[petsc-users] Failure to configure superlu_dist
Alexander Lindsay
alexlindsay239 at gmail.com
Mon Mar 28 16:33:50 CDT 2022
Ok, nothing to see here ... This was user error. I had MPI_ROOT set to a
different MPI install than that corresponding to the mpi in my PATH.
On Mon, Mar 28, 2022 at 2:13 PM Satish Balay <balay at mcs.anl.gov> wrote:
> I think moose is bound now to a petsc-3.16.5+ snapshot
> -- Could NOT find MPI_C (missing: MPI_C_HEADER_DIR) (found version "4.0")
> -- Found MPI_CXX: /home/lindad/mpich/installed/lib/libmpicxx.so (found
> version "4.0")
> -- Found MPI_Fortran: /home/lindad/mpich/installed/lib/libmpifort.so
> (found version "3.1")
> -- Configuring incomplete, errors occurred!
> This is strange. libmpifort is a different version than libmpicxx.so ?
> If specifying these additional options (manually) get a functional
> superlu_dist build - you can also specify them to petsc configure via
> --download-superlu_dist-cmake-arguments=string
> [but yeah - good to know if this issue persists with petsc/main]
> Satish
> On Mon, 28 Mar 2022, Barry Smith wrote:
> > Could you please try with the main branch of PETSc?
> > We've seen similar problems that have at least partially been dealt
> with in the main branch.
> > Barry
> > > On Mar 28, 2022, at 4:42 PM, Alexander Lindsay <
> alexlindsay239 at gmail.com> wrote:
> > > Attached is my configure.log. Error is:
> > > What's interesting is that cmake does successfully find MPI_CXX and
> MPI_Fortran albeit in a place I'd rather it not find it (a gcc mpi build
> located at $HOME/mpich/installed/lib whereas mpicc -show yields what it
> should at $HOME/mpich/installed-clang/lib).
> > > My same configure line worked well with PETSc 3.15.x. I noticed that
> these arguments are empty:
> > > -DMPI_C_INCLUDE_PATH:STRING="" -DMPI_C_HEADER_DIR:STRING=""
> -DMPI_C_LIBRARIES:STRING=""
> > > If I fill those with the correct values and manually cmake
> superlu_dist, then configure is successful
> > > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220328/ccbbf2c4/attachment.html>
