[petsc-users] DMSwarm
Tue Mar 15 08:39:53 CDT 2022
On Tue, Mar 15, 2022 at 9:33 AM Joauma Marichal <
joauma.marichal at uclouvain.be> wrote:
> Hello,
> I am writing to you as I am trying to implement a Lagrangian Particle
> Tracking method to my eulerian solver that relies on a 3D DMDA. To that
> end, I want to use the DMSwarm library but cannot find much documentation
> on it. Is there any examples that you would recommend for this specific
> application?  I understood the very basics but do not really understand how
> to use the following fields: DMSwarm_pid, DMSwarmPIC_coor and
> DMSwarm_cellid.
> I also understood that particles could be moved from one processor to
> another using DMSwarm_rank and the migrate functions. However, is there any
> way to link directly the coordinates of my particle to the processor on
> which it should be stored?
I was trying to do a similar thing. Here is my attempt:
https://gitlab.com/petsc/petsc/-/blob/main/src/ts/tutorials/ex77.c
It is simple, but hopefully how you integrate the particles in is somewhat
clear.
DMSwarmPIC_coor is the coordinate field, and it is updated by the user.
Then you call DMSwarmMigrate() to move the particles to the
appropriate process. DMSwarm_cellid is the cell number of the cell that
contains each particle. It is updated by Migrate().
     Matt
> Thanks a lot for your help.
> Best regards,
> Joauma
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220315/53d8d99b/attachment.html>
