[petsc-users] Failure to configure superlu_dist
Satish Balay
balay at mcs.anl.gov
Mon Mar 28 16:13:00 CDT 2022
I think moose is bound now to a petsc-3.16.5+ snapshot
-- Could NOT find MPI_C (missing: MPI_C_HEADER_DIR) (found version "4.0")
-- Found MPI_CXX: /home/lindad/mpich/installed/lib/libmpicxx.so (found version "4.0")
-- Found MPI_Fortran: /home/lindad/mpich/installed/lib/libmpifort.so (found version "3.1")
-- Configuring incomplete, errors occurred!
This is strange. libmpifort is a different version than libmpicxx.so ?
If specifying these additional options (manually) get a functional superlu_dist build - you can also specify them to petsc configure via
--download-superlu_dist-cmake-arguments=string
[but yeah - good to know if this issue persists with petsc/main]
Satish
On Mon, 28 Mar 2022, Barry Smith wrote:
> Could you please try with the main branch of PETSc?
> We've seen similar problems that have at least partially been dealt with in the main branch.
> Barry
> > On Mar 28, 2022, at 4:42 PM, Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
> > Attached is my configure.log. Error is:
> > What's interesting is that cmake does successfully find MPI_CXX and MPI_Fortran albeit in a place I'd rather it not find it (a gcc mpi build located at $HOME/mpich/installed/lib whereas mpicc -show yields what it should at $HOME/mpich/installed-clang/lib).
> > My same configure line worked well with PETSc 3.15.x. I noticed that these arguments are empty:
> > -DMPI_C_INCLUDE_PATH:STRING="" -DMPI_C_HEADER_DIR:STRING="" -DMPI_C_LIBRARIES:STRING=""
> > If I fill those with the correct values and manually cmake superlu_dist, then configure is successful
> > <configure.log>
