[petsc-users] Question about SuperLU
Xiaoye S. Li
xsli at lbl.gov
Thu Jun 9 19:28:13 CDT 2022
Are you using serial SuperLU, or distributed-memory SuperLU_DIST?
What are the algorithm options are you using?
Sherry Li
On Thu, Jun 9, 2022 at 2:20 PM Jorti, Zakariae via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I am solving non-linear problem that has 5 unknowns {ni, T, E, B, V}, and
> for the preconditioning part, I am using a FieldSplit preconditioner. At
> the last fieldsplit/level, we are left with a {B,V} block that tried to
> precondition in 2 different ways:
> a) SuperLU:
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_ksp_type preonly
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_type lu
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_factor_mat_solver_type
> superlu_dist
> b) a Schur-based fieldsplit preconditioner that uses SuperLU for both V
> and B blocks:
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_ksp_type gmres
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_type fieldsplit
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_fieldsplit_type schur
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_fieldsplit_schur_precondition
> selfp -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_B_ksp_type
> preonly -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_B_pc_type
> lu
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_B_pc_factor_mat_solver_type
> superlu_dist
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_V_ksp_type preonly
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_V_pc_type lu
> -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_V_pc_factor_mat_solver_type
> superlu_dist
> Option a) yields the following error:
> " Linear fieldsplit_ni_ solve converged due to CONVERGED_ATOL
> iterations 0
> Linear fieldsplit_TEBV_fieldsplit_tau_ solve converged due to
> CONVERGED_RTOL iterations 1
> Linear fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_EP_ solve
> converged due to CONVERGED_RTOL iterations 5
> Linear fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_ solve did
> not converge due to DIVERGED_PC_FAILED iterations 0
> PC failed due to FACTOR_NUMERIC_ZEROPIVOT "
> whereas options b) seems to be working well.
> Is it possible that the SuperLU on the {V,B} block uses a reordering that
> introduces a zero pivot or could there be another explanation for this
> error?
> Many thanks.
> Best,
> Zakariae
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220609/4b11bd3c/attachment.html>
