[petsc-users] Failure to configure superlu_dist
Barry Smith bsmith at petsc.dev
Mon Mar 28 16:03:37 CDT 2022
  Could you please try with the main branch of PETSc?
  We've seen similar problems that have at least partially been dealt with in the main branch.
   Barry
> On Mar 28, 2022, at 4:42 PM, Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
> Attached is my configure.log. Error is:
>  Could NOT find MPI_C (missing: MPI_C_HEADER_DIR) (found version "4.0")
> What's interesting is that cmake does successfully find MPI_CXX and MPI_Fortran albeit in a place I'd rather it not find it (a gcc mpi build located at $HOME/mpich/installed/lib whereas mpicc -show yields what it should at $HOME/mpich/installed-clang/lib).
> My same configure line worked well with PETSc 3.15.x. I noticed that these arguments are empty:
> -DMPI_C_INCLUDE_PATH:STRING="" -DMPI_C_HEADER_DIR:STRING="" -DMPI_C_LIBRARIES:STRING=""
> If I fill those with the correct values and manually cmake superlu_dist, then configure is successful
> <configure.log>
