[petsc-users] Dof ordering in DMPlexVecGet/Set/RestoreClosure
Blaise Bourdin bourdin at mcmaster.ca
Mon Nov 7 09:51:43 CST 2022
How are degree of freedom ordered in calls to DMPlexVec[Set/Get/Restore]Closure?
Given a FE mesh and a section for P2-Lagrange elements (i.e. 1 dof per vertex and edge), I was naively assuming that the “local” vector would contain dof at vertices then edges (in this order), since it matches the section ordering, but it looks like I get edges then vertices…
Here is my section (my mesh has 8 cells, 16 edges, and 9 vertices)
PetscSection Object: U 1 MPI process
  type not yet set
1 fields
  field 0 with 1 components
Process 0:
  (   0) dim  0 offset   0
  (   1) dim  0 offset   0
  (   2) dim  0 offset   0
  (   3) dim  0 offset   0
  (   4) dim  0 offset   0
  (   5) dim  0 offset   0
  (   6) dim  0 offset   0
  (   7) dim  0 offset   0
  (   8) dim  1 offset   0
  (   9) dim  1 offset   1
  (  10) dim  1 offset   2
  (  11) dim  1 offset   3
  (  12) dim  1 offset   4
  (  13) dim  1 offset   5
  (  14) dim  1 offset   6
  (  15) dim  1 offset   7
  (  16) dim  1 offset   8
  (  17) dim  1 offset   9
  (  18) dim  1 offset  10
  (  19) dim  1 offset  11
  (  20) dim  1 offset  12
  (  21) dim  1 offset  13
  (  22) dim  1 offset  14
  (  23) dim  1 offset  15
  (  24) dim  1 offset  16
  (  25) dim  1 offset  17
  (  26) dim  1 offset  18
  (  27) dim  1 offset  19
  (  28) dim  1 offset  20
  (  29) dim  1 offset  21
  (  30) dim  1 offset  22
  (  31) dim  1 offset  23
  (  32) dim  1 offset  24
Start from the following local vector:
Vec Object: U 1 MPI process
  type: seq
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
Call PetscCallA(DMPlexVecGetClosure(dmU,sectionU,U,0_Ki,UArray,ierr)) and get the following for Array:
10.000000000000000        11.000000000000000        12.000000000000000        1.0000000000000000        2.0000000000000000        3.0000000000000000
Is this ordering predictable and documented somewhere? Is it ordered by stratum?
Blaise
Canada Research Chair in Mathematical and Computational Aspects of Solid Mechanics (Tier 1)
Professor, Department of Mathematics & Statistics
Hamilton Hall room 409A, McMaster University
1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
