[petsc-users] Failure to configure superlu_dist
Alexander Lindsay alexlindsay239 at gmail.com
Mon Mar 28 15:42:27 CDT 2022
Attached is my configure.log. Error is:
 Could NOT find MPI_C (missing: MPI_C_HEADER_DIR) (found version "4.0")
What's interesting is that cmake does successfully find MPI_CXX and
MPI_Fortran albeit in a place I'd rather it not find it (a gcc mpi build
located at $HOME/mpich/installed/lib whereas mpicc -show yields what it
should at $HOME/mpich/installed-clang/lib).
My same configure line worked well with PETSc 3.15.x. I noticed that these
arguments are empty:
-DMPI_C_INCLUDE_PATH:STRING="" -DMPI_C_HEADER_DIR:STRING=""
-DMPI_C_LIBRARIES:STRING=""
If I fill those with the correct values and manually cmake superlu_dist,
then configure is successful
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220328/789c2d9a/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220328/789c2d9a/attachment-0001.bin>
