[petsc-users] petsc crash with float128
Matthew Knepley
knepley at gmail.com
Mon Nov 7 08:35:46 CST 2022
On Mon, Nov 7, 2022 at 9:27 AM Gong Ding via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear petsc developer,
> The petsc linear solver crash with following report
It will make it much easier to debug if you can send your matrix. The
easiest way to do this is to give
the options
-ksp_view_mat binary -ksp_view_rhs binary
and send that binary file.
Matt
> [1]PETSC ERROR:
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and
> [1]PETSC ERROR: --------------------- Stack Frames
> [1]PETSC ERROR: The line numbers in the error traceback are not always
> exact.
> [1]PETSC ERROR: #1 MatLUFactorNumeric_SeqAIJ_Inode() at
> /usr/local/petsc-3.18.0/src/mat/impls/aij/seq/inode.c:1259
> [1]PETSC ERROR: #2 MatLUFactorNumeric() at
> /usr/local/petsc-3.18.0/src/mat/interface/matrix.c:3200
> [1]PETSC ERROR: #3 PCSetUp_LU() at
> /usr/local/petsc-3.18.0/src/ksp/pc/impls/factor/lu/lu.c:120
> [1]PETSC ERROR: #4 PCSetUp() at
> /usr/local/petsc-3.18.0/src/ksp/pc/interface/precon.c:994
> [1]PETSC ERROR: #5 KSPSetUp() at
> /usr/local/petsc-3.18.0/src/ksp/ksp/interface/itfunc.c:406
> [1]PETSC ERROR: #6 PCSetUpOnBlocks_ASM() at
> /usr/local/petsc-3.18.0/src/ksp/pc/impls/asm/asm.c:417
> [1]PETSC ERROR: #7 PCSetUpOnBlocks() at
> /usr/local/petsc-3.18.0/src/ksp/pc/interface/precon.c:1027
> [1]PETSC ERROR: #8 KSPSetUpOnBlocks() at
> /usr/local/petsc-3.18.0/src/ksp/ksp/interface/itfunc.c:219
> [1]PETSC ERROR: #9 KSPSolve_Private() at
> /usr/local/petsc-3.18.0/src/ksp/ksp/interface/itfunc.c:826
> [1]PETSC ERROR: #10 KSPSolve() at
> /usr/local/petsc-3.18.0/src/ksp/ksp/interface/itfunc.c:1071
> [1]PETSC ERROR: #11 SNESSolve_NEWTONLS() at
> /usr/local/petsc-3.18.0/src/snes/impls/ls/ls.c:210
> [1]PETSC ERROR: #12 SNESSolve() at
> /usr/local/petsc-3.18.0/src/snes/interface/snes.c:4689
> The petsc is configured by
> export PETSC_ARCH=arch-linux2-float128-gcc
> export MPICH_CC=gcc
> export MPICH_CXX=g++
> export MPICH_F77=gfortran
> export MPICH_F90=gfortran
> python3 configure --with-precision=__float128 --download-f2cblaslapack=1
> --with-debugging=yes --with-x=0 --with-pic=1
> --with-mpi-dir=/usr/local/mpich-3.4.2/ COPTFLAGS="-O3 -mavx2"
> CXXOPTFLAGS="-O3 -mavx2" FOPTFLAGS="-O3 -mavx2" --force
> make
> and run with 8 mpi process.
> The linear solver is set as
> ierr = KSPSetType (ksp, (char*) KSPBCGSL); assert(!ierr);
> ierr = PCSetType (pc, (char*) PCASM); assert(!ierr);
> ierr = set_petsc_option("-sub_ksp_type","preonly");
> assert(!ierr);
> ierr = set_petsc_option("-sub_pc_type","lu"); assert(!ierr);
> ierr = set_petsc_option("-sub_pc_factor_reuse_fill","1");
> assert(!ierr);
> ierr = set_petsc_option("-sub_pc_factor_reuse_ordering","1");
> assert(!ierr);
> ierr =
> set_petsc_option("-sub_pc_factor_shift_type","NONZERO"); assert(!ierr);
> if remove set_petsc_option("-sub_pc_factor_reuse_ordering","1");
> it seems the crash will not happen. (Not fully tested)
> Hope this bug can be fixed.
> Gong Ding
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/ed9bcc8d/attachment.html>
