e-02
242 KSP Residual norm 5.318199192831e-02
243 KSP Residual norm 5.200548929935e-02
244 KSP Residual norm 5.137145664822e-02
245 KSP Residual norm 5.100698468417e-02
246 KSP Residual norm 5.086311752738e-02
247 KSP Residual norm 5.069951614995e-02
248 KSP Residual norm 5.052517434736e-02
249 KSP Residual norm 5.026992215475e-02
250 KSP Residual norm 4.987408865857e-02
251 KSP Residual norm 4.890818438174e-02
252 KSP Residual norm 4.698848817064e-02
253 KSP Residual norm 4.454318821273e-02
254 KSP Residual norm 4.227034224830e-02
255 KSP Residual norm 4.034532343129e-02
256 KSP Residual norm 3.826816461049e-02
257 KSP Residual norm 3.546422959034e-02
258 KSP Residual norm 3.152438750427e-02
259 KSP Residual norm 2.666534329919e-02
260 KSP Residual norm 2.273451643623e-02
261 KSP Residual norm 2.032964954510e-02
262 KSP Residual norm 1.911213212598e-02
263 KSP Residual norm 1.870124392934e-02
264 KSP Residual norm 1.859513016056e-02
265 KSP Residual norm 1.856908373010e-02
266 KSP Residual norm 1.855784143068e-02
267 KSP Residual norm 1.855264531313e-02
268 KSP Residual norm 1.854448304005e-02
269 KSP Residual norm 1.854188821635e-02
270 KSP Residual norm 1.854184383198e-02
271 KSP Residual norm 1.853557455946e-02
272 KSP Residual norm 1.853232759157e-02
273 KSP Residual norm 1.852533879538e-02
274 KSP Residual norm 1.841930886285e-02
275 KSP Residual norm 1.814854377540e-02
276 KSP Residual norm 1.766474415927e-02
277 KSP Residual norm 1.688902327559e-02
278 KSP Residual norm 1.582849871839e-02
279 KSP Residual norm 1.443244920700e-02
280 KSP Residual norm 1.276761236171e-02
281 KSP Residual norm 1.117896517141e-02
282 KSP Residual norm 9.945218890734e-03
283 KSP Residual norm 9.274855564470e-03
284 KSP Residual norm 8.947674940877e-03
285 KSP Residual norm 8.794670758608e-03
286 KSP Residual norm 8.693501092206e-03
287 KSP Residual norm 8.623910483801e-03
288 KSP Residual norm 8.539978225803e-03
289 KSP Residual norm 8.467608154458e-03
290 KSP Residual norm 8.354913555280e-03
291 KSP Residual norm 8.224429679520e-03
292 KSP Residual norm 8.055420778175e-03
293 KSP Residual norm 7.901727475913e-03
294 KSP Residual norm 7.736158017260e-03
295 KSP Residual norm 7.573268633665e-03
296 KSP Residual norm 7.275766809448e-03
297 KSP Residual norm 6.926264175499e-03
298 KSP Residual norm 6.455316921366e-03
299 KSP Residual norm 6.135871825629e-03
300 KSP Residual norm 5.815802936373e-03
301 KSP Residual norm 5.809278671103e-03
302 KSP Residual norm 5.803627952879e-03
303 KSP Residual norm 5.794936857507e-03
304 KSP Residual norm 5.789655155858e-03
305 KSP Residual norm 5.781477119539e-03
306 KSP Residual norm 5.776202093111e-03
307 KSP Residual norm 5.765554645772e-03
308 KSP Residual norm 5.762080109318e-03
309 KSP Residual norm 5.750454975867e-03
310 KSP Residual norm 5.748262391041e-03
311 KSP Residual norm 5.746673634119e-03
312 KSP Residual norm 5.746469425509e-03
313 KSP Residual norm 5.742812203391e-03
314 KSP Residual norm 5.742286605044e-03
315 KSP Residual norm 5.732355871339e-03
316 KSP Residual norm 5.730682670544e-03
317 KSP Residual norm 5.712171171785e-03
318 KSP Residual norm 5.707690227955e-03
319 KSP Residual norm 5.676376368431e-03
320 KSP Residual norm 5.639086679433e-03
321 KSP Residual norm 5.572856125008e-03
322 KSP Residual norm 5.487064483643e-03
323 KSP Residual norm 5.363315087169e-03
324 KSP Residual norm 5.264378585981e-03
325 KSP Residual norm 5.159674205926e-03
326 KSP Residual norm 5.087185444844e-03
327 KSP Residual norm 5.051759041343e-03
328 KSP Residual norm 5.022344061460e-03
329 KSP Residual norm 5.009797450522e-03
330 KSP Residual norm 4.995683397939e-03
331 KSP Residual norm 4.984097267028e-03
332 KSP Residual norm 4.965722685716e-03
333 KSP Residual norm 4.943113705146e-03
334 KSP Residual norm 4.912533391057e-03
335 KSP Residual norm 4.863367227476e-03
336 KSP Residual norm 4.786889743538e-03
337 KSP Residual norm 4.672466474345e-03
338 KSP Residual norm 4.540852484907e-03
339 KSP Residual norm 4.418716817189e-03
340 KSP Residual norm 4.301708151930e-03
341 KSP Residual norm 4.169066709030e-03
342 KSP Residual norm 4.033285474113e-03
343 KSP Residual norm 3.867290143524e-03
344 KSP Residual norm 3.721493727078e-03
345 KSP Residual norm 3.556479659131e-03
346 KSP Residual norm 3.365623693566e-03
347 KSP Residual norm 3.085180720366e-03
348 KSP Residual norm 2.783861973680e-03
349 KSP Residual norm 2.502004149817e-03
350 KSP Residual norm 2.335237960090e-03
  type: gmres
  tolerances:  relative=5.10987e-08, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000011  0.5110E-05  0.0000E+00
  0 KSP Residual norm 4.646794817862e+04
  1 KSP Residual norm 3.162242022473e+04
  2 KSP Residual norm 2.266759879554e+04
  3 KSP Residual norm 1.760418098266e+04
  4 KSP Residual norm 1.299759417060e+04
  5 KSP Residual norm 9.645934719434e+03
  6 KSP Residual norm 6.543291126285e+03
  7 KSP Residual norm 4.115535473748e+03
  8 KSP Residual norm 2.254598807031e+03
  9 KSP Residual norm 1.263992303710e+03
 10 KSP Residual norm 8.900185640390e+02
 11 KSP Residual norm 6.980863856526e+02
 12 KSP Residual norm 5.307253791507e+02
 13 KSP Residual norm 4.512837937539e+02
 14 KSP Residual norm 3.659219141456e+02
 15 KSP Residual norm 3.024730616733e+02
 16 KSP Residual norm 2.506979295463e+02
 17 KSP Residual norm 2.202161328039e+02
 18 KSP Residual norm 1.961317504103e+02
 19 KSP Residual norm 1.790017523110e+02
 20 KSP Residual norm 1.602205045150e+02
 21 KSP Residual norm 1.442237053844e+02
 22 KSP Residual norm 1.308405144875e+02
 23 KSP Residual norm 1.214744985265e+02
 24 KSP Residual norm 1.121530753700e+02
 25 KSP Residual norm 1.031728689503e+02
 26 KSP Residual norm 9.423191512980e+01
 27 KSP Residual norm 8.567620298887e+01
 28 KSP Residual norm 7.965921299605e+01
 29 KSP Residual norm 7.537769563024e+01
 30 KSP Residual norm 7.202631775398e+01
 31 KSP Residual norm 6.920185140438e+01
 32 KSP Residual norm 6.616516940982e+01
 33 KSP Residual norm 6.336472575155e+01
 34 KSP Residual norm 6.088969863615e+01
 35 KSP Residual norm 5.861903774171e+01
 36 KSP Residual norm 5.591688094047e+01
 37 KSP Residual norm 5.311092334528e+01
 38 KSP Residual norm 5.076240617862e+01
 39 KSP Residual norm 4.836529990336e+01
 40 KSP Residual norm 4.529665860372e+01
 41 KSP Residual norm 4.221254351253e+01
 42 KSP Residual norm 3.833126861123e+01
 43 KSP Residual norm 3.429262285787e+01
 44 KSP Residual norm 3.020864186320e+01
 45 KSP Residual norm 2.696211244743e+01
 46 KSP Residual norm 2.359858553862e+01
 47 KSP Residual norm 2.061168420293e+01
 48 KSP Residual norm 1.843541497525e+01
 49 KSP Residual norm 1.719362192511e+01
 50 KSP Residual norm 1.635140339042e+01
 51 KSP Residual norm 1.590547211897e+01
 52 KSP Residual norm 1.565697449274e+01
 53 KSP Residual norm 1.550563058421e+01
 54 KSP Residual norm 1.541475518815e+01
 55 KSP Residual norm 1.536042735851e+01
 56 KSP Residual norm 1.527574430274e+01
 57 KSP Residual norm 1.517730691536e+01
 58 KSP Residual norm 1.506734729924e+01
 59 KSP Residual norm 1.489909821204e+01
 60 KSP Residual norm 1.460005126490e+01
 61 KSP Residual norm 1.412288771079e+01
 62 KSP Residual norm 1.340680634019e+01
 63 KSP Residual norm 1.247702364428e+01
 64 KSP Residual norm 1.142217438868e+01
 65 KSP Residual norm 9.961282387227e+00
 66 KSP Residual norm 8.481185121766e+00
 67 KSP Residual norm 7.206810863397e+00
 68 KSP Residual norm 6.383858180062e+00
 69 KSP Residual norm 5.832798049185e+00
 70 KSP Residual norm 5.432852338110e+00
 71 KSP Residual norm 5.146464378760e+00
 72 KSP Residual norm 4.887691448197e+00
 73 KSP Residual norm 4.681980254912e+00
 74 KSP Residual norm 4.509316473713e+00
 75 KSP Residual norm 4.395781745960e+00
 76 KSP Residual norm 4.318774525041e+00
 77 KSP Residual norm 4.258360040624e+00
 78 KSP Residual norm 4.199772391385e+00
 79 KSP Residual norm 4.130209415176e+00
 80 KSP Residual norm 4.046391887596e+00
 81 KSP Residual norm 3.936065347817e+00
 82 KSP Residual norm 3.789941889868e+00
 83 KSP Residual norm 3.608058063732e+00
 84 KSP Residual norm 3.399071438071e+00
 85 KSP Residual norm 3.202548835955e+00
 86 KSP Residual norm 3.026597068546e+00
 87 KSP Residual norm 2.882117544994e+00
 88 KSP Residual norm 2.751155648505e+00
 89 KSP Residual norm 2.639472573017e+00
 90 KSP Residual norm 2.534519333513e+00
 91 KSP Residual norm 2.407660118371e+00
 92 KSP Residual norm 2.266501191463e+00
 93 KSP Residual norm 2.135824403692e+00
 94 KSP Residual norm 2.037936770818e+00
 95 KSP Residual norm 1.958715137022e+00
 96 KSP Residual norm 1.889000204637e+00
 97 KSP Residual norm 1.834238871518e+00
 98 KSP Residual norm 1.780684905104e+00
 99 KSP Residual norm 1.720783199113e+00
100 KSP Residual norm 1.666546529404e+00
101 KSP Residual norm 1.666523232786e+00
102 KSP Residual norm 1.666512718691e+00
103 KSP Residual norm 1.666495057175e+00
104 KSP Residual norm 1.666474301142e+00
105 KSP Residual norm 1.666424868831e+00
106 KSP Residual norm 1.666383760687e+00
107 KSP Residual norm 1.666291225791e+00
108 KSP Residual norm 1.666247306293e+00
109 KSP Residual norm 1.666122871135e+00
110 KSP Residual norm 1.666066600345e+00
111 KSP Residual norm 1.666022563782e+00
112 KSP Residual norm 1.665910038180e+00
113 KSP Residual norm 1.665399623132e+00
114 KSP Residual norm 1.664931768017e+00
115 KSP Residual norm 1.662814345067e+00
116 KSP Residual norm 1.660542424462e+00
117 KSP Residual norm 1.655658388257e+00
118 KSP Residual norm 1.650583025167e+00
119 KSP Residual norm 1.641156214116e+00
120 KSP Residual norm 1.630523457097e+00
121 KSP Residual norm 1.611205815075e+00
122 KSP Residual norm 1.595971833308e+00
123 KSP Residual norm 1.580967172391e+00
124 KSP Residual norm 1.570319619399e+00
125 KSP Residual norm 1.556172473435e+00
126 KSP Residual norm 1.543420376229e+00
127 KSP Residual norm 1.527000687096e+00
128 KSP Residual norm 1.509119740789e+00
129 KSP Residual norm 1.488347845738e+00
130 KSP Residual norm 1.463920373265e+00
131 KSP Residual norm 1.429561488880e+00
132 KSP Residual norm 1.388344828086e+00
133 KSP Residual norm 1.337998578976e+00
134 KSP Residual norm 1.294017675066e+00
135 KSP Residual norm 1.257189303507e+00
136 KSP Residual norm 1.225716063782e+00
137 KSP Residual norm 1.197453456397e+00
138 KSP Residual norm 1.180024204344e+00
139 KSP Residual norm 1.169881733023e+00
140 KSP Residual norm 1.157715193123e+00
141 KSP Residual norm 1.137585019244e+00
142 KSP Residual norm 1.109482266385e+00
143 KSP Residual norm 1.069874723192e+00
144 KSP Residual norm 1.027990343661e+00
145 KSP Residual norm 9.838742335151e-01
146 KSP Residual norm 9.504905354113e-01
147 KSP Residual norm 9.238443944919e-01
148 KSP Residual norm 9.066595587520e-01
149 KSP Residual norm 8.962199741238e-01
150 KSP Residual norm 8.920072794854e-01
151 KSP Residual norm 8.899915844412e-01
152 KSP Residual norm 8.871153437550e-01
153 KSP Residual norm 8.774056312874e-01
154 KSP Residual norm 8.510149016763e-01
155 KSP Residual norm 8.020866050001e-01
156 KSP Residual norm 7.287890736505e-01
157 KSP Residual norm 6.432774916255e-01
158 KSP Residual norm 5.620173316995e-01
159 KSP Residual norm 4.854687212288e-01
160 KSP Residual norm 4.260956822319e-01
161 KSP Residual norm 3.854479074816e-01
162 KSP Residual norm 3.593947206994e-01
163 KSP Residual norm 3.406495705678e-01
164 KSP Residual norm 3.225941492446e-01
165 KSP Residual norm 3.024735113179e-01
166 KSP Residual norm 2.753025194714e-01
167 KSP Residual norm 2.496758883075e-01
168 KSP Residual norm 2.313729382162e-01
169 KSP Residual norm 2.187860642275e-01
170 KSP Residual norm 2.112095793913e-01
171 KSP Residual norm 2.081917690206e-01
172 KSP Residual norm 2.070814875689e-01
173 KSP Residual norm 2.064977295169e-01
174 KSP Residual norm 2.060111299911e-01
175 KSP Residual norm 2.046383515425e-01
176 KSP Residual norm 2.028969215770e-01
177 KSP Residual norm 2.002107994610e-01
178 KSP Residual norm 1.967844170377e-01
179 KSP Residual norm 1.927700487270e-01
180 KSP Residual norm 1.867304642941e-01
181 KSP Residual norm 1.776594851051e-01
182 KSP Residual norm 1.643812361055e-01
183 KSP Residual norm 1.495518903851e-01
184 KSP Residual norm 1.352575491109e-01
185 KSP Residual norm 1.229316254969e-01
186 KSP Residual norm 1.144208944734e-01
187 KSP Residual norm 1.082886368793e-01
188 KSP Residual norm 1.049009616255e-01
189 KSP Residual norm 1.031392513748e-01
190 KSP Residual norm 1.024946496172e-01
191 KSP Residual norm 1.022796201487e-01
192 KSP Residual norm 1.021271725287e-01
193 KSP Residual norm 1.019882327321e-01
194 KSP Residual norm 1.018188450053e-01
195 KSP Residual norm 1.016666748915e-01
196 KSP Residual norm 1.015881439429e-01
197 KSP Residual norm 1.014325381569e-01
198 KSP Residual norm 1.009555487070e-01
199 KSP Residual norm 9.916503368946e-02
200 KSP Residual norm 9.512353976735e-02
201 KSP Residual norm 9.511259829209e-02
202 KSP Residual norm 9.511115335871e-02
203 KSP Residual norm 9.510970571566e-02
204 KSP Residual norm 9.510917281021e-02
205 KSP Residual norm 9.510816868749e-02
206 KSP Residual norm 9.510652065050e-02
207 KSP Residual norm 9.510093471149e-02
208 KSP Residual norm 9.510091097090e-02
209 KSP Residual norm 9.509194237274e-02
210 KSP Residual norm 9.509094326417e-02
211 KSP Residual norm 9.508852107988e-02
212 KSP Residual norm 9.508451459660e-02
213 KSP Residual norm 9.505025128523e-02
214 KSP Residual norm 9.502609235340e-02
215 KSP Residual norm 9.487003099015e-02
216 KSP Residual norm 9.472771782103e-02
217 KSP Residual norm 9.435320025548e-02
218 KSP Residual norm 9.415032621956e-02
219 KSP Residual norm 9.356784225753e-02
220 KSP Residual norm 9.311473827663e-02
221 KSP Residual norm 9.219336570237e-02
222 KSP Residual norm 9.122113528254e-02
223 KSP Residual norm 8.991004536890e-02
224 KSP Residual norm 8.878281133970e-02
225 KSP Residual norm 8.688647796089e-02
226 KSP Residual norm 8.488946968032e-02
227 KSP Residual norm 8.201449704689e-02
228 KSP Residual norm 7.803472954230e-02
229 KSP Residual norm 7.416340082455e-02
230 KSP Residual norm 7.025156240310e-02
231 KSP Residual norm 6.682423697934e-02
232 KSP Residual norm 6.377715365022e-02
233 KSP Residual norm 6.152556296138e-02
234 KSP Residual norm 6.015940034639e-02
235 KSP Residual norm 5.938800330336e-02
236 KSP Residual norm 5.889068481951e-02
237 KSP Residual norm 5.847366697739e-02
238 KSP Residual norm 5.800334100373e-02
239 KSP Residual norm 5.738706210463e-02
240 KSP Residual norm 5.623565670351e-02
241 KSP Residual norm 5.451463788283e-02
242 KSP Residual norm 5.317928586375e-02
243 KSP Residual norm 5.200251785626e-02
244 KSP Residual norm 5.136833573201e-02
245 KSP Residual norm 5.100377858251e-02
246 KSP Residual norm 5.085988113583e-02
247 KSP Residual norm 5.069624628278e-02
248 KSP Residual norm 5.052187713109e-02
249 KSP Residual norm 5.026660046006e-02
250 KSP Residual norm 4.987075054332e-02
251 KSP Residual norm 4.890483334637e-02
252 KSP Residual norm 4.698524273166e-02
253 KSP Residual norm 4.454027052718e-02
254 KSP Residual norm 4.226791245493e-02
255 KSP Residual norm 4.034344993038e-02
256 KSP Residual norm 3.826692857224e-02
257 KSP Residual norm 3.546362228324e-02
258 KSP Residual norm 3.152424025617e-02
259 KSP Residual norm 2.666545590093e-02
260 KSP Residual norm 2.273469766349e-02
261 KSP Residual norm 2.032983844588e-02
262 KSP Residual norm 1.911233527691e-02
263 KSP Residual norm 1.870147116090e-02
264 KSP Residual norm 1.859537662912e-02
265 KSP Residual norm 1.856934599691e-02
266 KSP Residual norm 1.855812009877e-02
267 KSP Residual norm 1.855293872036e-02
268 KSP Residual norm 1.854479898695e-02
269 KSP Residual norm 1.854221655835e-02
270 KSP Residual norm 1.854217370892e-02
271 KSP Residual norm 1.853588957393e-02
272 KSP Residual norm 1.853263571229e-02
273 KSP Residual norm 1.852565105626e-02
274 KSP Residual norm 1.841961867231e-02
275 KSP Residual norm 1.814883116977e-02
276 KSP Residual norm 1.766498717631e-02
277 KSP Residual norm 1.688919691430e-02
278 KSP Residual norm 1.582859615957e-02
279 KSP Residual norm 1.443247501455e-02
280 KSP Residual norm 1.276757468811e-02
281 KSP Residual norm 1.117886730837e-02
282 KSP Residual norm 9.945073345874e-03
283 KSP Residual norm 9.274683560541e-03
284 KSP Residual norm 8.947495266794e-03
285 KSP Residual norm 8.794488396727e-03
286 KSP Residual norm 8.693318095210e-03
287 KSP Residual norm 8.623727988327e-03
288 KSP Residual norm 8.539798007917e-03
289 KSP Residual norm 8.467432635007e-03
290 KSP Residual norm 8.354748480861e-03
291 KSP Residual norm 8.224282457437e-03
292 KSP Residual norm 8.055305933738e-03
293 KSP Residual norm 7.901656224839e-03
294 KSP Residual norm 7.736134433174e-03
295 KSP Residual norm 7.573288309290e-03
296 KSP Residual norm 7.275834188027e-03
297 KSP Residual norm 6.926359848768e-03
298 KSP Residual norm 6.455407605098e-03
299 KSP Residual norm 6.135911999974e-03
300 KSP Residual norm 5.815721709426e-03
301 KSP Residual norm 5.809189537421e-03
302 KSP Residual norm 5.803533225777e-03
303 KSP Residual norm 5.794836000227e-03
304 KSP Residual norm 5.789552589566e-03
305 KSP Residual norm 5.781374261718e-03
306 KSP Residual norm 5.776101634419e-03
307 KSP Residual norm 5.765457529932e-03
308 KSP Residual norm 5.761988765367e-03
309 KSP Residual norm 5.750367556006e-03
310 KSP Residual norm 5.748177181645e-03
311 KSP Residual norm 5.746589313940e-03
312 KSP Residual norm 5.746384389268e-03
313 KSP Residual norm 5.742728196224e-03
314 KSP Residual norm 5.742202818034e-03
315 KSP Residual norm 5.732272707176e-03
316 KSP Residual norm 5.730600488410e-03
317 KSP Residual norm 5.712087083553e-03
318 KSP Residual norm 5.707606315808e-03
319 KSP Residual norm 5.676289228117e-03
320 KSP Residual norm 5.638983301243e-03
321 KSP Residual norm 5.572742009517e-03
322 KSP Residual norm 5.486916236148e-03
323 KSP Residual norm 5.363130691547e-03
324 KSP Residual norm 5.264172950545e-03
325 KSP Residual norm 5.159483934042e-03
326 KSP Residual norm 5.087018890630e-03
327 KSP Residual norm 5.051621099686e-03
328 KSP Residual norm 5.022226978517e-03
329 KSP Residual norm 5.009693302385e-03
330 KSP Residual norm 4.995587088680e-03
331 KSP Residual norm 4.984005171897e-03
332 KSP Residual norm 4.965631751681e-03
333 KSP Residual norm 4.943022303916e-03
334 KSP Residual norm 4.912437291209e-03
335 KSP Residual norm 4.863252374359e-03
336 KSP Residual norm 4.786740757642e-03
337 KSP Residual norm 4.672277450951e-03
338 KSP Residual norm 4.540641032013e-03
339 KSP Residual norm 4.418500003959e-03
340 KSP Residual norm 4.301512182985e-03
341 KSP Residual norm 4.168907184322e-03
342 KSP Residual norm 4.033160938357e-03
343 KSP Residual norm 3.867191781838e-03
344 KSP Residual norm 3.721409167681e-03
345 KSP Residual norm 3.556386202244e-03
346 KSP Residual norm 3.365501963161e-03
347 KSP Residual norm 3.085023170277e-03
348 KSP Residual norm 2.783699371092e-03
349 KSP Residual norm 2.501859251092e-03
350 KSP Residual norm 2.335115925404e-03
351 KSP Residual norm 2.213077601007e-03
352 KSP Residual norm 2.112158046435e-03
353 KSP Residual norm 2.015212782694e-03
354 KSP Residual norm 1.921647641456e-03
355 KSP Residual norm 1.847060360217e-03
356 KSP Residual norm 1.796046691844e-03
357 KSP Residual norm 1.761488658540e-03
358 KSP Residual norm 1.731830078146e-03
359 KSP Residual norm 1.698722691838e-03
360 KSP Residual norm 1.653193001061e-03
361 KSP Residual norm 1.597041227116e-03
362 KSP Residual norm 1.535517323663e-03
363 KSP Residual norm 1.486882775757e-03
364 KSP Residual norm 1.445907704322e-03
365 KSP Residual norm 1.414834963836e-03
366 KSP Residual norm 1.386499811580e-03
367 KSP Residual norm 1.368133395281e-03
368 KSP Residual norm 1.354764032353e-03
369 KSP Residual norm 1.345499546054e-03
370 KSP Residual norm 1.334630652873e-03
371 KSP Residual norm 1.322675479046e-03
372 KSP Residual norm 1.308271168381e-03
373 KSP Residual norm 1.289084827283e-03
374 KSP Residual norm 1.265044687477e-03
375 KSP Residual norm 1.235592114417e-03
376 KSP Residual norm 1.210241281194e-03
377 KSP Residual norm 1.191268659617e-03
378 KSP Residual norm 1.179473987471e-03
379 KSP Residual norm 1.169202175105e-03
380 KSP Residual norm 1.155378315735e-03
381 KSP Residual norm 1.125754903783e-03
382 KSP Residual norm 1.063037787143e-03
383 KSP Residual norm 9.763442008759e-04
  type: gmres
  tolerances:  relative=2.10264e-08, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000012  0.2103E-05  0.0000E+00
  0 KSP Residual norm 4.646794731278e+04
  1 KSP Residual norm 3.162242104518e+04
  2 KSP Residual norm 2.266759974993e+04
  3 KSP Residual norm 1.760418161328e+04
  4 KSP Residual norm 1.299759456499e+04
  5 KSP Residual norm 9.645934799511e+03
  6 KSP Residual norm 6.543291138877e+03
  7 KSP Residual norm 4.115535418770e+03
  8 KSP Residual norm 2.254598850822e+03
  9 KSP Residual norm 1.263992408383e+03
 10 KSP Residual norm 8.900186868003e+02
 11 KSP Residual norm 6.980864777924e+02
 12 KSP Residual norm 5.307254274398e+02
 13 KSP Residual norm 4.512837930320e+02
 14 KSP Residual norm 3.659218722179e+02
 15 KSP Residual norm 3.024729982584e+02
 16 KSP Residual norm 2.506978794973e+02
 17 KSP Residual norm 2.202161209266e+02
 18 KSP Residual norm 1.961317965083e+02
 19 KSP Residual norm 1.790018637389e+02
 20 KSP Residual norm 1.602206958188e+02
 21 KSP Residual norm 1.442239708648e+02
 22 KSP Residual norm 1.308408305768e+02
 23 KSP Residual norm 1.214748382951e+02
 24 KSP Residual norm 1.121534128336e+02
 25 KSP Residual norm 1.031731837343e+02
 26 KSP Residual norm 9.423218782488e+01
 27 KSP Residual norm 8.567643081863e+01
 28 KSP Residual norm 7.965940258127e+01
 29 KSP Residual norm 7.537785631106e+01
 30 KSP Residual norm 7.202645258876e+01
 31 KSP Residual norm 6.920196875519e+01
 32 KSP Residual norm 6.616526975680e+01
 33 KSP Residual norm 6.336481610607e+01
 34 KSP Residual norm 6.088978194862e+01
 35 KSP Residual norm 5.861911725269e+01
 36 KSP Residual norm 5.591695634151e+01
 37 KSP Residual norm 5.311099510427e+01
 38 KSP Residual norm 5.076247366017e+01
 39 KSP Residual norm 4.836536072960e+01
 40 KSP Residual norm 4.529670726946e+01
 41 KSP Residual norm 4.221257706719e+01
 42 KSP Residual norm 3.833128568385e+01
 43 KSP Residual norm 3.429262665453e+01
 44 KSP Residual norm 3.020863604762e+01
 45 KSP Residual norm 2.696210181505e+01
 46 KSP Residual norm 2.359857617836e+01
 47 KSP Residual norm 2.061168111830e+01
 48 KSP Residual norm 1.843541926817e+01
 49 KSP Residual norm 1.719363099234e+01
 50 KSP Residual norm 1.635141682749e+01
 51 KSP Residual norm 1.590548782419e+01
 52 KSP Residual norm 1.565699103540e+01
 53 KSP Residual norm 1.550564714959e+01
 54 KSP Residual norm 1.541477176701e+01
 55 KSP Residual norm 1.536044346368e+01
 56 KSP Residual norm 1.527575954047e+01
 57 KSP Residual norm 1.517732089734e+01
 58 KSP Residual norm 1.506735928228e+01
 59 KSP Residual norm 1.489910639119e+01
 60 KSP Residual norm 1.460005344713e+01
 61 KSP Residual norm 1.412288055348e+01
 62 KSP Residual norm 1.340678988159e+01
 63 KSP Residual norm 1.247700217929e+01
 64 KSP Residual norm 1.142215577496e+01
 65 KSP Residual norm 9.961275149531e+00
 66 KSP Residual norm 8.481193969105e+00
 67 KSP Residual norm 7.206833614383e+00
 68 KSP Residual norm 6.383887850777e+00
 69 KSP Residual norm 5.832829192935e+00
 70 KSP Residual norm 5.432881766304e+00
 71 KSP Residual norm 5.146490570972e+00
 72 KSP Residual norm 4.887713492892e+00
 73 KSP Residual norm 4.681998668394e+00
 74 KSP Residual norm 4.509332268847e+00
 75 KSP Residual norm 4.395796267723e+00
 76 KSP Residual norm 4.318788462345e+00
 77 KSP Residual norm 4.258373628887e+00
 78 KSP Residual norm 4.199785516894e+00
 79 KSP Residual norm 4.130221800069e+00
 80 KSP Residual norm 4.046403437664e+00
 81 KSP Residual norm 3.936075986660e+00
 82 KSP Residual norm 3.789951875607e+00
 83 KSP Residual norm 3.608067643175e+00
 84 KSP Residual norm 3.399080523106e+00
 85 KSP Residual norm 3.202557155666e+00
 86 KSP Residual norm 3.026603967720e+00
 87 KSP Residual norm 2.882122496601e+00
 88 KSP Residual norm 2.751158514081e+00
 89 KSP Residual norm 2.639473500498e+00
 90 KSP Residual norm 2.534518757816e+00
 91 KSP Residual norm 2.407658320941e+00
 92 KSP Residual norm 2.266498909595e+00
 93 KSP Residual norm 2.135822273908e+00
 94 KSP Residual norm 2.037934903302e+00
 95 KSP Residual norm 1.958713491423e+00
 96 KSP Residual norm 1.888998697500e+00
 97 KSP Residual norm 1.834237384262e+00
 98 KSP Residual norm 1.780683405778e+00
 99 KSP Residual norm 1.720781738057e+00
100 KSP Residual norm 1.666545302354e+00
101 KSP Residual norm 1.666522006830e+00
102 KSP Residual norm 1.666511493137e+00
103 KSP Residual norm 1.666493832218e+00
104 KSP Residual norm 1.666473076755e+00
105 KSP Residual norm 1.666423645726e+00
106 KSP Residual norm 1.666382538012e+00
107 KSP Residual norm 1.666290004417e+00
108 KSP Residual norm 1.666246084513e+00
109 KSP Residual norm 1.666121651537e+00
110 KSP Residual norm 1.666065381803e+00
111 KSP Residual norm 1.666021347324e+00
112 KSP Residual norm 1.665908828020e+00
113 KSP Residual norm 1.665398445693e+00
114 KSP Residual norm 1.664930622420e+00
115 KSP Residual norm 1.662813337399e+00
116 KSP Residual norm 1.660541560196e+00
117 KSP Residual norm 1.655657800190e+00
118 KSP Residual norm 1.650582696885e+00
119 KSP Residual norm 1.641156295389e+00
120 KSP Residual norm 1.630523890853e+00
121 KSP Residual norm 1.611206675593e+00
122 KSP Residual norm 1.595972819254e+00
123 KSP Residual norm 1.580968184774e+00
124 KSP Residual norm 1.570320649375e+00
125 KSP Residual norm 1.556173590388e+00
126 KSP Residual norm 1.543421645531e+00
127 KSP Residual norm 1.527002175383e+00
128 KSP Residual norm 1.509121522465e+00
129 KSP Residual norm 1.488349919173e+00
130 KSP Residual norm 1.463922823656e+00
131 KSP Residual norm 1.429564305324e+00
132 KSP Residual norm 1.388347967095e+00
133 KSP Residual norm 1.338001853026e+00
134 KSP Residual norm 1.294020943409e+00
135 KSP Residual norm 1.257192528259e+00
136 KSP Residual norm 1.225719323868e+00
137 KSP Residual norm 1.197456800086e+00
138 KSP Residual norm 1.180027631404e+00
139 KSP Residual norm 1.169885209842e+00
140 KSP Residual norm 1.157718739879e+00
141 KSP Residual norm 1.137588603470e+00
142 KSP Residual norm 1.109485829113e+00
143 KSP Residual norm 1.069877927764e+00
144 KSP Residual norm 1.027992741492e+00
145 KSP Residual norm 9.838753707649e-01
146 KSP Residual norm 9.504905189103e-01
147 KSP Residual norm 9.238433515462e-01
148 KSP Residual norm 9.066579827439e-01
149 KSP Residual norm 8.962182914137e-01
150 KSP Residual norm 8.920057392198e-01
151 KSP Residual norm 8.899902877758e-01
152 KSP Residual norm 8.871145815306e-01
153 KSP Residual norm 8.774061487223e-01
154 KSP Residual norm 8.510175746773e-01
155 KSP Residual norm 8.020914882623e-01
156 KSP Residual norm 7.287954521432e-01
157 KSP Residual norm 6.432844005758e-01
158 KSP Residual norm 5.620240753090e-01
159 KSP Residual norm 4.854747542949e-01
160 KSP Residual norm 4.261007993652e-01
161 KSP Residual norm 3.854521951267e-01
162 KSP Residual norm 3.593983650577e-01
163 KSP Residual norm 3.406527607988e-01
164 KSP Residual norm 3.225969321442e-01
165 KSP Residual norm 3.024758161273e-01
166 KSP Residual norm 2.753041414007e-01
167 KSP Residual norm 2.496768504321e-01
168 KSP Residual norm 2.313733948186e-01
169 KSP Residual norm 2.187862029180e-01
170 KSP Residual norm 2.112095352924e-01
171 KSP Residual norm 2.081916374341e-01
172 KSP Residual norm 2.070813070073e-01
173 KSP Residual norm 2.064975124556e-01
174 KSP Residual norm 2.060108863621e-01
175 KSP Residual norm 2.046380957614e-01
176 KSP Residual norm 2.028966943621e-01
177 KSP Residual norm 2.002106693333e-01
178 KSP Residual norm 1.967844746642e-01
179 KSP Residual norm 1.927704154222e-01
180 KSP Residual norm 1.867313038672e-01
181 KSP Residual norm 1.776608527541e-01
182 KSP Residual norm 1.643830124161e-01
183 KSP Residual norm 1.495536716434e-01
184 KSP Residual norm 1.352590123680e-01
185 KSP Residual norm 1.229326164350e-01
186 KSP Residual norm 1.144215129681e-01
187 KSP Residual norm 1.082889702377e-01
188 KSP Residual norm 1.049011065164e-01
189 KSP Residual norm 1.031392752575e-01
190 KSP Residual norm 1.024946048600e-01
191 KSP Residual norm 1.022795332199e-01
192 KSP Residual norm 1.021270447570e-01
193 KSP Residual norm 1.019880656597e-01
194 KSP Residual norm 1.018186438994e-01
195 KSP Residual norm 1.016664509853e-01
196 KSP Residual norm 1.015879088706e-01
197 KSP Residual norm 1.014322940952e-01
198 KSP Residual norm 1.009553055733e-01
199 KSP Residual norm 9.916482572719e-02
200 KSP Residual norm 9.512342386941e-02
201 KSP Residual norm 9.511248325477e-02
202 KSP Residual norm 9.511103849526e-02
203 KSP Residual norm 9.510959103739e-02
204 KSP Residual norm 9.510905819151e-02
205 KSP Residual norm 9.510805412760e-02
206 KSP Residual norm 9.510640608740e-02
207 KSP Residual norm 9.510082034050e-02
208 KSP Residual norm 9.510079658877e-02
209 KSP Residual norm 9.509182851008e-02
210 KSP Residual norm 9.509082939911e-02
211 KSP Residual norm 9.508840735780e-02
212 KSP Residual norm 9.508440087119e-02
213 KSP Residual norm 9.505013905104e-02
214 KSP Residual norm 9.502598056332e-02
215 KSP Residual norm 9.486992426992e-02
216 KSP Residual norm 9.472761251821e-02
217 KSP Residual norm 9.435310083909e-02
218 KSP Residual norm 9.415021939905e-02
219 KSP Residual norm 9.356771856349e-02
220 KSP Residual norm 9.311458398468e-02
221 KSP Residual norm 9.219313590203e-02
222 KSP Residual norm 9.122081352849e-02
223 KSP Residual norm 8.990960779062e-02
224 KSP Residual norm 8.878228951961e-02
225 KSP Residual norm 8.688590759927e-02
226 KSP Residual norm 8.488895590805e-02
227 KSP Residual norm 8.201417932109e-02
228 KSP Residual norm 7.803474186097e-02
229 KSP Residual norm 7.416364318322e-02
230 KSP Residual norm 7.025184977968e-02
231 KSP Residual norm 6.682437208499e-02
232 KSP Residual norm 6.377701721370e-02
233 KSP Residual norm 6.152514736713e-02
234 KSP Residual norm 6.015877437983e-02
235 KSP Residual norm 5.938723196524e-02
236 KSP Residual norm 5.888980306932e-02
237 KSP Residual norm 5.847268850172e-02
238 KSP Residual norm 5.800226683014e-02
239 KSP Residual norm 5.738589338689e-02
240 KSP Residual norm 5.623434384786e-02
241 KSP Residual norm 5.451314298112e-02
242 KSP Residual norm 5.317767831461e-02
243 KSP Residual norm 5.200082549237e-02
244 KSP Residual norm 5.136658926865e-02
245 KSP Residual norm 5.100199127167e-02
246 KSP Residual norm 5.085807254300e-02
247 KSP Residual norm 5.069440664953e-02
248 KSP Residual norm 5.052000746379e-02
249 KSP Residual norm 5.026470967770e-02
250 KSP Residual norm 4.986886326396e-02
251 KSP Residual norm 4.890299937499e-02
252 KSP Residual norm 4.698362078497e-02
253 KSP Residual norm 4.453901631550e-02
254 KSP Residual norm 4.226707084775e-02
255 KSP Residual norm 4.034300334185e-02
256 KSP Residual norm 3.826690444286e-02
257 KSP Residual norm 3.546399155642e-02
258 KSP Residual norm 3.152487139489e-02
259 KSP Residual norm 2.666615373973e-02
260 KSP Residual norm 2.273529749082e-02
261 KSP Residual norm 2.033031774416e-02
262 KSP Residual norm 1.911274616748e-02
263 KSP Residual norm 1.870185940863e-02
264 KSP Residual norm 1.859575804799e-02
265 KSP Residual norm 1.856972669256e-02
266 KSP Residual norm 1.855850234749e-02
267 KSP Residual norm 1.855332362484e-02
268 KSP Residual norm 1.854518944259e-02
269 KSP Residual norm 1.854261065721e-02
270 KSP Residual norm 1.854256832463e-02
271 KSP Residual norm 1.853627791637e-02
272 KSP Residual norm 1.853302020335e-02
273 KSP Residual norm 1.852603960906e-02
274 KSP Residual norm 1.842001652988e-02
275 KSP Residual norm 1.814923469822e-02
276 KSP Residual norm 1.766539189835e-02
277 KSP Residual norm 1.688959965275e-02
278 KSP Residual norm 1.582899452433e-02
279 KSP Residual norm 1.443286151646e-02
280 KSP Residual norm 1.276791138162e-02
281 KSP Residual norm 1.117910328389e-02
282 KSP Residual norm 9.945192398621e-03
283 KSP Residual norm 9.274722330789e-03
284 KSP Residual norm 8.947491273942e-03
285 KSP Residual norm 8.794462929387e-03
286 KSP Residual norm 8.693281164315e-03
287 KSP Residual norm 8.623684562087e-03
288 KSP Residual norm 8.539751270738e-03
289 KSP Residual norm 8.467385129320e-03
290 KSP Residual norm 8.354704923939e-03
291 KSP Residual norm 8.224247410752e-03
292 KSP Residual norm 8.055285339542e-03
293 KSP Residual norm 7.901654282735e-03
294 KSP Residual norm 7.736153001615e-03
295 KSP Residual norm 7.573325450255e-03
296 KSP Residual norm 7.275893170653e-03
297 KSP Residual norm 6.926429962956e-03
298 KSP Residual norm 6.455466141228e-03
299 KSP Residual norm 6.135933821795e-03
300 KSP Residual norm 5.815666338693e-03
301 KSP Residual norm 5.809130374282e-03
302 KSP Residual norm 5.803471533640e-03
303 KSP Residual norm 5.794771509496e-03
304 KSP Residual norm 5.789487508510e-03
305 KSP Residual norm 5.781309242740e-03
306 KSP Residual norm 5.776038138812e-03
307 KSP Residual norm 5.765396125330e-03
308 KSP Residual norm 5.761930813666e-03
309 KSP Residual norm 5.750312745072e-03
310 KSP Residual norm 5.748124141314e-03
311 KSP Residual norm 5.746537120795e-03
312 KSP Residual norm 5.746331630360e-03
313 KSP Residual norm 5.742676946322e-03
314 KSP Residual norm 5.742152064610e-03
315 KSP Residual norm 5.732223570720e-03
316 KSP Residual norm 5.730552189587e-03
317 KSP Residual norm 5.712038029083e-03
318 KSP Residual norm 5.707557159969e-03
319 KSP Residual norm 5.676236889977e-03
320 KSP Residual norm 5.638920820929e-03
321 KSP Residual norm 5.572669912271e-03
322 KSP Residual norm 5.486823306587e-03
323 KSP Residual norm 5.363016325985e-03
324 KSP Residual norm 5.264046821956e-03
325 KSP Residual norm 5.159363540733e-03
326 KSP Residual norm 5.086909662956e-03
327 KSP Residual norm 5.051526220793e-03
328 KSP Residual norm 5.022143193224e-03
329 KSP Residual norm 5.009617113449e-03
330 KSP Residual norm 4.995517097644e-03
331 KSP Residual norm 4.983940331292e-03
332 KSP Residual norm 4.965572839561e-03
333 KSP Residual norm 4.942970028556e-03
334 KSP Residual norm 4.912390369396e-03
335 KSP Residual norm 4.863206089647e-03
336 KSP Residual norm 4.786688659006e-03
337 KSP Residual norm 4.672213023382e-03
338 KSP Residual norm 4.540560084753e-03
339 KSP Residual norm 4.418401034658e-03
340 KSP Residual norm 4.301401892454e-03
341 KSP Residual norm 4.168790120742e-03
342 KSP Residual norm 4.033040098318e-03
343 KSP Residual norm 3.867066002873e-03
344 KSP Residual norm 3.721283767923e-03
345 KSP Residual norm 3.556259019987e-03
346 KSP Residual norm 3.365372845471e-03
347 KSP Residual norm 3.084897156456e-03
348 KSP Residual norm 2.783594984744e-03
349 KSP Residual norm 2.501786880130e-03
350 KSP Residual norm 2.335067791420e-03
351 KSP Residual norm 2.213045922261e-03
352 KSP Residual norm 2.112134354959e-03
353 KSP Residual norm 2.015185314019e-03
354 KSP Residual norm 1.921607887327e-03
355 KSP Residual norm 1.847008089694e-03
356 KSP Residual norm 1.795987920661e-03
357 KSP Residual norm 1.761428942028e-03
358 KSP Residual norm 1.731774056091e-03
359 KSP Residual norm 1.698674871035e-03
360 KSP Residual norm 1.653156894973e-03
361 KSP Residual norm 1.597017442915e-03
362 KSP Residual norm 1.535501845922e-03
363 KSP Residual norm 1.486869322257e-03
364 KSP Residual norm 1.445892831993e-03
365 KSP Residual norm 1.414816442941e-03
366 KSP Residual norm 1.386476306093e-03
367 KSP Residual norm 1.368105027367e-03
368 KSP Residual norm 1.354730645712e-03
369 KSP Residual norm 1.345461804246e-03
370 KSP Residual norm 1.334588721147e-03
371 KSP Residual norm 1.322630037734e-03
372 KSP Residual norm 1.308224169717e-03
373 KSP Residual norm 1.289038656360e-03
374 KSP Residual norm 1.265002144359e-03
375 KSP Residual norm 1.235554683894e-03
376 KSP Residual norm 1.210209450767e-03
377 KSP Residual norm 1.191241556973e-03
378 KSP Residual norm 1.179449565205e-03
379 KSP Residual norm 1.169178374947e-03
380 KSP Residual norm 1.155352854464e-03
381 KSP Residual norm 1.125723749533e-03
382 KSP Residual norm 1.062993527811e-03
383 KSP Residual norm 9.762876455431e-04
384 KSP Residual norm 8.716309045662e-04
385 KSP Residual norm 8.013198190313e-04
386 KSP Residual norm 7.590298588319e-04
387 KSP Residual norm 7.325493526081e-04
388 KSP Residual norm 7.092832495076e-04
389 KSP Residual norm 6.905482888929e-04
390 KSP Residual norm 6.651035332174e-04
391 KSP Residual norm 6.329192505908e-04
392 KSP Residual norm 5.934260255682e-04
393 KSP Residual norm 5.507211577125e-04
394 KSP Residual norm 5.189019973442e-04
395 KSP Residual norm 4.986106613015e-04
396 KSP Residual norm 4.859300702288e-04
397 KSP Residual norm 4.790237962945e-04
398 KSP Residual norm 4.753571936752e-04
399 KSP Residual norm 4.724859815474e-04
400 KSP Residual norm 4.702641411933e-04
401 KSP Residual norm 4.702579166046e-04
402 KSP Residual norm 4.702534659785e-04
403 KSP Residual norm 4.702525781263e-04
404 KSP Residual norm 4.702299514249e-04
405 KSP Residual norm 4.701596375520e-04
406 KSP Residual norm 4.700691125180e-04
407 KSP Residual norm 4.698943817501e-04
408 KSP Residual norm 4.697609274545e-04
409 KSP Residual norm 4.694146251088e-04
410 KSP Residual norm 4.689422028394e-04
411 KSP Residual norm 4.679409820991e-04
412 KSP Residual norm 4.659081767473e-04
413 KSP Residual norm 4.629674775264e-04
414 KSP Residual norm 4.605243382532e-04
415 KSP Residual norm 4.560441149686e-04
416 KSP Residual norm 4.513686394189e-04
417 KSP Residual norm 4.450436141934e-04
418 KSP Residual norm 4.404953743552e-04
419 KSP Residual norm 4.335300489375e-04
420 KSP Residual norm 4.264768336500e-04
421 KSP Residual norm 4.181313634857e-04
422 KSP Residual norm 4.089015109050e-04
423 KSP Residual norm 3.985765547747e-04
424 KSP Residual norm 3.864181772886e-04
425 KSP Residual norm 3.734937889570e-04
426 KSP Residual norm 3.635550581939e-04
427 KSP Residual norm 3.577463564334e-04
428 KSP Residual norm 3.555886330691e-04
429 KSP Residual norm 3.551496423876e-04
430 KSP Residual norm 3.550376898585e-04
431 KSP Residual norm 3.550369026011e-04
432 KSP Residual norm 3.550360644293e-04
433 KSP Residual norm 3.550360525119e-04
434 KSP Residual norm 3.550176246692e-04
435 KSP Residual norm 3.549902835946e-04
436 KSP Residual norm 3.549036707847e-04
437 KSP Residual norm 3.548071395013e-04
438 KSP Residual norm 3.545764041904e-04
439 KSP Residual norm 3.540769831233e-04
440 KSP Residual norm 3.530350156530e-04
441 KSP Residual norm 3.511736453965e-04
442 KSP Residual norm 3.487568430332e-04
443 KSP Residual norm 3.465785100421e-04
444 KSP Residual norm 3.449082826015e-04
445 KSP Residual norm 3.426375398689e-04
446 KSP Residual norm 3.395704495875e-04
447 KSP Residual norm 3.345017986412e-04
448 KSP Residual norm 3.289448827594e-04
449 KSP Residual norm 3.211778782644e-04
450 KSP Residual norm 3.124123987309e-04
451 KSP Residual norm 3.003492432774e-04
452 KSP Residual norm 2.839866872435e-04
453 KSP Residual norm 2.610213073183e-04
454 KSP Residual norm 2.329921788251e-04
  type: gmres
  tolerances:  relative=5.4108e-09, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000013  0.5411E-06  0.0000E+00
  0 KSP Residual norm 4.646794822626e+04
  1 KSP Residual norm 3.162242077343e+04
  2 KSP Residual norm 2.266759984161e+04
  3 KSP Residual norm 1.760418142042e+04
  4 KSP Residual norm 1.299759449042e+04
  5 KSP Residual norm 9.645934643032e+03
  6 KSP Residual norm 6.543290985433e+03
  7 KSP Residual norm 4.115535304728e+03
  8 KSP Residual norm 2.254598766890e+03
  9 KSP Residual norm 1.263992474215e+03
 10 KSP Residual norm 8.900187580860e+02
 11 KSP Residual norm 6.980865815692e+02
 12 KSP Residual norm 5.307254900605e+02
 13 KSP Residual norm 4.512838654665e+02
 14 KSP Residual norm 3.659219148356e+02
 15 KSP Residual norm 3.024730469541e+02
 16 KSP Residual norm 2.506979232056e+02
 17 KSP Residual norm 2.202161713121e+02
 18 KSP Residual norm 1.961318569785e+02
 19 KSP Residual norm 1.790019269757e+02
 20 KSP Residual norm 1.602207730064e+02
 21 KSP Residual norm 1.442240457485e+02
 22 KSP Residual norm 1.308409171066e+02
 23 KSP Residual norm 1.214749155682e+02
 24 KSP Residual norm 1.121534925634e+02
 25 KSP Residual norm 1.031732465118e+02
 26 KSP Residual norm 9.423224877402e+01
 27 KSP Residual norm 8.567647791972e+01
 28 KSP Residual norm 7.965945297625e+01
 29 KSP Residual norm 7.537790258719e+01
 30 KSP Residual norm 7.202650270462e+01
 31 KSP Residual norm 6.920201897717e+01
 32 KSP Residual norm 6.616532352887e+01
 33 KSP Residual norm 6.336487172875e+01
 34 KSP Residual norm 6.088983795357e+01
 35 KSP Residual norm 5.861917427246e+01
 36 KSP Residual norm 5.591701083299e+01
 37 KSP Residual norm 5.311104956787e+01
 38 KSP Residual norm 5.076252322962e+01
 39 KSP Residual norm 4.836540940484e+01
 40 KSP Residual norm 4.529674703769e+01
 41 KSP Residual norm 4.221261172536e+01
 42 KSP Residual norm 3.833130603276e+01
 43 KSP Residual norm 3.429263903662e+01
 44 KSP Residual norm 3.020863603026e+01
 45 KSP Residual norm 2.696209771691e+01
 46 KSP Residual norm 2.359856635093e+01
 47 KSP Residual norm 2.061167087891e+01
 48 KSP Residual norm 1.843540784797e+01
 49 KSP Residual norm 1.719362005583e+01
 50 KSP Residual norm 1.635140604746e+01
 51 KSP Residual norm 1.590547749463e+01
 52 KSP Residual norm 1.565698108399e+01
 53 KSP Residual norm 1.550563728058e+01
 54 KSP Residual norm 1.541476201591e+01
 55 KSP Residual norm 1.536043342096e+01
 56 KSP Residual norm 1.527574927660e+01
 57 KSP Residual norm 1.517730989565e+01
 58 KSP Residual norm 1.506734792655e+01
 59 KSP Residual norm 1.489909393503e+01
 60 KSP Residual norm 1.460004021110e+01
 61 KSP Residual norm 1.412286506854e+01
 62 KSP Residual norm 1.340677302184e+01
 63 KSP Residual norm 1.247698365546e+01
 64 KSP Residual norm 1.142213845447e+01
 65 KSP Residual norm 9.961260444371e+00
 66 KSP Residual norm 8.481183174203e+00
 67 KSP Residual norm 7.206825912256e+00
 68 KSP Residual norm 6.383882335656e+00
 69 KSP Residual norm 5.832825077366e+00
 70 KSP Residual norm 5.432878629735e+00
 71 KSP Residual norm 5.146488155495e+00
 72 KSP Residual norm 4.887711604292e+00
 73 KSP Residual norm 4.681997301782e+00
 74 KSP Residual norm 4.509331348025e+00
 75 KSP Residual norm 4.395795874463e+00
 76 KSP Residual norm 4.318788491415e+00
 77 KSP Residual norm 4.258374123525e+00
 78 KSP Residual norm 4.199786363435e+00
 79 KSP Residual norm 4.130223094419e+00
 80 KSP Residual norm 4.046405115872e+00
 81 KSP Residual norm 3.936078212201e+00
 82 KSP Residual norm 3.789954577019e+00
 83 KSP Residual norm 3.608070740542e+00
 84 KSP Residual norm 3.399083555797e+00
 85 KSP Residual norm 3.202559727621e+00
 86 KSP Residual norm 3.026605725927e+00
 87 KSP Residual norm 2.882123286308e+00
 88 KSP Residual norm 2.751158392625e+00
 89 KSP Residual norm 2.639472709867e+00
 90 KSP Residual norm 2.534517671218e+00
 91 KSP Residual norm 2.407657350916e+00
 92 KSP Residual norm 2.266498704105e+00
 93 KSP Residual norm 2.135823139858e+00
 94 KSP Residual norm 2.037936699132e+00
 95 KSP Residual norm 1.958715965927e+00
 96 KSP Residual norm 1.889001563270e+00
 97 KSP Residual norm 1.834240286215e+00
 98 KSP Residual norm 1.780686054485e+00
 99 KSP Residual norm 1.720783899532e+00
100 KSP Residual norm 1.666546951991e+00
101 KSP Residual norm 1.666523656538e+00
102 KSP Residual norm 1.666513142804e+00
103 KSP Residual norm 1.666495481830e+00
104 KSP Residual norm 1.666474726336e+00
105 KSP Residual norm 1.666425295299e+00
106 KSP Residual norm 1.666384187465e+00
107 KSP Residual norm 1.666291653481e+00
108 KSP Residual norm 1.666247733236e+00
109 KSP Residual norm 1.666123300155e+00
110 KSP Residual norm 1.666067030737e+00
111 KSP Residual norm 1.666022997006e+00
112 KSP Residual norm 1.665910480956e+00
113 KSP Residual norm 1.665400110612e+00
114 KSP Residual norm 1.664932302233e+00
115 KSP Residual norm 1.662815067298e+00
116 KSP Residual norm 1.660543343911e+00
117 KSP Residual norm 1.655659666809e+00
118 KSP Residual norm 1.650584641754e+00
119 KSP Residual norm 1.641158310720e+00
120 KSP Residual norm 1.630525923759e+00
121 KSP Residual norm 1.611208544210e+00
122 KSP Residual norm 1.595974417415e+00
123 KSP Residual norm 1.580969463350e+00
124 KSP Residual norm 1.570321748771e+00
125 KSP Residual norm 1.556174551208e+00
126 KSP Residual norm 1.543422627177e+00
127 KSP Residual norm 1.527003283546e+00
128 KSP Residual norm 1.509122951771e+00
129 KSP Residual norm 1.488351796101e+00
130 KSP Residual norm 1.463925324107e+00
131 KSP Residual norm 1.429567531261e+00
132 KSP Residual norm 1.388351856477e+00
133 KSP Residual norm 1.338006064598e+00
134 KSP Residual norm 1.294025110591e+00
135 KSP Residual norm 1.257196428534e+00
136 KSP Residual norm 1.225722851828e+00
137 KSP Residual norm 1.197459861941e+00
138 KSP Residual norm 1.180030332991e+00
139 KSP Residual norm 1.169887710661e+00
140 KSP Residual norm 1.157721092802e+00
141 KSP Residual norm 1.137590830867e+00
142 KSP Residual norm 1.109488020356e+00
143 KSP Residual norm 1.069880137654e+00
144 KSP Residual norm 1.027994943237e+00
145 KSP Residual norm 9.838774600292e-01
146 KSP Residual norm 9.504924320947e-01
147 KSP Residual norm 9.238450678655e-01
148 KSP Residual norm 9.066595527083e-01
149 KSP Residual norm 8.962197965563e-01
150 KSP Residual norm 8.920072654936e-01
151 KSP Residual norm 8.899918835355e-01
152 KSP Residual norm 8.871163348474e-01
153 KSP Residual norm 8.774082918160e-01
154 KSP Residual norm 8.510204229716e-01
155 KSP Residual norm 8.020950925204e-01
156 KSP Residual norm 7.287995168520e-01
157 KSP Residual norm 6.432885216051e-01
158 KSP Residual norm 5.620279655327e-01
159 KSP Residual norm 4.854781516386e-01
160 KSP Residual norm 4.261036315706e-01
161 KSP Residual norm 3.854545756085e-01
162 KSP Residual norm 3.594004435727e-01
163 KSP Residual norm 3.406546727197e-01
164 KSP Residual norm 3.225987218618e-01
165 KSP Residual norm 3.024774649764e-01
166 KSP Residual norm 2.753054760910e-01
167 KSP Residual norm 2.496777632655e-01
168 KSP Residual norm 2.313738843752e-01
169 KSP Residual norm 2.187863357620e-01
170 KSP Residual norm 2.112093992304e-01
171 KSP Residual norm 2.081913509559e-01
172 KSP Residual norm 2.070809454023e-01
173 KSP Residual norm 2.064971042050e-01
174 KSP Residual norm 2.060104489654e-01
175 KSP Residual norm 2.046376343042e-01
176 KSP Residual norm 2.028962425915e-01
177 KSP Residual norm 2.002102715976e-01
178 KSP Residual norm 1.967841901788e-01
179 KSP Residual norm 1.927703234186e-01
180 KSP Residual norm 1.867315322002e-01
181 KSP Residual norm 1.776615015520e-01
182 KSP Residual norm 1.643841092728e-01
183 KSP Residual norm 1.495549626484e-01
184 KSP Residual norm 1.352602271329e-01
185 KSP Residual norm 1.229335649576e-01
186 KSP Residual norm 1.144222074610e-01
187 KSP Residual norm 1.082894703145e-01
188 KSP Residual norm 1.049014913912e-01
189 KSP Residual norm 1.031395995602e-01
190 KSP Residual norm 1.024949013605e-01
191 KSP Residual norm 1.022798142870e-01
192 KSP Residual norm 1.021273104837e-01
193 KSP Residual norm 1.019883159157e-01
194 KSP Residual norm 1.018188800019e-01
195 KSP Residual norm 1.016666766870e-01
196 KSP Residual norm 1.015881280555e-01
197 KSP Residual norm 1.014325050613e-01
198 KSP Residual norm 1.009555057498e-01
199 KSP Residual norm 9.916500979184e-02
200 KSP Residual norm 9.512357698278e-02
201 KSP Residual norm 9.511263638783e-02
202 KSP Residual norm 9.511119162807e-02
203 KSP Residual norm 9.510974418328e-02
204 KSP Residual norm 9.510921134403e-02
205 KSP Residual norm 9.510820728151e-02
206 KSP Residual norm 9.510655923969e-02
207 KSP Residual norm 9.510097348854e-02
208 KSP Residual norm 9.510094973959e-02
209 KSP Residual norm 9.509198177705e-02
210 KSP Residual norm 9.509098268393e-02
211 KSP Residual norm 9.508856069439e-02
212 KSP Residual norm 9.508455427144e-02
213 KSP Residual norm 9.505029268519e-02
214 KSP Residual norm 9.502613444994e-02
215 KSP Residual norm 9.487007866844e-02
216 KSP Residual norm 9.472776655154e-02
217 KSP Residual norm 9.435325245714e-02
218 KSP Residual norm 9.415036666330e-02
219 KSP Residual norm 9.356785367004e-02
220 KSP Residual norm 9.311470491983e-02
221 KSP Residual norm 9.219322242883e-02
222 KSP Residual norm 9.122085790065e-02
223 KSP Residual norm 8.990959648900e-02
224 KSP Residual norm 8.878223615034e-02
225 KSP Residual norm 8.688581774085e-02
226 KSP Residual norm 8.488886828575e-02
227 KSP Residual norm 8.201413442023e-02
228 KSP Residual norm 7.803476694805e-02
229 KSP Residual norm 7.416369785251e-02
230 KSP Residual norm 7.025188096999e-02
231 KSP Residual norm 6.682434688549e-02
232 KSP Residual norm 6.377692127244e-02
233 KSP Residual norm 6.152498733933e-02
234 KSP Residual norm 6.015856249857e-02
235 KSP Residual norm 5.938697735965e-02
236 KSP Residual norm 5.888951009425e-02
237 KSP Residual norm 5.847235569041e-02
238 KSP Residual norm 5.800188816763e-02
239 KSP Residual norm 5.738546406416e-02
240 KSP Residual norm 5.623383204919e-02
241 KSP Residual norm 5.451251858027e-02
242 KSP Residual norm 5.317697585382e-02
243 KSP Residual norm 5.200006525184e-02
244 KSP Residual norm 5.136580418529e-02
245 KSP Residual norm 5.100119851935e-02
246 KSP Residual norm 5.085728322485e-02
247 KSP Residual norm 5.069362450273e-02
248 KSP Residual norm 5.051923627544e-02
249 KSP Residual norm 5.026395471778e-02
250 KSP Residual norm 4.986813166368e-02
251 KSP Residual norm 4.890230775916e-02
252 KSP Residual norm 4.698301115055e-02
253 KSP Residual norm 4.453852876078e-02
254 KSP Residual norm 4.226671954955e-02
255 KSP Residual norm 4.034279143119e-02
256 KSP Residual norm 3.826685223962e-02
257 KSP Residual norm 3.546410244985e-02
258 KSP Residual norm 3.152510292709e-02
259 KSP Residual norm 2.666643086336e-02
260 KSP Residual norm 2.273555055252e-02
261 KSP Residual norm 2.033053074492e-02
262 KSP Residual norm 1.911293418832e-02
263 KSP Residual norm 1.870204051412e-02
264 KSP Residual norm 1.859593883588e-02
265 KSP Residual norm 1.856990938526e-02
266 KSP Residual norm 1.855868777284e-02
267 KSP Residual norm 1.855351178386e-02
268 KSP Residual norm 1.854538206212e-02
269 KSP Residual norm 1.854280587239e-02
270 KSP Residual norm 1.854276387522e-02
271 KSP Residual norm 1.853646968542e-02
272 KSP Residual norm 1.853320979137e-02
273 KSP Residual norm 1.852623150851e-02
274 KSP Residual norm 1.842021417198e-02
275 KSP Residual norm 1.814943787886e-02
276 KSP Residual norm 1.766559867069e-02
277 KSP Residual norm 1.688980801928e-02
278 KSP Residual norm 1.582920024028e-02
279 KSP Residual norm 1.443305452771e-02
280 KSP Residual norm 1.276807126640e-02
281 KSP Residual norm 1.117920819147e-02
282 KSP Residual norm 9.945238622787e-03
283 KSP Residual norm 9.274731796559e-03
284 KSP Residual norm 8.947483194588e-03
285 KSP Residual norm 8.794447437306e-03
286 KSP Residual norm 8.693262653595e-03
287 KSP Residual norm 8.623664730161e-03
288 KSP Residual norm 8.539731384035e-03
289 KSP Residual norm 8.467365890416e-03
290 KSP Residual norm 8.354688380369e-03
291 KSP Residual norm 8.224235778388e-03
292 KSP Residual norm 8.055281629964e-03
293 KSP Residual norm 7.901660239048e-03
294 KSP Residual norm 7.736169545487e-03
295 KSP Residual norm 7.573351994412e-03
296 KSP Residual norm 7.275933026631e-03
297 KSP Residual norm 6.926479773868e-03
298 KSP Residual norm 6.455519149623e-03
299 KSP Residual norm 6.135977712406e-03
300 KSP Residual norm 5.815683635987e-03
301 KSP Residual norm 5.809146057896e-03
302 KSP Residual norm 5.803486088091e-03
303 KSP Residual norm 5.794784795152e-03
304 KSP Residual norm 5.789500414155e-03
305 KSP Residual norm 5.781321985995e-03
306 KSP Residual norm 5.776051285592e-03
307 KSP Residual norm 5.765409767218e-03
308 KSP Residual norm 5.761945549764e-03
309 KSP Residual norm 5.750328078829e-03
310 KSP Residual norm 5.748139885148e-03
311 KSP Residual norm 5.746553021969e-03
312 KSP Residual norm 5.746347387752e-03
313 KSP Residual norm 5.742692911091e-03
314 KSP Residual norm 5.742168080928e-03
315 KSP Residual norm 5.732239688621e-03
316 KSP Residual norm 5.730568468742e-03
317 KSP Residual norm 5.712053691009e-03
318 KSP Residual norm 5.707572724610e-03
319 KSP Residual norm 5.676251395237e-03
320 KSP Residual norm 5.638931585969e-03
321 KSP Residual norm 5.572677855676e-03
322 KSP Residual norm 5.486823689784e-03
323 KSP Residual norm 5.363008991929e-03
324 KSP Residual norm 5.264035290717e-03
325 KSP Residual norm 5.159355626463e-03
326 KSP Residual norm 5.086907490885e-03
327 KSP Residual norm 5.051530706858e-03
328 KSP Residual norm 5.022152659530e-03
329 KSP Residual norm 5.009629704330e-03
330 KSP Residual norm 4.995531904988e-03
331 KSP Residual norm 4.983956605585e-03
332 KSP Residual norm 4.965590223693e-03
333 KSP Residual norm 4.942988177863e-03
334 KSP Residual norm 4.912408143932e-03
335 KSP Residual norm 4.863220248506e-03
336 KSP Residual norm 4.786694913657e-03
337 KSP Residual norm 4.672207423334e-03
338 KSP Residual norm 4.540542662174e-03
339 KSP Residual norm 4.418374224038e-03
340 KSP Residual norm 4.301370761201e-03
341 KSP Residual norm 4.168757751072e-03
342 KSP Residual norm 4.033008065213e-03
343 KSP Residual norm 3.867033898002e-03
344 KSP Residual norm 3.721252934868e-03
345 KSP Residual norm 3.556227479583e-03
346 KSP Residual norm 3.365339316905e-03
347 KSP Residual norm 3.084862040616e-03
348 KSP Residual norm 2.783564675568e-03
349 KSP Residual norm 2.501765217511e-03
350 KSP Residual norm 2.335053894487e-03
351 KSP Residual norm 2.213037947705e-03
352 KSP Residual norm 2.112129091189e-03
353 KSP Residual norm 2.015177812051e-03
354 KSP Residual norm 1.921594629339e-03
355 KSP Residual norm 1.846988911408e-03
356 KSP Residual norm 1.795965282507e-03
357 KSP Residual norm 1.761405356393e-03
358 KSP Residual norm 1.731751697203e-03
359 KSP Residual norm 1.698655810878e-03
360 KSP Residual norm 1.653142854083e-03
361 KSP Residual norm 1.597008784353e-03
362 KSP Residual norm 1.535496824955e-03
363 KSP Residual norm 1.486865314880e-03
364 KSP Residual norm 1.445888537290e-03
365 KSP Residual norm 1.414811114092e-03
366 KSP Residual norm 1.386469693105e-03
367 KSP Residual norm 1.368097138167e-03
368 KSP Residual norm 1.354721317254e-03
369 KSP Residual norm 1.345451133476e-03
370 KSP Residual norm 1.334576782051e-03
371 KSP Residual norm 1.322617039752e-03
372 KSP Residual norm 1.308210823250e-03
373 KSP Residual norm 1.289025770705e-03
374 KSP Residual norm 1.264990586362e-03
375 KSP Residual norm 1.235544814977e-03
376 KSP Residual norm 1.210201337677e-03
377 KSP Residual norm 1.191234883376e-03
378 KSP Residual norm 1.179443636270e-03
379 KSP Residual norm 1.169172356530e-03
380 KSP Residual norm 1.155345744322e-03
381 KSP Residual norm 1.125713595538e-03
382 KSP Residual norm 1.062976637316e-03
383 KSP Residual norm 9.762641652374e-04
384 KSP Residual norm 8.716038682560e-04
385 KSP Residual norm 8.012962266541e-04
386 KSP Residual norm 7.590116849294e-04
387 KSP Residual norm 7.325360408237e-04
388 KSP Residual norm 7.092734657377e-04
389 KSP Residual norm 6.905408683972e-04
390 KSP Residual norm 6.650966259938e-04
391 KSP Residual norm 6.329106926544e-04
392 KSP Residual norm 5.934149712095e-04
393 KSP Residual norm 5.507080289724e-04
394 KSP Residual norm 5.188880043285e-04
395 KSP Residual norm 4.985962058471e-04
396 KSP Residual norm 4.859150223756e-04
397 KSP Residual norm 4.790086199191e-04
398 KSP Residual norm 4.753422113532e-04
399 KSP Residual norm 4.724714675948e-04
400 KSP Residual norm 4.702504240004e-04
401 KSP Residual norm 4.702442019163e-04
402 KSP Residual norm 4.702397512609e-04
403 KSP Residual norm 4.702388631292e-04
404 KSP Residual norm 4.702162416798e-04
405 KSP Residual norm 4.701459333256e-04
406 KSP Residual norm 4.700554170236e-04
407 KSP Residual norm 4.698807226304e-04
408 KSP Residual norm 4.697472896512e-04
409 KSP Residual norm 4.694010882714e-04
410 KSP Residual norm 4.689287553821e-04
411 KSP Residual norm 4.679276995809e-04
412 KSP Residual norm 4.658949482341e-04
413 KSP Residual norm 4.629542814226e-04
414 KSP Residual norm 4.605113028598e-04
415 KSP Residual norm 4.560316390586e-04
416 KSP Residual norm 4.513565949552e-04
417 KSP Residual norm 4.450321431784e-04
418 KSP Residual norm 4.404841558713e-04
419 KSP Residual norm 4.335194352888e-04
420 KSP Residual norm 4.264668885211e-04
421 KSP Residual norm 4.181214590158e-04
422 KSP Residual norm 4.088915918672e-04
423 KSP Residual norm 3.985660786171e-04
424 KSP Residual norm 3.864072783567e-04
425 KSP Residual norm 3.734820872173e-04
426 KSP Residual norm 3.635428937919e-04
427 KSP Residual norm 3.577334329466e-04
428 KSP Residual norm 3.555749555722e-04
429 KSP Residual norm 3.551356405094e-04
430 KSP Residual norm 3.550235148181e-04
431 KSP Residual norm 3.550227136427e-04
432 KSP Residual norm 3.550218592117e-04
433 KSP Residual norm 3.550218486085e-04
434 KSP Residual norm 3.550033870440e-04
435 KSP Residual norm 3.549760337811e-04
436 KSP Residual norm 3.548894167055e-04
437 KSP Residual norm 3.547929031145e-04
438 KSP Residual norm 3.545622399114e-04
439 KSP Residual norm 3.540630377786e-04
440 KSP Residual norm 3.530214586366e-04
441 KSP Residual norm 3.511606368326e-04
442 KSP Residual norm 3.487445502299e-04
443 KSP Residual norm 3.465666915659e-04
444 KSP Residual norm 3.448968636169e-04
445 KSP Residual norm 3.426265085719e-04
446 KSP Residual norm 3.395600026506e-04
447 KSP Residual norm 3.344920917956e-04
448 KSP Residual norm 3.289366319599e-04
449 KSP Residual norm 3.211722441080e-04
450 KSP Residual norm 3.124100821602e-04
451 KSP Residual norm 3.003489022678e-04
452 KSP Residual norm 2.839872899584e-04
453 KSP Residual norm 2.610230481486e-04
454 KSP Residual norm 2.329979888007e-04
455 KSP Residual norm 2.043883637229e-04
456 KSP Residual norm 1.811509203361e-04
457 KSP Residual norm 1.643766366681e-04
458 KSP Residual norm 1.527855154103e-04
459 KSP Residual norm 1.460844832408e-04
460 KSP Residual norm 1.426488168586e-04
461 KSP Residual norm 1.399609319481e-04
462 KSP Residual norm 1.373602625668e-04
463 KSP Residual norm 1.345857440613e-04
464 KSP Residual norm 1.316861516476e-04
465 KSP Residual norm 1.283131728679e-04
466 KSP Residual norm 1.249706287515e-04
467 KSP Residual norm 1.218939942205e-04
468 KSP Residual norm 1.193793955139e-04
469 KSP Residual norm 1.172323333536e-04
470 KSP Residual norm 1.148196506681e-04
471 KSP Residual norm 1.120629276565e-04
KSP Object:(coupledsolve_) 1 MPI processes
  type: gmres
    GMRES: restart=100, using Modified Gram-Schmidt Orthogonalization
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=2.42143e-09, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object:(coupledsolve_) 1 MPI processes
  type: ilu
    ILU: out-of-place factorization
    1 level of fill
    tolerance for zero pivot 2.22045e-14
    using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
    matrix ordering: natural
    factor fill ratio given 1, needed 2.44153
      Factored matrix follows:
        Mat Object:         1 MPI processes
          type: seqaij
          rows=8788000, cols=8788000
          package used to perform factorization: petsc
          total: nonzeros=3.56993e+08, allocated nonzeros=3.56993e+08
          total number of mallocs used during MatSetValues calls =0
            not using I-node routines
  linear system matrix = precond matrix:
    type: seqaij
    total: nonzeros=1.46217e+08, allocated nonzeros=1.46217e+08
 0000014  0.2421E-06  0.0000E+00
  Residual norms for coupledsolve_ solve.
  0 KSP Residual norm 4.646794810691e+04
  1 KSP Residual norm 3.162242075761e+04
  2 KSP Residual norm 2.266759983726e+04
  3 KSP Residual norm 1.760418141753e+04
  4 KSP Residual norm 1.299759449714e+04
  5 KSP Residual norm 9.645934642400e+03
  6 KSP Residual norm 6.543290988195e+03
  7 KSP Residual norm 4.115535306869e+03
  8 KSP Residual norm 2.254598778350e+03
  9 KSP Residual norm 1.263992493945e+03
 10 KSP Residual norm 8.900187831475e+02
 11 KSP Residual norm 6.980866059791e+02
 12 KSP Residual norm 5.307255116026e+02
 13 KSP Residual norm 4.512838836038e+02
 14 KSP Residual norm 3.659219299843e+02
 15 KSP Residual norm 3.024730598341e+02
 16 KSP Residual norm 2.506979349814e+02
 17 KSP Residual norm 2.202161829815e+02
 18 KSP Residual norm 1.961318690385e+02
 19 KSP Residual norm 1.790019398102e+02
 20 KSP Residual norm 1.602207865930e+02
 21 KSP Residual norm 1.442240604348e+02
 22 KSP Residual norm 1.308409321019e+02
 23 KSP Residual norm 1.214749304872e+02
 24 KSP Residual norm 1.121535063557e+02
 25 KSP Residual norm 1.031732593214e+02
 26 KSP Residual norm 9.423226016898e+01
 27 KSP Residual norm 8.567648909121e+01
 28 KSP Residual norm 7.965946410115e+01
 29 KSP Residual norm 7.537791446986e+01
 30 KSP Residual norm 7.202651510202e+01
 31 KSP Residual norm 6.920203229413e+01
 32 KSP Residual norm 6.616533744580e+01
 33 KSP Residual norm 6.336488635282e+01
 34 KSP Residual norm 6.088985273694e+01
 35 KSP Residual norm 5.861918915608e+01
 36 KSP Residual norm 5.591702541758e+01
 37 KSP Residual norm 5.311106371072e+01
 38 KSP Residual norm 5.076253667168e+01
 39 KSP Residual norm 4.836542178274e+01
 40 KSP Residual norm 4.529675757395e+01
 41 KSP Residual norm 4.221261972185e+01
 42 KSP Residual norm 3.833131069090e+01
 43 KSP Residual norm 3.429264042593e+01
 44 KSP Residual norm 3.020863469488e+01
 45 KSP Residual norm 2.696209461326e+01
 46 KSP Residual norm 2.359856230637e+01
 47 KSP Residual norm 2.061166657150e+01
 48 KSP Residual norm 1.843540363329e+01
 49 KSP Residual norm 1.719361592234e+01
 50 KSP Residual norm 1.635140219452e+01
 51 KSP Residual norm 1.590547386991e+01
 52 KSP Residual norm 1.565697761497e+01
 53 KSP Residual norm 1.550563387357e+01
 54 KSP Residual norm 1.541475864742e+01
 55 KSP Residual norm 1.536043001005e+01
 56 KSP Residual norm 1.527574578790e+01
 57 KSP Residual norm 1.517730630754e+01
 58 KSP Residual norm 1.506734423730e+01
 59 KSP Residual norm 1.489909005769e+01
 60 KSP Residual norm 1.460003611591e+01
 61 KSP Residual norm 1.412286059144e+01
 62 KSP Residual norm 1.340676807635e+01
 63 KSP Residual norm 1.247697836334e+01
 64 KSP Residual norm 1.142213318359e+01
 65 KSP Residual norm 9.961255438204e+00
 66 KSP Residual norm 8.481178586570e+00
 67 KSP Residual norm 7.206821619221e+00
 68 KSP Residual norm 6.383878391759e+00
 69 KSP Residual norm 5.832821558498e+00
 70 KSP Residual norm 5.432875576703e+00
 71 KSP Residual norm 5.146485558122e+00
 72 KSP Residual norm 4.887709497378e+00
 73 KSP Residual norm 4.681995603370e+00
 74 KSP Residual norm 4.509330025672e+00
 75 KSP Residual norm 4.395794840334e+00
 76 KSP Residual norm 4.318787688289e+00
 77 KSP Residual norm 4.258373522003e+00
 78 KSP Residual norm 4.199785941638e+00
 79 KSP Residual norm 4.130222873727e+00
 80 KSP Residual norm 4.046405113141e+00
 81 KSP Residual norm 3.936078464802e+00
 82 KSP Residual norm 3.789955081463e+00
 83 KSP Residual norm 3.608071435774e+00
 84 KSP Residual norm 3.399084293504e+00
 85 KSP Residual norm 3.202560363586e+00
 86 KSP Residual norm 3.026606154748e+00
 87 KSP Residual norm 2.882123472968e+00
 88 KSP Residual norm 2.751158365072e+00
 89 KSP Residual norm 2.639472547185e+00
 90 KSP Residual norm 2.534517485730e+00
 91 KSP Residual norm 2.407657284280e+00
 92 KSP Residual norm 2.266498938600e+00
 93 KSP Residual norm 2.135823756718e+00
 94 KSP Residual norm 2.037937625809e+00
 95 KSP Residual norm 1.958717118067e+00
 96 KSP Residual norm 1.889002834876e+00
 97 KSP Residual norm 1.834241562542e+00
 98 KSP Residual norm 1.780687234093e+00
 99 KSP Residual norm 1.720784895351e+00
100 KSP Residual norm 1.666547741509e+00
101 KSP Residual norm 1.666524446025e+00
102 KSP Residual norm 1.666513932252e+00
103 KSP Residual norm 1.666496271222e+00
104 KSP Residual norm 1.666475515679e+00
105 KSP Residual norm 1.666426084569e+00
106 KSP Residual norm 1.666384976650e+00
107 KSP Residual norm 1.666292442454e+00
108 KSP Residual norm 1.666248522068e+00
109 KSP Residual norm 1.666124088842e+00
110 KSP Residual norm 1.666067819431e+00
111 KSP Residual norm 1.666023785908e+00
112 KSP Residual norm 1.665911270639e+00
113 KSP Residual norm 1.665400903213e+00
114 KSP Residual norm 1.664933098387e+00
115 KSP Residual norm 1.662815875229e+00
116 KSP Residual norm 1.660544163086e+00
117 KSP Residual norm 1.655660502538e+00
118 KSP Residual norm 1.650585489940e+00
119 KSP Residual norm 1.641159162737e+00
120 KSP Residual norm 1.630526756611e+00
121 KSP Residual norm 1.611209286575e+00
122 KSP Residual norm 1.595975040180e+00
123 KSP Residual norm 1.580969959292e+00
124 KSP Residual norm 1.570322169950e+00
125 KSP Residual norm 1.556174913393e+00
126 KSP Residual norm 1.543422986009e+00
127 KSP Residual norm 1.527003678615e+00
128 KSP Residual norm 1.509123453301e+00
129 KSP Residual norm 1.488352452639e+00
130 KSP Residual norm 1.463926200309e+00
131 KSP Residual norm 1.429568664926e+00
132 KSP Residual norm 1.388353224988e+00
133 KSP Residual norm 1.338007545801e+00
134 KSP Residual norm 1.294026572451e+00
135 KSP Residual norm 1.257197786726e+00
136 KSP Residual norm 1.225724065108e+00
137 KSP Residual norm 1.197460892123e+00
138 KSP Residual norm 1.180031223617e+00
139 KSP Residual norm 1.169888523316e+00
140 KSP Residual norm 1.157721847695e+00
141 KSP Residual norm 1.137591536124e+00
142 KSP Residual norm 1.109488712008e+00
143 KSP Residual norm 1.069880849650e+00
144 KSP Residual norm 1.027995689890e+00
145 KSP Residual norm 9.838782250260e-01
146 KSP Residual norm 9.504931872701e-01
147 KSP Residual norm 9.238457984743e-01
148 KSP Residual norm 9.066602524981e-01
149 KSP Residual norm 8.962204739838e-01
150 KSP Residual norm 8.920079408034e-01
151 KSP Residual norm 8.899925704449e-01
152 KSP Residual norm 8.871170511077e-01
153 KSP Residual norm 8.774090851420e-01
154 KSP Residual norm 8.510213670927e-01
155 KSP Residual norm 8.020962052070e-01
156 KSP Residual norm 7.288007260549e-01
157 KSP Residual norm 6.432897269366e-01
158 KSP Residual norm 5.620290976014e-01
159 KSP Residual norm 4.854791425503e-01
160 KSP Residual norm 4.261044655838e-01
161 KSP Residual norm 3.854552902030e-01
162 KSP Residual norm 3.594010817075e-01
163 KSP Residual norm 3.406552700481e-01
164 KSP Residual norm 3.225992899331e-01
165 KSP Residual norm 3.024779973603e-01
166 KSP Residual norm 2.753059168495e-01
167 KSP Residual norm 2.496780747110e-01
168 KSP Residual norm 2.313740619370e-01
169 KSP Residual norm 2.187863961222e-01
170 KSP Residual norm 2.112093693900e-01
171 KSP Residual norm 2.081912701810e-01
172 KSP Residual norm 2.070808391910e-01
173 KSP Residual norm 2.064969824895e-01
174 KSP Residual norm 2.060103174300e-01
175 KSP Residual norm 2.046374935573e-01
176 KSP Residual norm 2.028961032415e-01
177 KSP Residual norm 2.002101464764e-01
178 KSP Residual norm 1.967840971492e-01
179 KSP Residual norm 1.927702854852e-01
180 KSP Residual norm 1.867315884746e-01
181 KSP Residual norm 1.776616859760e-01
182 KSP Residual norm 1.643844380850e-01
183 KSP Residual norm 1.495553614517e-01
184 KSP Residual norm 1.352606113439e-01
185 KSP Residual norm 1.229338709486e-01
186 KSP Residual norm 1.144224341323e-01
187 KSP Residual norm 1.082896348414e-01
188 KSP Residual norm 1.049016189933e-01
189 KSP Residual norm 1.031397081841e-01
190 KSP Residual norm 1.024950019179e-01
191 KSP Residual norm 1.022799109141e-01
192 KSP Residual norm 1.021274036252e-01
193 KSP Residual norm 1.019884057480e-01
194 KSP Residual norm 1.018189669410e-01
195 KSP Residual norm 1.016667615568e-01
196 KSP Residual norm 1.015882116213e-01
197 KSP Residual norm 1.014325868938e-01
198 KSP Residual norm 1.009555851518e-01
199 KSP Residual norm 9.916508450329e-02
200 KSP Residual norm 9.512363998600e-02
201 KSP Residual norm 9.511269937225e-02
202 KSP Residual norm 9.511125460601e-02
203 KSP Residual norm 9.510980715868e-02
204 KSP Residual norm 9.510927431938e-02
205 KSP Residual norm 9.510827025568e-02
206 KSP Residual norm 9.510662221392e-02
207 KSP Residual norm 9.510103645969e-02
208 KSP Residual norm 9.510101271187e-02
209 KSP Residual norm 9.509204477214e-02
210 KSP Residual norm 9.509104568254e-02
211 KSP Residual norm 9.508862370566e-02
212 KSP Residual norm 9.508461729726e-02
213 KSP Residual norm 9.505035574463e-02
214 KSP Residual norm 9.502619756294e-02
215 KSP Residual norm 9.487014180223e-02
216 KSP Residual norm 9.472782946844e-02
217 KSP Residual norm 9.435331438293e-02
218 KSP Residual norm 9.415042732283e-02
219 KSP Residual norm 9.356791090739e-02
220 KSP Residual norm 9.311475849175e-02
221 KSP Residual norm 9.219326719359e-02
222 KSP Residual norm 9.122089187296e-02
223 KSP Residual norm 8.990961608637e-02
224 KSP Residual norm 8.878224474434e-02
225 KSP Residual norm 8.688581595611e-02
226 KSP Residual norm 8.488886503277e-02
227 KSP Residual norm 8.201413767821e-02
228 KSP Residual norm 7.803478069870e-02
229 KSP Residual norm 7.416371267022e-02
230 KSP Residual norm 7.025188664633e-02
231 KSP Residual norm 6.682434007888e-02
232 KSP Residual norm 6.377690154012e-02
233 KSP Residual norm 6.152495703153e-02
234 KSP Residual norm 6.015852321817e-02
235 KSP Residual norm 5.938693002418e-02
236 KSP Residual norm 5.888945489824e-02
237 KSP Residual norm 5.847229168462e-02
238 KSP Residual norm 5.800181326437e-02
239 KSP Residual norm 5.738537648091e-02
240 KSP Residual norm 5.623372330132e-02
241 KSP Residual norm 5.451238039824e-02
242 KSP Residual norm 5.317681700245e-02
243 KSP Residual norm 5.199989138181e-02
244 KSP Residual norm 5.136562467978e-02
245 KSP Residual norm 5.100101829002e-02
246 KSP Residual norm 5.085710505038e-02
247 KSP Residual norm 5.069344997416e-02
248 KSP Residual norm 5.051906659675e-02
249 KSP Residual norm 5.026379117139e-02
250 KSP Residual norm 4.986797540495e-02
251 KSP Residual norm 4.890216163225e-02
252 KSP Residual norm 4.698288152440e-02
253 KSP Residual norm 4.453842173030e-02
254 KSP Residual norm 4.226663865825e-02
255 KSP Residual norm 4.034273933076e-02
256 KSP Residual norm 3.826683519246e-02
257 KSP Residual norm 3.546412355480e-02
258 KSP Residual norm 3.152515422767e-02
259 KSP Residual norm 2.666649589111e-02
260 KSP Residual norm 2.273561318108e-02
261 KSP Residual norm 2.033058636919e-02
262 KSP Residual norm 1.911298513974e-02
263 KSP Residual norm 1.870209036244e-02
264 KSP Residual norm 1.859598888377e-02
265 KSP Residual norm 1.856996004328e-02
266 KSP Residual norm 1.855873921750e-02
267 KSP Residual norm 1.855356398188e-02
268 KSP Residual norm 1.854543545982e-02
269 KSP Residual norm 1.854285995895e-02
270 KSP Residual norm 1.854281804937e-02
271 KSP Residual norm 1.853652288942e-02
272 KSP Residual norm 1.853326245045e-02
273 KSP Residual norm 1.852628472766e-02
274 KSP Residual norm 1.842026872696e-02
275 KSP Residual norm 1.814949376584e-02
276 KSP Residual norm 1.766565542352e-02
277 KSP Residual norm 1.688986514795e-02
278 KSP Residual norm 1.582925629649e-02
279 KSP Residual norm 1.443310622619e-02
280 KSP Residual norm 1.276811308283e-02
281 KSP Residual norm 1.117923508808e-02
282 KSP Residual norm 9.945250354564e-03
283 KSP Residual norm 9.274734482235e-03
284 KSP Residual norm 8.947481829721e-03
285 KSP Residual norm 8.794444600849e-03
286 KSP Residual norm 8.693259428721e-03
287 KSP Residual norm 8.623661497136e-03
288 KSP Residual norm 8.539728449687e-03
289 KSP Residual norm 8.467363352760e-03
290 KSP Residual norm 8.354686695037e-03
291 KSP Residual norm 8.224235408159e-03
292 KSP Residual norm 8.055283155129e-03
293 KSP Residual norm 7.901663955282e-03
294 KSP Residual norm 7.736175520138e-03
295 KSP Residual norm 7.573360103243e-03
296 KSP Residual norm 7.275943927412e-03
297 KSP Residual norm 6.926492953090e-03
298 KSP Residual norm 6.455533246443e-03
299 KSP Residual norm 6.135990305827e-03
300 KSP Residual norm 5.815690583724e-03
301 KSP Residual norm 5.809152629618e-03
302 KSP Residual norm 5.803492395627e-03
303 KSP Residual norm 5.794790802164e-03
304 KSP Residual norm 5.789506330147e-03
305 KSP Residual norm 5.781327854368e-03
306 KSP Residual norm 5.776057239817e-03
307 KSP Residual norm 5.765415815221e-03
308 KSP Residual norm 5.761951834111e-03
309 KSP Residual norm 5.750334446552e-03
310 KSP Residual norm 5.748146325205e-03
311 KSP Residual norm 5.746559479322e-03
312 KSP Residual norm 5.746353820849e-03
313 KSP Residual norm 5.742699345674e-03
314 KSP Residual norm 5.742174512041e-03
315 KSP Residual norm 5.732246080288e-03
316 KSP Residual norm 5.730574880264e-03
317 KSP Residual norm 5.712059936522e-03
318 KSP Residual norm 5.707578948264e-03
319 KSP Residual norm 5.676257411415e-03
320 KSP Residual norm 5.638936819304e-03
321 KSP Residual norm 5.572682586723e-03
322 KSP Residual norm 5.486826842445e-03
323 KSP Residual norm 5.363010543759e-03
324 KSP Residual norm 5.264036004148e-03
325 KSP Residual norm 5.159357348633e-03
326 KSP Residual norm 5.086910701296e-03
327 KSP Residual norm 5.051535547500e-03
328 KSP Residual norm 5.022158695710e-03
329 KSP Residual norm 5.009636465614e-03
330 KSP Residual norm 4.995539141414e-03
331 KSP Residual norm 4.983964108461e-03
332 KSP Residual norm 4.965597835405e-03
333 KSP Residual norm 4.942995754939e-03
334 KSP Residual norm 4.912415347661e-03
335 KSP Residual norm 4.863226213769e-03
336 KSP Residual norm 4.786698474513e-03
337 KSP Residual norm 4.672207559890e-03
338 KSP Residual norm 4.540539583071e-03
339 KSP Residual norm 4.418368827383e-03
340 KSP Residual norm 4.301364458880e-03
341 KSP Residual norm 4.168751433557e-03
342 KSP Residual norm 4.033002137488e-03
343 KSP Residual norm 3.867028284959e-03
344 KSP Residual norm 3.721247815503e-03
345 KSP Residual norm 3.556222267004e-03
346 KSP Residual norm 3.365333558372e-03
347 KSP Residual norm 3.084855662912e-03
348 KSP Residual norm 2.783559072230e-03
349 KSP Residual norm 2.501761321000e-03
350 KSP Residual norm 2.335051700362e-03
351 KSP Residual norm 2.213037125387e-03
352 KSP Residual norm 2.112128898680e-03
353 KSP Residual norm 2.015177068780e-03
354 KSP Residual norm 1.921592494891e-03
355 KSP Residual norm 1.846985309803e-03
356 KSP Residual norm 1.795960768872e-03
357 KSP Residual norm 1.761400523236e-03
358 KSP Residual norm 1.731747073136e-03
359 KSP Residual norm 1.698651887652e-03
360 KSP Residual norm 1.653140049924e-03
361 KSP Residual norm 1.597007193699e-03
362 KSP Residual norm 1.535496047114e-03
363 KSP Residual norm 1.486864751207e-03
364 KSP Residual norm 1.445887903275e-03
365 KSP Residual norm 1.414810259573e-03
366 KSP Residual norm 1.386468592605e-03
367 KSP Residual norm 1.368095797393e-03
368 KSP Residual norm 1.354719697465e-03
369 KSP Residual norm 1.345449245927e-03
370 KSP Residual norm 1.334574645450e-03
371 KSP Residual norm 1.322614697314e-03
372 KSP Residual norm 1.308208428381e-03
373 KSP Residual norm 1.289023494425e-03
374 KSP Residual norm 1.264988604541e-03
375 KSP Residual norm 1.235543199360e-03
376 KSP Residual norm 1.210200100254e-03
377 KSP Residual norm 1.191233959455e-03
378 KSP Residual norm 1.179442872209e-03
379 KSP Residual norm 1.169171556271e-03
380 KSP Residual norm 1.155344659783e-03
381 KSP Residual norm 1.125711734362e-03
382 KSP Residual norm 1.062973061923e-03
383 KSP Residual norm 9.762588906071e-04
384 KSP Residual norm 8.715976322063e-04
385 KSP Residual norm 8.012907725167e-04
386 KSP Residual norm 7.590075280667e-04
387 KSP Residual norm 7.325330604107e-04
388 KSP Residual norm 7.092713404573e-04
389 KSP Residual norm 6.905393205645e-04
390 KSP Residual norm 6.650952132692e-04
391 KSP Residual norm 6.329088933802e-04
392 KSP Residual norm 5.934125703047e-04
393 KSP Residual norm 5.507050911113e-04
394 KSP Residual norm 5.188848130310e-04
395 KSP Residual norm 4.985928665174e-04
396 KSP Residual norm 4.859115220543e-04
397 KSP Residual norm 4.790050823536e-04
398 KSP Residual norm 4.753387230773e-04
399 KSP Residual norm 4.724681005677e-04
400 KSP Residual norm 4.702472628809e-04
401 KSP Residual norm 4.702410414784e-04
402 KSP Residual norm 4.702365908185e-04
403 KSP Residual norm 4.702357025969e-04
404 KSP Residual norm 4.702130823616e-04
405 KSP Residual norm 4.701427754872e-04
406 KSP Residual norm 4.700522615340e-04
407 KSP Residual norm 4.698775763982e-04
408 KSP Residual norm 4.697441484206e-04
409 KSP Residual norm 4.693979701890e-04
410 KSP Residual norm 4.689256564867e-04
411 KSP Residual norm 4.679246358983e-04
412 KSP Residual norm 4.658918884626e-04
413 KSP Residual norm 4.629512249622e-04
414 KSP Residual norm 4.605082857274e-04
415 KSP Residual norm 4.560287612790e-04
416 KSP Residual norm 4.513538217795e-04
417 KSP Residual norm 4.450295091477e-04
418 KSP Residual norm 4.404815834668e-04
419 KSP Residual norm 4.335170152215e-04
420 KSP Residual norm 4.264646317886e-04
421 KSP Residual norm 4.181191977349e-04
422 KSP Residual norm 4.088892967807e-04
423 KSP Residual norm 3.985636049611e-04
424 KSP Residual norm 3.864046420567e-04
425 KSP Residual norm 3.734792076123e-04
426 KSP Residual norm 3.635398919625e-04
427 KSP Residual norm 3.577302611420e-04
428 KSP Residual norm 3.555716139671e-04
429 KSP Residual norm 3.551322255585e-04
430 KSP Residual norm 3.550200597119e-04
431 KSP Residual norm 3.550192551964e-04
432 KSP Residual norm 3.550183967314e-04
433 KSP Residual norm 3.550183864539e-04
434 KSP Residual norm 3.549999153823e-04
435 KSP Residual norm 3.549725570512e-04
436 KSP Residual norm 3.548859346539e-04
437 KSP Residual norm 3.547894212027e-04
438 KSP Residual norm 3.545587714835e-04
439 KSP Residual norm 3.540596213996e-04
440 KSP Residual norm 3.530181415334e-04
441 KSP Residual norm 3.511574671087e-04
442 KSP Residual norm 3.487415811318e-04
443 KSP Residual norm 3.465638702458e-04
444 KSP Residual norm 3.448941735613e-04
445 KSP Residual norm 3.426239551630e-04
446 KSP Residual norm 3.395576418709e-04
447 KSP Residual norm 3.344899652857e-04
448 KSP Residual norm 3.289348942811e-04
449 KSP Residual norm 3.211711509651e-04
450 KSP Residual norm 3.124097804007e-04
451 KSP Residual norm 3.003490411097e-04
452 KSP Residual norm 2.839876088999e-04
453 KSP Residual norm 2.610235867574e-04
454 KSP Residual norm 2.329994531450e-04
455 KSP Residual norm 2.043909809151e-04
456 KSP Residual norm 1.811539138107e-04
457 KSP Residual norm 1.643791291553e-04
458 KSP Residual norm 1.527871243231e-04
459 KSP Residual norm 1.460853545617e-04
460 KSP Residual norm 1.426492657245e-04
461 KSP Residual norm 1.399611387208e-04
462 KSP Residual norm 1.373603159317e-04
463 KSP Residual norm 1.345857583069e-04
464 KSP Residual norm 1.316861856642e-04
465 KSP Residual norm 1.283133419902e-04
466 KSP Residual norm 1.249709793605e-04
467 KSP Residual norm 1.218945425499e-04
468 KSP Residual norm 1.193800265417e-04
469 KSP Residual norm 1.172329156101e-04
470 KSP Residual norm 1.148200174082e-04
471 KSP Residual norm 1.120629726159e-04
472 KSP Residual norm 1.091118129848e-04
473 KSP Residual norm 1.061725614793e-04
474 KSP Residual norm 1.033153656826e-04
475 KSP Residual norm 1.005018109536e-04
476 KSP Residual norm 9.646565792756e-05
477 KSP Residual norm 9.020951231770e-05
478 KSP Residual norm 8.296762926069e-05
479 KSP Residual norm 7.593618510068e-05
480 KSP Residual norm 7.097572660506e-05
481 KSP Residual norm 6.732987174641e-05
482 KSP Residual norm 6.412880276792e-05
483 KSP Residual norm 6.167793404088e-05
484 KSP Residual norm 6.035778814743e-05
485 KSP Residual norm 5.960656188693e-05
486 KSP Residual norm 5.899064558115e-05
487 KSP Residual norm 5.827127982777e-05
488 KSP Residual norm 5.813772750608e-05
489 KSP Residual norm 5.810336099034e-05
490 KSP Residual norm 5.803721683450e-05
491 KSP Residual norm 5.778784731204e-05
492 KSP Residual norm 5.734565431260e-05
493 KSP Residual norm 5.645647836154e-05
494 KSP Residual norm 5.434940735722e-05
495 KSP Residual norm 5.040606975969e-05
496 KSP Residual norm 4.552604078033e-05
497 KSP Residual norm 4.244123530600e-05
498 KSP Residual norm 3.980419532993e-05
499 KSP Residual norm 3.804071829180e-05
500 KSP Residual norm 3.666594738094e-05
501 KSP Residual norm 3.664637051487e-05
502 KSP Residual norm 3.664377567650e-05
503 KSP Residual norm 3.663032470292e-05
504 KSP Residual norm 3.662738424657e-05
505 KSP Residual norm 3.657511123991e-05
506 KSP Residual norm 3.652168542525e-05
507 KSP Residual norm 3.640554719656e-05
508 KSP Residual norm 3.625587635226e-05
509 KSP Residual norm 3.601156273871e-05
510 KSP Residual norm 3.589038227556e-05
511 KSP Residual norm 3.580921879189e-05
  type: gmres
  tolerances:  relative=7.71289e-10, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000015  0.7713E-07  0.0000E+00
  0 KSP Residual norm 4.646794820899e+04
  1 KSP Residual norm 3.162242076737e+04
  2 KSP Residual norm 2.266759987827e+04
  3 KSP Residual norm 1.760418141741e+04
  4 KSP Residual norm 1.299759449795e+04
  5 KSP Residual norm 9.645934629749e+03
  6 KSP Residual norm 6.543290973422e+03
  7 KSP Residual norm 4.115535296707e+03
  8 KSP Residual norm 2.254598774104e+03
  9 KSP Residual norm 1.263992507458e+03
 10 KSP Residual norm 8.900187992408e+02
 11 KSP Residual norm 6.980866268682e+02
 12 KSP Residual norm 5.307255288249e+02
 13 KSP Residual norm 4.512839010567e+02
 14 KSP Residual norm 3.659219422601e+02
 15 KSP Residual norm 3.024730703737e+02
 16 KSP Residual norm 2.506979426991e+02
 17 KSP Residual norm 2.202161894880e+02
 18 KSP Residual norm 1.961318752240e+02
 19 KSP Residual norm 1.790019453230e+02
 20 KSP Residual norm 1.602207929459e+02
 21 KSP Residual norm 1.442240663618e+02
 22 KSP Residual norm 1.308409395461e+02
 23 KSP Residual norm 1.214749373733e+02
 24 KSP Residual norm 1.121535142813e+02
 25 KSP Residual norm 1.031732663136e+02
 26 KSP Residual norm 9.423226807834e+01
 27 KSP Residual norm 8.567649654448e+01
 28 KSP Residual norm 7.965947268645e+01
 29 KSP Residual norm 7.537792309374e+01
 30 KSP Residual norm 7.202652449618e+01
 31 KSP Residual norm 6.920204188935e+01
 32 KSP Residual norm 6.616534761933e+01
 33 KSP Residual norm 6.336489685963e+01
 34 KSP Residual norm 6.088986346481e+01
 35 KSP Residual norm 5.861920017382e+01
 36 KSP Residual norm 5.591703639485e+01
 37 KSP Residual norm 5.311107475454e+01
 38 KSP Residual norm 5.076254698594e+01
 39 KSP Residual norm 4.836543147442e+01
 40 KSP Residual norm 4.529676540526e+01
 41 KSP Residual norm 4.221262587245e+01
 42 KSP Residual norm 3.833131373392e+01
 43 KSP Residual norm 3.429264120656e+01
 44 KSP Residual norm 3.020863307889e+01
 45 KSP Residual norm 2.696209206379e+01
 46 KSP Residual norm 2.359855888159e+01
 47 KSP Residual norm 2.061166319364e+01
 48 KSP Residual norm 1.843540039459e+01
 49 KSP Residual norm 1.719361305322e+01
 50 KSP Residual norm 1.635139961358e+01
 51 KSP Residual norm 1.590547156595e+01
 52 KSP Residual norm 1.565697549896e+01
 53 KSP Residual norm 1.550563184332e+01
 54 KSP Residual norm 1.541475665628e+01
 55 KSP Residual norm 1.536042800080e+01
 56 KSP Residual norm 1.527574375082e+01
 57 KSP Residual norm 1.517730416740e+01
 58 KSP Residual norm 1.506734202036e+01
 59 KSP Residual norm 1.489908764776e+01
 60 KSP Residual norm 1.460003346776e+01
 61 KSP Residual norm 1.412285748193e+01
 62 KSP Residual norm 1.340676458921e+01
 63 KSP Residual norm 1.247697451702e+01
 64 KSP Residual norm 1.142212946011e+01
 65 KSP Residual norm 9.961252075805e+00
 66 KSP Residual norm 8.481175718201e+00
 67 KSP Residual norm 7.206819103175e+00
 68 KSP Residual norm 6.383876179541e+00
 69 KSP Residual norm 5.832819615006e+00
 70 KSP Residual norm 5.432873907996e+00
 71 KSP Residual norm 5.146484146324e+00
 72 KSP Residual norm 4.887708341839e+00
 73 KSP Residual norm 4.681994675563e+00
 74 KSP Residual norm 4.509329296295e+00
 75 KSP Residual norm 4.395794276130e+00
 76 KSP Residual norm 4.318787253012e+00
 77 KSP Residual norm 4.258373205363e+00
 78 KSP Residual norm 4.199785724010e+00
 79 KSP Residual norm 4.130222774285e+00
 80 KSP Residual norm 4.046405133887e+00
 81 KSP Residual norm 3.936078645839e+00
 82 KSP Residual norm 3.789955420792e+00
 83 KSP Residual norm 3.608071911567e+00
 84 KSP Residual norm 3.399084809541e+00
 85 KSP Residual norm 3.202560820748e+00
 86 KSP Residual norm 3.026606474824e+00
 87 KSP Residual norm 2.882123626323e+00
 88 KSP Residual norm 2.751158368300e+00
 89 KSP Residual norm 2.639472452003e+00
 90 KSP Residual norm 2.534517366302e+00
 91 KSP Residual norm 2.407657234227e+00
 92 KSP Residual norm 2.266499085399e+00
 93 KSP Residual norm 2.135824151210e+00
 94 KSP Residual norm 2.037938220478e+00
 95 KSP Residual norm 1.958717852318e+00
 96 KSP Residual norm 1.889003641921e+00
 97 KSP Residual norm 1.834242367736e+00
 98 KSP Residual norm 1.780687975558e+00
 99 KSP Residual norm 1.720785519730e+00
100 KSP Residual norm 1.666548235620e+00
101 KSP Residual norm 1.666524940135e+00
102 KSP Residual norm 1.666514426342e+00
103 KSP Residual norm 1.666496765281e+00
104 KSP Residual norm 1.666476009713e+00
105 KSP Residual norm 1.666426578570e+00
106 KSP Residual norm 1.666385470610e+00
107 KSP Residual norm 1.666292936289e+00
108 KSP Residual norm 1.666249015817e+00
109 KSP Residual norm 1.666124582511e+00
110 KSP Residual norm 1.666068313142e+00
111 KSP Residual norm 1.666024279764e+00
112 KSP Residual norm 1.665911765170e+00
113 KSP Residual norm 1.665401400090e+00
114 KSP Residual norm 1.664933598256e+00
115 KSP Residual norm 1.662816384738e+00
116 KSP Residual norm 1.660544682643e+00
117 KSP Residual norm 1.655661036668e+00
118 KSP Residual norm 1.650586037021e+00
119 KSP Residual norm 1.641159717532e+00
120 KSP Residual norm 1.630527305334e+00
121 KSP Residual norm 1.611209780143e+00
122 KSP Residual norm 1.595975456969e+00
123 KSP Residual norm 1.580970290601e+00
124 KSP Residual norm 1.570322452493e+00
125 KSP Residual norm 1.556175156915e+00
126 KSP Residual norm 1.543423229669e+00
127 KSP Residual norm 1.527003948263e+00
128 KSP Residual norm 1.509123796585e+00
129 KSP Residual norm 1.488352901634e+00
130 KSP Residual norm 1.463926797764e+00
131 KSP Residual norm 1.429569435243e+00
132 KSP Residual norm 1.388354150635e+00
133 KSP Residual norm 1.338008540021e+00
134 KSP Residual norm 1.294027544802e+00
135 KSP Residual norm 1.257198684139e+00
136 KSP Residual norm 1.225724862325e+00
137 KSP Residual norm 1.197461568428e+00
138 KSP Residual norm 1.180031810001e+00
139 KSP Residual norm 1.169889062148e+00
140 KSP Residual norm 1.157722353867e+00
141 KSP Residual norm 1.137592017324e+00
142 KSP Residual norm 1.109489192043e+00
143 KSP Residual norm 1.069881349467e+00
144 KSP Residual norm 1.027996212098e+00
145 KSP Residual norm 9.838787526692e-01
146 KSP Residual norm 9.504937002617e-01
147 KSP Residual norm 9.238462867868e-01
148 KSP Residual norm 9.066607148063e-01
149 KSP Residual norm 8.962209185061e-01
150 KSP Residual norm 8.920083838305e-01
151 KSP Residual norm 8.899930225962e-01
152 KSP Residual norm 8.871175275252e-01
153 KSP Residual norm 8.774096256709e-01
154 KSP Residual norm 8.510220318430e-01
155 KSP Residual norm 8.020970089755e-01
156 KSP Residual norm 7.288016156249e-01
157 KSP Residual norm 6.432906268503e-01
158 KSP Residual norm 5.620299536321e-01
159 KSP Residual norm 4.854799041426e-01
160 KSP Residual norm 4.261051186962e-01
161 KSP Residual norm 3.854558583944e-01
162 KSP Residual norm 3.594015924885e-01
163 KSP Residual norm 3.406557474513e-01
164 KSP Residual norm 3.225997398989e-01
165 KSP Residual norm 3.024784131243e-01
166 KSP Residual norm 2.753062559938e-01
167 KSP Residual norm 2.496783119768e-01
168 KSP Residual norm 2.313741977446e-01
169 KSP Residual norm 2.187864466343e-01
170 KSP Residual norm 2.112093555882e-01
171 KSP Residual norm 2.081912204893e-01
172 KSP Residual norm 2.070807718406e-01
173 KSP Residual norm 2.064969044019e-01
174 KSP Residual norm 2.060102327457e-01
175 KSP Residual norm 2.046374033842e-01
176 KSP Residual norm 2.028960156085e-01
177 KSP Residual norm 2.002100716468e-01
178 KSP Residual norm 1.967840485581e-01
179 KSP Residual norm 1.927702800414e-01
180 KSP Residual norm 1.867316538947e-01
181 KSP Residual norm 1.776618442764e-01
182 KSP Residual norm 1.643846963201e-01
183 KSP Residual norm 1.495556635578e-01
184 KSP Residual norm 1.352608966176e-01
185 KSP Residual norm 1.229340952173e-01
186 KSP Residual norm 1.144225979608e-01
187 KSP Residual norm 1.082897505083e-01
188 KSP Residual norm 1.049017051345e-01
189 KSP Residual norm 1.031397784489e-01
190 KSP Residual norm 1.024950652316e-01
191 KSP Residual norm 1.022799709701e-01
192 KSP Residual norm 1.021274610510e-01
193 KSP Residual norm 1.019884609121e-01
194 KSP Residual norm 1.018190203156e-01
195 KSP Residual norm 1.016668138214e-01
196 KSP Residual norm 1.015882632672e-01
197 KSP Residual norm 1.014326378376e-01
198 KSP Residual norm 1.009556354161e-01
199 KSP Residual norm 9.916513392061e-02
200 KSP Residual norm 9.512368538380e-02
201 KSP Residual norm 9.511274478236e-02
202 KSP Residual norm 9.511130001611e-02
203 KSP Residual norm 9.510985257092e-02
204 KSP Residual norm 9.510931973258e-02
205 KSP Residual norm 9.510831566974e-02
206 KSP Residual norm 9.510666762985e-02
207 KSP Residual norm 9.510108188183e-02
208 KSP Residual norm 9.510105813453e-02
209 KSP Residual norm 9.509209022090e-02
210 KSP Residual norm 9.509109113343e-02
211 KSP Residual norm 9.508866916632e-02
212 KSP Residual norm 9.508466276696e-02
213 KSP Residual norm 9.505040127082e-02
214 KSP Residual norm 9.502624314039e-02
215 KSP Residual norm 9.487018755074e-02
216 KSP Residual norm 9.472787517931e-02
217 KSP Residual norm 9.435335979333e-02
218 KSP Residual norm 9.415047197756e-02
219 KSP Residual norm 9.356795364966e-02
220 KSP Residual norm 9.311479898934e-02
221 KSP Residual norm 9.219330203039e-02
222 KSP Residual norm 9.122091980114e-02
223 KSP Residual norm 8.990963482712e-02
224 KSP Residual norm 8.878225650886e-02
225 KSP Residual norm 8.688582159444e-02
226 KSP Residual norm 8.488887073618e-02
227 KSP Residual norm 8.201414912578e-02
228 KSP Residual norm 7.803480100034e-02
229 KSP Residual norm 7.416373475897e-02
230 KSP Residual norm 7.025190233864e-02
231 KSP Residual norm 6.682434550799e-02
232 KSP Residual norm 6.377689492521e-02
233 KSP Residual norm 6.152493963587e-02
234 KSP Residual norm 6.015849670484e-02
235 KSP Residual norm 5.938689591366e-02
236 KSP Residual norm 5.888941363968e-02
237 KSP Residual norm 5.847224274652e-02
238 KSP Residual norm 5.800175520498e-02
239 KSP Residual norm 5.738530826903e-02
240 KSP Residual norm 5.623363890917e-02
241 KSP Residual norm 5.451227438244e-02
242 KSP Residual norm 5.317669641447e-02
243 KSP Residual norm 5.199976060994e-02
244 KSP Residual norm 5.136549006714e-02
245 KSP Residual norm 5.100088301516e-02
246 KSP Residual norm 5.085697096328e-02
247 KSP Residual norm 5.069331792919e-02
248 KSP Residual norm 5.051893730666e-02
249 KSP Residual norm 5.026366546374e-02
250 KSP Residual norm 4.986785419431e-02
251 KSP Residual norm 4.890204703365e-02
252 KSP Residual norm 4.698277898145e-02
253 KSP Residual norm 4.453833645345e-02
254 KSP Residual norm 4.226657387554e-02
255 KSP Residual norm 4.034269721906e-02
256 KSP Residual norm 3.826682067816e-02
257 KSP Residual norm 3.546413911587e-02
258 KSP Residual norm 3.152519390496e-02
259 KSP Residual norm 2.666654704666e-02
260 KSP Residual norm 2.273566358078e-02
261 KSP Residual norm 2.033063246893e-02
262 KSP Residual norm 1.911302837641e-02
263 KSP Residual norm 1.870213294628e-02
264 KSP Residual norm 1.859603156285e-02
265 KSP Residual norm 1.857000308512e-02
266 KSP Residual norm 1.855878275541e-02
267 KSP Residual norm 1.855360801823e-02
268 KSP Residual norm 1.854548031699e-02
269 KSP Residual norm 1.854290530044e-02
270 KSP Residual norm 1.854286345349e-02
271 KSP Residual norm 1.853656759117e-02
272 KSP Residual norm 1.853330675049e-02
273 KSP Residual norm 1.852632944725e-02
274 KSP Residual norm 1.842031450563e-02
275 KSP Residual norm 1.814954070685e-02
276 KSP Residual norm 1.766570334322e-02
277 KSP Residual norm 1.688991379841e-02
278 KSP Residual norm 1.582930449636e-02
279 KSP Residual norm 1.443315120077e-02
280 KSP Residual norm 1.276815012247e-02
281 KSP Residual norm 1.117926002092e-02
282 KSP Residual norm 9.945262873317e-03
283 KSP Residual norm 9.274739395188e-03
284 KSP Residual norm 8.947483109571e-03
285 KSP Residual norm 8.794444387642e-03
286 KSP Residual norm 8.693258663739e-03
287 KSP Residual norm 8.623660557605e-03
288 KSP Residual norm 8.539727623879e-03
289 KSP Residual norm 8.467362753673e-03
290 KSP Residual norm 8.354686690725e-03
291 KSP Residual norm 8.224236311532e-03
292 KSP Residual norm 8.055285312143e-03
293 KSP Residual norm 7.901667464033e-03
294 KSP Residual norm 7.736180366841e-03
295 KSP Residual norm 7.573366107019e-03
296 KSP Residual norm 7.275951435176e-03
297 KSP Residual norm 6.926501460936e-03
298 KSP Residual norm 6.455541889207e-03
299 KSP Residual norm 6.135997568996e-03
300 KSP Residual norm 5.815693925701e-03
301 KSP Residual norm 5.809155730512e-03
302 KSP Residual norm 5.803495329190e-03
303 KSP Residual norm 5.794793550803e-03
304 KSP Residual norm 5.789509029071e-03
305 KSP Residual norm 5.781330542567e-03
306 KSP Residual norm 5.776060001268e-03
307 KSP Residual norm 5.765418674138e-03
308 KSP Residual norm 5.761954871014e-03
309 KSP Residual norm 5.750337588762e-03
310 KSP Residual norm 5.748149532079e-03
311 KSP Residual norm 5.746562707840e-03
312 KSP Residual norm 5.746357030764e-03
313 KSP Residual norm 5.742702573484e-03
314 KSP Residual norm 5.742177743093e-03
315 KSP Residual norm 5.732249311250e-03
316 KSP Residual norm 5.730578133999e-03
317 KSP Residual norm 5.712063107531e-03
318 KSP Residual norm 5.707582112662e-03
319 KSP Residual norm 5.676260458741e-03
320 KSP Residual norm 5.638939374706e-03
321 KSP Residual norm 5.572684845222e-03
322 KSP Residual norm 5.486828117123e-03
323 KSP Residual norm 5.363010856193e-03
324 KSP Residual norm 5.264035858141e-03
325 KSP Residual norm 5.159357930698e-03
326 KSP Residual norm 5.086912300173e-03
327 KSP Residual norm 5.051538230249e-03
328 KSP Residual norm 5.022162172143e-03
329 KSP Residual norm 5.009640426937e-03
330 KSP Residual norm 4.995543436341e-03
331 KSP Residual norm 4.983968600309e-03
332 KSP Residual norm 4.965602450619e-03
333 KSP Residual norm 4.943000408421e-03
334 KSP Residual norm 4.912419833617e-03
335 KSP Residual norm 4.863229988401e-03
336 KSP Residual norm 4.786700790944e-03
337 KSP Residual norm 4.672207708803e-03
338 KSP Residual norm 4.540537562900e-03
339 KSP Residual norm 4.418365115806e-03
340 KSP Residual norm 4.301359916666e-03
341 KSP Residual norm 4.168746636443e-03
342 KSP Residual norm 4.032997409484e-03
343 KSP Residual norm 3.867023623556e-03
344 KSP Residual norm 3.721243438578e-03
345 KSP Residual norm 3.556217889989e-03
346 KSP Residual norm 3.365328979174e-03
347 KSP Residual norm 3.084850936862e-03
348 KSP Residual norm 2.783555190338e-03
349 KSP Residual norm 2.501758951534e-03
350 KSP Residual norm 2.335050694541e-03
351 KSP Residual norm 2.213037167897e-03
352 KSP Residual norm 2.112129476653e-03
353 KSP Residual norm 2.015177394061e-03
354 KSP Residual norm 1.921591985140e-03
355 KSP Residual norm 1.846983886427e-03
356 KSP Residual norm 1.795958774742e-03
357 KSP Residual norm 1.761398316338e-03
358 KSP Residual norm 1.731744971419e-03
359 KSP Residual norm 1.698650181272e-03
360 KSP Residual norm 1.653138967081e-03
361 KSP Residual norm 1.597006768280e-03
362 KSP Residual norm 1.535496011728e-03
363 KSP Residual norm 1.486864749479e-03
364 KSP Residual norm 1.445887762864e-03
365 KSP Residual norm 1.414809899524e-03
366 KSP Residual norm 1.386467990980e-03
367 KSP Residual norm 1.368094978496e-03
368 KSP Residual norm 1.354718649627e-03
369 KSP Residual norm 1.345447991354e-03
370 KSP Residual norm 1.334573194482e-03
371 KSP Residual norm 1.322613081527e-03
372 KSP Residual norm 1.308206752593e-03
373 KSP Residual norm 1.289021877704e-03
374 KSP Residual norm 1.264987183561e-03
375 KSP Residual norm 1.235542045425e-03
376 KSP Residual norm 1.210199245792e-03
377 KSP Residual norm 1.191233370185e-03
378 KSP Residual norm 1.179442432859e-03
379 KSP Residual norm 1.169171129665e-03
380 KSP Residual norm 1.155344075758e-03
381 KSP Residual norm 1.125710666196e-03
382 KSP Residual norm 1.062970903900e-03
383 KSP Residual norm 9.762556633214e-04
384 KSP Residual norm 8.715938325298e-04
385 KSP Residual norm 8.012875105018e-04
386 KSP Residual norm 7.590051160232e-04
387 KSP Residual norm 7.325314113980e-04
388 KSP Residual norm 7.092702403806e-04
389 KSP Residual norm 6.905385804323e-04
390 KSP Residual norm 6.650945416878e-04
391 KSP Residual norm 6.329079460675e-04
392 KSP Residual norm 5.934111947678e-04
393 KSP Residual norm 5.507033384615e-04
394 KSP Residual norm 5.188828726111e-04
395 KSP Residual norm 4.985908057612e-04
396 KSP Residual norm 4.859093362318e-04
397 KSP Residual norm 4.790028538432e-04
398 KSP Residual norm 4.753365148561e-04
399 KSP Residual norm 4.724659632135e-04
400 KSP Residual norm 4.702452561267e-04
401 KSP Residual norm 4.702390351765e-04
402 KSP Residual norm 4.702345845105e-04
403 KSP Residual norm 4.702336962324e-04
404 KSP Residual norm 4.702110767488e-04
405 KSP Residual norm 4.701407708655e-04
406 KSP Residual norm 4.700502584088e-04
407 KSP Residual norm 4.698755792008e-04
408 KSP Residual norm 4.697421541860e-04
409 KSP Residual norm 4.693959896717e-04
410 KSP Residual norm 4.689236864800e-04
411 KSP Residual norm 4.679226852698e-04
412 KSP Residual norm 4.658899348373e-04
413 KSP Residual norm 4.629492696532e-04
414 KSP Residual norm 4.605063543842e-04
415 KSP Residual norm 4.560269176983e-04
416 KSP Residual norm 4.513520390475e-04
417 KSP Residual norm 4.450278080215e-04
418 KSP Residual norm 4.404799204991e-04
419 KSP Residual norm 4.335154571563e-04
420 KSP Residual norm 4.264631913032e-04
421 KSP Residual norm 4.181177671534e-04
422 KSP Residual norm 4.088878546919e-04
423 KSP Residual norm 3.985620577737e-04
424 KSP Residual norm 3.864029984060e-04
425 KSP Residual norm 3.734774164136e-04
426 KSP Residual norm 3.635380328465e-04
427 KSP Residual norm 3.577283023425e-04
428 KSP Residual norm 3.555695534752e-04
429 KSP Residual norm 3.551301208574e-04
430 KSP Residual norm 3.550179308363e-04
431 KSP Residual norm 3.550171242782e-04
432 KSP Residual norm 3.550162633063e-04
433 KSP Residual norm 3.550162532351e-04
434 KSP Residual norm 3.549977756105e-04
435 KSP Residual norm 3.549704130061e-04
436 KSP Residual norm 3.548837850119e-04
437 KSP Residual norm 3.547872695997e-04
438 KSP Residual norm 3.545566260772e-04
439 KSP Residual norm 3.540575066932e-04
440 KSP Residual norm 3.530160856286e-04
441 KSP Residual norm 3.511554954001e-04
442 KSP Residual norm 3.487397180877e-04
443 KSP Residual norm 3.465620800106e-04
444 KSP Residual norm 3.448924457216e-04
445 KSP Residual norm 3.426222866913e-04
446 KSP Residual norm 3.395560600771e-04
447 KSP Residual norm 3.344884923351e-04
448 KSP Residual norm 3.289336439103e-04
449 KSP Residual norm 3.211703064033e-04
450 KSP Residual norm 3.124094462207e-04
451 KSP Residual norm 3.003489954096e-04
452 KSP Residual norm 2.839876696933e-04
453 KSP Residual norm 2.610237808449e-04
454 KSP Residual norm 2.330002634976e-04
455 KSP Residual norm 2.043925900147e-04
456 KSP Residual norm 1.811558179928e-04
457 KSP Residual norm 1.643807313360e-04
458 KSP Residual norm 1.527881498162e-04
459 KSP Residual norm 1.460858908095e-04
460 KSP Residual norm 1.426495199025e-04
461 KSP Residual norm 1.399612283907e-04
462 KSP Residual norm 1.373602999485e-04
463 KSP Residual norm 1.345857091568e-04
464 KSP Residual norm 1.316861427335e-04
465 KSP Residual norm 1.283133793096e-04
466 KSP Residual norm 1.249711324232e-04
467 KSP Residual norm 1.218948259787e-04
468 KSP Residual norm 1.193803696279e-04
469 KSP Residual norm 1.172332341933e-04
470 KSP Residual norm 1.148202045262e-04
471 KSP Residual norm 1.120629586644e-04
472 KSP Residual norm 1.091116441167e-04
473 KSP Residual norm 1.061723050322e-04
474 KSP Residual norm 1.033150688044e-04
475 KSP Residual norm 1.005014880236e-04
476 KSP Residual norm 9.646535630483e-05
477 KSP Residual norm 9.020933738294e-05
478 KSP Residual norm 8.296759033794e-05
479 KSP Residual norm 7.593625966553e-05
480 KSP Residual norm 7.097578933365e-05
481 KSP Residual norm 6.732988998414e-05
482 KSP Residual norm 6.412873790041e-05
483 KSP Residual norm 6.167786833766e-05
484 KSP Residual norm 6.035769984769e-05
485 KSP Residual norm 5.960644103590e-05
486 KSP Residual norm 5.899046838854e-05
487 KSP Residual norm 5.827107803373e-05
488 KSP Residual norm 5.813751844255e-05
489 KSP Residual norm 5.810315799590e-05
490 KSP Residual norm 5.803702209937e-05
491 KSP Residual norm 5.778769091719e-05
492 KSP Residual norm 5.734554115354e-05
493 KSP Residual norm 5.645638974202e-05
494 KSP Residual norm 5.434934669677e-05
495 KSP Residual norm 5.040611056136e-05
496 KSP Residual norm 4.552620049061e-05
497 KSP Residual norm 4.244133017525e-05
498 KSP Residual norm 3.980423557742e-05
499 KSP Residual norm 3.804067673840e-05
500 KSP Residual norm 3.666583472557e-05
501 KSP Residual norm 3.664625757887e-05
502 KSP Residual norm 3.664366300196e-05
503 KSP Residual norm 3.663021288051e-05
504 KSP Residual norm 3.662727247821e-05
505 KSP Residual norm 3.657499867291e-05
506 KSP Residual norm 3.652156888548e-05
507 KSP Residual norm 3.640542016812e-05
508 KSP Residual norm 3.625574112310e-05
509 KSP Residual norm 3.601141808469e-05
510 KSP Residual norm 3.589023724195e-05
511 KSP Residual norm 3.580907281057e-05
512 KSP Residual norm 3.578919639818e-05
513 KSP Residual norm 3.564505339443e-05
514 KSP Residual norm 3.555880752915e-05
515 KSP Residual norm 3.539369911404e-05
516 KSP Residual norm 3.522870124460e-05
517 KSP Residual norm 3.505167799097e-05
518 KSP Residual norm 3.486732506700e-05
519 KSP Residual norm 3.447155992189e-05
520 KSP Residual norm 3.368541633781e-05
521 KSP Residual norm 3.241794908384e-05
522 KSP Residual norm 3.071082769022e-05
523 KSP Residual norm 2.887798403104e-05
524 KSP Residual norm 2.732422721810e-05
525 KSP Residual norm 2.626683896557e-05
526 KSP Residual norm 2.553182411319e-05
527 KSP Residual norm 2.500000821245e-05
528 KSP Residual norm 2.473966089595e-05
529 KSP Residual norm 2.462914628294e-05
530 KSP Residual norm 2.457423894088e-05
531 KSP Residual norm 2.451837664784e-05
532 KSP Residual norm 2.437998317263e-05
533 KSP Residual norm 2.415824026520e-05
534 KSP Residual norm 2.394728366071e-05
535 KSP Residual norm 2.373648130184e-05
536 KSP Residual norm 2.353235724776e-05
537 KSP Residual norm 2.335112025751e-05
538 KSP Residual norm 2.324328002623e-05
539 KSP Residual norm 2.316336537669e-05
540 KSP Residual norm 2.306013033500e-05
541 KSP Residual norm 2.292513301106e-05
542 KSP Residual norm 2.272089490802e-05
543 KSP Residual norm 2.241217075528e-05
544 KSP Residual norm 2.199495432613e-05
545 KSP Residual norm 2.153388199436e-05
546 KSP Residual norm 2.108236140818e-05
547 KSP Residual norm 2.063720513125e-05
548 KSP Residual norm 2.020755800710e-05
549 KSP Residual norm 1.977765172809e-05
550 KSP Residual norm 1.936173741585e-05
551 KSP Residual norm 1.883849999339e-05
552 KSP Residual norm 1.808110100702e-05
553 KSP Residual norm 1.677710817069e-05
554 KSP Residual norm 1.521036213774e-05
555 KSP Residual norm 1.374436968929e-05
  type: gmres
  tolerances:  relative=3.12126e-10, absolute=1e-50, divergence=10000
  type: ilu
    1 level of fill
          type: seqaij
    type: seqaij
 0000016  0.3121E-07  0.0000E+00
  0 KSP Residual norm 4.646794820121e+04
  1 KSP Residual norm 3.162242077295e+04
  2 KSP Residual norm 2.266759988501e+04
  3 KSP Residual norm 1.760418142308e+04
  4 KSP Residual norm 1.299759450213e+04
  5 KSP Residual norm 9.645934632692e+03
  6 KSP Residual norm 6.543290976185e+03
  7 KSP Residual norm 4.115535299190e+03
  8 KSP Residual norm 2.254598776897e+03
  9 KSP Residual norm 1.263992510339e+03
 10 KSP Residual norm 8.900188030816e+02
 11 KSP Residual norm 6.980866318235e+02
 12 KSP Residual norm 5.307255349302e+02
 13 KSP Residual norm 4.512839074387e+02
 14 KSP Residual norm 3.659219482847e+02
 15 KSP Residual norm 3.024730757817e+02
 16 KSP Residual norm 2.506979472260e+02
 17 KSP Residual norm 2.202161931302e+02
 18 KSP Residual norm 1.961318778407e+02
 19 KSP Residual norm 1.790019470572e+02
 20 KSP Residual norm 1.602207935481e+02
 21 KSP Residual norm 1.442240661885e+02
 22 KSP Residual norm 1.308409388208e+02
 23 KSP Residual norm 1.214749365150e+02
 24 KSP Residual norm 1.121535134198e+02
 25 KSP Residual norm 1.031732657430e+02
 26 KSP Residual norm 9.423226787189e+01
 27 KSP Residual norm 8.567649691696e+01
 28 KSP Residual norm 7.965947346121e+01
 29 KSP Residual norm 7.537792423036e+01
 30 KSP Residual norm 7.202652583670e+01
 31 KSP Residual norm 6.920204343174e+01
 32 KSP Residual norm 6.616534931960e+01
 33 KSP Residual norm 6.336489874026e+01
 34 KSP Residual norm 6.088986545116e+01
 35 KSP Residual norm 5.861920225904e+01
 36 KSP Residual norm 5.591703853556e+01
 37 KSP Residual norm 5.311107690712e+01
 38 KSP Residual norm 5.076254906901e+01
 39 KSP Residual norm 4.836543340085e+01
 40 KSP Residual norm 4.529676702383e+01
 41 KSP Residual norm 4.221262705742e+01
 42 KSP Residual norm 3.833131434012e+01
 43 KSP Residual norm 3.429264127033e+01
 44 KSP Residual norm 3.020863270589e+01
 45 KSP Residual norm 2.696209139846e+01
 46 KSP Residual norm 2.359855804301e+01
 47 KSP Residual norm 2.061166229149e+01
 48 KSP Residual norm 1.843539950349e+01
 49 KSP Residual norm 1.719361218498e+01
 50 KSP Residual norm 1.635139880498e+01
 51 KSP Residual norm 1.590547081364e+01
 52 KSP Residual norm 1.565697479183e+01
 53 KSP Residual norm 1.550563116215e+01
 54 KSP Residual norm 1.541475599507e+01
 55 KSP Residual norm 1.536042734626e+01
 56 KSP Residual norm 1.527574309808e+01
 57 KSP Residual norm 1.517730351007e+01
 58 KSP Residual norm 1.506734135824e+01
 59 KSP Residual norm 1.489908696943e+01
 60 KSP Residual norm 1.460003277175e+01
 61 KSP Residual norm 1.412285675200e+01
 62 KSP Residual norm 1.340676381237e+01
 63 KSP Residual norm 1.247697369631e+01
 64 KSP Residual norm 1.142212862306e+01
 65 KSP Residual norm 9.961251195833e+00
 66 KSP Residual norm 8.481174768037e+00
 67 KSP Residual norm 7.206818055059e+00
 68 KSP Residual norm 6.383875108463e+00
 69 KSP Residual norm 5.832818592797e+00
 70 KSP Residual norm 5.432872978840e+00
 71 KSP Residual norm 5.146483330802e+00
 72 KSP Residual norm 4.887707660868e+00
 73 KSP Residual norm 4.681994111614e+00
 74 KSP Residual norm 4.509328834763e+00
 75 KSP Residual norm 4.395793886939e+00
 76 KSP Residual norm 4.318786917182e+00
 77 KSP Residual norm 4.258372913662e+00
 78 KSP Residual norm 4.199785470681e+00
 79 KSP Residual norm 4.130222564846e+00
 80 KSP Residual norm 4.046404973517e+00
 81 KSP Residual norm 3.936078545267e+00
 82 KSP Residual norm 3.789955381440e+00
 83 KSP Residual norm 3.608071923332e+00
 84 KSP Residual norm 3.399084845196e+00
 85 KSP Residual norm 3.202560850738e+00
 86 KSP Residual norm 3.026606480568e+00
 87 KSP Residual norm 2.882123604494e+00
 88 KSP Residual norm 2.751158326935e+00
 89 KSP Residual norm 2.639472405167e+00
 90 KSP Residual norm 2.534517333109e+00
 91 KSP Residual norm 2.407657242197e+00
 92 KSP Residual norm 2.266499166310e+00
 93 KSP Residual norm 2.135824314991e+00
 94 KSP Residual norm 2.037938449027e+00
 95 KSP Residual norm 1.958718126866e+00
 96 KSP Residual norm 1.889003940158e+00
 97 KSP Residual norm 1.834242666046e+00
 98 KSP Residual norm 1.780688252567e+00
 99 KSP Residual norm 1.720785755618e+00
100 KSP Residual norm 1.666548422081e+00
101 KSP Residual norm 1.666525126573e+00
102 KSP Residual norm 1.666514612766e+00
103 KSP Residual norm 1.666496951685e+00
104 KSP Residual norm 1.666476196101e+00
105 KSP Residual norm 1.666426764930e+00
106 KSP Residual norm 1.666385656954e+00
107 KSP Residual norm 1.666293122578e+00
108 KSP Residual norm 1.666249202090e+00
109 KSP Residual norm 1.666124768731e+00
110 KSP Residual norm 1.666068499357e+00
111 KSP Residual norm 1.666024466004e+00
112 KSP Residual norm 1.665911951522e+00
113 KSP Residual norm 1.665401586714e+00
114 KSP Residual norm 1.664933785327e+00
115 KSP Residual norm 1.662816572848e+00
116 KSP Residual norm 1.660544871722e+00
117 KSP Residual norm 1.655661226319e+00
118 KSP Residual norm 1.650586226633e+00
119 KSP Residual norm 1.641159903328e+00
120 KSP Residual norm 1.630527482983e+00
121 KSP Residual norm 1.611209932633e+00
122 KSP Residual norm 1.595975581440e+00
123 KSP Residual norm 1.580970386495e+00
124 KSP Residual norm 1.570322531587e+00
125 KSP Residual norm 1.556175221818e+00
126 KSP Residual norm 1.543423292128e+00
127 KSP Residual norm 1.527004016369e+00
128 KSP Residual norm 1.509123885026e+00
129 KSP Residual norm 1.488353021083e+00
130 KSP Residual norm 1.463926960803e+00
131 KSP Residual norm 1.429569649275e+00
132 KSP Residual norm 1.388354409322e+00
133 KSP Residual norm 1.338008816625e+00
134 KSP Residual norm 1.294027811825e+00
135 KSP Residual norm 1.257198925438e+00
136 KSP Residual norm 1.225725069512e+00
137 KSP Residual norm 1.197461734920e+00
138 KSP Residual norm 1.180031946650e+00
139 KSP Residual norm 1.169889183013e+00
140 KSP Residual norm 1.157722463646e+00
141 KSP Residual norm 1.137592119057e+00
142 KSP Residual norm 1.109489294519e+00
143 KSP Residual norm 1.069881463745e+00
144 KSP Residual norm 1.027996344679e+00
145 KSP Residual norm 9.838789034108e-01
146 KSP Residual norm 9.504938609612e-01
147 KSP Residual norm 9.238464523166e-01
148 KSP Residual norm 9.066608784988e-01
149 KSP Residual norm 8.962210776621e-01
150 KSP Residual norm 8.920085404757e-01
151 KSP Residual norm 8.899931787411e-01
152 KSP Residual norm 8.871176840512e-01
153 KSP Residual norm 8.774097852543e-01
154 KSP Residual norm 8.510222023397e-01
155 KSP Residual norm 8.020971952653e-01
156 KSP Residual norm 7.288018116067e-01
157 KSP Residual norm 6.432908218984e-01
158 KSP Residual norm 5.620301400923e-01
159 KSP Residual norm 4.854800735374e-01
160 KSP Residual norm 4.261052693861e-01
161 KSP Residual norm 3.854559958811e-01
162 KSP Residual norm 3.594017212634e-01
163 KSP Residual norm 3.406558707185e-01
164 KSP Residual norm 3.225998576206e-01
165 KSP Residual norm 3.024785228215e-01
166 KSP Residual norm 2.753063465357e-01
167 KSP Residual norm 2.496783764715e-01
168 KSP Residual norm 2.313742356493e-01
169 KSP Residual norm 2.187864615458e-01
170 KSP Residual norm 2.112093529273e-01
171 KSP Residual norm 2.081912080364e-01
172 KSP Residual norm 2.070807546835e-01
173 KSP Residual norm 2.064968844770e-01
174 KSP Residual norm 2.060102111602e-01
175 KSP Residual norm 2.046373803173e-01
176 KSP Residual norm 2.028959931109e-01
177 KSP Residual norm 2.002100521179e-01
178 KSP Residual norm 1.967840351086e-01
179 KSP Residual norm 1.927702762238e-01
180 KSP Residual norm 1.867316661520e-01
181 KSP Residual norm 1.776618786193e-01
182 KSP Residual norm 1.643847566082e-01
183 KSP Residual norm 1.495557376661e-01
184 KSP Residual norm 1.352609696004e-01
185 KSP Residual norm 1.229341548569e-01
186 KSP Residual norm 1.144226428216e-01
187 KSP Residual norm 1.082897831466e-01
188 KSP Residual norm 1.049017302936e-01
189 KSP Residual norm 1.031397997305e-01
190 KSP Residual norm 1.024950850002e-01
191 KSP Residual norm 1.022799901920e-01
192 KSP Residual norm 1.021274799866e-01
193 KSP Residual norm 1.019884797110e-01
194 KSP Residual norm 1.018190390773e-01
195 KSP Residual norm 1.016668326031e-01
196 KSP Residual norm 1.015882820594e-01
197 KSP Residual norm 1.014326565943e-01
198 KSP Residual norm 1.009556540043e-01
199 KSP Residual norm 9.916515171835e-02
200 KSP Residual norm 9.512370044069e-02
201 KSP Residual norm 9.511275983111e-02
202 KSP Residual norm 9.511131506271e-02
203 KSP Residual norm 9.510986761576e-02
204 KSP Residual norm 9.510933477694e-02
205 KSP Residual norm 9.510833071353e-02
206 KSP Residual norm 9.510668267384e-02
207 KSP Residual norm 9.510109692511e-02
208 KSP Residual norm 9.510107317806e-02
209 KSP Residual norm 9.509210526366e-02
210 KSP Residual norm 9.509110617656e-02
211 KSP Residual norm 9.508868421041e-02
212 KSP Residual norm 9.508467781345e-02
213 KSP Residual norm 9.505041631624e-02
214 KSP Residual norm 9.502625819529e-02
215 KSP Residual norm 9.487020259295e-02
216 KSP Residual norm 9.472789018845e-02
217 KSP Residual norm 9.435337458810e-02
218 KSP Residual norm 9.415048658853e-02
219 KSP Residual norm 9.356796773537e-02
220 KSP Residual norm 9.311481258198e-02
221 KSP Residual norm 9.219331440403e-02
222 KSP Residual norm 9.122093067600e-02
223 KSP Residual norm 8.990964367346e-02
224 KSP Residual norm 8.878226382269e-02
225 KSP Residual norm 8.688582735745e-02
226 KSP Residual norm 8.488887608393e-02
227 KSP Residual norm 8.201415476002e-02
228 KSP Residual norm 7.803480677285e-02
229 KSP Residual norm 7.416373936907e-02
230 KSP Residual norm 7.025190482766e-02
231 KSP Residual norm 6.682434643966e-02
232 KSP Residual norm 6.377689478540e-02
233 KSP Residual norm 6.152493881049e-02
234 KSP Residual norm 6.015849505485e-02
235 KSP Residual norm 5.938689333013e-02
236 KSP Residual norm 5.888940992912e-02
237 KSP Residual norm 5.847223762170e-02
238 KSP Residual norm 5.800174821599e-02
239 KSP Residual norm 5.738529909769e-02
240 KSP Residual norm 5.623362622164e-02
241 KSP Residual norm 5.451225692018e-02
242 KSP Residual norm 5.317667566871e-02
243 KSP Residual norm 5.199973768688e-02
244 KSP Residual norm 5.136546664176e-02
245 KSP Residual norm 5.100085993635e-02
246 KSP Residual norm 5.085694856545e-02
247 KSP Residual norm 5.069329659465e-02
248 KSP Residual norm 5.051891723651e-02
249 KSP Residual norm 5.026364676362e-02
250 KSP Residual norm 4.986783676072e-02
251 KSP Residual norm 4.890203070691e-02
252 KSP Residual norm 4.698276330245e-02
253 KSP Residual norm 4.453832120123e-02
254 KSP Residual norm 4.226655991312e-02
255 KSP Residual norm 4.034268586182e-02
256 KSP Residual norm 3.826681348000e-02
257 KSP Residual norm 3.546413750381e-02
258 KSP Residual norm 3.152519768271e-02
259 KSP Residual norm 2.666655449770e-02
260 KSP Residual norm 2.273567265713e-02
261 KSP Residual norm 2.033064210676e-02
262 KSP Residual norm 1.911303817580e-02
263 KSP Residual norm 1.870214285337e-02
264 KSP Residual norm 1.859604156274e-02
265 KSP Residual norm 1.857001317550e-02
266 KSP Residual norm 1.855879295226e-02
267 KSP Residual norm 1.855361831653e-02
268 KSP Residual norm 1.854549077950e-02
269 KSP Residual norm 1.854291586046e-02
270 KSP Residual norm 1.854287402608e-02
271 KSP Residual norm 1.853657802312e-02
272 KSP Residual norm 1.853331710124e-02
273 KSP Residual norm 1.852633988804e-02
274 KSP Residual norm 1.842032519920e-02
275 KSP Residual norm 1.814955175628e-02
276 KSP Residual norm 1.766571474999e-02
277 KSP Residual norm 1.688992551541e-02
278 KSP Residual norm 1.582931607683e-02
279 KSP Residual norm 1.443316170578e-02
280 KSP Residual norm 1.276815839331e-02
281 KSP Residual norm 1.117926539043e-02
282 KSP Residual norm 9.945265555672e-03
283 KSP Residual norm 9.274740564630e-03
284 KSP Residual norm 8.947483602577e-03
285 KSP Residual norm 8.794444649207e-03
286 KSP Residual norm 8.693258885772e-03
287 KSP Residual norm 8.623660810084e-03
288 KSP Residual norm 8.539727968957e-03
289 KSP Residual norm 8.467363202209e-03
290 KSP Residual norm 8.354687309574e-03
291 KSP Residual norm 8.224237137113e-03
292 KSP Residual norm 8.055286368630e-03
293 KSP Residual norm 7.901668706091e-03
294 KSP Residual norm 7.736181748603e-03
295 KSP Residual norm 7.573367598708e-03
296 KSP Residual norm 7.275953096869e-03
297 KSP Residual norm 6.926503289955e-03
298 KSP Residual norm 6.455543874566e-03
299 KSP Residual norm 6.135999530427e-03
300 KSP Residual norm 5.815695447129e-03
301 KSP Residual norm 5.809157211314e-03
302 KSP Residual norm 5.803496781030e-03
303 KSP Residual norm 5.794794970337e-03
304 KSP Residual norm 5.789510438756e-03
305 KSP Residual norm 5.781331947972e-03
306 KSP Residual norm 5.776061415510e-03
307 KSP Residual norm 5.765420097917e-03
308 KSP Residual norm 5.761956316981e-03
309 KSP Residual norm 5.750339033038e-03
310 KSP Residual norm 5.748150977455e-03
311 KSP Residual norm 5.746564149784e-03
312 KSP Residual norm 5.746358473418e-03
313 KSP Residual norm 5.742704000622e-03
314 KSP Residual norm 5.742179163934e-03
315 KSP Residual norm 5.732250704249e-03
316 KSP Residual norm 5.730579521621e-03
317 KSP Residual norm 5.712064466143e-03
318 KSP Residual norm 5.707583467054e-03
319 KSP Residual norm 5.676261801920e-03
320 KSP Residual norm 5.638940655289e-03
321 KSP Residual norm 5.572686119465e-03
322 KSP Residual norm 5.486829270739e-03
323 KSP Residual norm 5.363011900677e-03
324 KSP Residual norm 5.264036861538e-03
325 KSP Residual norm 5.159359122740e-03
326 KSP Residual norm 5.086913731986e-03
327 KSP Residual norm 5.051539888910e-03
328 KSP Residual norm 5.022163992716e-03
329 KSP Residual norm 5.009642335424e-03
330 KSP Residual norm 4.995545393353e-03
331 KSP Residual norm 4.983970567331e-03
332 KSP Residual norm 4.965604387243e-03
333 KSP Residual norm 4.943002271641e-03
334 KSP Residual norm 4.912421560658e-03
335 KSP Residual norm 4.863231436581e-03
336 KSP Residual norm 4.786701764192e-03
337 KSP Residual norm 4.672208025754e-03
338 KSP Residual norm 4.540537274945e-03
339 KSP Residual norm 4.418364423945e-03
340 KSP Residual norm 4.301359063959e-03
341 KSP Residual norm 4.168745791627e-03
342 KSP Residual norm 4.032996661213e-03
343 KSP Residual norm 3.867022987699e-03
344 KSP Residual norm 3.721242920022e-03
345 KSP Residual norm 3.556217408130e-03
346 KSP Residual norm 3.365328459562e-03
347 KSP Residual norm 3.084850335568e-03
348 KSP Residual norm 2.783554644191e-03
349 KSP Residual norm 2.501758587950e-03
350 KSP Residual norm 2.335050554919e-03
351 KSP Residual norm 2.213037226800e-03
352 KSP Residual norm 2.112129649281e-03
353 KSP Residual norm 2.015177538088e-03
354 KSP Residual norm 1.921591991170e-03
355 KSP Residual norm 1.846983730772e-03
356 KSP Residual norm 1.795958510851e-03
357 KSP Residual norm 1.761398005030e-03
358 KSP Residual norm 1.731744669742e-03
359 KSP Residual norm 1.698649941093e-03
360 KSP Residual norm 1.653138830187e-03
361 KSP Residual norm 1.597006736777e-03
362 KSP Residual norm 1.535496029318e-03
363 KSP Residual norm 1.486864751966e-03
364 KSP Residual norm 1.445887722523e-03
365 KSP Residual norm 1.414809810311e-03
366 KSP Residual norm 1.386467859902e-03
367 KSP Residual norm 1.368094817408e-03
368 KSP Residual norm 1.354718460954e-03
369 KSP Residual norm 1.345447779901e-03
370 KSP Residual norm 1.334572964939e-03
371 KSP Residual norm 1.322612840183e-03
372 KSP Residual norm 1.308206515946e-03
373 KSP Residual norm 1.289021663464e-03
374 KSP Residual norm 1.264987008466e-03
375 KSP Residual norm 1.235541919237e-03
376 KSP Residual norm 1.210199171309e-03
377 KSP Residual norm 1.191233343534e-03
378 KSP Residual norm 1.179442434523e-03
379 KSP Residual norm 1.169171134718e-03
380 KSP Residual norm 1.155344051311e-03
381 KSP Residual norm 1.125710546909e-03
382 KSP Residual norm 1.062970567251e-03
383 KSP Residual norm 9.762551092829e-04
384 KSP Residual norm 8.715931560316e-04
385 KSP Residual norm 8.012869359532e-04
386 KSP Residual norm 7.590047084899e-04
387 KSP Residual norm 7.325311548101e-04
388 KSP Residual norm 7.092700905607e-04
389 KSP Residual norm 6.905385000869e-04
390 KSP Residual norm 6.650944698267e-04
391 KSP Residual norm 6.329078135345e-04
392 KSP Residual norm 5.934109628314e-04
393 KSP Residual norm 5.507029998022e-04
394 KSP Residual norm 5.188824609645e-04
395 KSP Residual norm 4.985903395866e-04
396 KSP Residual norm 4.859088238936e-04
397 KSP Residual norm 4.790023202304e-04
398 KSP Residual norm 4.753359807683e-04
399 KSP Residual norm 4.724654435006e-04
400 KSP Residual norm 4.702447667809e-04
401 KSP Residual norm 4.702385459535e-04
402 KSP Residual norm 4.702340952853e-04
403 KSP Residual norm 4.702332069864e-04
404 KSP Residual norm 4.702105876309e-04
405 KSP Residual norm 4.701402820496e-04
406 KSP Residual norm 4.700497700580e-04
407 KSP Residual norm 4.698750923377e-04
408 KSP Residual norm 4.697416679318e-04
409 KSP Residual norm 4.693955056765e-04
410 KSP Residual norm 4.689232036487e-04
411 KSP Residual norm 4.679222047688e-04
412 KSP Residual norm 4.658894513198e-04
413 KSP Residual norm 4.629487867544e-04
414 KSP Residual norm 4.605058797028e-04
415 KSP Residual norm 4.560264680471e-04
416 KSP Residual norm 4.513516060096e-04
417 KSP Residual norm 4.450273961016e-04
418 KSP Residual norm 4.404795214622e-04
419 KSP Residual norm 4.335150901076e-04
420 KSP Residual norm 4.264628565582e-04
421 KSP Residual norm 4.181174346641e-04
422 KSP Residual norm 4.088875103290e-04
423 KSP Residual norm 3.985616737365e-04
424 KSP Residual norm 3.864025638874e-04
425 KSP Residual norm 3.734769219525e-04
426 KSP Residual norm 3.635375118893e-04
427 KSP Residual norm 3.577277614055e-04
428 KSP Residual norm 3.555689955859e-04
429 KSP Residual norm 3.551295558307e-04
430 KSP Residual norm 3.550173617798e-04
431 KSP Residual norm 3.550165548427e-04
432 KSP Residual norm 3.550156933547e-04
433 KSP Residual norm 3.550156833320e-04
434 KSP Residual norm 3.549972037875e-04
435 KSP Residual norm 3.549698393113e-04
436 KSP Residual norm 3.548832082026e-04
437 KSP Residual norm 3.547866905840e-04
438 KSP Residual norm 3.545560468118e-04
439 KSP Residual norm 3.540569338306e-04
440 KSP Residual norm 3.530155279079e-04
441 KSP Residual norm 3.511549618114e-04
442 KSP Residual norm 3.487392176101e-04
443 KSP Residual norm 3.465616071158e-04
444 KSP Residual norm 3.448919983631e-04
445 KSP Residual norm 3.426218669471e-04
446 KSP Residual norm 3.395556754858e-04
447 KSP Residual norm 3.344881487351e-04
448 KSP Residual norm 3.289333584185e-04
449 KSP Residual norm 3.211701098462e-04
450 KSP Residual norm 3.124093538201e-04
451 KSP Residual norm 3.003489562746e-04
452 KSP Residual norm 2.839876442654e-04
453 KSP Residual norm 2.610237751511e-04
454 KSP Residual norm 2.330003787422e-04
455 KSP Residual norm 2.043928706990e-04
456 KSP Residual norm 1.811561719118e-04
457 KSP Residual norm 1.643810475895e-04
458 KSP Residual norm 1.527883735615e-04
459 KSP Residual norm 1.460860306959e-04
460 KSP Residual norm 1.426496087387e-04
461 KSP Residual norm 1.399612850653e-04
462 KSP Residual norm 1.373603321984e-04
463 KSP Residual norm 1.345857300321e-04
464 KSP Residual norm 1.316861590374e-04
465 KSP Residual norm 1.283134020302e-04
466 KSP Residual norm 1.249711643149e-04
467 KSP Residual norm 1.218948694600e-04
468 KSP Residual norm 1.193804148917e-04
469 KSP Residual norm 1.172332693152e-04
470 KSP Residual norm 1.148202125137e-04
471 KSP Residual norm 1.120629298054e-04
472 KSP Residual norm 1.091115909292e-04
473 KSP Residual norm 1.061722410488e-04
474 KSP Residual norm 1.033150015427e-04
475 KSP Residual norm 1.005014185661e-04
476 KSP Residual norm 9.646529417265e-05
477 KSP Residual norm 9.020930158675e-05
478 KSP Residual norm 8.296757556483e-05
479 KSP Residual norm 7.593626126040e-05
480 KSP Residual norm 7.097578650000e-05
481 KSP Residual norm 6.732987878802e-05
482 KSP Residual norm 6.412870991308e-05
483 KSP Residual norm 6.167784122976e-05
484 KSP Residual norm 6.035766938838e-05
485 KSP Residual norm 5.960640487175e-05
486 KSP Residual norm 5.899042079356e-05
487 KSP Residual norm 5.827102498813e-05
488 KSP Residual norm 5.813746340944e-05
489 KSP Residual norm 5.810310441546e-05
490 KSP Residual norm 5.803696984630e-05
491 KSP Residual norm 5.778764627336e-05
492 KSP Residual norm 5.734550618969e-05
493 KSP Residual norm 5.645636107473e-05
494 KSP Residual norm 5.434932625934e-05
495 KSP Residual norm 5.040611547404e-05
496 KSP Residual norm 4.552623748666e-05
497 KSP Residual norm 4.244135931970e-05
498 KSP Residual norm 3.980425878943e-05
499 KSP Residual norm 3.804068563001e-05
500 KSP Residual norm 3.666582841476e-05
501 KSP Residual norm 3.664625115645e-05
502 KSP Residual norm 3.664365663964e-05
503 KSP Residual norm 3.663020673719e-05
504 KSP Residual norm 3.662726636131e-05
505 KSP Residual norm 3.657499234638e-05
506 KSP Residual norm 3.652156164018e-05
507 KSP Residual norm 3.640541061396e-05
508 KSP Residual norm 3.625572962518e-05
509 KSP Residual norm 3.601140429895e-05
510 KSP Residual norm 3.589022311180e-05
511 KSP Residual norm 3.580905842091e-05
512 KSP Residual norm 3.578918154702e-05
513 KSP Residual norm 3.564503738238e-05
514 KSP Residual norm 3.555879011704e-05
515 KSP Residual norm 3.539367812531e-05
516 KSP Residual norm 3.522867490617e-05
517 KSP Residual norm 3.505164606126e-05
518 KSP Residual norm 3.486728700443e-05
519 KSP Residual norm 3.447151133505e-05
520 KSP Residual norm 3.368534926696e-05
521 KSP Residual norm 3.241786154838e-05
522 KSP Residual norm 3.071072865434e-05
523 KSP Residual norm 2.887789224509e-05
524 KSP Residual norm 2.732415348856e-05
525 KSP Residual norm 2.626678458948e-05
526 KSP Residual norm 2.553178744050e-05
527 KSP Residual norm 2.499998708708e-05
528 KSP Residual norm 2.473964778841e-05
529 KSP Residual norm 2.462913726389e-05
530 KSP Residual norm 2.457423226619e-05
531 KSP Residual norm 2.451837260327e-05
532 KSP Residual norm 2.437998385498e-05
533 KSP Residual norm 2.415824540315e-05
534 KSP Residual norm 2.394729052208e-05
535 KSP Residual norm 2.373648745952e-05
536 KSP Residual norm 2.353236145250e-05
537 KSP Residual norm 2.335112365027e-05
538 KSP Residual norm 2.324328424042e-05
539 KSP Residual norm 2.316337106701e-05
540 KSP Residual norm 2.306013865188e-05
541 KSP Residual norm 2.292514500673e-05
542 KSP Residual norm 2.272091128957e-05
543 KSP Residual norm 2.241219147523e-05
544 KSP Residual norm 2.199497746037e-05
545 KSP Residual norm 2.153390383940e-05
546 KSP Residual norm 2.108237866348e-05
547 KSP Residual norm 2.063721552310e-05
548 KSP Residual norm 2.020756105562e-05
549 KSP Residual norm 1.977764681226e-05
550 KSP Residual norm 1.936172334631e-05
551 KSP Residual norm 1.883847330385e-05
552 KSP Residual norm 1.808105646329e-05
553 KSP Residual norm 1.677704172193e-05
554 KSP Residual norm 1.521028214595e-05
555 KSP Residual norm 1.374429270314e-05
556 KSP Residual norm 1.263008460808e-05
557 KSP Residual norm 1.172761484747e-05
558 KSP Residual norm 1.122125157933e-05
559 KSP Residual norm 1.093194966962e-05
560 KSP Residual norm 1.074985240635e-05
561 KSP Residual norm 1.063172228100e-05
562 KSP Residual norm 1.055582757389e-05
563 KSP Residual norm 1.047465660246e-05
564 KSP Residual norm 1.035869979742e-05
565 KSP Residual norm 1.018370782707e-05
566 KSP Residual norm 1.000060114212e-05
567 KSP Residual norm 9.851104029364e-06
568 KSP Residual norm 9.744970140937e-06
569 KSP Residual norm 9.678200471464e-06
570 KSP Residual norm 9.593727341280e-06
571 KSP Residual norm 9.478937238697e-06
572 KSP Residual norm 9.289971875556e-06
573 KSP Residual norm 9.077432414607e-06
574 KSP Residual norm 8.809603923972e-06
575 KSP Residual norm 8.465913470656e-06
576 KSP Residual norm 8.032248889436e-06
577 KSP Residual norm 7.586651043516e-06
578 KSP Residual norm 7.280953016823e-06
579 KSP Residual norm 7.055471862536e-06
580 KSP Residual norm 6.860406178092e-06
581 KSP Residual norm 6.714491274270e-06
582 KSP Residual norm 6.582344451042e-06
583 KSP Residual norm 6.464658082349e-06
584 KSP Residual norm 6.361107589779e-06
585 KSP Residual norm 6.268887549994e-06
586 KSP Residual norm 6.164151375870e-06
587 KSP Residual norm 6.031138843377e-06
588 KSP Residual norm 5.877778342818e-06
589 KSP Residual norm 5.700706671045e-06
590 KSP Residual norm 5.520474933152e-06
591 KSP Residual norm 5.362284063344e-06
592 KSP Residual norm 5.203914907852e-06
593 KSP Residual norm 5.051299481294e-06
594 KSP Residual norm 4.864744993054e-06
595 KSP Residual norm 4.652319505484e-06
596 KSP Residual norm 4.456044786944e-06
KSP Object:(coupledsolve_) 1 MPI processes
  type: gmres
    GMRES: restart=100, using Modified Gram-Schmidt Orthogonalization
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=9.6184e-11, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object:(coupledsolve_) 1 MPI processes
  type: ilu
    ILU: out-of-place factorization
    1 level of fill
    tolerance for zero pivot 2.22045e-14
    using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
    matrix ordering: natural
    factor fill ratio given 1, needed 2.44153
      Factored matrix follows:
        Mat Object:         1 MPI processes
          type: seqaij
          rows=8788000, cols=8788000
          package used to perform factorization: petsc
          total: nonzeros=3.56993e+08, allocated nonzeros=3.56993e+08
          total number of mallocs used during MatSetValues calls =0
            not using I-node routines
  linear system matrix = precond matrix:
    type: seqaij
    total: nonzeros=1.46217e+08, allocated nonzeros=1.46217e+08
 0000017  0.9618E-08  0.0000E+00
TIME FOR CALCULATION:  0.8095E+04
 L2-NORM ERROR U    VELOCITY  2.803369989662701E-005
 L2-NORM ERROR V    VELOCITY  2.790402445981405E-005
 L2-NORM ERROR W    VELOCITY  2.917168464344412E-005
 L2-NORM ERROR ABS. VELOCITY  3.168282567469746E-005
 L2-NORM ERROR      PRESSURE  1.392955988162038E-003
      *** CALCULATION FINISHED - SEE RESULTS ***
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./caffa3d.cpld.lnx on a arch-openmpi-opt-intel-hlr-ext named hpb0024 with 1 processor, by gu08vomo Mon Feb  2 02:21:24 2015
Using Petsc Release Version 3.5.3, Jan, 31, 2015
                         Max       Max/Min        Avg      Total
Time (sec):           8.124e+03      1.00000   8.124e+03
Objects:              3.930e+02      1.00000   3.930e+02
Flops:                1.317e+13      1.00000   1.317e+13  1.317e+13
Flops/sec:            1.621e+09      1.00000   1.621e+09  1.621e+09
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 9.9606e+01   1.2%  2.6364e+07   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:        CPLD_SOL: 8.0248e+03  98.8%  1.3166e+13 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
ThreadCommRunKer      73 1.0 6.5088e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNorm                1 1.0 2.3034e-01 1.0 1.76e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 67  0  0  0    76
VecScale               1 1.0 6.9630e-03 1.0 8.79e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 33  0  0  0  1262
VecSet               590 1.0 5.9857e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecScatterBegin      628 1.0 1.7977e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize           1 1.0 6.9640e-03 1.0 8.79e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 33  0  0  0  1262
MatAssemblyBegin      34 1.0 1.6212e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        34 1.0 1.7639e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatZeroEntries        17 1.0 1.3217e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
--- Event Stage 1: CPLD_SOL
VecDot            224557 1.0 2.0988e+03 1.0 3.95e+12 1.0 0.0e+00 0.0e+00 0.0e+00 26 30  0  0  0  26 30  0  0  0  1881
VecMDot             4819 1.0 4.6719e+01 1.0 8.47e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1813
VecNorm             4836 1.0 2.7221e+01 1.0 8.50e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  3123
VecScale            4819 1.0 4.2187e+01 1.0 4.23e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0  1004
VecCopy               72 1.0 5.5840e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                72 1.0 2.6911e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY           224667 1.0 2.9981e+03 1.0 3.95e+12 1.0 0.0e+00 0.0e+00 0.0e+00 37 30  0  0  0  37 30  0  0  0  1317
VecMAXPY            4874 1.0 8.9722e+01 1.0 1.68e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1877
VecNormalize        4819 1.0 6.9335e+01 1.0 1.27e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1832
MatMult             4819 1.0 7.0751e+02 1.0 1.37e+12 1.0 0.0e+00 0.0e+00 0.0e+00  9 10  0  0  0   9 10  0  0  0  1932
MatSolve            4819 1.0 1.7652e+03 1.0 3.40e+12 1.0 0.0e+00 0.0e+00 0.0e+00 22 26  0  0  0  22 26  0  0  0  1925
MatLUFactorNum        17 1.0 8.0536e+01 1.0 1.25e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1546
MatILUFactorSym       17 1.0 1.6276e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatGetRowIJ           17 1.0 4.2915e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering        17 1.0 6.3720e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView               34 1.0 3.3295e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog      4764 1.0 5.0960e+03 1.0 7.89e+12 1.0 0.0e+00 0.0e+00 0.0e+00 63 60  0  0  0  64 60  0  0  0  1549
KSPSetUp              17 1.0 1.0602e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              17 1.0 8.0201e+03 1.0 1.32e+13 1.0 0.0e+00 0.0e+00 0.0e+00 99100  0  0  0 100100  0  0  0  1641
PCSetUp               17 1.0 2.4407e+02 1.0 1.25e+11 1.0 0.0e+00 0.0e+00 0.0e+00  3  1  0  0  0   3  1  0  0  0   510
PCApply             4819 1.0 1.7652e+03 1.0 3.40e+12 1.0 0.0e+00 0.0e+00 0.0e+00 22 26  0  0  0  22 26  0  0  0  1925
--- Event Stage 2: Unknown
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    71            280   8208424320     0
      Vector Scatter     4              3         1956     0
           Index Set    12             11     70312712     0
   IS L to G Mapping     4              3     79093788     0
              Matrix     2              3   6381679896     0
       Krylov Solver     0              1       169864     0
      Preconditioner     0              1         1016     0
              Vector   212              0            0     0
           Index Set    51             48   1124902016     0
              Matrix    17             16  68542708736     0
   Matrix Null Space    17              0            0     0
       Krylov Solver     1              0            0     0
      Preconditioner     1              0            0     0
              Viewer     1              0            0     0
Average time to get PetscTime(): 9.53674e-08
#PETSc Option Table entries:
-coupledsolve_ksp_gmres_modifiedgramschmidt
-coupledsolve_ksp_gmres_restart 100
-coupledsolve_ksp_monitor
-coupledsolve_ksp_view
-coupledsolve_pc_factor_levels 1
-log_summary
-on_error_abort
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: PETSC_ARCH=arch-openmpi-opt-intel-hlr-ext PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3 -prefix=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext --with-blas-lapack-dir=/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64/ --with-mpi-dir=/shared/apps/openmpi/1.8.2_intel COPTFLAGS="-O3 -xHost" FOPTFLAGS="-O3 -xHost" CXXOPTFLAGS="-O3 -xHost" --with-debugging=0 --download-hypre --download-ml
Libraries compiled on Sun Feb  1 16:09:22 2015 on hla0003
Machine characteristics: Linux-3.0.101-0.40-default-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /home/gu08vomo/soft/petsc/3.5.3
Using PETSc arch: arch-openmpi-opt-intel-hlr-ext
Using C compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpicc  -fPIC -wd1572 -O3 -xHost  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpif90  -fPIC -O3 -xHost   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/shared/apps/openmpi/1.8.2_intel/include
Using C linker: /shared/apps/openmpi/1.8.2_intel/bin/mpicc
Using Fortran linker: /shared/apps/openmpi/1.8.2_intel/bin/mpif90
Using libraries: -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lpetsc -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lHYPRE -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -lmpi_cxx -lml -lmpi_cxx -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lX11 -lpthread -lssl -lcrypto -lmpi_usempi_ignore_tkr -lmpi_mpifh -lifport -lifcore -lm -lmpi_cxx -ldl -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -lmpi -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -limf -lsvml -lirng -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lpthread -lirc_s -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -ldl
