[petsc-users] PETSc Windows Installation
Mohammad Ali Yaqteen mhyaqteen at sju.ac.kr
Sun Nov 6 21:01:34 CST 2022
I used the following command to install PETSc again: (I have also attached the configure.log file with this email)
./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 –download-f2blaslapack –download-scalapack –download-mumps
It runs successfully and then I make all and make a check after that. It gives me the following:
$ make PETSC_DIR=/home/SEJONG/petsc-3.18.1 PETSC_ARCH=arch-mswin-c-debug check
Running check examples to verify correct installation
Using PETSC_DIR=/home/SEJONG/petsc-3.18.1 and PETSC_ARCH=arch-mswin-c-debug
Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
See https://petsc.org/release/faq/
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
[DESKTOP-R1C768B:29360] [[36285,0],0] unable to open debugger attach fifo
mpiexec detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[36285,1],0]
  Exit code:    127
Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
[DESKTOP-R1C768B:29383] [[36298,0],0] unable to open debugger attach fifo
1,9c1,5
< lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
<   0 SNES Function norm 0.239155
<     0 KSP Residual norm 0.235858
<     1 KSP Residual norm < 1.e-11
<   1 SNES Function norm 6.81968e-05
<     0 KSP Residual norm 2.30906e-05
<   2 SNES Function norm < 1.e-11
< Number of SNES iterations = 2
> [DESKTOP-R1C768B:29409] [[36332,0],0] unable to open debugger attach fifo
/home/SEJONG/petsc-3.18.1/src/snes/tutorials
Possible problem with ex19 running with mumps, diffs above
Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process
[DESKTOP-R1C768B:29494] [[35899,0],0] unable to open debugger attach fifo
  Process name: [[35899,1],0]
  Exit code:    127
Completed test examples
Error while running make check
make[1]: *** [makefile:149: check] Error 1
make: *** [GNUmakefile:17: check] Error 2
Sent: Sunday, November 6, 2022 10:42 PM
To: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] PETSc Windows Installation
We need to see configure.log to see what is going on. Can you send it?
     Matt
On Sun, Nov 6, 2022 at 4:29 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr<mailto:mhyaqteen at sju.ac.kr>> wrote:
Dear Sir/Madam,
I am installing PETSc on windows but it keeps giving me unexpected errors. I want to use it on MS Visual Studio or Codeblocks. When I use the command on your webpage (./configure --with-cc='win32fe cl' --with-fc='win32fe ifort' --with-cxx='win32fe cl' --with-mpi=0 --download-fblaslapack), I get the following error message:
$ ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort' --with-cxx='win32fe cl' --with-mpi=0 --download-fblaslapack
                         Configuring PETSc to compile on your system
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:1341)*******************************************************************************
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
C compiler you provided with -with-cc=win32fe cl cannot be found or does not work.
Cannot compile/link C with /home/SEJONG/petsc-3.18.1/lib/petsc/bin/win32fe/win32fe cl.
Kindly look into this problem! Your prompt response will highly be appreciated
Thank you
Ali
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/1a03a900/attachment-0001.html>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221107/1a03a900/attachment-0001.obj>
