[petsc-users] DMSwarm
Joauma Marichal
joauma.marichal at uclouvain.be
Fri Mar 18 10:02:34 CDT 2022
Hello,
I am writing to you as I am trying to implement a Lagrangian Particle Tracking method to my eulerian solver that relies on a 3D collocated DMDA.
I have been using examples to develop a first basic code. The latter creates particles on rank 0 with random coordinates on the whole domain and then migrates them to the rank corresponding to these coordinates. Unfortunately, as I migrate I am loosing some particles. I came to understand that when I create a DMDA with 6 grid points in each 3 directions and then set coordinates in between 0 and 1 using ,DMDASetUniformCoordinates and running on 2 processors, I obtain the following coordinates values on each proc:
[Proc 0] X = 0.000000 0.200000 0.400000 0.600000 0.800000 1.000000
[Proc 0] Y = 0.000000 0.200000 0.400000 0.600000 0.800000 1.000000
[Proc 0] Z = 0.000000 0.200000 0.400000
[Proc 1] X = 0.000000 0.200000 0.400000 0.600000 0.800000 1.000000
[Proc 1] Y = 0.000000 0.200000 0.400000 0.600000 0.800000 1.000000
[Proc 1] Z = 0.600000 0.800000 1.000000 .
Furthermore, it appears that the particles that I am losing are (in the case of 2 processors) located in between z = 0.4 and z = 0.6. How can this be avoided?
I attach my code to this email (I run it using mpirun -np 2 ./cobpor).
Furthermore, my actual code relies on a collocated 3D DMDA, however the DMDASetUniformCoordinates seems to be working for staggered grids only... How would you advice to deal with particles in this case?
Thanks a lot for your help.
Best regards,
Joauma
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220318/137b1454/attachment-0001.html>
Type: application/zip
Desc: Particle_test2.zip
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220318/137b1454/attachment-0001.zip>
