[petsc-users] Dof ordering in DMPlexVecGet/Set/RestoreClosure
Matthew Knepley
knepley at gmail.com
Mon Nov 7 11:14:33 CST 2022
On Mon, Nov 7, 2022 at 10:51 AM Blaise Bourdin <bourdin at mcmaster.ca> wrote:
> Hi,
> How are degree of freedom ordered in calls to
> DMPlexVec[Set/Get/Restore]Closure?
> Given a FE mesh and a section for P2-Lagrange elements (i.e. 1 dof per
> vertex and edge), I was naively assuming that the “local” vector would
> contain dof at vertices then edges (in this order), since it matches the
> section ordering, but it looks like I get edges then vertices…
> Here is my section (my mesh has 8 cells, 16 edges, and 9 vertices)
> PetscSection Object: U 1 MPI process
> type not yet set
> 1 fields
> field 0 with 1 components
> Process 0:
> ( 0) dim 0 offset 0
> ( 1) dim 0 offset 0
> ( 2) dim 0 offset 0
> ( 3) dim 0 offset 0
> ( 4) dim 0 offset 0
> ( 5) dim 0 offset 0
> ( 6) dim 0 offset 0
> ( 7) dim 0 offset 0
> ( 8) dim 1 offset 0
> ( 9) dim 1 offset 1
> ( 10) dim 1 offset 2
> ( 11) dim 1 offset 3
> ( 12) dim 1 offset 4
> ( 13) dim 1 offset 5
> ( 14) dim 1 offset 6
> ( 15) dim 1 offset 7
> ( 16) dim 1 offset 8
> ( 17) dim 1 offset 9
> ( 18) dim 1 offset 10
> ( 19) dim 1 offset 11
> ( 20) dim 1 offset 12
> ( 21) dim 1 offset 13
> ( 22) dim 1 offset 14
> ( 23) dim 1 offset 15
> ( 24) dim 1 offset 16
> ( 25) dim 1 offset 17
> ( 26) dim 1 offset 18
> ( 27) dim 1 offset 19
> ( 28) dim 1 offset 20
> ( 29) dim 1 offset 21
> ( 30) dim 1 offset 22
> ( 31) dim 1 offset 23
> ( 32) dim 1 offset 24
> Start from the following local vector:
> Vec Object: U 1 MPI process
> type: seq
> 1.
> 2.
> 3.
> 4.
> 5.
> 6.
> 7.
> 8.
> 9.
> 10.
> 11.
> 12.
> 13.
> 14.
> 15.
> 16.
> 17.
> 18.
> 19.
> 20.
> 21.
> 22.
> 23.
> 24.
> 25.
> Call PetscCallA(DMPlexVecGetClosure(dmU,sectionU,U,0_Ki,UArray,ierr)) and
> get the following for Array:
> 10.000000000000000 11.000000000000000 12.000000000000000
> 1.0000000000000000 2.0000000000000000 3.0000000000000000
> Is this ordering predictable and documented somewhere? Is it ordered by
> stratum?
The ordering is determined. It follows the same order that
DMPlexGetTransitiveClosure() gives for the points.
Transitive closure orders points by stratum. It is a BFS of the Hasse
Diagram, starting from the initial point. For
your triangle, it would be
tri0, e0, e1, e2, v0, v1, v2
For each cell type, the order of faces is specified in Table 1.2 of the
attached. This gives an order to each level
of the BFS.
Matt
> Regards,
> Blaise
> Canada Research Chair in Mathematical and Computational Aspects of Solid
> Mechanics (Tier 1)
> Professor, Department of Mathematics & Statistics
> Hamilton Hall room 409A, McMaster University
> 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
> https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/0ee614cc/attachment-0001.html>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/0ee614cc/attachment-0001.pdf>
