[petsc-users] PETSc Windows Installation
Pierre Jolivet pierre at joliv.et
Mon Nov 7 23:23:04 CST 2022
My bad, I sent non-updated instructions.
Here is the proper list of packages: https://github.com/FreeFem/FreeFem-sources/tree/develop/etc/jenkins/deployRelease#windows (develop branch instead of master)
If the pacman -R command fails, that’s no big deal.
By default, PETSc configure picks up the wrong Python and assume that we are running Cygwin, which is wrong.
You can force the use of the « proper » Python by using /usr/bin/python ./configure instead of just ./configure
Pierre
> On 8 Nov 2022, at 1:06 AM, Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr> wrote:
> Although I followed the steps in the explanation you sent me, these are the errors that I got:
> From: Pierre Jolivet <pierre at joliv.et>
> Sent: Monday, November 7, 2022 10:38 PM
> To: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
> Cc: petsc-users <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] PETSc Windows Installation
> You are not running under a MinGW x64 shell, but a MinGW UCRT (Universal C Runtime) x64 shell instead.
> This may work, but I’ve never tried it myself.
> Thanks,
> Pierre
> On 7 Nov 2022, at 2:29 PM, Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr> wrote:
> Do I have to follow all the steps in the first link as it says the following in step 6:
> $ pacman -S mingw-w64-ucrt-x86_64-gcc
> resolving dependencies...
> looking for conflicting packages...
> Packages (15) mingw-w64-ucrt-x86_64-binutils-2.39-2
>             mingw-w64-ucrt-x86_64-crt-git-10.0.0.r68.g6eb571448-1
>             mingw-w64-ucrt-x86_64-gcc-libs-12.2.0-1  mingw-w64-ucrt-x86_64-gmp-6.2.1-3
>             mingw-w64-ucrt-x86_64-headers-git-10.0.0.r68.g6eb571448-1
>             mingw-w64-ucrt-x86_64-isl-0.25-1  mingw-w64-ucrt-x86_64-libiconv-1.17-1
>             mingw-w64-ucrt-x86_64-libwinpthread-git-10.0.0.r68.g6eb571448-1
>             mingw-w64-ucrt-x86_64-mpc-1.2.1-1  mingw-w64-ucrt-x86_64-mpfr-4.1.0.p13-1
>             mingw-w64-ucrt-x86_64-windows-default-manifest-6.4-4
>             mingw-w64-ucrt-x86_64-winpthreads-git-10.0.0.r68.g6eb571448-1
>             mingw-w64-ucrt-x86_64-zlib-1.2.12-1  mingw-w64-ucrt-x86_64-zstd-1.5.2-2
>             mingw-w64-ucrt-x86_64-gcc-12.2.0-1
> Total Installed Size:  397.59 MiB
> :: Proceed with installation? [Y/n]
> [... downloading and installation continues ...]
> Thanks
> Ali
> Sent: Monday, November 7, 2022 10:06 PM
> Please, keep the list in copy.
> You can get MSYS2 from https://www.msys2.org/
> Then install the following packages: https://github.com/FreeFem/FreeFem-sources/tree/master/etc/jenkins/deployRelease#windows-system
> Also install MS-MPI: https://www.microsoft.com/en-us/download/details.aspx?id=100593
> Configure and compile PETSc under a MSYS2 MinGW x64 shell.
> Compile your code, and copy the binary.
> Notice in my screenshot that there are two shells, the MinGW one for building PETSc.
> The Microsoft (native one) for launching the binary.
> Thanks,
> Pierre
> <image001.png>
> On 7 Nov 2022, at 1:53 PM, Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr> wrote:
> Is there a guide for it? That would be very useful! Because I have been trying a lot of things but every now and then there is a little step that is either outdated or can’t run!
> Your help will be highly appreciated
> Thanks
> Ali
> Sent: Monday, November 7, 2022 9:50 PM
> Or you can use MinGW, it’s not tricky, you don’t need to change any PETSc code, and you can ship .exe for either x86_64 (mingw-w64-x86_64-gcc) or ARM (mingw-w64-clang-aarch64-clang, without MPI).
> Thanks,
> Pierre
> On 7 Nov 2022, at 1:38 PM, hamid badi <badi.hamid at gmail.com> wrote:
> You can try gcc/clang cross-compilers, it's a little but tricky, i had to change some petsc codes but it works fine.
> Le lun. 7 nov. 2022 à 13:30, Matthew Knepley <knepley at gmail.com> a écrit :
> On Mon, Nov 7, 2022 at 7:11 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr> wrote:
> Once I finish writing the code, the .exe file will not change. Can I make an .exe file using WSL2 and VScode?
> If you build in WSL2, it will link to system libraries. You would probably need to run in WSL2 after that. If you are planning
> on running on native Windows, you likely need to build there.
>   Thanks,
>      Matt
> Thanks,
> Ali
> From: Matthew Knepley <knepley at gmail.com>
> Sent: Monday, November 7, 2022 7:13 PM
> On Mon, Nov 7, 2022 at 12:21 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr> wrote:
> I have written backend code for a software company. If WSL2 and VSCode(Linux) can be called through a command line and executed at the backend, then it will be great. But if I have to install WSL2 and other required things on every other PC that will run that software, then I think I will be at a disadvantage. What do you suggest?
> As long as you do not change the architecture and the compiler libraries are available, you can run the executable.
>   Thanks,
>      Matt
> Thank you
> Ali
> -----Original Message-----
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Monday, November 7, 2022 12:00 AM
> To: Matthew Knepley <knepley at gmail.com>
> Cc: Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>; petsc-users at mcs.anl.gov
> Likely the compilers are not setup correctly as per instructions.
> https://petsc.org/release/install/windows/#installation-with-microsoft-intel-windows-compilers
> And if you do not have a specific windows need - and only need IDE - perhaps a WSL2 (aka linux) install with VSCode(linux) might be the way to go.
> Satish
> On Sun, 6 Nov 2022, Matthew Knepley wrote:
> > We need to see configure.log to see what is going on. Can you send it?
> >   Thanks,
> >      Matt
> > On Sun, Nov 6, 2022 at 4:29 AM Mohammad Ali Yaqteen
> > wrote:
> > > Dear Sir/Madam,
> > > I am installing PETSc on windows but it keeps giving me unexpected errors.
> > > I want to use it on MS Visual Studio or Codeblocks. When I use the
> > > command on your webpage (./configure --with-cc='win32fe cl'
> > > --with-fc='win32fe ifort' --with-cxx='win32fe cl' --with-mpi=0
> > > --download-fblaslapack), I get the following error message:
> > > $ ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
> > > --with-cxx='win32fe cl' --with-mpi=0 --download-fblaslapack
> > >                          Configuring PETSc to compile on your system
> > > TESTING: checkCCompiler from
> > > config.setCompilers(config/BuildSystem/config/setCompilers.py:1341)*
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> > > details):
> > > C compiler you provided with -with-cc=win32fe cl cannot be found or
> > > does not work.
> > > Cannot compile/link C with
> > > /home/SEJONG/petsc-3.18.1/lib/petsc/bin/win32fe/win32fe cl.
> > > Kindly look into this problem! Your prompt response will highly be
> > > appreciated
> > > Thank you
> > > Ali
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221108/a7d27b05/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221108/a7d27b05/attachment-0001.png>
